Zigbee Light Switch example builds only once
When trying to compile a zigbee light switch example for the nrf5340-cpu_app target using visual studio using the zigbee fota prj file, the application compiles only once. Any other attempts to re-build this application fail with a FLASH overflow error
See build log
I am currently running nrf Connect SDK v2.1.0
Can anyone help me build the application more than once?
    So I see that the original build succeeds, and so does the second (the one that just builds 4 files starting at line 389 in your build log).  What do you do between that build and the one after (starting at line 404)?
    What triggers it to do a pristine build? (It doesn't use the flag "--pristine", but something triggers it to build everything from scratch).
    Edvin
  • I noticed that changing the PRJ caused this issue to appear
    enabling/disabling PRJ values. i.e changing the image version to `CONFIG_MCUBOOT_IMAGE_VERSION="1.2.4" for example
    Once I reverted all my changes to the example PRJ I tried simple forcing a pristine build was enough to cause this issue to appear
  • I see. I can replicate the issue as well. While I don't know exactly why it happens yet, it has to do with the definition "USE_PARTITION_MANAGER" which is set when I do a pristine build, but it is not set when the build directory doesn't exist. When this is defined, it includes the content of sysflash.h, which refers to PM_MCUBOOT_PRIMARY_1_ID, which isn't defined.
    I believe it has to do with these lines:
    # We are using partition manager if we are a child image or if we are
    # the root image and the 'partition_manager' target exists.
    set(using_partition_manager
      $<OR:$<BOOL:${IMAGE_NAME}>,$<TARGET_EXISTS:partition_manager>>
    zephyr_compile_definitions(
      USE_PARTITION_MANAGER=${using_partition_manager}
    from CMakeLists.txt in NCS\nrf\subsys\partition_manager\CMakeLists.txt
    I am not sure whether the issue is that the USE_PARTITION_MANAGER is being set wrongly (why it is set on a new build, but not a pristine build), or if the PM_MCUBOOT_PRIMARY_1_ID should be defined somewhere that is not included. I will have to look into it later. (Hopefully tomorrow).
    Edvin
  • Where/who  is USE_PARTITION_MANAGER being set?
    Sorry for the late reply. I have not got the chance to look more into details on this yet. I found that when I built from the command line, the issue didn't occur, and I discovered that it only occurs (from the command line) when I include the file nrf5340dk_nrf5340_cpuapp_fota.conf is included. I will try to look into why it fails. The main reason is that e.g. PM_MCUBOOT_PRIMARY_1_ID is not defined, but I am not sure where this is typically set. I will try to compare it to some other applications using DFU, (such as NCS\nrf\applications\machine_learning) that doesn't have this error.
    As mentioned, I think it is being set in the CMakeLists.txt file from NCS\nrf\subsys\partition_manager\CMakeLists.txt.
    Sorry for the inconvenience.
    BR,
    Edvin
