Default system heap listener
How can a heap listener be used on the system heap?  That is, the system heap that is used for k_malloc() and k_free(), with size set in kconfig as follows.  The kconfig to enable the listener is also added
CONFIG_HEAP_MEM_POOL_SIZE=/* size in bytes */
CONFIG_SYS_HEAP_LISTENER=y
In particular, I'm trying to find out what _heap_id should be used with the macros
HEAP_LISTENER_ALLOC_DEFINE(name, _heap_id, _alloc_cb)
HEAP_LISTENER_FREE_DEFINE(name, _heap_id, _free_cb)
I tried using "HEAP_ID_LIBC" for the _heap_id in the above listener define macros.  It builds, but no calls to the _alloc_cb or _free_cb functions occur, despite many uses of k_malloc() and k_free().  I would assume HEAP_ID_LIBC is for C library calls with malloc() and free(), and not the Zephyr memory pool heap functions k_malloc() and k_free().
What should be used for the heap ID with the heap memory pool?  Is there an example of using the heap listener API?
Thank you,
Walt
    Not tried it myself, but I suggest to check out the documentaiton and the test example for the heap:
    https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/zephyr/kernel/memory_management/heap.html
    \zephyr\tests\lib\heap\src\
    Kenneth
     * Copyright (c) 2016 Intel Corporation
    #include <zephyr.h>
    #include <drivers/gpio.h>
    #include <zephyr/sys/heap_listener.h>
    /* 1000 msec = 1 sec */
    #define SLEEP_TIME_MS   5000
    /* The devicetree node identifier for the "led0" alias. */
    #define LED0_NODE DT_ALIAS(led0)
    void main_heap_listener_alloc_cbh(uintptr_t heap_id, void *mem, size_t bytes);
    void main_heap_listener_free_cbh(uintptr_t heap_id, void *mem, size_t bytes);
    //**SYSHP static struct sys_heap listener_heap;
    //**SYSHP static void *heapmem[1024];
    /* using defined system heap */
    //**SYSHP HEAP_LISTENER_ALLOC_DEFINE(AllocListener, HEAP_ID_FROM_POINTER(&listener_heap), main_heap_listener_alloc_cbh);
    //**SYSHP HEAP_LISTENER_FREE_DEFINE(FreeListener, HEAP_ID_FROM_POINTER(&listener_heap), main_heap_listener_free_cbh);
    /* using default system heap */
    HEAP_LISTENER_ALLOC_DEFINE(AllocListener, HEAP_ID_LIBC, main_heap_listener_alloc_cbh);
    HEAP_LISTENER_FREE_DEFINE(FreeListener, HEAP_ID_LIBC, main_heap_listener_free_cbh);
        printk("=> Allocate %i <=\n", bytes);
    } // main_heap_listener_alloc_cbh()
        printk("=> Free %i <=\n", bytes);
    } // main_heap_listener_free_cbh()
     * A build error on this line means your board is unsupported.
     * See the sample documentation for information on how to fix this.
    static const struct gpio_dt_spec led = GPIO_DT_SPEC_GET(LED0_NODE, gpios);
    void main(void)
    	int ret;
        /* init system heap */
    //**SYSHP     sys_heap_init(&listener_heap, heapmem, 1024);
        /* Register heap listeners */
    	heap_listener_register(&AllocListener);
    	heap_listener_register(&FreeListener);
        printk("Registered heap listeners..\n");
    	if (!device_is_ready(led.port)) {
    		return;
    	ret = gpio_pin_configure_dt(&led, GPIO_OUTPUT_ACTIVE);
    	if (ret < 0) {
    		return;
    //**SYSHP     void *mem = sys_heap_alloc(&listener_heap, 32U);
        void *mem = k_malloc(32);  /* default heap */
        char *str = (char*)mem;
        str[0] = 'h';
    //**SYSHP     sys_heap_free(&listener_heap, mem);
        k_free(mem);        /* default heap */
    	while (1) {
    		ret = gpio_pin_toggle_dt(&led);
    		if (ret < 0) {
    			return;
    		k_msleep(SLEEP_TIME_MS);
    Kenneth,
    Thank you for the reply.  That heap test source was very helpful for understanding using the system heap and heap listener.
    I took the blinky example:
    \ncs\v2.0.2\zephyr\samples\basic\blinky
    and added a defined system heap and listeners to it.  I updated the prj.conf as follows:
    CONFIG_GPIO=y
    # System heap
    CONFIG_HEAP_MEM_POOL_SIZE=1024
    And the main.c per the attached file.  I got the listeners working with the defined system heap, "listener_heap", and would see the following on the console:
    *** Booting Zephyr OS build v3.0.99-ncs1-1 ***
    => Allocate 36 <=
    => Free 36 <=
    I then commented out the defined heap lines using //**SYSHP, and changed the listener define macros  HEAP_LISTENER_ALLOC_DEFINE & HEAP_LISTENER_FREE_DEFINE to use the default heap ID,
    HEAP_ID_LIBC
    I then changed the allocation and free lines to use the default heap:
        str[0] = 'h';
     However, I can't get the listeners to work with the default heap.  Is there some other part of the setup for the default heap this is missing?
    Walt
  • Good question, don't know, we don't have much experience with this kernel api in specific. I suggest to direct this question to the zephyr support, for instance the zephyr discord channel:
    https://docs.zephyrproject.org/latest/introduction/index.html#resources
    Kenneth
    I am facing the same issue. Have you found a solution?
    Thanks!
  • Hi Jason,
    Unfortunately I have not.  I posted to the Zephyr users mailing list but got no replies.  Perhaps you might reply adding that you are also facing the same issue?
    https://lists.zephyrproject.org/g/users/message/3122?p=%2C%2C%2C20%2C0%2C0%2C0%3A%3ACreated%2C%2Cheap+listener%2C20%2C1%2C0%2C95045476
    Regrettably, poor support is often a hallmark of open source software.
    Best,
    Walt
