I've been using the default connection interval for HID BLE devices but iOS 16 changed the their minimum connection interval from 11.25ms to 15ms. I just wanted to know how to set that in NCS manually.
Thank you.
Thank you.
Hi jclyde,
Have you tried what is suggested in this previous DevZone question?
Changing Advertisement and connection intervals at run time? NCS
Hieu
Yes, I tried changing bt_le_adv_param .interval_min / .interval_max to what iOS tells me it should be (15-30ms) but I am still getting errors similar to this post Getting continuous disconnects with iOS 16,
They claimed changing the intervals worked while mine does not. So I wanted to make sure I was changing the right variables.
That's odd. My quick check shows that there hasn't been any change regarding connection interval and iOS 16 recently.
I notice that you are quoting advertisement parameters (**_adv_param), not connection parameters. Could you perhaps be having the same mix-up in your code? Shall we take a look at how you are calling the APIs?
