bt_gatt_notify() can block when running on Zephyr workqueue.
Hi everyone,
I called "bt_gatt_notify()" from workqueue.
Usually there is no problem, but when move far away, "bt_gatt_notify()" doesn't return.
I called "bt_gatt_notify()" from "main()" works fine.
Shouldn't "bt_gatt_notify()" be called from workqueue?
thank you
    This was a surprise to me, but I see another thread describing a similar issue. I need to look into it and get back to you.
    I did a quick attempt to reproduce this now, by slightly modifying the Bluetooth: Peripheral CSC sample (zephyr/samples/bluetooth/peripheral_csc) as you can see in the attached diff. However, this worked as expected with nRF Connect SDK 2.1.2. Can you share a piece of code that reproduce this, and let me know which SDK version you are using.
    diff --git a/samples/bluetooth/peripheral_csc/src/main.c b/samples/bluetooth/peripheral_csc/src/main.c
    index d3e7f29901..0c126d87e2 100644
    --- a/samples/bluetooth/peripheral_csc/src/main.c
    +++ b/samples/bluetooth/peripheral_csc/src/main.c
    @@ -82,6 +82,7 @@ static uint8_t supported_locations[] = CSC_SUPPORTED_LOCATIONS;
     static uint8_t sensor_location; /* Current Sensor Location */
     static bool csc_simulate;
     static bool ctrl_point_configured;
    +struct k_work work;
     static void csc_meas_ccc_cfg_changed(const struct bt_gatt_attr *attr,
     				     uint16_t value)
    @@ -396,10 +397,17 @@ static void bas_notify(void)
     	bt_bas_set_battery_level(battery_level);
    +void csc_simulate_deferred(struct k_work *item)
    +	csc_simulation();
     void main(void)
     	int err;
    +	k_work_init(&work, csc_simulate_deferred);
     	err = bt_enable(NULL);
     	if (err) {
     		printk("Bluetooth init failed (err %d)\n", err);
    @@ -413,7 +421,7 @@ void main(void)
     		/* CSC simulation */
     		if (csc_simulate) {
    -			csc_simulation();
    +			k_work_submit(&work);
     		/* Battery level simulation */
  • Hi Einar
    I have attached the diff from your code.
    After this change, it still works fine if nRF52833 is nearby, otherwise "bt_gatt_notify()" may not return.
    Again, calling csc_simulation() instead of k_work_submit() always works fine.
    I am using nRF Connect SDK 2.1.0.
    thank you
    @@ -419,3 +419,3 @@
     	while (1) {
    -		k_sleep(K_SECONDS(1));
    +		k_sleep(K_MSEC(50));
    I see the same now. There seems to be a dead-lock here as the Zephyr Bluetooth stack also use the system workqueue. The bt_gatt_notify() function blocks when there are no available buffers, and as this is done from the system workqueue this blocks, preventing other queued items to be executed. And that is needed to empty the buffer. So this is fundamentally not working and should not be done.
    For future reference, here is the full modified peripheral_csc sample main.c for NCS 2.1.2 used to reproduce the issue:
    /* main.c - Bluetooth Cycling Speed and Cadence app main entry point */
     * Copyright (c) 2016 Intel Corporation
    #include <stdbool.h>
    #include <zephyr/types.h>
    #include <stddef.h>
    #include <string.h>
    #include <errno.h>
    #include <zephyr/random/rand32.h>
    #include <zephyr/sys/byteorder.h>
    #include <zephyr/zephyr.h>
    #include <zephyr/bluetooth/hci.h>
    #include <zephyr/bluetooth/hci_vs.h>
    #include <zephyr/bluetooth/conn.h>
    #include <zephyr/bluetooth/uuid.h>
    #include <zephyr/bluetooth/gatt.h>
    #include <zephyr/bluetooth/services/bas.h>
    #define CSC_SUPPORTED_LOCATIONS		{ CSC_LOC_OTHER, \
    					  CSC_LOC_FRONT_WHEEL, \
    					  CSC_LOC_REAR_WHEEL, \
    					  CSC_LOC_LEFT_CRANK, \
    					  CSC_LOC_RIGHT_CRANK }
    #define CSC_FEATURE			(CSC_FEAT_WHEEL_REV | \
    					 CSC_FEAT_CRANK_REV | \
    					 CSC_FEAT_MULTI_SENSORS)
    /* CSC Sensor Locations */
    #define CSC_LOC_OTHER			0x00
    #define CSC_LOC_TOP_OF_SHOE		0x01
    #define CSC_LOC_IN_SHOE			0x02
    #define CSC_LOC_HIP			0x03
    #define CSC_LOC_FRONT_WHEEL		0x04
    #define CSC_LOC_LEFT_CRANK		0x05
    #define CSC_LOC_RIGHT_CRANK		0x06
    #define CSC_LOC_LEFT_PEDAL		0x07
    #define CSC_LOC_RIGHT_PEDAL		0x08
    #define CSC_LOC_FRONT_HUB		0x09
    #define CSC_LOC_REAR_DROPOUT		0x0a
    #define CSC_LOC_CHAINSTAY		0x0b
    #define CSC_LOC_REAR_WHEEL		0x0c
    #define CSC_LOC_REAR_HUB		0x0d
    #define CSC_LOC_CHEST			0x0e
    /* CSC Application error codes */
    #define CSC_ERR_IN_PROGRESS		0x80
    #define CSC_ERR_CCC_CONFIG		0x81
    /* SC Control Point Opcodes */
    #define SC_CP_OP_SET_CWR		0x01
    #define SC_CP_OP_CALIBRATION		0x02
    #define SC_CP_OP_UPDATE_LOC		0x03
    #define SC_CP_OP_REQ_SUPP_LOC		0x04
    #define SC_CP_OP_RESPONSE		0x10
    /* SC Control Point Response Values */
    #define SC_CP_RSP_SUCCESS		0x01
    #define SC_CP_RSP_OP_NOT_SUPP		0x02
    #define SC_CP_RSP_INVAL_PARAM		0x03
    #define SC_CP_RSP_FAILED		0x04
    /* CSC Feature */
    #define CSC_FEAT_WHEEL_REV		BIT(0)
    #define CSC_FEAT_CRANK_REV		BIT(1)
    #define CSC_FEAT_MULTI_SENSORS		BIT(2)
    /* CSC Measurement Flags */
    #define CSC_WHEEL_REV_DATA_PRESENT	BIT(0)
    #define CSC_CRANK_REV_DATA_PRESENT	BIT(1)
    /* Cycling Speed and Cadence Service declaration */
    static uint32_t cwr; /* Cumulative Wheel Revolutions */
    struct k_work work;
    				     uint16_t value)
    	csc_simulate = value == BT_GATT_CCC_NOTIFY;
    static void ctrl_point_ccc_cfg_changed(const struct bt_gatt_attr *attr,
    				       uint16_t value)
    	ctrl_point_configured = value == BT_GATT_CCC_INDICATE;
    static ssize_t read_location(struct bt_conn *conn,
    			     const struct bt_gatt_attr *attr, void *buf,
    			     uint16_t len, uint16_t offset)
    	uint8_t *value = attr->user_data;
    	return bt_gatt_attr_read(conn, attr, buf, len, offset, value,
    				 sizeof(*value));
    static ssize_t read_csc_feature(struct bt_conn *conn,
    	uint16_t csc_feature = CSC_FEATURE;
    				 &csc_feature, sizeof(csc_feature));
    static void ctrl_point_ind(struct bt_conn *conn, uint8_t req_op, uint8_t status,
    			   const void *data, uint16_t data_len);
    struct write_sc_ctrl_point_req {
    	uint8_t op;
    	union {
    		uint32_t cwr;
    		uint8_t location;
    } __packed;
    static ssize_t write_ctrl_point(struct bt_conn *conn,
    				const void *buf, uint16_t len, uint16_t offset,
    				uint8_t flags)
    	const struct write_sc_ctrl_point_req *req = buf;
    	uint8_t status;
    	int i;
    	if (!ctrl_point_configured) {
    		return BT_GATT_ERR(CSC_ERR_CCC_CONFIG);
    	if (!len) {
    		return BT_GATT_ERR(BT_ATT_ERR_INVALID_ATTRIBUTE_LEN);
    	switch (req->op) {
    	case SC_CP_OP_SET_CWR:
    		if (len != sizeof(req->op) + sizeof(req->cwr)) {
    			status = SC_CP_RSP_INVAL_PARAM;
    		cwr = sys_le32_to_cpu(req->cwr);
    		status = SC_CP_RSP_SUCCESS;
    	case SC_CP_OP_UPDATE_LOC:
    		if (len != sizeof(req->op) + sizeof(req->location)) {
    		/* Break if the requested location is the same as current one */
    		if (req->location == sensor_location) {
    		/* Pre-set status */
    		/* Check if requested location is supported */
    		for (i = 0; i < ARRAY_SIZE(supported_locations); i++) {
    			if (supported_locations[i] == req->location) {
    				sensor_location = req->location;
    	case SC_CP_OP_REQ_SUPP_LOC:
    		if (len != sizeof(req->op)) {
    		/* Indicate supported locations and return */
    		ctrl_point_ind(conn, req->op, SC_CP_RSP_SUCCESS,
    			       &supported_locations,
    			       sizeof(supported_locations));
    		return len;
    		status = SC_CP_RSP_OP_NOT_SUPP;
    	ctrl_point_ind(conn, req->op, status, NULL, 0);
    	return len;
    BT_GATT_SERVICE_DEFINE(csc_svc,
    	BT_GATT_PRIMARY_SERVICE(BT_UUID_CSC),
    	BT_GATT_CHARACTERISTIC(BT_UUID_CSC_MEASUREMENT, BT_GATT_CHRC_NOTIFY,
    			       0x00, NULL, NULL, NULL),
    	BT_GATT_CCC(csc_meas_ccc_cfg_changed,
    		    BT_GATT_PERM_READ | BT_GATT_PERM_WRITE),
    	BT_GATT_CHARACTERISTIC(BT_UUID_SENSOR_LOCATION, BT_GATT_CHRC_READ,
    			       BT_GATT_PERM_READ, read_location, NULL,
    			       &sensor_location),
    	BT_GATT_CHARACTERISTIC(BT_UUID_CSC_FEATURE, BT_GATT_CHRC_READ,
    			       BT_GATT_PERM_READ, read_csc_feature, NULL, NULL),
    	BT_GATT_CHARACTERISTIC(BT_UUID_SC_CONTROL_POINT,
    			       BT_GATT_CHRC_WRITE | BT_GATT_CHRC_INDICATE,
    			       BT_GATT_PERM_WRITE, NULL, write_ctrl_point,
    			       &sensor_location),
    	BT_GATT_CCC(ctrl_point_ccc_cfg_changed,
    struct sc_ctrl_point_ind {
    	uint8_t op;
    	uint8_t req_op;
    	uint8_t status;
    	uint8_t data[];
    } __packed;
    	struct sc_ctrl_point_ind *ind;
    	uint8_t buf[sizeof(*ind) + data_len];
    	ind = (void *) buf;
    	ind->op = SC_CP_OP_RESPONSE;
    	ind->req_op = req_op;
    	ind->status = status;
    	/* Send data (supported locations) if present */
    	if (data && data_len) {
    		memcpy(ind->data, data, data_len);
    	bt_gatt_notify(conn, &csc_svc.attrs[8], buf, sizeof(buf));
    struct csc_measurement_nfy {
    	uint8_t flags;
    	uint8_t data[];
    } __packed;
    struct wheel_rev_data_nfy {
    	uint32_t cwr;
    	uint16_t lwet;
    } __packed;
    struct crank_rev_data_nfy {
    	uint16_t ccr;
    	uint16_t lcet;
    } __packed;
    static void measurement_nfy(struct bt_conn *conn, uint32_t cwr, uint16_t lwet,
    			    uint16_t ccr, uint16_t lcet)
    	struct csc_measurement_nfy *nfy;
    	uint8_t buf[sizeof(*nfy) +
    		    (cwr ? sizeof(struct wheel_rev_data_nfy) : 0) +
    		    (ccr ? sizeof(struct crank_rev_data_nfy) : 0)];
    	uint16_t len = 0U;
    	nfy = (void *) buf;
    	nfy->flags = 0U;
    	/* Send Wheel Revolution data is present */
    	if (cwr) {
    		struct wheel_rev_data_nfy data;
    		nfy->flags |= CSC_WHEEL_REV_DATA_PRESENT;
    		data.cwr = sys_cpu_to_le32(cwr);
    		data.lwet = sys_cpu_to_le16(lwet);
    		memcpy(nfy->data, &data, sizeof(data));
    		len += sizeof(data);
    	/* Send Crank Revolution data is present */
    	if (ccr) {
    		struct crank_rev_data_nfy data;
    		nfy->flags |= CSC_CRANK_REV_DATA_PRESENT;
    		data.ccr = sys_cpu_to_le16(ccr);
    		data.lcet = sys_cpu_to_le16(lcet);
    		memcpy(nfy->data + len, &data, sizeof(data));
    	bt_gatt_notify(NULL, &csc_svc.attrs[1], buf, sizeof(buf));
    static uint16_t lwet; /* Last Wheel Event Time */
    static uint16_t ccr;  /* Cumulative Crank Revolutions */
    static uint16_t lcet; /* Last Crank Event Time */
    static void csc_simulation(void)
    	static uint8_t i;
    	uint32_t rand = sys_rand32_get();
    	bool nfy_crank = false, nfy_wheel = false;
    	/* Measurements don't have to be updated every second */
    	if (!(i % 2)) {
    		lwet += 1050 + rand % 50;
    		cwr += 2U;
    		nfy_wheel = true;
    	if (!(i % 3)) {
    		lcet += 1000 + rand % 50;
    		ccr += 1U;
    		nfy_crank = true;
    	 * In typical applications, the CSC Measurement characteristic is
    	 * notified approximately once per second. This interval may vary
    	 * and is determined by the Server and not required to be configurable
    	 * by the Client.
    	measurement_nfy(NULL, nfy_wheel ? cwr : 0, nfy_wheel ? lwet : 0,
    			nfy_crank ? ccr : 0, nfy_crank ? lcet : 0);
    	 * The Last Crank Event Time value and Last Wheel Event Time roll over
    	 * every 64 seconds.
    	if (!(i % 64)) {
    		lcet = 0U;
    		lwet = 0U;
    		i = 0U;
    	i++;
    static void set_tx_power(uint8_t handle_type, uint16_t handle, int8_t tx_pwr_lvl)
    	struct bt_hci_cp_vs_write_tx_power_level *cp;
    	struct bt_hci_rp_vs_write_tx_power_level *rp;
    	struct net_buf *buf, *rsp = NULL;
    	int err;
    	buf = bt_hci_cmd_create(BT_HCI_OP_VS_WRITE_TX_POWER_LEVEL,
    				sizeof(*cp));
    	if (!buf) {
    		printk("Unable to allocate command buffer\n");
    		return;
    	cp = net_buf_add(buf, sizeof(*cp));
    	cp->handle = sys_cpu_to_le16(handle);
    	cp->handle_type = handle_type;
    	cp->tx_power_level = tx_pwr_lvl;
    	err = bt_hci_cmd_send_sync(BT_HCI_OP_VS_WRITE_TX_POWER_LEVEL,
    				   buf, &rsp);
    	if (err) {
    		uint8_t reason = rsp ?
    			((struct bt_hci_rp_vs_write_tx_power_level *)
    			  rsp->data)->status : 0;
    		printk("Set Tx power err: %d reason 0x%02x\n", err, reason);
    		return;
    	rp = (void *)rsp->data;
    	printk("Actual Tx Power: %d\n", rp->selected_tx_power);
    	net_buf_unref(rsp);
    static void connected(struct bt_conn *conn, uint8_t err)
    	if (err) {
    		printk("Connection failed (err 0x%02x)\n", err);
    	} else {
    		printk("Connected\n");
    	// Use a Tx power of -40 dBm to more easily reproduce the issue described in
    	// https://devzone.nordicsemi.com/f/nordic-q-a/93785/bt_gatt_notify-can-block-when-running-on-zephyr-workqueue
    	set_tx_power(BT_HCI_VS_LL_HANDLE_TYPE_CONN, 0, -40);
    	printk("Disconnected (reason 0x%02x)\n", reason);
    BT_CONN_CB_DEFINE(conn_callbacks) = {
    	.connected = connected,
    	.disconnected = disconnected,
    static const struct bt_data ad[] = {
    	BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
    	BT_DATA_BYTES(BT_DATA_UUID16_ALL,
    		      BT_UUID_16_ENCODE(BT_UUID_CSC_VAL),
    		      BT_UUID_16_ENCODE(BT_UUID_BAS_VAL))
    static void bt_ready(void)
    	int err;
    	printk("Bluetooth initialized\n");
    	err = bt_le_adv_start(BT_LE_ADV_CONN_NAME, ad, ARRAY_SIZE(ad), NULL, 0);
    	if (err) {
    		printk("Advertising failed to start (err %d)\n", err);
    		return;
    	printk("Advertising successfully started\n");
    	uint8_t battery_level = bt_bas_get_battery_level();
    	battery_level--;
    	if (!battery_level) {
    		battery_level = 100U;
    	csc_simulation();
    void main(void)
    	int err;
    	if (err) {
    		return;
    	bt_ready();
    	while (1) {
    		//k_sleep(K_SECONDS(1));
    		if (csc_simulate) {
    			//csc_simulation();
    		bas_notify();
    There is also a need to add "CONFIG_BT_CTLR_TX_PWR_DYNAMIC_CONTROL=y" to prj.conf. In addition to what has been discussed, this sample use -40 dBm as Tx power in connections to make it easy to reproduce the issue on the desk by moving the central a short distance away from the peripheral to cause packet loss and trigger the issue.
  • Hi Einar
    Thank you for taking the time to answer my questions.
    I feel better now that I know why it is not working.
    thank you
