nRF24L01 communication loss problem
The chip I am using is the nRF24L01.
Not the nRF24L01P.
One module is Rx-receiver and two modules are Tx-transmitter.
The test is carried out with one Rx module and one Tx module.
On the Tx-transmitter, Rx-receiver, the antenna is drawn in a pattern.
It is the same pattern antenna used for 2.4GHz Bluetooth communication in the past.
The circuit was referenced in the data sheet.
Transmitter and receiver are operating within 1m.
Tx-transmitter transmits 32byte data at 250Hz cycle.
The Rx-receiver is receiving well, but communication is not possible at a certain location and angle.
When communication is not possible, put an aluminum cooking foil near the transmitter or receiver to establish communication again.
The register settings are as follows.
Rx-receiver Tx-transmitter
void nRF24_Init(void)
    // Write to registers their initial values
    nRF24_WriteReg(nRF24_REG_CONFIG, 0x08);
    nRF24_WriteReg(nRF24_REG_EN_AA, 0x3F);
    nRF24_WriteReg(nRF24_REG_EN_RXADDR, 0x3F);
    nRF24_WriteReg(nRF24_REG_SETUP_AW, 0x03);
    nRF24_WriteReg(nRF24_REG_SETUP_RETR, 0x03);
    nRF24_WriteReg(nRF24_REG_RF_CH, 0x02);
    nRF24_WriteReg(nRF24_REG_RF_SETUP, 0x0F);
    nRF24_WriteReg(nRF24_REG_STATUS, 0x00);
    nRF24_WriteReg(nRF24_REG_RX_PW_P0, 0x00);
    nRF24_WriteReg(nRF24_REG_RX_PW_P1, 0x00);
    nRF24_WriteReg(nRF24_REG_RX_PW_P2, 0x00);
    nRF24_WriteReg(nRF24_REG_RX_PW_P3, 0x00);
    nRF24_WriteReg(nRF24_REG_RX_PW_P4, 0x00);
    nRF24_WriteReg(nRF24_REG_RX_PW_P5, 0x00);
    nRF24_WriteReg(nRF24_CMD_ACTIVATE, 0x73);
    nRF24_WriteReg(nRF24_REG_DYNPD, 0x00);
    nRF24_WriteReg(nRF24_REG_FEATURE, 0x00);
    // Clear the FIFO's
    nRF24_FlushRX();
    nRF24_FlushTX();
    // Clear any pending interrupt flags
    nRF24_ClearIRQFlags();
    // Deassert CSN pin (chip release)
    nRF24_CSN_H();
///////////////// Initialize nRF ////////////////////////////////////
// RX/TX disabled
    nRF24_CE_L();
// Initialize the nRF24L01 to its default state
    nRF24_Init();
// Set RF channel
    nRF24_SetRFChannel(40);
// Set data rate
    nRF24_SetDataRate(nRF24_DR_2Mbps);
// Set CRC scheme
    nRF24_SetCRCScheme(nRF24_CRC_2byte);
// Set address width, its common for all pipes (RX and TX)
    nRF24_SetAddrWidth(3);
// Configure RX PIPE1
    static const uint8_t nRF24_ADDR1[] = { 'N', 'd', '1' };
// program address for pipe
    nRF24_SetAddr(nRF24_PIPE1, nRF24_ADDR1);
// Auto-ACK: enabled, payload length: 32 bytes
    nRF24_SetRXPipe(nRF24_PIPE1, nRF24_AA_ON, 32);
// Configure RX PIPE2
    static const uint8_t nRF24_ADDR2[] = { '2' };
    nRF24_SetAddr(nRF24_PIPE2, nRF24_ADDR2);
    nRF24_SetRXPipe(nRF24_PIPE2, nRF24_AA_ON, 32);
// Set TX power for Auto-ACK
// (maximum, to ensure that transmitter will hear ACK reply)
    nRF24_SetTXPower(nRF24_TXPWR_0dBm);
// Set operational mode (PRX == receiver)
    nRF24_SetOperationalMode(nRF24_MODE_RX);
// Clear any pending IRQ flags
// Wake the transceiver
    nRF24_SetPowerMode(nRF24_PWR_UP);
// Enable DPL
    nRF24_SetDynamicPayloadLength(nRF24_DPL_ON);
    nRF24_SetPayloadWithAck(1);
// Put the transceiver to the RX mode
    nRF24_CE_H();
   nRF24_WriteReg(nRF24_REG_EN_RXADDR, 0x03);
   nRF24_WriteReg(nRF24_REG_RF_SETUP, 0x0E);
   // Clear the FIFO's
   nRF24_FlushRX();
   nRF24_FlushTX();
   nRF24_CSN_H();
   nRF24_Init();
// Set RF channel
// Set data rate
// Set CRC scheme
// Configure TX PIPE
   static const uint8_t nRF24_ADDR[] = { 'N', 'd', '1' };
// program TX address
   nRF24_SetAddr(nRF24_PIPETX, nRF24_ADDR);
// program address for pipe#0, must be same as TX (for Auto-ACK)
   nRF24_SetAddr(nRF24_PIPE0, nRF24_ADDR);
// Set TX power (maximum)
// Configure auto retransmit: 0 retransmissions with pause of 2500s in between
   nRF24_SetAutoRetr(nRF24_ARD_2500us, 0);
// Enable Auto-ACK for pipe#0 (for ACK packets)
   nRF24_EnableAA(nRF24_PIPE0);
// Set operational mode (PTX == transmitter)
   nRF24_SetOperationalMode(nRF24_MODE_TX);
// Enable DPL
  1. Is this problem due to the antenna?
    If the distance between Tx and Rx is less than 1m, will it be affected by the antenna?
  2. Is there anything I need to change in the above settings?
  3. Is there a function to automatically change the channel in an area where RF 2.4GHz communication is not available in the nRF24L01 chip?
