I am working with nRF52840 SoC (custom board) and AT25QL641 QSPI Flash chip. I am on v2.1.0 of nRF Connect SDK. The slot1 (update slot) is on an external flash.
Whenever I try to upload the update image from nRF Connect Device Manager I get "Remote error: No Entry (5)". This is translated from a "MGMT_ERR_ENOENT" error code return from img_mgmt_read_info() of MCUmanager. I have seen this thread with a similar issue:
Failure in mgmt while trying to upgrade the app using external flash as secondary slot
but increasing stack sizes did not resolve my issue.
I have also looked through a number of DFU+MCUboot+External Flash threads to get to this point. It is possible that this issue is related to the partition manager or MCUboot configuration since I have had prior issues with those.
My child_image/mcuboot.conf looks like this:
CONFIG_PINCTRL=y CONFIG_FLASH=y CONFIG_NRFX_QSPI=y CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK=n CONFIG_NORDIC_QSPI_NOR=y CONFIG_NORDIC_QSPI_NOR_STACK_WRITE_BUFFER_SIZE=16 CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y CONFIG_BOOT_MAX_IMG_SECTORS=256 CONFIG_PM_EXTERNAL_FLASH_BASE=0x0
I don't use a static partition file.
The device tree is modified in the following way:
/delete-node/ &slot0_partition; /delete-node/ &slot1_partition; // Extending boot partition in internal flash (since slot1 will be moved) &flash0{ partitions { slot0_partition: partition@c000 { label = "image-0"; reg = <0xc000 0xE4000>; }; }; }; &qspi { status = "okay"; pinctrl-0 = <&qspi_default>; pinctrl-1 = <&qspi_sleep>; pinctrl-names = "default", "sleep"; at25ql641: at25ql641@0 { compatible = "nordic,qspi-nor"; reg = < 0 >; jedec-id = [ 1F 43 17 ]; sck-frequency = < 133000000 >; //size-in-bytes = < 67108864 >; Does not work with partition manager size=<536870912>; partitions { compatible = "fixed-partitions"; #address-cells = <1>; #size-cells = <1>; slot1_partition: partition@0 { label = "image-1"; reg = <0x0 0x0E4000>; }; }; }; }; / { chosen { nordic,pm-ext-flash = &at25ql641; }; };
I have already applied the "partition_manager.cmake" fix from this thread:
RE: nRF9160dk FOTA using external flash, ncs 2.0.2
Finally, I have also confirmed that I am able to read and write to external flash from the application itself.
Thank you,
Andy
