Hi - I am trying to commission my NRF5340DK board with NRF Connect SDK v.2.1.1 using Google Home App over Matter using the Matter light bulb sample.
My OTBR is a Google Nest Hub 2 running Chrome OS
My smartphone is Motorola Pure G running Android 11; Google Home Assistant app (GHA) version: 2.60.1.19
The GHA app is able to connect and begin the matter commissioning process. See the log from the NRF5340DK below. But after a few moments, while waiting to connect, the GHA "Connecting to Device Screen" abruptly closes (crashes?) and brings me back to my GHA home settings screen with nothing added.
Welcome any suggestions or advice. I am excited and eager to get my Nordic device to be controllable with GHA.
Thanks! Dan.
uart:~$ I: nRF5 802154 radio initialized I: 4 Sectors of 4096 bytes I: alloc wra: 1, e20 I: data wra: 1, 310 *** Booting Zephyr OS build v3.1.99-ncs1 *** I: Init CHIP stack I: 173 [DL]BLE address: D0:50:98:AB:07:E6 I: 199 [DL]OpenThread started: OK I: 202 [DL]Setting OpenThread device type to ROUTER I: 207 [SVR]Server initializing... D: 210 [FP]Initializing FabricTable from persistent storage I: 216 [TS]Last Known Good Time: 2022-11-04T17:19:10 I: 221 [DMG]AccessControl: initializing I: 225 [DMG]Examples::AccessControlDelegate::Init I: 229 [DMG]AccessControl: setting I: 232 [DMG]DefaultAclStorage: initializing I: 236 [DMG]DefaultAclStorage: 0 entries loaded D: 240 [IN]UDP::Init bind&listen port=5540 E: 244 [IN]SO_REUSEPORT failed: 109 D: 248 [IN]UDP::Init bound to port=5540 D: 251 [IN]BLEBase::Init - setting/overriding transport D: 256 [IN]TransportMgr initialized D: 262 [DL]Using Thread extended MAC for hostname. I: 267 [ZCL]Using ZAP configuration... D: 272 [DMG]Failed to read stored attribute (0, 0x0000_0028, 0x0000_0005: a0 D: 280 [DMG]Failed to read stored attribute (1, 0x0000_0006, 0x0000_4003: a0 D: 287 [DMG]Failed to read stored attribute (1, 0x0000_0008, 0x0000_4000: a0 I: 294 [DMG]AccessControlCluster: initializing D: 298 [DMG]Endpoint 0, Cluster 0x0000_0030 update version to b3226524 D: 305 [DL]Boot reason: 1 D: 307 [ZCL]GeneralDiagnostics: OnDeviceReboot D: 311 [DMG]Endpoint 0, Cluster 0x0000_0033 update version to 79b42976 D: 318 [EVL]LogEvent event number: 0x00000000000B0000 priority: 2, endpoint id: 0x0 cluster id: 0x0000_0033 event id: 0x3 Sys timestamp: 0x000000000000013D I: 331 [ZCL]Initiating Admin Commissioning cluster. D: 336 [DMG]Endpoint 1, Cluster 0x0000_0003 update version to d7cb0a04 D: 343 [DMG]Endpoint 1, Cluster 0x0000_0004 update version to 7add5022 D: 349 [DMG]Endpoint 1, Cluster 0x0000_0004 update version to 7add5023 I: 355 [ZCL]On/Off set value: 1 0 I: 358 [ZCL]On/off already set to new value D: 363 [DMG]Endpoint 1, Cluster 0x0000_0008 update version to 74ff3545 I: 369 [ZCL]Cluster LevelControl: attribute CurrentLevel set to 254 D: 375 [ZCL]LED is off. Try to use move-to-level-with-on-off instead of move-to-level D: 385 [IN]SecureSession[0x20004440]: Allocated Type:1 LSID:3920 D: 390 [SC]Assigned local session key ID 3920 D: 394 [SC]Waiting for PBKDF param request D: 398 [DL]CHIPoBLE advertising set to on I: 402 [DIS]Updating services using commissioning mode 1 D: 407 [DL]Using Thread extended MAC for hostname. D: 412 [DL]Using Thread extended MAC for hostname. I: 417 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=1 E: 426 [DIS]Failed to advertise commissionable node: 3 E: 431 [DIS]Failed to finalize service update: 1c I: 435 [DIS]Updating services using commissioning mode 1 D: 440 [DL]Using Thread extended MAC for hostname. D: 445 [DL]Using Thread extended MAC for hostname. I: 450 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=1 E: 459 [DIS]Failed to advertise commissionable node: 3 E: 464 [DIS]Failed to finalize service update: 1c I: 469 [DIS]Delaying proxy of operational discovery: missing delegate I: 475 [IN]CASE Server enabling CASE session setups D: 480 [IN]SecureSession[0x200044f8]: Allocated Type:2 LSID:3921 D: 486 [SC]Allocated SecureSession (0x200044f8) - waiting for Sigma1 msg I: 492 [SVR]Joining Multicast groups D: 495 [ZCL]Emitting StartUp event D: 499 [EVL]LogEvent event number: 0x00000000000B0001 priority: 2, endpoint id: 0x0 cluster id: 0x0000_0028 event id: 0x0 Sys timestamp: 0x00000000000001F2 I: 512 [SVR]Server Listening... I: 515 [DL]Device Configuration: I: 519 [DL] Serial Number: 11223344556677889900 I: 523 [DL] Vendor Id: 65521 (0xFFF1) I: 526 [DL] Product Id: 32773 (0x8005) I: 530 [DL] Hardware Version: 0 I: 534 [DL] Setup Pin Code (0 for UNKNOWN/ERROR): 20202021 I: 539 [DL] Setup Discriminator (0xFFFF for UNKNOWN/ERROR): 3840 (0xF00) I: 546 [DL] Manufacturing Date: (not set) I: 550 [DL] Device Type: 65535 (0xFFFF) I: 555 [SVR]SetupQRCode: [MT:6FCJ142C00KA0648G00] I: 559 [SVR]Copy/paste the below URL in a browser to see the QR Code: I: 565 [SVR]https://project-chip.github.io/connectedhomeip/qrcode.html?data=MT%3A6FCJ142C00KA0648G00 I: 574 [SVR]Manual pairing code: [34970112332] I: 579 [DL]CHIP task running I: 586 [DL]CHIPoBLE advertising started D: 590 [DMG]Endpoint 1, Cluster 0x0000_0006 update version to 9cf20249 I: 596 [ZCL]Cluster OnOff: attribute OnOff set to 0 D: 602 [DMG]Endpoint 1, Cluster 0x0000_0008 update version to 74ff3546 I: 608 [ZCL]Cluster LevelControl: attribute CurrentLevel set to 254 D: 614 [ZCL]LED is off. Try to use move-to-level-with-on-off instead of move-to-level I: 622 [DL]NFC Tag emulation started I: 30590 [DL]CHIPoBLE advertising mode changed to slow I: BLE advertising is already enabled I: 58026 [DL]BLE connection established (ConnId: 0x00) I: 58031 [DL]Current number of connections: 1/1 I: 58035 [DL]CHIPoBLE advertising stopped I: 58039 [DL]NFC Tag emulation stopped D: 58899 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 58906 [BLE]local and remote recv window sizes = 5 I: 58911 [BLE]selected BTP version 4 I: 58915 [BLE]using BTP fragment sizes rx 128 / tx 128. D: 58920 [DL]ConnId: 0x00, New CCCD value: 0x0002 D: 58925 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 6) D: 58932 [IN]BLE EndPoint 0x200127e0 Connection Complete I: 58937 [DL]CHIPoBLE connection established (ConnId: 0x00, GATT MTU: 131) D: 59076 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 59125 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 59132 [EM]>>> [E:50320r M:135532235] (U) Msg RX from 0:6C981F11760AF692 [0000] --- Type 0000:20 (SecureChannel:PBKDFParamRequest) D: 59144 [EM]Handling via exchange: 50320r, Delegate: 0x20006624 D: 59150 [SC]Received PBKDF param request D: 59153 [SC]Peer assigned session ID 8013 D: 59157 [SC]Found MRP parameters in the message D: 59162 [SC]Including MRP parameters in PBKDF param response I: 59168 [EM]<<< [E:50320r M:215290337] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:21 (SecureChannel:PBKDFParamResponse) I: 59180 [IN](U) Sending msg 215290337 to IP address 'BLE' D: 59185 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) D: 59192 [SC]Sent PBKDF param response D: 59271 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 59278 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 14) D: 59368 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 59376 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 59384 [EM]>>> [E:50320r M:135532236] (U) Msg RX from 0:6C981F11760AF692 [0000] --- Type 0000:22 (SecureChannel:PASE_Pake1) D: 59395 [EM]Found matching exchange: 50320r, Delegate: 0x20006624 D: 59401 [SC]Received spake2p msg1 I: 60867 [EM]<<< [E:50320r M:215290338] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:23 (SecureChannel:PASE_Pake2) I: 60878 [IN](U) Sending msg 215290338 to IP address 'BLE' D: 60883 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) D: 60891 [SC]Sent spake2p msg2 E: 60894 [DL]Long dispatch time: 1518 ms, for event type 16388 D: 60977 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 60984 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 6) D: 61074 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 61082 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 61090 [EM]>>> [E:50320r M:135532237] (U) Msg RX from 0:6C981F11760AF692 [0000] --- Type 0000:24 (SecureChannel:PASE_Pake3) D: 61101 [EM]Found matching exchange: 50320r, Delegate: 0x20006624 D: 61107 [SC]Received spake2p msg3 D: 61110 [SC]Sending status report. Protocol code 0, exchange 50320 I: 61117 [EM]<<< [E:50320r M:215290339] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport) I: 61128 [IN](U) Sending msg 215290339 to IP address 'BLE' D: 61133 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 35) I: 61141 [SC]SecureSession[0x20004440]: Moving from state 'kEstablishing' --> 'kActive' D: 61149 [IN]SecureSession[0x20004440]: Activated - Type:1 LSID:3920 D: 61155 [IN]New secure session activated for device <FFFFFFFB00000000, 0>, LSID:3920 PSID:8013! I: 61164 [SVR]Commissioning completed session establishment step I: 61170 [DIS]Updating services using commissioning mode 0 D: 61175 [DL]Using Thread extended MAC for hostname. D: 61181 [DL]Using Thread extended MAC for hostname. I: 61186 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=0 E: 61195 [DIS]Failed to advertise extended commissionable node: 3 D: 61201 [DIS]Scheduling extended discovery timeout in 900s E: 61206 [DIS]Failed to finalize service update: 1c D: 61211 [DL]CHIPoBLE advertising set to off I: 61215 [SVR]Device completed Rendezvous process E: 61219 [DL]Long dispatch time: 137 ms, for event type 16388 D: 61226 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 61233 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 61241 [EM]>>> [E:50321r M:236387520] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest) D: 61251 [EM]Handling via exchange: 50321r, Delegate: 0x200101ac D: 61257 [IM]Received Read request D: 61261 [DMG]IM RH moving to [GeneratingReports] D: 61265 [DMG]Building Reports for ReadHandler with LastReportGeneration = 0 DirtyGeneration = 0 D: 61274 [DMG]<RE:Run> Cluster 28, Attribute 2 is dirty D: 61279 [DMG]Reading attribute: Cluster=0x0000_0028 Endpoint=0 AttributeId=0x0000_0002 (expanded=0) D: 61288 [DMG]<RE> Sending report (payload has 37 bytes)... I: 61294 [EM]<<< [E:50321r M:133502508] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData) I: 61304 [IN](S) Sending msg 133502508 on secure session with LSID: 3920 D: 61310 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 72) D: 61318 [DMG]<RE> OnReportConfirm: NumReports = 0 D: 61323 [DMG]<RE> ReportsInFlight = 0 with readHandler 0, RE has no more messages D: 61330 [DMG]IM RH moving to [AwaitingDestruction] D: 61335 [DMG]All ReadHandler-s are clean, clear GlobalDirtySet D: 61416 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 61424 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 61432 [EM]>>> [E:50322r M:236387521] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest) D: 61442 [EM]Handling via exchange: 50322r, Delegate: 0x200101ac D: 61447 [IM]Received Read request D: 61451 [DMG]IM RH moving to [GeneratingReports] D: 61456 [DMG]Building Reports for ReadHandler with LastReportGeneration = 0 DirtyGeneration = 0 D: 61464 [DMG]<RE:Run> Cluster 28, Attribute 4 is dirty D: 61469 [DMG]Reading attribute: Cluster=0x0000_0028 Endpoint=0 AttributeId=0x0000_0004 (expanded=0) D: 61478 [DMG]<RE> Sending report (payload has 37 bytes)... I: 61484 [EM]<<< [E:50322r M:133502509] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData) I: 61494 [IN](S) Sending msg 133502509 on secure session with LSID: 3920 D: 61501 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 72) D: 61508 [DMG]<RE> OnReportConfirm: NumReports = 0 D: 61513 [DMG]<RE> ReportsInFlight = 0 with readHandler 0, RE has no more messages D: 61520 [DMG]IM RH moving to [AwaitingDestruction] D: 61525 [DMG]All ReadHandler-s are clean, clear GlobalDirtySet D: 61562 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 61570 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 61578 [EM]>>> [E:50323r M:236387522] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest) D: 61588 [EM]Handling via exchange: 50323r, Delegate: 0x200101ac D: 61594 [IM]Received Read request D: 61598 [DMG]IM RH moving to [GeneratingReports] D: 61602 [DMG]Building Reports for ReadHandler with LastReportGeneration = 0 DirtyGeneration = 0 D: 61611 [DMG]<RE:Run> Cluster 3e, Attribute 2 is dirty D: 61616 [DMG]Reading attribute: Cluster=0x0000_003E Endpoint=0 AttributeId=0x0000_0002 (expanded=0) D: 61625 [DMG]<RE> Sending report (payload has 36 bytes)... I: 61631 [EM]<<< [E:50323r M:133502510] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData) I: 61641 [IN](S) Sending msg 133502510 on secure session with LSID: 3920 D: 61647 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) D: 61655 [DMG]<RE> OnReportConfirm: NumReports = 0 D: 61659 [DMG]<RE> ReportsInFlight = 0 with readHandler 0, RE has no more messages D: 61667 [DMG]IM RH moving to [AwaitingDestruction] D: 61671 [DMG]All ReadHandler-s are clean, clear GlobalDirtySet D: 61708 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 61716 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 61724 [EM]>>> [E:50324r M:236387523] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest) D: 61734 [EM]Handling via exchange: 50324r, Delegate: 0x200101ac D: 61740 [IM]Received Read request D: 61744 [DMG]IM RH moving to [GeneratingReports] D: 61748 [DMG]Building Reports for ReadHandler with LastReportGeneration = 0 DirtyGeneration = 0 D: 61757 [DMG]<RE:Run> Cluster 3e, Attribute 3 is dirty D: 61762 [DMG]Reading attribute: Cluster=0x0000_003E Endpoint=0 AttributeId=0x0000_0003 (expanded=0) D: 61771 [DMG]<RE> Sending report (payload has 36 bytes)... I: 61777 [EM]<<< [E:50324r M:133502511] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData) I: 61787 [IN](S) Sending msg 133502511 on secure session with LSID: 3920 D: 61793 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) D: 61801 [DMG]<RE> OnReportConfirm: NumReports = 0 D: 61806 [DMG]<RE> ReportsInFlight = 0 with readHandler 0, RE has no more messages D: 61813 [DMG]IM RH moving to [AwaitingDestruction] D: 61818 [DMG]All ReadHandler-s are clean, clear GlobalDirtySet D: 61854 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 61862 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 61870 [EM]>>> [E:50325r M:236387524] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest) D: 61881 [EM]Handling via exchange: 50325r, Delegate: 0x200101ac D: 61886 [IM]Received Read request D: 61890 [DMG]IM RH moving to [GeneratingReports] D: 61895 [DMG]Building Reports for ReadHandler with LastReportGeneration = 0 DirtyGeneration = 0 D: 61903 [DMG]<RE:Run> Cluster 3e, Attribute 1 is dirty D: 61908 [DMG]Reading attribute: Cluster=0x0000_003E Endpoint=0 AttributeId=0x0000_0001 (expanded=0) D: 61917 [DMG]<RE> Sending report (payload has 36 bytes)... I: 61923 [EM]<<< [E:50325r M:133502512] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData) I: 61933 [IN](S) Sending msg 133502512 on secure session with LSID: 3920 D: 61940 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) D: 61947 [DMG]<RE> OnReportConfirm: NumReports = 0 D: 61952 [DMG]<RE> ReportsInFlight = 0 with readHandler 0, RE has no more messages D: 61959 [DMG]IM RH moving to [AwaitingDestruction] D: 61964 [DMG]All ReadHandler-s are clean, clear GlobalDirtySet D: 62001 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 62009 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 62017 [EM]>>> [E:50326r M:236387525] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest) D: 62027 [EM]Handling via exchange: 50326r, Delegate: 0x200101ac D: 62032 [IM]Received Read request D: 62036 [DMG]IM RH moving to [GeneratingReports] D: 62041 [DMG]Building Reports for ReadHandler with LastReportGeneration = 0 DirtyGeneration = 0 D: 62049 [DMG]<RE:Run> Cluster 1d, Attribute 1 is dirty D: 62054 [DMG]Reading attribute: Cluster=0x0000_001D Endpoint=0 AttributeId=0x0000_0001 (expanded=0) D: 62064 [DMG]<RE> Sending report (payload has 372 bytes)... I: 62071 [EM]<<< [E:50326r M:133502513] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData) I: 62082 [IN](S) Sending msg 133502513 on secure session with LSID: 3920 D: 62088 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) D: 62096 [DMG]<RE> OnReportConfirm: NumReports = 0 D: 62100 [DMG]<RE> ReportsInFlight = 0 with readHandler 0, RE has no more messages D: 62108 [DMG]IM RH moving to [AwaitingDestruction] D: 62112 [DMG]All ReadHandler-s are clean, clear GlobalDirtySet D: 62147 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 62154 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) D: 62244 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 62252 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) D: 62342 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 62349 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 29) D: 62440 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 62448 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 62927 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 62935 [EM]>>> [E:50327r M:236387526] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:0a (IM:TimedRequest) D: 62945 [EM]Handling via exchange: 50327r, Delegate: 0x200101ac D: 62951 [DMG]Got Timed Request with timeout 10000: handler 0x200105a8 exchange 50327r I: 62959 [EM]<<< [E:50327r M:133502514] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:01 (IM:StatusResponse) I: 62970 [IN](S) Sending msg 133502514 on secure session with LSID: 3920 D: 62976 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 43) D: 62984 [DMG]Timed Request time limit 0x0000000000011D18: handler 0x200105a8 exchange 50327r D: 63073 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 63081 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 63089 [EM]>>> [E:50327r M:236387527] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) D: 63100 [EM]Found matching exchange: 50327r, Delegate: 0x200105a8 D: 63106 [DMG]Timed following action arrived at 0x000000000000F682: handler 0x200105a8 exchange 50327r D: 63115 [DMG]Handing timed invoke to IM engine: handler 0x200105a8 exchange 50327r D: 63123 [DMG]Received command for Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0000 I: 63131 [FS]GeneralCommissioning: Received ArmFailSafe (120s) D: 63136 [DMG]Endpoint 0, Cluster 0x0000_0030 update version to b3226525 D: 63143 [DMG]Command handler moving to [ Preparing] D: 63148 [DMG]Command handler moving to [AddingComm] D: 63152 [DMG]Command handler moving to [AddedComma] D: 63157 [DMG]Decreasing reference count for CommandHandler, remaining 0 I: 63164 [EM]<<< [E:50327r M:133502515] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse) I: 63176 [IN](S) Sending msg 133502515 on secure session with LSID: 3920 D: 63182 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) D: 63190 [DMG]Command handler moving to [CommandSen] D: 63194 [DMG]Command handler moving to [AwaitingDe] E: 63199 [DL]Long dispatch time: 118 ms, for event type 16388 D: 63268 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 63276 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 63284 [EM]>>> [E:50328r M:236387528] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest) D: 63294 [EM]Handling via exchange: 50328r, Delegate: 0x200101ac D: 63300 [IM]Received Read request D: 63304 [DMG]IM RH moving to [GeneratingReports] D: 63308 [DMG]Building Reports for ReadHandler with LastReportGeneration = 0 DirtyGeneration = 0 D: 63317 [DMG]<RE:Run> Cluster 30, Attribute 3 is dirty D: 63322 [DMG]Reading attribute: Cluster=0x0000_0030 Endpoint=0 AttributeId=0x0000_0003 (expanded=0) D: 63331 [DMG]<RE> Sending report (payload has 36 bytes)... I: 63337 [EM]<<< [E:50328r M:133502516] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData) I: 63347 [IN](S) Sending msg 133502516 on secure session with LSID: 3920 D: 63353 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) D: 63361 [DMG]<RE> OnReportConfirm: NumReports = 0 D: 63366 [DMG]<RE> ReportsInFlight = 0 with readHandler 0, RE has no more messages D: 63373 [DMG]IM RH moving to [AwaitingDestruction] D: 63378 [DMG]All ReadHandler-s are clean, clear GlobalDirtySet D: 63415 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 63422 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 63430 [EM]>>> [E:50329r M:236387529] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:0a (IM:TimedRequest) D: 63441 [EM]Handling via exchange: 50329r, Delegate: 0x200101ac D: 63446 [DMG]Got Timed Request with timeout 10000: handler 0x200105a8 exchange 50329r I: 63455 [EM]<<< [E:50329r M:133502517] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:01 (IM:StatusResponse) I: 63465 [IN](S) Sending msg 133502517 on secure session with LSID: 3920 D: 63472 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 43) D: 63479 [DMG]Timed Request time limit 0x0000000000011F07: handler 0x200105a8 exchange 50329r D: 63564 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 63572 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 63580 [EM]>>> [E:50329r M:236387530] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) D: 63591 [EM]Found matching exchange: 50329r, Delegate: 0x200105a8 D: 63598 [DMG]Timed following action arrived at 0x000000000000F86D: handler 0x200105a8 exchange 50329r D: 63607 [DMG]Handing timed invoke to IM engine: handler 0x200105a8 exchange 50329r D: 63614 [DMG]Received command for Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0002 D: 63624 [DMG]Endpoint 0, Cluster 0x0000_0030 update version to b3226526 D: 63630 [DMG]Command handler moving to [ Preparing] D: 63635 [DMG]Command handler moving to [AddingComm] D: 63640 [DMG]Command handler moving to [AddedComma] D: 63645 [DMG]Decreasing reference count for CommandHandler, remaining 0 I: 63652 [EM]<<< [E:50329r M:133502518] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse) I: 63663 [IN](S) Sending msg 133502518 on secure session with LSID: 3920 D: 63669 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) D: 63677 [DMG]Command handler moving to [CommandSen] D: 63682 [DMG]Command handler moving to [AwaitingDe] E: 63686 [DL]Long dispatch time: 114 ms, for event type 16388 D: 63744 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 63752 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 63760 [EM]>>> [E:50330r M:236387531] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) D: 63771 [EM]Handling via exchange: 50330r, Delegate: 0x200101ac D: 63778 [DMG]Received command for Endpoint=0 Cluster=0x0000_003E Command=0x0000_0002 I: 63785 [ZCL]OpCreds: Certificate Chain request received for DAC D: 63791 [DMG]Command handler moving to [ Preparing] D: 63796 [DMG]Command handler moving to [AddingComm] D: 63801 [DMG]Command handler moving to [AddedComma] D: 63805 [DMG]Decreasing reference count for CommandHandler, remaining 0 I: 63815 [EM]<<< [E:50330r M:133502519] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse) I: 63826 [IN](S) Sending msg 133502519 on secure session with LSID: 3920 D: 63832 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) D: 63840 [DMG]Command handler moving to [CommandSen] D: 63845 [DMG]Command handler moving to [AwaitingDe] D: 63924 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 63932 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) D: 64014 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 64022 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) D: 64104 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 64112 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) D: 64195 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 64203 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 64210 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 57) D: 64284 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 64330 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 64338 [EM]>>> [E:50331r M:236387532] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) D: 64349 [EM]Handling via exchange: 50331r, Delegate: 0x200101ac D: 64355 [DMG]Received command for Endpoint=0 Cluster=0x0000_003E Command=0x0000_0002 I: 64363 [ZCL]OpCreds: Certificate Chain request received for PAI D: 64368 [DMG]Command handler moving to [ Preparing] D: 64373 [DMG]Command handler moving to [AddingComm] D: 64378 [DMG]Command handler moving to [AddedComma] D: 64383 [DMG]Decreasing reference count for CommandHandler, remaining 0 I: 64392 [EM]<<< [E:50331r M:133502520] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse) I: 64403 [IN](S) Sending msg 133502520 on secure session with LSID: 3920 D: 64410 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) D: 64417 [DMG]Command handler moving to [CommandSen] D: 64422 [DMG]Command handler moving to [AwaitingDe] D: 64464 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 64472 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) D: 64554 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 64562 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) D: 64644 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 64652 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) D: 64735 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 64743 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 64750 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 28) D: 64824 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 64832 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 64841 [EM]>>> [E:50332r M:236387533] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) D: 64852 [EM]Handling via exchange: 50332r, Delegate: 0x200101ac D: 64858 [DMG]Received command for Endpoint=0 Cluster=0x0000_003E Command=0x0000_0000 I: 64865 [ZCL]OpCreds: Received an AttestationRequest command I: 64900 [ZCL]OpCreds: AttestationRequest successful. D: 64905 [DMG]Command handler moving to [ Preparing] D: 64910 [DMG]Command handler moving to [AddingComm] D: 64915 [DMG]Command handler moving to [AddedComma] D: 64920 [DMG]Decreasing reference count for CommandHandler, remaining 0 I: 64930 [EM]<<< [E:50332r M:133502521] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse) I: 64941 [IN](S) Sending msg 133502521 on secure session with LSID: 3920 D: 64948 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) D: 64955 [DMG]Command handler moving to [CommandSen] D: 64960 [DMG]Command handler moving to [AwaitingDe] E: 64965 [DL]Long dispatch time: 133 ms, for event type 16388 D: 65004 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 65012 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) D: 65139 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 65147 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) D: 65229 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 65237 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) D: 65320 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 65328 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 65335 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) D: 65409 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 65417 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 91) D: 65499 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 65507 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 65516 [EM]>>> [E:50333r M:236387534] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) D: 65527 [EM]Handling via exchange: 50333r, Delegate: 0x200101ac D: 65533 [DMG]Received command for Endpoint=0 Cluster=0x0000_003E Command=0x0000_0004 I: 65540 [ZCL]OpCreds: Received a CSRRequest command D: 65545 [ZCL]OpCreds: Finding fabric with fabricIndex 0x0 I: 65703 [ZCL]OpCreds: AllocatePendingOperationalKey succeeded I: 65738 [ZCL]OpCreds: CSRRequest successful. D: 65742 [DMG]Command handler moving to [ Preparing] D: 65747 [DMG]Command handler moving to [AddingComm] D: 65751 [DMG]Command handler moving to [AddedComma] D: 65756 [DMG]Decreasing reference count for CommandHandler, remaining 0 I: 65765 [EM]<<< [E:50333r M:133502522] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse) I: 65776 [IN](S) Sending msg 133502522 on secure session with LSID: 3920 D: 65782 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) D: 65790 [DMG]Command handler moving to [CommandSen] D: 65795 [DMG]Command handler moving to [AwaitingDe] E: 65799 [DL]Long dispatch time: 292 ms, for event type 16388 D: 65859 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 65867 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) D: 65949 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 65957 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) D: 66039 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 66047 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 66130 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 66138 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 67165 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 67255 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 67345 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 67352 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) I: 67362 [EM]>>> [E:50334r M:236387535] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) D: 67373 [EM]Handling via exchange: 50334r, Delegate: 0x200101ac D: 67379 [DMG]Received command for Endpoint=0 Cluster=0x0000_003E Command=0x0000_000B I: 67387 [ZCL]OpCreds: Received an AddTrustedRootCertificate command I: 67449 [ZCL]OpCreds: AddTrustedRootCertificate successful. D: 67454 [DMG]Command handler moving to [ Preparing] D: 67459 [DMG]Command handler moving to [AddingComm] D: 67464 [DMG]Command handler moving to [AddedComma] D: 67469 [DMG]Decreasing reference count for CommandHandler, remaining 0 I: 67476 [EM]<<< [E:50334r M:133502523] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse) I: 67487 [IN](S) Sending msg 133502523 on secure session with LSID: 3920 D: 67493 [DMG]Command handler moving to [CommandSen] D: 67498 [DMG]Command handler moving to [AwaitingDe] E: 67503 [DL]Long dispatch time: 157 ms, for event type 16388 D: 67508 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 67516 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 67) D: 67614 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 67622 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 67705 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 67840 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 67930 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 67937 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 68019 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 68027 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 68200 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 68211 [EM]>>> [E:50335r M:236387536] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) D: 68222 [EM]Handling via exchange: 50335r, Delegate: 0x200101ac D: 68228 [DMG]Received command for Endpoint=0 Cluster=0x0000_003E Command=0x0000_0006 I: 68236 [ZCL]OpCreds: Received an AddNOC command I: 68243 [FP]Validating NOC chain I: 68357 [FP]NOC chain validation successful I: 68361 [FP]Added new fabric at index: 0x1 I: 68365 [FP]Assigned compressed fabric ID: 0x92E031A4919A5BB7, node ID: 0x00000000976BBA25 I: 68373 [TS]Last Known Good Time: 2022-11-04T17:19:10 I: 68378 [TS]New proposed Last Known Good Time: 2022-11-05T01:44:49 I: 68384 [TS]Updating pending Last Known Good Time to 2022-11-05T01:44:49 D: 68391 [DMG]Endpoint 0, Cluster 0x0000_003E update version to 7f479bec D: 68397 [DMG]Endpoint 0, Cluster 0x0000_003E update version to 7f479bed D: 68412 [EVL]LogEvent event number: 0x00000000000B0002 priority: 1, endpoint id: 0x0 cluster id: 0x0000_001F event id: 0x0 Sys timestamp: 0x0000000000010B3B I: 68426 [ZCL]OpCreds: ACL entry created for Fabric index 0x1 CASE Admin Subject 0xFFFFFFFD00010001 D: 68435 [DL]Using Thread extended MAC for hostname. I: 68439 [DIS]Advertise operational node 92E031A4919A5BB7-00000000976BBA25 D: 68446 [DMG]Endpoint 0, Cluster 0x0000_003E update version to 7f479bee D: 68453 [DMG]Endpoint 0, Cluster 0x0000_003E update version to 7f479bef D: 68459 [DMG]Command handler moving to [ Preparing] D: 68464 [DMG]Command handler moving to [AddingComm] D: 68468 [DMG]Command handler moving to [AddedComma] I: 68473 [ZCL]OpCreds: successfully created fabric index 0x1 via AddNOC D: 68480 [DMG]Decreasing reference count for CommandHandler, remaining 0 I: 68487 [EM]<<< [E:50335r M:133502524] (S) Msg TX to 1:FFFFFFFB00000000 [5BB7] --- Type 0001:09 (IM:InvokeCommandResponse) I: 68498 [IN](S) Sending msg 133502524 on secure session with LSID: 3920 D: 68504 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) D: 68512 [DMG]Command handler moving to [CommandSen] D: 68516 [DMG]Command handler moving to [AwaitingDe] E: 68521 [DL]Long dispatch time: 321 ms, for event type 16388 D: 68559 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 71079 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 73586 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 73644 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 76164 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 78672 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 78819 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 81249 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 83757 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 83814 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) I: 86784 [DL]BLE GAP connection terminated (reason 0x13) D: 86790 [IN]Clearing BLE pending packets. I: 86794 [DL]Current number of connections: 0/1 I: 183136 [FS]Fail-safe timer expired E: 183140 [SVR]Failsafe timer expired D: 183143 [IN]SecureSession[0x20004440]: MarkForEviction Type:1 LSID:3920 I: 183150 [SC]SecureSession[0x20004440]: Moving from state 'kActive' --> 'kPendingEviction' D: 183158 [IN]SecureSession[0x20004440]: Released - Type:1 LSID:3920 E: 183164 [SVR]Commissioning failed (attempt 1): 32 D: 183170 [IN]SecureSession[0x20004440]: Allocated Type:1 LSID:3922 D: 183176 [SC]Assigned local session key ID 3922 D: 183181 [SC]Waiting for PBKDF param request D: 183185 [DL]CHIPoBLE advertising set to on I: 183189 [DIS]Updating services using commissioning mode 1 D: 183194 [DL]Using Thread extended MAC for hostname. D: 183199 [DL]Using Thread extended MAC for hostname. I: 183204 [DIS]Advertise operational node 92E031A4919A5BB7-00000000976BBA25 E: 183211 [DIS]Failed to advertise operational node: 3 D: 183216 [DL]Using Thread extended MAC for hostname. I: 183221 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=1 E: 183230 [DIS]Failed to advertise commissionable node: 3 E: 183235 [DIS]Failed to finalize service update: 1c E: 183240 [ZCL]OpCreds: Got FailSafeTimerExpired E: 183245 [ZCL]OpCreds: Proceeding to FailSafeCleanup on fail-safe expiry! D: 183251 [IN]Expiring all sessions for fabric 0x1!! E: 183256 [FP]Reverting pending fabric data for fabric 0x1 D: 183261 [EVL]LogEvent event number: 0x00000000000B0003 priority: 1, endpoint id: 0x0 cluster id: 0x0000_0028 event id: 0x2 Sys timestamp: 0x000000000002CBDD D: 183275 [DMG]All ReadHandler-s are clean, clear GlobalDirtySet E: 183282 [FP]Warning: metadata not found during delete of fabric 0x1 I: 183292 [FP]Fabric (0x1) deleted. I: 183295 [ZCL]OpCreds: Fabric index 0x1 was removed D: 183300 [DMG]Endpoint 0, Cluster 0x0000_003E update version to 7f479bf0 D: 183307 [DMG]Endpoint 0, Cluster 0x0000_003E update version to 7f479bf1 I: 183323 [TS]Pending Last Known Good Time: 2022-11-05T01:44:49 I: 183329 [TS]Previous Last Known Good Time: 2022-11-04T17:19:10 I: 183335 [TS]Reverted Last Known Good Time to previous value D: 183341 [EVL]LogEvent event number: 0x00000000000B0004 priority: 1, endpoint id: 0x0 cluster id: 0x0000_0028 event id: 0x2 Sys timestamp: 0x000000000002CC2D D: 183355 [DMG]All ReadHandler-s are clean, clear GlobalDirtySet E: 183361 [FP]Warning: metadata not found during delete of fabric 0x1 E: 183369 [ZCL]OpCreds: failed to delete fabric at index 1: d8 D: 183374 [DMG]Endpoint 0, Cluster 0x0000_0030 update version to b3226527 D: 183381 [ZCL]Failsafe timeout, tell platform driver to revert network credentials. E: 183389 [DL]Long dispatch time: 249 ms, for event type 32782 I: 183394 [FS]Fail-safe cleanly disarmed I: 183402 [DL]CHIPoBLE advertising started I: 183406 [DL]NFC Tag emulation started I: 213405 [DL]CHIPoBLE advertising mode changed to slow
