Default system heap listener
How can a heap listener be used on the system heap?  That is, the system heap that is used for k_malloc() and k_free(), with size set in kconfig as follows.  The kconfig to enable the listener is also added
CONFIG_HEAP_MEM_POOL_SIZE=/* size in bytes */
CONFIG_SYS_HEAP_LISTENER=y
In particular, I'm trying to find out what _heap_id should be used with the macros
HEAP_LISTENER_ALLOC_DEFINE(name, _heap_id, _alloc_cb)
HEAP_LISTENER_FREE_DEFINE(name, _heap_id, _free_cb)
I tried using "HEAP_ID_LIBC" for the _heap_id in the above listener define macros.  It builds, but no calls to the _alloc_cb or _free_cb functions occur, despite many uses of k_malloc() and k_free().  I would assume HEAP_ID_LIBC is for C library calls with malloc() and free(), and not the Zephyr memory pool heap functions k_malloc() and k_free().
What should be used for the heap ID with the heap memory pool?  Is there an example of using the heap listener API?
Thank you,
Walt
    Regrettably, poor support is often a hallmark of open source software.
    yes, but fortunately, in most cases, you may find out by reading the source code.
    I have figured out how to get the default system heap. It is a global variable.
    so you can call it simply as follow:
    extern struct k_heap _system_heap;
    void main_heap_listener_alloc_cbh(uintptr_t heap_id, void *mem, size_t bytes);
    void main_heap_listener_free_cbh(uintptr_t heap_id, void *mem, size_t bytes);
    HEAP_LISTENER_ALLOC_DEFINE(AllocListener, HEAP_ID_FROM_POINTER(&_system_heap.heap), main_heap_listener_alloc_cbh);
    HEAP_LISTENER_FREE_DEFINE(FreeListener, HEAP_ID_FROM_POINTER(&_system_heap.heap), main_heap_listener_free_cbh);
  • Jason,
    Awesome!  I was able to get it working using the default heap global variable.  Thank you for posting your solution; that's a big help.
    Well done,
    Walt
    (PS- for posterity, this was working with nRF Connect v2.2.0)
  • This was so hard to find, thanks for posting this. I have been looking for a way to effectivity monitor the system heap use for a while and had finally found sys_heap_runtime_stats_get() and sys_heap_print_info(), but no way to get a ref to the system heap and your replay has done that. Thanks so much for posting this!
    I will add for other out there that may have been looking for the same you can use CONFIG_SYS_HEAP_RUNTIME_STATS to enable the heap stats APIs mentioned above. These can then be called in the following manner:
    static struct sys_memory_stats stats;
    sys_heap_print_info(&_system_heap,true);
    //or
    sys_heap_runtime_stats_get(&_system_heap, &stats);
    I hope this helps anyone that comes across the same problem.
