CONFIG_BOOT_BUILD_DIRECT_XIP_VARIANT is undefined symbol
I'm using a nRF5340DK with nRF Connect SDK v1.9.0 and want to use MCUBoot with Direct-XIP.
Using the hello_world sample project, I added MCUBoot.
In the MCUBoot prf.conf file located at "ncs\v1.9.0\bootloader\mcuboot\boot\zephyr" I added "CONFIG_BOOT_DIRECT_XIP=y" and now upon starting i get:
*** Booting Zephyr OS build v2.7.99-ncs1  ***
I: Starting Direct-XIP bootloader
I: Primary   slot: version=1.0.0+0
I: Image 0 Secondary slot: Image not found
I: Image 0 loaded from the primary slot
I: Bootloader chainload address offset: 0xc000
I: Jumping to the image slot
Executing application version {1}
build time: Nov  9 2022 09:38:48
So this should work.
Now I want to load an image into the secondary slot to be executed from there. If I just flash another image with higher version number into offset 0x74000 (from pm.config), I can see the image via mcumgr in the second slot and marked as "pending", but after a reset it is still marked as pending.
The bootloader gives me this output:
I: Secondary slot: version=2.0.0+0
I: Image 0 loaded from the secondary slot
I: Bootloader chainload address offset: 0x74000
So apparently it boots from 0x74000 but still executes the old code. I think this is because the image in the secondary slot was built for slot 0, therefore it links to the wrong addresses.
Here I found the "CONFIG_BOOT_BUILD_DIRECT_XIP_VARIANT=y" option and added it to my prj.conf from hello_world, but in Segger Embedded Studio I get:
-- Using NCS Toolchain 1.9.0 for building. (C:/ncs/v1.9.0/toolchain/cmake)
C:/ncs/v1.9.0/zephyr/samples/hello_world/prj.conf:6: warning: attempt to assign the value 'y' to the undefined symbol BOOT_BUILD_DIRECT_XIP_VARIANT
error: Aborting due to Kconfig warnings
CMake Error at C:/ncs/v1.9.0/zephyr/cmake/kconfig.cmake:272 (message):
  command failed with return code: 1
  C:/ncs/v1.9.0/zephyr/cmake/app/boilerplate.cmake:544 (include)
  C:/ncs/v1.9.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include)
  C:/ncs/v1.9.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:40 (include_boilerplate)
  CMakeLists.txt:5 (find_package)
error: cmake failed
create_nordic_project.py failed (1)
How can I fix this issue?
Alex
prj.conf of hello_world:
# Ensure an MCUboot-compatible binary is generated.
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_MCUBOOT_IMAGE_VERSION="2"
#CONFIG_BOOT_SIGNATURE_KEY_FILE="privMCUBoot.pem"
# Enable mcumgr.
CONFIG_MCUMGR=y
# Enable most core commands.
CONFIG_MCUMGR_CMD_IMG_MGMT=y
CONFIG_MCUMGR_CMD_OS_MGMT=y
# Enable the serial mcumgr transport.
CONFIG_MCUMGR_SMP_UART=y
# Some command handlers require a large stack.
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
prj.conf of mcuboot (ncs\v1.9.0\bootloader\mcuboot\boot\zephyr)
CONFIG_PM=n
CONFIG_MAIN_STACK_SIZE=10240
CONFIG_MBEDTLS_CFG_FILE="mcuboot-mbedtls-cfg.h"
CONFIG_BOOT_SWAP_SAVE_ENCTLV=n
CONFIG_BOOT_ENCRYPT_RSA=n
CONFIG_BOOT_ENCRYPT_EC256=n
CONFIG_BOOT_ENCRYPT_X25519=n
CONFIG_BOOT_UPGRADE_ONLY=n
CONFIG_BOOT_BOOTSTRAP=n
### mbedTLS has its own heap
# CONFIG_HEAP_MEM_POOL_SIZE is not set
### We never want Zephyr's copy of tinycrypt.  If tinycrypt is needed,
### MCUboot has its own copy in tree.
# CONFIG_TINYCRYPT is not set
# CONFIG_TINYCRYPT_ECC_DSA is not set
# CONFIG_TINYCRYPT_SHA256 is not set
CONFIG_FLASH=y
CONFIG_FPROTECT=y
### Various Zephyr boards enable features that we don't want.
# CONFIG_BT is not set
# CONFIG_BT_CTLR is not set
# CONFIG_I2C is not set
CONFIG_LOG=y
CONFIG_LOG_MODE_MINIMAL=y # former CONFIG_MODE_MINIMAL
### Ensure Zephyr logging changes don't use more resources
CONFIG_LOG_DEFAULT_LEVEL=0
### Decrease footprint by ~4 KB in comparison to CBPRINTF_COMPLETE=y
CONFIG_CBPRINTF_NANO=y
