How to use passkey in BT_NUS_SECURITY_ENABLED
Hello
I   need passkey
I  am working  on  a   project
I connected the  peripheral_uart  to android application
So   I send the data on   application  , I need a secure connection to   connected the  ble device on   application   . So  i set a passkey for   secure connection
So the peripheral_uart request for passkey to application then we enter a passkey   then the peripheral_uart is connected with application . .
I Enabled the   BT_NUS_SECURITY_ENABLED  ,
CONFIG_BT_FIXED_PASSKEY=y in prj.config
I used this Board - NRF5340_DK
version-nrf connect sdk v 1.9.1
This is my  prj.config
# Copyright (c) 2018 Nordic Semiconductor
# Enable the UART driver
CONFIG_UART_ASYNC_API=y
CONFIG_NRFX_UARTE0=y
CONFIG_SERIAL=y
CONFIG_GPIO=y
# Make sure printk is printing to the UART console
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME="kulr-12345"
CONFIG_BT_DEVICE_NAME_DYNAMIC=y
CONFIG_BT_DEVICE_APPEARANCE=833
CONFIG_BT_MAX_CONN=1
CONFIG_BT_MAX_PAIRED=1
CONFIG_BT_SMP_ENFORCE_MITM=n
# Enable the NUS service
CONFIG_BT_NUS=y
# Enable bonding
CONFIG_BT_SETTINGS=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
# Enable DK LED and Buttons library
CONFIG_DK_LIBRARY=y
# This example requires more workqueue stack
# Config logger
CONFIG_LOG=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_UART=n
CONFIG_ASSERT=y
CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN=64
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=4096
CONFIG_LOG_BUFFER_SIZE=4096
CONFIG_HEAP_MEM_POOL_SIZE=2048
CONFIG_BT_NUS_SECURITY_ENABLED=y
CONFIG_BT_BUF_ACL_RX_SIZE=128
CONFIG_BT_L2CAP_TX_MTU=128
CONFIG_BT_SMP=y
CONFIG_FPU=y
