Hello
For some reason the example doesn't work, am I doing something wrong?
In this example, there was no overlay file, which I made myself.
I use a sensor: https://www.mikroe.com/lightranger-2-click
https://download.mikroe.com/documents/datasheets/vl53l0x-sensor-datasheet.pdf
* Copyright (c) 2017 STMicroelectronics
#include <zephyr/zephyr.h>
#include <zephyr/device.h>
#include <zephyr/drivers/sensor.h>
#include <stdio.h>
void main(void)
const struct device *dev = DEVICE_DT_GET_ONE(st_vl53l0x);
struct sensor_value value;
int ret;
if (!device_is_ready(dev)) {
printk("sensor: device not ready.\n");
return;
while (1) {
ret = sensor_sample_fetch(dev);
if (ret) {
printk("sensor_sample_fetch failed ret %d\n", ret);
return;
ret = sensor_channel_get(dev, SENSOR_CHAN_PROX, &value);
printk("prox is %d\n", value.val1);
SENSOR_CHAN_DISTANCE,
&value);
printf("distance is %.3fm\n", sensor_value_to_double(&value));
k_sleep(K_MSEC(1000));
// To get started, press Ctrl+Space to bring up the completion menu and view the available nodes.
// You can also use the buttons in the sidebar to perform actions on nodes.
// Actions currently available include:
// * Enabling / disabling the node
// * Adding the bus to a bus
// * Removing the node
// * Connecting ADC channels
// For more help, browse the DeviceTree documentation at https://docs.zephyrproject.org/latest/guides/dts/index.html
// You can also visit the nRF DeviceTree extension documentation at https://nrfconnect.github.io/vscode-nrf-connect/devicetree/nrfdevicetree.html
&arduino_i2c {
status = "okay";
clock-frequency = <I2C_BITRATE_FAST>;
vl53l0x: vl53l0x@52 {
compatible = "st,vl53l0x";
reg = <0x52>;
and prj.conf:
CONFIG_STDOUT_CONSOLE=y CONFIG_I2C=y CONFIG_GPIO=y CONFIG_SENSOR=y CONFIG_VL53L0X_PROXIMITY_THRESHOLD=100 #debug #CONFIG_DEBUG=y #CONFIG_LOG=y #CONFIG_SENSOR_LOG_LEVEL_DBG=y CONFIG_CBPRINTF_FP_SUPPORT=y
I have also used, for example, the ENS210 sensor from the same manufacturer and it has worked beautifully.
Thank you.
