NRF51 error, the processor is reset after a time with ble
I'll explain my code:
NRF51 takes samples of a sensor every 10 minutes. In addition, softdevice S110 is used... An user can connect at any time, so advertising is used all the time.
When I leave the device for hours, i can't connect to device, an error occurs and NRF51 is reset.
Any help?
My configuration:
#define APP_ADV_INTERVAL                        180
#define APP_ADV_TIMEOUT_IN_SECONDS      0
#define APP_TIMER_PRESCALER             0
#define APP_TIMER_MAX_TIMERS           (16 + BSP_APP_TIMERS_NUMBER)
#define APP_TIMER_OP_QUEUE_SIZE      8
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)
#define MAX_CONN_INTERVAL              MSEC_TO_UNITS(75, UNIT_1_25_MS)
#define SLAVE_LATENCY                   0
#define CONN_SUP_TIMEOUT            MSEC_TO_UNITS(6000, UNIT_10_MS)
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER)
#define NEXT_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(30000, APP_TIMER_PRESCALER)
#define MAX_CONN_PARAMS_UPDATE_COUNT    3
And mi advertising_init function:
static void advertising_init(void){
uint32_t      err_code;
ble_advdata_t advdata;
ble_advdata_t scanrsp;
// Build advertising data struct to pass into @ref ble_advertising_init.
memset(&advdata, 0, sizeof(advdata));
advdata.name_type          = BLE_ADVDATA_FULL_NAME;
advdata.include_appearance = false;
advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
memset(&scanrsp, 0, sizeof(scanrsp));
scanrsp.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
scanrsp.uuids_complete.p_uuids  = m_adv_uuids;
ble_adv_modes_config_t options = {0};
options.ble_adv_fast_enabled  = BLE_ADV_FAST_ENABLED;
options.ble_adv_fast_interval = APP_ADV_INTERVAL;
options.ble_adv_fast_timeout  = APP_ADV_TIMEOUT_IN_SECONDS;
err_code = ble_advertising_init(&advdata, &scanrsp, &options, NULL, NULL);
Thanks in advance.
  • What is your advertising timeout set to? APP_ADV_TIMEOUT_IN_SECONDS?
    Are you sure the device has reset? Do you have a System Reset enabled in your app_error_handler() function?
  • I think yes, look at that:
    __WEAK void app_error_handler(uint32_t error_code, uint32_t line_num, const uint8_t * p_file_name)
        // On assert, the system can only recover with a reset.
    #ifndef DEBUG
        NVIC_SystemReset();
    #else
    #ifdef BSP_DEFINES_ONLY
        LEDS_ON(LEDS_MASK);
    #else
        UNUSED_VARIABLE(bsp_indication_set(BSP_INDICATE_FATAL_ERROR));
        // This call can be used for debug purposes during application development.
        // @note CAUTION: Activating this code will write the stack to flash on an error.
        //                This function should NOT be used in a final product.
        //                It is intended STRICTLY for development/debugging purposes.
        //                The flash write will happen EVEN if the radio is active, thus interrupting
        //                any communication.
        //                Use with care. Uncomment the line below to use.
        //ble_debug_assert_handler(error_code, line_num, p_file_name);
    #endif // BSP_DEFINES_ONLY
        // The following variable helps Keil keep the call stack visible, in addition, it can be set to
        // 0 in the debugger to continue executing code after the error check.
        volatile bool loop = true;
        UNUSED_VARIABLE(loop);
        m_error_code = error_code;
        m_line_num = line_num;
        m_p_file_name = p_file_name;
        UNUSED_VARIABLE(m_error_code);
        UNUSED_VARIABLE(m_line_num);
        UNUSED_VARIABLE(m_p_file_name);
        __disable_irq();
        while(loop);
    #endif // DEBUG
    /*lint -restore */
    APP_ADV_TIMEOUT_IN_SECONDS = 0, unlimited, because I need connect at any time. This device should be works several months.
  • So put a breakpoint in your app error handler, leave the device for as long as it takes to get into this state, and when it goes into the error handler, use the debugger to find which call returned an error message and caused the error.
