Unable to generate PWM pulse
Hi, I am trying to generate PWM pulse based on sample application in GitHub. However instead of using different modes and multiple channels, I tried to simplify it to just configuring Timer2, one channel, and one output pin. I am trying to set the duty cycle value in BLE data handler, using 2 PPI channels to toggle a pin once when it reaches CC[0] (to set the duty cycle) and once to finish a complete period CC[1]. I'm not getting any pulse on my oscilloscope. Attached PWM part of the code below, any hint on what might be wrong? Could there be any dependencies with other peripherals initialization?
// PWM Timer Definitions
#define PWM_TIMER			NRF_TIMER2
#define PWM_IRQHandler		TIMER2_IRQHandler
#define PWM_IRQn			TIMER2_IRQn
#define GPIOTE_CHANNEL_NO	2
#define PWM_MAX_VALUE		1000UL      // 1 tick equals 1µ , multiply by 1000 for ms value
uint16_t pwm_value;
uint8_t pwm_running;
/**@brief Function for Starting PWM timer.
static void pwm_init(void)
	nrf_gpio_cfg_output(REGULATOR_PIN);		// Set regulator pin as output
	// Configure GPIOTE_CHANNEL_NUMBER to toggle the GPIO pin state with input.
	// nrf_gpiote_task_configure(GPIOTE_CHANNEL_NO, REGULATOR_PIN, NRF_GPIOTE_POLARITY_TOGGLE, NRF_GPIOTE_INITIAL_VALUE_HIGH);
	pwm_running = 0;
	// Configure TIMER2 for compare[0] event every 1 ms.
	PWM_TIMER->PRESCALER = 3;            // Prescaler 4 results in 1 tick equals 1 microsecond.
	PWM_TIMER->TASKS_CLEAR = 1;
	PWM_TIMER->BITMODE = TIMER_BITMODE_BITMODE_16Bit;	// 16 bit mode.
	PWM_TIMER->CC[1]     = PWM_MAX_VALUE;       // 1 tick equals 1µ , multiply by 1000 for ms value
	pwm_value = 300;
	PWM_TIMER->CC[0] = pwm_value;
	PWM_TIMER->MODE = TIMER_MODE_MODE_Timer;	// Set the timer in Timer Mode.
	PWM_TIMER->SHORTS = TIMER_SHORTS_COMPARE1_CLEAR_Msk;
	PWM_TIMER->EVENTS_COMPARE[0] = PWM_TIMER->EVENTS_COMPARE[1] = 0;
	// Configure PPI channel 0 to toggle REGULATOR_PIN on every TIMER2 COMPARE[0] match
	sd_ppi_channel_assign(0, &(PWM_TIMER->EVENTS_COMPARE[0]), &(NRF_GPIOTE->TASKS_OUT[GPIOTE_CHANNEL_NO]));
	// Enable PPI channel 0
	sd_ppi_channel_enable_set(1 << 0);
	// Configure PPI channel 1 to toggle REGULATOR_PIN on every TIMER2 COMPARE[1] match
	sd_ppi_channel_assign(1, &(PWM_TIMER->EVENTS_COMPARE[1]), &(NRF_GPIOTE->TASKS_OUT[GPIOTE_CHANNEL_NO]));
	// Enable PPI channel 1
	sd_ppi_channel_enable_set(1 << 1);
	sd_nvic_SetPriority(PWM_IRQn, 1);	//must have to set the priority
//	sd_nvic_ClearPendingIRQ(PWM_IRQn);
	sd_nvic_EnableIRQ(PWM_IRQn);
  __enable_irq();
	/* Start clock */
	PWM_TIMER->TASKS_START = 1;
/**@brief   Sets the value for PWM
 * @details Sets the variable for PWM value
 * In next interrupt the value is updated to the timer register
static void pwm_set_value(uint16_t value)
	if(value <= PWM_MAX_VALUE)
		pwm_value = value;
		PWM_TIMER->SHORTS = TIMER_SHORTS_COMPARE1_CLEAR_Msk | TIMER_SHORTS_COMPARE1_STOP_Msk;
		if((PWM_TIMER->INTENSET & TIMER_INTENSET_COMPARE1_Msk) == 0)
			PWM_TIMER->TASKS_STOP = 1;
			PWM_TIMER->INTENSET = TIMER_INTENSET_COMPARE1_Msk;
/**@brief   Function for handling Timer2 interrupt.
 * @details This function will set the PWM value to CC register
 * keeps the GPIO pin high/low at the max/min value of PWM respectively
void PWM_IRQHandler(void)
	PWM_TIMER->INTENCLR = 0xFFFFFFFF;
	if(pwm_value == 0)
//		nrf_gpiote_unconfig(2);   Can anyone suggest what should be done here
//		nrf_gpiote_task_disable(0);
		nrf_gpio_pin_write(REGULATOR_PIN, 0);
		pwm_running = 0;
	else if (pwm_value >= PWM_MAX_VALUE)
		nrf_gpio_pin_write(REGULATOR_PIN, 1);
		pwm_running = 0;
		if(pwm_running == 0)
			pwm_running = 1;
/**@brief Application main function.
    uint32_t err_code;
    bool erase_bonds;
    uint8_t  start_string[] = START_STRING;
    //  Initialize.
    APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_MAX_TIMERS, APP_TIMER_OP_QUEUE_SIZE, false);
    uart_init();
    ble_stack_init();
    gap_params_init();
    services_init();
    advertising_init();
    conn_params_init();
    pwm_init();
    printf("%s",start_string);
    err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
    // Enter main loop.
    for (;;)
      power_manage();
