Summary: My custom board with an external crystal is consuming 208 µA when powered down under Zephyr, and I need to reduce it to less than 20 or so.
My board is based on a Fanstel BT840, and includes an external crystal and capacitors as recommended in the data sheet. It uses Zephyr to manage tasks and converse over Bluetooth. It is powered by a coin cell.
I'm using a Nordic Powerkit II to measure current draw. When the device is awake and in use, it consumes about 370 µA, which is great and well within my spec. But when I enter deep sleep, it consumes 208 µA constantly. The board works otherwise, which indicates to me that the internal clock is being used rather than the external crystal.
This is under v1.9.1 of the Nordic SDK. My firmware includes MCU Boot for firmware updates.
My prj.conf includes the following lines:
CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC=n CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM=y
To power down, I use the following code:
pm_power_state_force(0, (struct pm_state_info){PM_STATE_SOFT_OFF, 0, 0});
My research into this on the DevZone includes a post saying that I should expect single digit µA numbers for current draw:
The LF clock (either RC or crystal OSC) is the only clock source that is kept running continously. The 64MHz HF clock (sourced either internally or from the 32MHz crystal) is only enabled when necessary. This allows significant power saving: Chip uses single digit µA instead of a few 100µA in idle.
Any thoughts on how I can assure that the external crystal is being used for the clock and reduce power draw during sleep?
Steve
P.S. The complete prj.conf and the relevant part of the schematic is below.
CONFIG_DEBUG=y CONFIG_DEBUG_INFO=y CONFIG_DEBUG_OPTIMIZATIONS=y CONFIG_HEAP_MEM_POOL_SIZE=30000 CONFIG_PRINTK=y CONFIG_ASSERT=y CONFIG_SPI=y CONFIG_USE_SEGGER_RTT=y CONFIG_RTT_CONSOLE=y CONFIG_CONSOLE=y CONFIG_THREAD_NAME=y CONFIG_THREAD_ANALYZER=y CONFIG_THREAD_ANALYZER_AUTO=y CONFIG_THREAD_ANALYZER_RUN_UNLOCKED=y CONFIG_THREAD_ANALYZER_USE_PRINTK=y CONFIG_ASSERT=y CONFIG_ASSERT_VERBOSE=y CONFIG_ASSERT_NO_COND_INFO=n CONFIG_ASSERT_NO_MSG_INFO=n CONFIG_RESET_ON_FATAL_ERROR=n CONFIG_THREAD_NAME=y CONFIG_LOG=y CONFIG_LOG_PRINTK=y CONFIG_BT=y CONFIG_BT_DEBUG_LOG=y CONFIG_BT_SMP=y CONFIG_BT_PERIPHERAL=y CONFIG_BT_BAS=y CONFIG_BT_DEVICE_APPEARANCE=310 CONFIG_BT_DIS=y CONFIG_BT_DIS_PNP=n CONFIG_BT_DIS_MODEL="Abvio" CONFIG_BT_DIS_MANUF="Abvio" CONFIG_BT_DIS_SERIAL_NUMBER=y CONFIG_BT_DIS_FW_REV=y CONFIG_BT_DIS_HW_REV=y CONFIG_BT_DIS_SERIAL_NUMBER_STR="1234" CONFIG_BT_DIS_FW_REV_STR="1.0.22" CONFIG_BT_DIS_HW_REV_STR="1" CONFIG_BT_USER_DATA_LEN_UPDATE=y CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=n CONFIG_BT_BUF_ACL_RX_SIZE=251 CONFIG_BT_GATT_CLIENT=y CONFIG_BT_ATT_PREPARE_COUNT=2 CONFIG_BT_CONN_TX_MAX=10 CONFIG_BT_L2CAP_TX_BUF_COUNT=10 CONFIG_BT_L2CAP_TX_MTU=247 CONFIG_BT_L2CAP_DYNAMIC_CHANNEL=y CONFIG_BT_CTLR_PHY_2M=y CONFIG_BT_CTLR_RX_BUFFERS=2 CONFIG_BT_BUF_ACL_TX_COUNT=10 CONFIG_BT_BUF_ACL_TX_SIZE=251 CONFIG_BT_CTLR_DATA_LENGTH_MAX=251 CONFIG_BT_DEVICE_NAME="Abvio" CONFIG_PM=y CONFIG_PM_DEVICE=y CONFIG_MCUMGR=y CONFIG_MCUMGR_CMD_IMG_MGMT=y CONFIG_MCUMGR_CMD_OS_MGMT=y CONFIG_BOOTLOADER_MCUBOOT=y CONFIG_MCUMGR_SMP_BT=y CONFIG_MCUMGR_SMP_BT_AUTHEN=n CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096 CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC=n CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM=y
