nRF5340: Unable to Access I2C with nRF connect SDK v.2.1.2
I attached LIS2DS12 accelerometer sensor driver to the nrf5340 board, and I am trying to do (1) i2c access and (2) single tap interrupt handling (the sensor activates INT1 when tap event is detected).
1. nRF Connect SDK and toolchain version:  v.2.1.2
2. Build configuration:
- Board:
nrf5340dk_nrf5340_cpuapp
- Configuration (prj.conf):
CONFIG_GPIO=y
CONFIG_I2C=y
3. Code
 * Copyright (c) 2016 Intel Corporation
#include <zephyr/zephyr.h>
#include <zephyr/drivers/i2c.h>
// define
/*LIS2DH*/
#define ST_I2C_ADDR 0x1d
#define ST_REG_WAI 0x0f
#define I2C_MAX_ATTEMPT 10
// leds
/* 1000 msec = 1 sec */
// #define SLEEP_TIME_MS   1000
// #define LED0_NODE DT_ALIAS(led0)
// static const struct gpio_dt_spec led = GPIO_DT_SPEC_GET(LED0_NODE, gpios);
// devices
static const struct device *i2c_dev;
// functions
bool read_reg_value(const struct device* dev, uint16_t dev_addr, uint8_t reg_addr, uint8_t* value);
void read_regs_whoami();
	int ret;
	int counter = I2C_MAX_ATTEMPT;
	while(counter > 0)
		ret = i2c_reg_read_byte(dev, dev_addr, reg_addr, value);
		if (!ret)
			return true;
		counter--;
	return false;
	int ret;
	uint8_t wai = 0;
	/* Read the WHOAMI register */
	ret = read_reg_value(i2c_dev, ST_I2C_ADDR, ST_REG_WAI, &wai);
	if (ret)
		printk("WHO AM I: 0x%x\n", wai);
		printk("ERROR: Unable get reg value (WAI)\n");
// main
void main(void)
	i2c_dev = DEVICE_DT_GET(DT_NODELABEL(i2c1));
	if (i2c_dev == NULL || !device_is_ready(i2c_dev))
        printk("Could not get I2C device\n");
        return;
	read_regs_whoami();
	read_regs_whoami();
4. Expected result: successfully reads WAI register
5. Actual result: failed WAI read even after 10 attempts.
6. Problem description:
The function "i2c_reg_read_byte()" calls a function "i2c_nrfx_twim_transfer()" in a file "ncs/v2.1.2/zephyr/drivers/i2c/i2c_nrfx_twim.c".
The error happens at line 152 in i2c_nrfx_twim.c file, saying  k_sem_take() is not successful.
//(line 152)
ret = k_sem_take(&dev_data->completion_sync,
				 I2C_TRANSFER_TIMEOUT_MSEC); // FAILED
A comment in the file says it might be because of a hardware issue, and it could be resolved with a retry.
I checked this was not a hardware issue because, with nRF Connect SDK v.2.0.0, this worked after 1-2 attempts.
It would be appreciated if you could help me resolve this issue. I am attaching the i2c_nrfx_twim.c file for your reference.
Thank you.
 * Copyright (c) 2018, Nordic Semiconductor ASA
#include <zephyr/dt-bindings/i2c/i2c.h>
#include <zephyr/pm/device.h>
#include <zephyr/pm/device_runtime.h>
#include <zephyr/drivers/pinctrl.h>
#include <soc.h>
#include <nrfx_twim.h>
#include <zephyr/sys/util.h>
LOG_MODULE_REGISTER(i2c_nrfx_twim, CONFIG_I2C_LOG_LEVEL);
#define I2C_TRANSFER_TIMEOUT_MSEC		K_MSEC(500)
struct i2c_nrfx_twim_data {
	struct k_sem transfer_sync;
	struct k_sem completion_sync;
	volatile nrfx_err_t res;
	uint8_t *msg_buf;
struct i2c_nrfx_twim_config {
	nrfx_twim_t twim;
	nrfx_twim_config_t twim_config;
	uint16_t concat_buf_size;
	uint16_t flash_buf_max_size;
	void (*irq_connect)(void);
#ifdef CONFIG_PINCTRL
	const struct pinctrl_dev_config *pcfg;
static int i2c_nrfx_twim_recover_bus(const struct device *dev);
static int i2c_nrfx_twim_transfer(const struct device *dev,
				  struct i2c_msg *msgs,
				  uint8_t num_msgs, uint16_t addr)
	struct i2c_nrfx_twim_data *dev_data = dev->data;
	const struct i2c_nrfx_twim_config *dev_config = dev->config;
	int ret = 0;
	uint8_t *msg_buf = dev_data->msg_buf;
	uint16_t msg_buf_used = 0;
	uint16_t concat_buf_size = dev_config->concat_buf_size;
	nrfx_twim_xfer_desc_t cur_xfer = {
		.address = addr
	k_sem_take(&dev_data->transfer_sync, K_FOREVER);
	/* Dummy take on completion_sync sem to be sure that it is empty */
	k_sem_take(&dev_data->completion_sync, K_NO_WAIT);
	(void)pm_device_runtime_get(dev);
	for (size_t i = 0; i < num_msgs; i++) {
		if (I2C_MSG_ADDR_10_BITS & msgs[i].flags) {
			ret = -ENOTSUP;
		/* This fragment needs to be merged with the next one if:
		 * - it is not the last fragment
		 * - it does not end a bus transaction
		 * - the next fragment does not start a bus transaction
		 * - the direction of the next fragment is the same as this one
		bool concat_next = ((i + 1) < num_msgs)
				&& !(msgs[i].flags & I2C_MSG_STOP)
				&& !(msgs[i + 1].flags & I2C_MSG_RESTART)
				&& ((msgs[i].flags & I2C_MSG_READ)
				    == (msgs[i + 1].flags & I2C_MSG_READ));
		/* If we need to concatenate the next message, or we've
		 * already committed to concatenate this message, add it to
		 * the buffer after verifying there's room.
		if (concat_next || (msg_buf_used != 0)) {
			if ((msg_buf_used + msgs[i].len) > concat_buf_size) {
				LOG_ERR("Need to use concatenation buffer and "
					"provided size is insufficient "
					"(%u + %u > %u). "
					"Adjust the zephyr,concat-buf-size "
					"property in the \"%s\" node.",
					msg_buf_used, msgs[i].len,
					concat_buf_size, dev->name);
				ret = -ENOSPC;
			if (!(msgs[i].flags & I2C_MSG_READ)) {
				memcpy(msg_buf + msg_buf_used,
				       msgs[i].buf,
				       msgs[i].len);
			msg_buf_used += msgs[i].len;
		/* TWIM peripherals cannot transfer data directly from
		 * flash. If a buffer located in flash is provided for
		 * a write transaction, its content must be copied to
		 * RAM before the transfer can be requested.
		} else if (!(msgs[i].flags & I2C_MSG_READ) &&
			   !nrfx_is_in_ram(msgs[i].buf)) {
			if (msgs[i].len > dev_config->flash_buf_max_size) {
				LOG_ERR("Cannot copy flash buffer of size: %u. "
					"Adjust the zephyr,flash-buf-max-size "
					msgs[i].len, dev->name);
				ret = -EINVAL;
			memcpy(msg_buf, msgs[i].buf, msgs[i].len);
			msg_buf_used = msgs[i].len;
		if (concat_next) {
			continue;
		if (msg_buf_used == 0) {
			cur_xfer.p_primary_buf = msgs[i].buf;
			cur_xfer.primary_length = msgs[i].len;
		} else {
			cur_xfer.p_primary_buf = msg_buf;
			cur_xfer.primary_length = msg_buf_used;
		cur_xfer.type = (msgs[i].flags & I2C_MSG_READ) ?
			NRFX_TWIM_XFER_RX : NRFX_TWIM_XFER_TX;
		nrfx_err_t res = nrfx_twim_xfer(&dev_config->twim,
						&cur_xfer,
						(msgs[i].flags & I2C_MSG_STOP) ?
						 0 : NRFX_TWIM_FLAG_TX_NO_STOP);
		if (res != NRFX_SUCCESS) {
			if (res == NRFX_ERROR_BUSY) {
				ret = -EBUSY;
			} else {
				ret = -EIO;
		if (ret != 0) {
			/* Whatever the frequency, completion_sync should have
			 * been given by the event handler.
			 * If it hasn't, it's probably due to an hardware issue
			 * on the I2C line, for example a short between SDA and
			 * GND.
			 * This is issue has also been when trying to use the
			 * I2C bus during MCU internal flash erase.
			 * In many situation, a retry is sufficient.
			 * However, some time the I2C device get stuck and need
			 * help to recover.
			 * Therefore we always call i2c_nrfx_twim_recover_bus()
			 * to make sure everything has been done to restore the
			 * bus from this error.
			LOG_ERR("Error on I2C line occurred for message %d", i);
			(void)i2c_nrfx_twim_recover_bus(dev);
			ret = -EIO;
		res = dev_data->res;
			LOG_ERR("Error 0x%08X occurred for message %d", res, i);
			ret = -EIO;
		/* If concatenated messages were I2C_MSG_READ type, then
		 * content of concatenation buffer has to be copied back into
		 * buffers provided by user. */
		if ((msgs[i].flags & I2C_MSG_READ)
		    && cur_xfer.p_primary_buf == msg_buf) {
			int j = i;
			while (msg_buf_used >= msgs[j].len) {
				msg_buf_used -= msgs[j].len;
				memcpy(msgs[j].buf,
				       msgs[j].len);
				j--;
		msg_buf_used = 0;
	(void)pm_device_runtime_put(dev);
	k_sem_give(&dev_data->transfer_sync);
	return ret;
static void event_handler(nrfx_twim_evt_t const *p_event, void *p_context)
	struct i2c_nrfx_twim_data *dev_data = p_context;
	switch (p_event->type) {
	case NRFX_TWIM_EVT_DONE:
		dev_data->res = NRFX_SUCCESS;
	case NRFX_TWIM_EVT_ADDRESS_NACK:
		dev_data->res = NRFX_ERROR_DRV_TWI_ERR_ANACK;
	case NRFX_TWIM_EVT_DATA_NACK:
		dev_data->res = NRFX_ERROR_DRV_TWI_ERR_DNACK;
		dev_data->res = NRFX_ERROR_INTERNAL;
	k_sem_give(&dev_data->completion_sync);
static int i2c_nrfx_twim_configure(const struct device *dev,
				   uint32_t i2c_config)
	if (I2C_ADDR_10_BITS & i2c_config) {
		return -EINVAL;
	switch (I2C_SPEED_GET(i2c_config)) {
	case I2C_SPEED_STANDARD:
		nrf_twim_frequency_set(dev_config->twim.p_twim,
				       NRF_TWIM_FREQ_100K);
	case I2C_SPEED_FAST:
				       NRF_TWIM_FREQ_400K);
#if NRF_TWIM_HAS_1000_KHZ_FREQ
	case I2C_SPEED_FAST_PLUS:
				       NRF_TWIM_FREQ_1000K);
		LOG_ERR("unsupported speed");
		return -EINVAL;
	return 0;
	enum pm_device_state state;
	uint32_t scl_pin;
	uint32_t sda_pin;
	nrfx_err_t err;
	scl_pin = nrf_twim_scl_pin_get(dev_config->twim.p_twim);
	sda_pin = nrf_twim_sda_pin_get(dev_config->twim.p_twim);
#else
	scl_pin = dev_config->twim_config.scl;
	sda_pin = dev_config->twim_config.sda;
	/* disable peripheral if active (required to release SCL/SDA lines) */
	(void)pm_device_state_get(dev, &state);
	if (state == PM_DEVICE_STATE_ACTIVE) {
		nrfx_twim_disable(&dev_config->twim);
	err = nrfx_twim_bus_recover(scl_pin, sda_pin);
	/* restore peripheral if it was active before */
		(void)pinctrl_apply_state(dev_config->pcfg,
					  PINCTRL_STATE_DEFAULT);
		nrfx_twim_enable(&dev_config->twim);
	return (err == NRFX_SUCCESS ? 0 : -EBUSY);
static const struct i2c_driver_api i2c_nrfx_twim_driver_api = {
	.configure   = i2c_nrfx_twim_configure,
	.transfer    = i2c_nrfx_twim_transfer,
	.recover_bus = i2c_nrfx_twim_recover_bus,
#ifdef CONFIG_PM_DEVICE
static int twim_nrfx_pm_action(const struct device *dev,
			       enum pm_device_action action)
	int ret = 0;
	switch (action) {
	case PM_DEVICE_ACTION_RESUME:
		ret = pinctrl_apply_state(dev_config->pcfg,
		if (ret < 0) {
			return ret;
	case PM_DEVICE_ACTION_SUSPEND:
					  PINCTRL_STATE_SLEEP);
		if (ret < 0) {
			return ret;
		ret = -ENOTSUP;
	return ret;
#endif /* CONFIG_PM_DEVICE */
static int i2c_nrfx_twim_init(const struct device *dev)
	dev_config->irq_connect();
	int err = pinctrl_apply_state(dev_config->pcfg,
				      COND_CODE_1(CONFIG_PM_DEVICE_RUNTIME,
						  (PINCTRL_STATE_SLEEP),
						  (PINCTRL_STATE_DEFAULT)));
	if (err < 0) {
		return err;
	if (nrfx_twim_init(&dev_config->twim, &dev_config->twim_config,
			   event_handler, dev_data) != NRFX_SUCCESS) {
		LOG_ERR("Failed to initialize device: %s", dev->name);
		return -EIO;
#ifdef CONFIG_PM_DEVICE_RUNTIME
	pm_device_init_suspended(dev);
	pm_device_runtime_enable(dev);
#else
	return 0;
#define I2C_NRFX_TWIM_INVALID_FREQUENCY  ((nrf_twim_frequency_t)-1)
#define I2C_NRFX_TWIM_FREQUENCY(bitrate)				       \
	(bitrate == I2C_BITRATE_STANDARD  ? NRF_TWIM_FREQ_100K :	       \
	 bitrate == 250000                ? NRF_TWIM_FREQ_250K :	       \
	 bitrate == I2C_BITRATE_FAST      ? NRF_TWIM_FREQ_400K :	       \
	IF_ENABLED(NRF_TWIM_HAS_1000_KHZ_FREQ,				       \
	(bitrate == I2C_BITRATE_FAST_PLUS ? NRF_TWIM_FREQ_1000K :))	       \
					    I2C_NRFX_TWIM_INVALID_FREQUENCY)
#define I2C(idx) DT_NODELABEL(i2c##idx)
#define I2C_FREQUENCY(idx)						       \
	I2C_NRFX_TWIM_FREQUENCY(DT_PROP(I2C(idx), clock_frequency))
#define CONCAT_BUF_SIZE(idx)						       \
	COND_CODE_1(DT_NODE_HAS_PROP(I2C(idx), zephyr_concat_buf_size),	       \
		    (DT_PROP(I2C(idx), zephyr_concat_buf_size)), (0))
#define FLASH_BUF_MAX_SIZE(idx)						       \
	COND_CODE_1(DT_NODE_HAS_PROP(I2C(idx), zephyr_flash_buf_max_size),     \
		    (DT_PROP(I2C(idx), zephyr_flash_buf_max_size)), (0))
#define USES_MSG_BUF(idx)						       \
	COND_CODE_0(CONCAT_BUF_SIZE(idx),				       \
		(COND_CODE_0(FLASH_BUF_MAX_SIZE(idx), (0), (1))),	       \
		(1))
#define MSG_BUF_SIZE(idx)  MAX(CONCAT_BUF_SIZE(idx), FLASH_BUF_MAX_SIZE(idx))
#define I2C_NRFX_TWIM_PIN_CFG(idx)			\
	COND_CODE_1(CONFIG_PINCTRL,			\
		(.skip_gpio_cfg = true,			\
		 .skip_psel_cfg = true,),		\
		(.scl = DT_PROP(I2C(idx), scl_pin),	\
		 .sda = DT_PROP(I2C(idx), sda_pin),))
#define I2C_NRFX_TWIM_DEVICE(idx)					       \
	NRF_DT_CHECK_PIN_ASSIGNMENTS(I2C(idx), 1, scl_pin, sda_pin);	       \
	BUILD_ASSERT(I2C_FREQUENCY(idx) !=				       \
		     I2C_NRFX_TWIM_INVALID_FREQUENCY,			       \
		     "Wrong I2C " #idx " frequency setting in dts");	       \
	static void irq_connect##idx(void)				       \
		IRQ_CONNECT(DT_IRQN(I2C(idx)), DT_IRQ(I2C(idx), priority),     \
			    nrfx_isr, nrfx_twim_##idx##_irq_handler, 0);       \
	IF_ENABLED(USES_MSG_BUF(idx),					       \
		(static uint8_t twim_##idx##_msg_buf[MSG_BUF_SIZE(idx)];))     \
	static struct i2c_nrfx_twim_data twim_##idx##_data = {		       \
		.transfer_sync = Z_SEM_INITIALIZER(			       \
			twim_##idx##_data.transfer_sync, 1, 1),		       \
		.completion_sync = Z_SEM_INITIALIZER(			       \
			twim_##idx##_data.completion_sync, 0, 1),	       \
			(.msg_buf = twim_##idx##_msg_buf,))		       \
	IF_ENABLED(CONFIG_PINCTRL, (PINCTRL_DT_DEFINE(I2C(idx))));	       \
	static const struct i2c_nrfx_twim_config twim_##idx##z_config = {      \
		.twim = NRFX_TWIM_INSTANCE(idx),			       \
		.twim_config = {					       \
			.frequency = I2C_FREQUENCY(idx),		       \
		.concat_buf_size = CONCAT_BUF_SIZE(idx),		       \
		.flash_buf_max_size = FLASH_BUF_MAX_SIZE(idx),		       \
		.irq_connect = irq_connect##idx,			       \
		IF_ENABLED(CONFIG_PINCTRL,				       \
			(.pcfg = PINCTRL_DT_DEV_CONFIG_GET(I2C(idx)),))	       \
	PM_DEVICE_DT_DEFINE(I2C(idx), twim_nrfx_pm_action);		       \
	I2C_DEVICE_DT_DEFINE(I2C(idx),					       \
		      i2c_nrfx_twim_init,				       \
		      PM_DEVICE_DT_GET(I2C(idx)),			       \
		      &twim_##idx##_data,				       \
		      &twim_##idx##z_config,				       \
		      POST_KERNEL,					       \
		      CONFIG_I2C_INIT_PRIORITY,				       \
		      &i2c_nrfx_twim_driver_api)
#ifdef CONFIG_I2C_0_NRF_TWIM
I2C_NRFX_TWIM_DEVICE(0);
#ifdef CONFIG_I2C_1_NRF_TWIM
I2C_NRFX_TWIM_DEVICE(1);
#ifdef CONFIG_I2C_2_NRF_TWIM
I2C_NRFX_TWIM_DEVICE(2);
#ifdef CONFIG_I2C_3_NRF_TWIM
I2C_NRFX_TWIM_DEVICE(3);
    It's strange that it worked fine with SDK v2.0.0 but not v2.1.0. I'm was not able to find any relevant changes between these 2 releases, at least.
    I think the easiest way to troubleshoot this further is if you could probe the SDA/SCL lines with a scope or logic analyzer if you have that. Also, in case you use the internal GPIO pull-ups, please make sure they have been enabled with the bias-pull-up property in in your devicetree.
     &pinctrl {
    	i2c2_default: i2c2_default {
    		group1 {
    			psels = <NRF_PSEL(TWIM_SDA, 0, 30)>,
    				<NRF_PSEL(TWIM_SCL, 0, 31)>;
    				bias-pull-up;
    	i2c2_sleep: i2c2_sleep {
    		group1 {
    			low-power-enable;
    And just in case you haven't noticed, ST also include a driver for this IC in the SDK if you want to try it:  https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.1.2/zephyr/build/dts/api/compatibles/st,lis2ds12.html. To enable this driver you can select CONFIG_LIS2DS12=y and add the lis2dh12 subnode to your i2c:
    &i2c1
        lis2dh12@1d {
            compatible = "st,lis2ds12";
            reg = <0x1d >;
    Vidar
  • Hello, I edited overlay files following your suggestion, but unfortunately i2c still didn'twork with SDK 2.1.2. It still worked with SDK 2.0.0. Do you have any other suggestions?
    Also, I enabled lis2dh12 driver. In the overlay file, we defined its i2c reg address (reg = <0x1d>). Is there any way to use this value instead of using hardcoded value in the code (#define ST_I2C_ADDR 0x1d)?
    #define ST_I2C_ADDR 0x1d // hardcoded
    uint8_t wai = 0;
    1. DTS Overlay file
        // overwrite
        gpio_fwd: nrf-gpio-forwarder {
    		compatible = "nordic,nrf-gpio-forwarder";
    		status = "okay";
    		uart {
    			gpios = <&gpio1 1 0>, <&gpio1 4 0>, <&gpio0 11 0>, <&gpio0 10 0>;
        st_motion_interrupts {
            compatible = "gpio-keys";
            st_int1 {
                gpios = < &gpio1 0x0 (GPIO_PULL_UP | GPIO_ACTIVE_LOW) >;
                label = "st_lis2dh12_int1";
    &i2c1
        lis2dh12@1d {
            reg = <0x1d >;
            label = "st_lis2dh12";
    // overwrite - added bias-pull-up to i2c1_sleep.
    &pinctrl {
        i2c1_default: i2c1_default {
            group1 {
                psels = <NRF_PSEL(TWIM_SDA, 1, 2)>,
                    <NRF_PSEL(TWIM_SCL, 1, 3)>;
                    bias-pull-up; // added
        i2c1_sleep: i2c1_sleep {
            group1 {
                low-power-enable;
    2. Config (prj.conf) file
    CONFIG_GPIO=y
    CONFIG_I2C=y
    CONFIG_SENSOR=y
    CONFIG_LIS2DS12=y
    3. Code
    - unchanged
    Thank you,
    Sincerely,
    SK.
    The ST driver I mentioned can be used via the sensor subsystem as demonstrated by the  Generic 3-Axis accelerometer polling sample and LIS2DH: Motion Sensor Monitor sample. However, please note that these are for the LIS2DH IC and not the LIS2DS IC you use so you will need to adapt the sample (change compatible and node name) to ensure the build system includes the correct driver.
    From the specification I see the LIS2DS does not support supply voltages >1.98 V. Have you made sure the nRF5340 supply/IO voltage does not exceed this?
    https://www.st.com/en/mems-and-sensors/lis2ds12.html
    Vidar
  • After checking the voltage, I was able to fix the issue. We can close this ticket. Thank you!
    Sincerely,
    SK.
