Initializing nRF52832 Over the air
I have several devices with the RIGADO BMDWare on them but whose hardware is inaccessible. I want to initialize these nRF52832 chips with out nRF Bootloader, Softdevice and Application.
I have loaded the nRF Bootloader and Application as a RIGADO update package (generated with RIGADO genimage tools).
Then I upload the application (generated with command below)  with nRF DFU which is working fine.
	nrfutil pkg generate --hw-version 52 --app-boot-validation VALIDATE_GENERATED_CRC --sd-req 0xCB --application-version $(APP_FW_VER_HEX) --application app.hex --key-file priv.pem app.zip
The problem arises when I try to update the Bootloader (generated with below command) over the NRF DFU or over UART. In this case the Bootloader does not start at all bricking the device.
nrfutil pkg generate --hw-version 52  --sd-req 0xCB --bootloader-version $(BL_FW_VER_HEX) --bootloader bootloader.hex --sd-id 0xCB --key-file priv.pem Bootloader.zip
I have read out the following settings page contents:
- After updating the Softdevice (version 0x01060000) and Bootloader (0x01000200) with a RIGADO package and App oder nRF_DFU (device is working)
* File:                     dump.hex
* Family:                   nRF52
* Start Address:            0x00000000
* CRC:                      0x14F73526
* Settings Version:         0x00000002 (2)
* App Version:              0x01060000 (17170432)
* Bootloader Version:       0x01000200 (16777728)
* Bank Layout:              0x00000000
* Current Bank:             0x00000000
* Application Size:         0x0001AF60 (110432 bytes)
* Application CRC:          0xE9B9C5E8
* Bank0 Bank Code:          0x00000001
* Softdevice Size:          0x00000000 (0 bytes)
* Boot Validation CRC:      0x5B4052C4
* SD Boot Validation Type:  0x00000000 (0)
* App Boot Validation Type: 0x00000001 (1)
- After trying updating the Bootloader (to version 0x01020000) over nRF_DFU or UART (device is NOT working and settings file looks strange)
* File:                     dump.hex
* Family:                   nRF52
* CRC:                      0xACAA9FEB
* App Version:              0x01000000 (16777216)
* Application Size:         0x00008004 (32772 bytes)
* Application CRC:          0x48A91DBA
* Boot Validation CRC:      0x43C489A2
Another Observations:
- If I read out the working hex before BL update and then flash it again with the nRF programmer it also stops working. Is this due to some wrong information in the MBR?
- when I read out the hex with the nRF programmer I can see differences in the MBR settings page and the Bootloader settings page (start at :10E00000 and :10F00000). Is as expected or should these regions stay intact?
My questions are:
- What step in the chip initialization am I missing?
- Do I need to send a settings.hex file over nRF_DFU and if yes how can I do it?
- Do I need to write into the MBR and if yes how can I do it OTA or by modifying the Bootloader?
    No,
    No,
    The settings.hex files are only used if you program the application using a programmer directly, and not over DFU. When you perform a DFU then the bootloader will generate the settings file on it's own.
    The MBR never (!) changes. The MBR is part of the softdevice, but even if you update the softdevice, the MBR is constant in all versions, and is not updated when you perform a softdevice update.
    If you were using a normal bootloader from our SDK, I would be able to help you more, but I don't know what Rigado has done in their bootloader. I think you need to reach out to them to see if they have done anything custom in their bootloader project. For all I know, they could have forbidden/limited the bootloader to update itself.
    Edvin
  • Thank you for the response, Edvin.
    I can update the RIGADO bootloader OTA with an nRF bootloader and softdevice S132 v7.0.1 from SDK16. The problem arises when I try to update the bootloader a second time OTA or over UART. At this point the bootloader settings get changed.
    - should the bootloader settings at 0x7E0000 get changed upon an nRF bootloader update?
    - does the change of the MBR upon a BL update imply that the BL writes into the wrong location?
    Yes.
    The MBR should not change. Are you sure that it does? Remember that the MBR is located from 0x00000000 to 0x00001000. Is that changing? Or are you talking about the MBR settings page? Because that will change.
    Try to debug your bootloader. Or you can test with the _debug bootloadert (SDK\examples\dfui\secure_bootloader\<whatever_bootloader_you_are_using>_debug
    And monitor the RTT log. It should state whats happening.
    Edvin
  • Oh, yes what I meant is that the Bootloader settings and the MBR settings are changing upon a bootloader update. (at 0x7E0000 and 0x7F0000)
    This happens even when the BL should be the same.
    Ok I will try to debug the Bootloader over RTT.
