Hi ,
I am working on thingy53 and using ncs 1.9.1 I need to enable the BMI270 sensor and need the acceleration and gyroscope data from it.
So for that, I primary using the sample which is located at ncs/zephyr/samples/sensor/bmi270
But I have facing some sort of problems in i2c/pins for bmi270.
Could you help me to get the bmi270 working and print it's values
Here is the prf.conf and rest of the file is located in that folder
CONFIG_STDOUT_CONSOLE=y CONFIG_I2C=y CONFIG_SENSOR=y CONFIG_BMI270=y CONFIG_LOG=y CONFIG_USE_SEGGER_RTT=y CONFIG_LOG_BACKEND_RTT=y CONFIG_LOG_BACKEND_UART=y CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN=64 CONFIG_MAIN_STACK_SIZE=8192 CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=4096 CONFIG_LOG_BUFFER_SIZE=4096
When I have used bmi270 application as it is, it is showing the error for - &arduino_i2c that it is not known
So I simply changes the app.overlay file and modify &arduino_i2c to i2c1
