BLE HID can first identify whether IOS or Android sends different report descriptors
最近,我做了一个HID项目,发现其他蓝牙设备可以根据连接的主机是IOS还是Android发送不同的报告描述符。
  • Hi
    If I understand you correctly you want a BLE HID device to know if it is connected to and Android or an iOS phone?
    I don't think there is a good way to do this unfortunately, but I will do some investigating internally and get back to you.
    Best regards
    Torbjørn
  • Yes, I need to know the host's operating system before sending the report descriptor
  • Android 报告描述符
    0x05, 0x0D,        // Usage Page (Digitizer)
    0x09, 0x04,        // Usage (Touch Screen)
    0xA1, 0x01,        // Collection (Application)
    0x85, 0x01,        //   Report ID (1)
    0x09, 0x22,        //   Usage (Finger)
    0xA1, 0x02,        //   Collection (Logical)
    0x09, 0x42,        //     Usage (Tip Switch)
    0x09, 0x32,        //     Usage (In Range)
    0x15, 0x00,        //     Logical Minimum (0)
    0x25, 0x01,        //     Logical Maximum (1)
    0x75, 0x01,        //     Report Size (1)
    0x95, 0x02,        //     Report Count (2)
    0x81, 0x02,        //     Input (Data,Var,Abs,No Wrap,Linear,Preferred State,No Null Position)
    0x95, 0x06,        //     Report Count (6)
    0x81, 0x01,        //     Input (Const,Array,Abs,No Wrap,Linear,Preferred State,No Null Position)
    0x05, 0x01,        //     Usage Page (Generic Desktop Ctrls)
    0x09, 0x30,        //     Usage (X)
    0x09, 0x31,        //     Usage (Y)
    0x26, 0xE8, 0x03,  //     Logical Maximum (1000)
    0x35, 0x00,        //     Physical Minimum (0)
    0x45, 0x00,        //     Physical Maximum (0)
    0x55, 0x00,        //     Unit Exponent (0)
    0x65, 0x00,        //     Unit (None)
    0x75, 0x10,        //     Report Size (16)
    0xC0,              //   End Collection
    0x05, 0x0C,        // Usage Page (Consumer)
    0x09, 0x01,        // Usage (Consumer Control)
    0x85, 0x02,        //   Report ID (2)
    0x95, 0x01,        //   Report Count (1)
    0x15, 0x01,        //   Logical Minimum (1)
    0x26, 0x8C, 0x02,  //   Logical Maximum (652)
    0x19, 0x01,        //   Usage Minimum (Consumer Control)
    0x2A, 0x8C, 0x02,  //   Usage Maximum (AC Send)
    0x81, 0x60,        //   Input (Data,Array,Abs,No Wrap,Linear,No Preferred State,Null State)
    0x85, 0x03,        //   Report ID (3)
    0x95, 0x18,        //   Report Count (24)
    0x0A, 0x40, 0x00,  //   Usage (Menu)
    0x0A, 0x92, 0x01,  //   Usage (AL Calculator)
    0x0A, 0x83, 0x01,  //   Usage (AL Consumer Control Configuration)
    0x0A, 0x23, 0x02,  //   Usage (AC Home)
    0x0A, 0x8A, 0x01,  //   Usage (AL Email Reader)
    0x0A, 0x82, 0x01,  //   Usage (AL Programmable Button Configuration)
    0x0A, 0x21, 0x02,  //   Usage (AC Search)
    0x0A, 0x24, 0x02,  //   Usage (AC Back)
    0x0A, 0x25, 0x02,  //   Usage (AC Forward)
    0x0A, 0x26, 0x02,  //   Usage (AC Stop)
    0x0A, 0x27, 0x02,  //   Usage (AC Refresh)
    0x09, 0xB6,        //   Usage (Scan Previous Track)
    0x09, 0xB5,        //   Usage (Scan Next Track)
    0x09, 0xB7,        //   Usage (Stop)
    0x09, 0xCD,        //   Usage (Play/Pause)
    0x09, 0xE9,        //   Usage (Volume Increment)
    0x09, 0xEA,        //   Usage (Volume Decrement)
    0x09, 0xE2,        //   Usage (Mute)
    0x09, 0xB8,        //   Usage (Eject)
    0x09, 0x30,        //   Usage (Power)
    0x09, 0xCF,        //   Usage (0xCF)
    0x09, 0xB9,        //   Usage (Random Play)
    0x0A, 0xB1, 0x01,  //   Usage (AL Screen Saver)
    0x0A, 0x04, 0x02,  //   Usage (AC Exit)
    0x09, 0x06,        // Usage (Keyboard)
    0x85, 0x04,        //   Report ID (4)
    0x05, 0x07,        //   Usage Page (Kbrd/Keypad)
    0x19, 0xE0,        //   Usage Minimum (0xE0)
    0x29, 0xE7,        //   Usage Maximum (0xE7)
    0x95, 0x08,        //   Report Count (8)
    0x75, 0x08,        //   Report Size (8)
    0x95, 0x05,        //   Report Count (5)
    0x05, 0x08,        //   Usage Page (LEDs)
    0x19, 0x01,        //   Usage Minimum (Num Lock)
    0x29, 0x05,        //   Usage Maximum (Kana)
    0x91, 0x02,        //   Output (Data,Var,Abs,No Wrap,Linear,Preferred State,No Null Position,Non-volatile)
    0x75, 0x03,        //   Report Size (3)
    0x91, 0x01,        //   Output (Const,Array,Abs,No Wrap,Linear,Preferred State,No Null Position,Non-volatile)
    0x25, 0x65,        //   Logical Maximum (101)
    0x19, 0x00,        //   Usage Minimum (0x00)
    0x29, 0x65,        //   Usage Maximum (0x65)
    0x81, 0x00,        //   Input (Data,Array,Abs,No Wrap,Linear,Preferred State,No Null Position)
    0x85, 0x05,        //   Report ID (5)
    IOS 报告描述符
    05 01 09 06 a1 01 85 04 05 07 19
    e0 29 e7 15 00 25 01 75 01 95 08 81 02 95 01 75
    08 81 01 95 05 75 01 05 08 19 01 29 05 91 02 95
    01 75 03 91 01 95 06 75 08 15 00 25 65 05 07 19
    00 29 65 81 00 c0 05 0c 09 01 a1 01 85 05 75 10
    95 01 15 01 26 8c 02 19 01 2a 8c 02 81 60 c0 05
    01 09 02 a1 01 85 01 09 01 a1 00 75 08 95 01 05
    01 09 38 15 81 25 7f 81 06 05 0c 0a 38 02 95 01
    81 06 c0 85 02 09 01 a1 00 95 03 75 01 05 09 19
    01 29 03 15 00 25 01 81 02 95 01 75 01 81 03 75
    0e 95 02 05 01 09 30 09 31 16 01 e0 26 ff 1f 81
    06 c0 c0 05 0c 09 01 a1 01 85 03 15 00 25 01 75
    01 95 18 0a 40 00 0a 92 01 0a 83 01 0a 23 02 0a
    8a 01 0a 82 01 0a 21 02 0a 24 02 0a 25 02 0a 26
    02 0a 27 02 09 b6 09 b5 09 b7 09 cd 09 e9 09 ea
    09 e2 09 b8 09 30 09 cf 09 b9 0a b1 01 0a 04 02
    81 02 c0
    0x09, 0x02,        // Usage (Mouse)
    0x09, 0x01,        //   Usage (Pointer)
    0xA1, 0x00,        //   Collection (Physical)
    0x09, 0x38,        //     Usage (Wheel)
    0x15, 0x81,        //     Logical Minimum (-127)
    0x25, 0x7F,        //     Logical Maximum (127)
    0x81, 0x06,        //     Input (Data,Var,Rel,No Wrap,Linear,Preferred State,No Null Position)
    0x0A, 0x38, 0x02,  //     Usage (AC Pan)
    0x95, 0x03,        //     Report Count (3)
    0x05, 0x09,        //     Usage Page (Button)
    0x19, 0x01,        //     Usage Minimum (0x01)
    0x29, 0x03,        //     Usage Maximum (0x03)
    0x81, 0x03,        //     Input (Const,Var,Abs,No Wrap,Linear,Preferred State,No Null Position)
    0x75, 0x0E,        //     Report Size (14)
    0x16, 0x01, 0xE0,  //     Logical Minimum (-8191)
    0x26, 0xFF, 0x1F,  //     Logical Maximum (8191)
    10 00 fe 7f
    01 00 c8 00
    01 00 c8 00
    00 00 00 00
    10 00 fe 7f
    10 00 fe 7f
    10 00 fe 7f
    20 03 70 fe
    20 03 70 fe
    01 00 00 00
    00 00 00 00
    01 00 00 00
    00 00 00 00
    10 00 fe 7f
    10 00 fe 7f
    10 00 fe 7f
    e0 01 70 fe
    e0 01 70 fe
    01 00 c8 00
    01 00 c8 00
    01 00 c8 00
    00 00 00 00
    10 00 fe 7f
    10 00 fe 7f
    10 00 fe 7f
    e0 01 70 fe
    e0 01 70 fe
    01 00 c8 00
    01 00 c8 00
    01 00 c8 00
    00 00 00 00
    10 00 fe 7f
    10 00 fe 7f
    10 00 fe 7f
    10 00 fe 7f
    e0 01 70 fe
    e0 01 70 fe
    01 00 c8 00
    01 00 c8 00
    10 00 fe 7f
    10 00 fe 7f
    10 00 fe 7f
    e0 01 70 fe
    e0 01 70 fe
    10 00 fe 7f
    10 00 fe 7f
    10 00 fe 7f
    10 00 fe 7f
    e0 01 70 fe
    e0 01 70 fe
    01 00 c8 00
    01 00 c8 00
    01 00 c8 00
    00 00 00 00
    10 00 fe 7f
    10 00 fe 7f
    10 00 fe 7f
    10 00 fe 7f
    e0 01 c0 fe
    01 00 38 ff
    01 00 38 ff
    01 00 38 ff
    00 00 00 00
    10 00 fe 7f
    10 00 fe 7f
    10 00 fe 7f
    10 00 fe 7f
    e0 01 c0 fe
    e0 01 c0 fe
    01 00 38 ff
    00 00 00 00
    10 00 fe 7f
    10 00 fe 7f
    10 00 fe 7f
    10 00 fe 7f
    e0 01 c0 fe
    e0 01 c0 fe
    01 00 38 ff
    01 00 38 ff
    01 00 38 ff
    00 00 00 00
    10 00 fe 7f
    At present, I just don't know how it distinguishes between IOS and Android. Maybe we can see his solution in the packet capture information, but I still can't know his method
  • I know how to solve this problem
    I need to define two HID services. I don't know whether nrf52,840 supports this operation
  • Hi
    You can create as many service as you like in the nRF52840, you will only be limited by the available memory.
    Are you planning to use the nRF5 SDK or the nRF Connect SDK for developing the firmware?
    Best regards
    Torbjørn
  • I want to perform the function of initializing the service after the connection is successful. I don't know whether the nRF5 SDK and nRF Connect SDK support it
  • Hi
    In the nRF5 SDK you can add services dynamically, but you can not remove them without doing a full reset of the nRF device.
    In the nRF Connect SDK you can both add and remove services dynamically, as long as you enable the BT_GATT_DYNAMIC_DB configuration.
    Then you can use the bt_gatt_service_register/unregister functions to enable and disable different services.
    Best regards
    Torbjørn
