How to do multichannel adc in low power consumption
I am new to nrf52832 development. The question is that:
I want to do multichannel(4 or 5 channels) ADC in scan mode every 1s. and the MCU consumes ultra low current(3-5uA) at idle time.
I tried this example and it works just fine.
It seems to be using  workaround from Errata 212 to cut the current consumption, but I didn't quite understand it. Could anyone help to explain it?
And is there other ways to do the same thing?
PS: I have tried another example but current consumption(about 1.3mA) is far higher than the former one.
    In some cases, the SAADC enter a bad state. This workaround recovers by making a copy of some undocumented internal registers (including those that hold the offset calibration), and resetting the SAADC peripheral (disable and re-enable) by writing to an undocumented internal register, before writing back the data that was there before the reset.
    The first example you refer to use the V2 API of the nrfx_saadc driver, and this is significantly improved and handles things like errata 212. So I recommend you use this. With that, as long as you stop the SAADC when not in use, you should get a low sleep current.
