How can i convert USB DFU code from pca10056_usb to pca10040 ?
Hello ,
I want to convert the code of dfu pca10056_usb to pca10040 for this i have updated the following -
1. Updated board from PCA10056 to PCA10046
2.Updated the linker.
But I am getting this error
where im missing
  • Hi Shweta,
    Could you please let us know what you want to achieve ?
    Why do you want to have USB DFU support on PCA10040 when the nRF52832 doesn't have USB support ?
    If you want to do UART DFU you can use the \examples\dfu\secure_bootloader\pca10040_uart example.
  • Hello Hung Bui,
    First of all my bad let me rephrase the problem statement.
    I am having MDBT50Q-U(nrf52833) and want to perform USB DFU.
    As there is no example code directly usable in nRF SDK 16.0.0 so I was trying to convert the given code according to my requirement but I was unable to modify compiler and linker settings.
  • Ok so you want to make the example works for nRF52833.
    I noticed that you set the FLASH_SIZE to 0x7000. On the original firmware for nRF52840 it's 0xa000. This explains why you got the issue with flash when compiling.
    Please try the following setting:
    FLASH_START = 0xC000
    FLASH_SIZE= 0xA000
    Please use the BOARD_PCA10100 if you want to compile for nRF52833.
  • On the same project I have changed the settings as suggested by you that is(note here i have not changed the board it is here "BOARD_PCA10040" and "NRF52840_XXAA)-
    1.
    It build and then starts giving error
    2. When I change the board to NRF52833xxAA  and BOARD_PCA10100 that is
    it shows following error
  • Hi Shweta,
    The nRF52833 doesn't have the hardware Cryptocell so you have to select other backend.
    I would suggest you to study the \examples\dfu\secure_bootloader\pca10100e_usb\ in SDK v17.1 .
    The sample is made for nRF52820 to run on the PCA10100 which is the DK for NRF52833.
    The only modification as far as I can see to make it run on nRF52820 is to modify the RAM and ROM size and start location of the bootloader.
    In the sdk_config.h you will find
    NRF_CRYPTO_BACKEND_NRF_SW_ENABLED 1
    and
    NRF_CRYPTO_BACKEND_CC310_BL_ENABLED 0.
