JLinkARM DLL unknown error
Sometimes I get random JLinkARM DLL unknown error when I reset my device. I tried different PC, debugger, supply of chip. Nothing fixed this issue.
NRF52840 REV 3
nrfjprog version: 10.18.1 external
JLinkARM.dll version: 7.82
[2022-Nov-11 12:20:21] [debug] --------------------------------------------------------------------------------
[2022-Nov-11 12:20:21] [debug] nrfjprog --recover --log
[2022-Nov-11 12:20:21] [debug] nrfjprog version 10.18.1 external
[2022-Nov-11 12:20:21] [ info] Load library at C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.dll.
[2022-Nov-11 12:20:21] [ info] Library loaded, loading member functions.
[2022-Nov-11 12:20:21] [ info] Member functions succesfully loaded.
[2022-Nov-11 12:20:21] [debug] [ Client] - open
[2022-Nov-11 12:20:21] [debug] [ Client] - start
[2022-Nov-11 12:20:21] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 158743a1-75c2-400e-a75a-5203003f1b64.
[2022-Nov-11 12:20:21] [trace] [ Client] - Command open executed for 35 milliseconds with result 0
[2022-Nov-11 12:20:21] [debug] [ Client] - config
[2022-Nov-11 12:20:21] [trace] [ Client] - Command config executed for 15 milliseconds with result 0
[2022-Nov-11 12:20:21] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
[2022-Nov-11 12:20:21] [debug] [ Client] - enum_emu_snr
[2022-Nov-11 12:20:21] [debug] [  JLink] - Logger sink registered in JLink logger
[2022-Nov-11 12:20:21] [debug] [  nRFXX] - open
[2022-Nov-11 12:20:21] [debug] [  nRFXX] - just_check_family
[2022-Nov-11 12:20:21] [debug] [SeggerBackend] - open_dll
[2022-Nov-11 12:20:21] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
[2022-Nov-11 12:20:21] [ info] [SeggerBackend] - Load library at C:\Program Files\SEGGER\JLink\JLink_x64.dll.
[2022-Nov-11 12:20:21] [ info] [SeggerBackend] - Library loaded, loading member functions.
[2022-Nov-11 12:20:21] [ info] [SeggerBackend] - Member functions succesfully loaded.
[2022-Nov-11 12:20:21] [debug] [SeggerBackend] - Set batch mode
[2022-Nov-11 12:20:21] [debug] [SeggerBackend] - dll_version
[2022-Nov-11 12:20:21] [ info] [SeggerBackend] - Segger dll version 7.82.  loaded.
[2022-Nov-11 12:20:21] [trace] [ Worker] - Command open executed for 4 milliseconds with result 0
[2022-Nov-11 12:20:21] [debug] [  nRFXX] - config
[2022-Nov-11 12:20:21] [trace] [ Worker] - Command config executed for 2 milliseconds with result 0
[2022-Nov-11 12:20:21] [trace] [ Client] - Command enum_emu_con_info executed for 15 milliseconds with result 0
[2022-Nov-11 12:20:21] [debug] [ Client] - connect_to_emu_with_snr
[2022-Nov-11 12:20:21] [debug] [  nRFXX] - enum_emu_con_info
[2022-Nov-11 12:20:21] [debug] [SeggerBackend] - is_connected_to_emu
[2022-Nov-11 12:20:21] [debug] [SeggerBackend] - enum_emu_con_info
[2022-Nov-11 12:20:21] [trace] [ Worker] - Command enum_emu_con_info executed for 1 milliseconds with result 0
[2022-Nov-11 12:20:21] [debug] [  nRFXX] - connect_to_emu_with_snr
[2022-Nov-11 12:20:21] [debug] [SeggerBackend] - connect_to_emu_with_snr
[2022-Nov-11 12:20:21] [debug] [SeggerBackend] - ---just_enum_emu_snr
[2022-Nov-11 12:20:21] [debug] [SeggerBackend] - ---just_get_num_emus
[2022-Nov-11 12:20:21] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
[2022-Nov-11 12:20:21] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
[2022-Nov-11 12:20:21] [debug] [SeggerBackend] - Segger logging enabled.
[2022-Nov-11 12:20:21] [trace] [  JLink] - Firmware: J-Link EDU Mini V1 compiled Sep 22 2022 14:55:40
[2022-Nov-11 12:20:21] [trace] [ Client] - Command connect_to_emu_with_snr executed for 45 milliseconds with result 0
[2022-Nov-11 12:20:21] [debug] [ Client] - read_connected_emu_snr
[2022-Nov-11 12:20:21] [trace] [  JLink] - Hardware: V1.00
[2022-Nov-11 12:20:21] [trace] [  JLink] - S/N: 801023250
[2022-Nov-11 12:20:21] [trace] [  JLink] - OEM: SEGGER
[2022-Nov-11 12:20:21] [trace] [  JLink] - Feature(s): FlashBP, GDB
[2022-Nov-11 12:20:21] [trace] [  JLink] - USB speed mode: Full speed (12 MBit/s)
[2022-Nov-11 12:20:21] [trace] [  JLink] - TELNET listener socket opened on port 19021
[2022-Nov-11 12:20:21] [trace] [  JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
[2022-Nov-11 12:20:21] [trace] [  JLink] - WEBSRV Webserver running on local port 19080
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 19.273ms returns "O.K."
[2022-Nov-11 12:20:21] [trace] [  JLink] - JLINK_HasError()
[2022-Nov-11 12:20:21] [trace] [  JLink] - JLINK_Lock()
[2022-Nov-11 12:20:21] [trace] [  JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.002ms returns 0x01
[2022-Nov-11 12:20:21] [trace] [  JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.002ms returns 0x00
[2022-Nov-11 12:20:21] [trace] [  JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.003ms returns 0x00
[2022-Nov-11 12:20:21] [trace] [  JLink] - JLINK_SetHookUnsecureDialog
[2022-Nov-11 12:20:21] [trace] [  JLink] - JLINK_SetHookUnsecureDialog(...)
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.011ms returns 0
[2022-Nov-11 12:20:21] [trace] [  JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.431ms returns 0x00
[2022-Nov-11 12:20:21] [trace] [  JLink] - JLINK_GetSpeedInfo()
[2022-Nov-11 12:20:21] [trace] [  JLink] - 96000000 Hz / n, n >= 24
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.009ms
[2022-Nov-11 12:20:21] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 4000kHz
[2022-Nov-11 12:20:21] [trace] [  JLink] - JLINK_SetSpeed(2000)
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.113ms
[2022-Nov-11 12:20:21] [trace] [  JLink] - JLINK_GetSpeed()
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.004ms returns 2000
[2022-Nov-11 12:20:21] [debug] [SeggerBackend] - SWD clock set to 2000kHz
[2022-Nov-11 12:20:21] [trace] [  JLink] - JLINK_GetSN()
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.004ms returns 801023250
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.008ms
[2022-Nov-11 12:20:21] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 33 milliseconds with result 0
[2022-Nov-11 12:20:21] [debug] [  nRFXX] - read_connected_emu_snr
[2022-Nov-11 12:20:21] [trace] [ Client] - Command read_connected_emu_snr executed for 15 milliseconds with result 0
[2022-Nov-11 12:20:21] [debug] [ Client] - read_device_family
[2022-Nov-11 12:20:21] [trace] [  JLink] - JLINK_IsOpen()
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.009ms returns 0x01
[2022-Nov-11 12:20:21] [debug] [SeggerBackend] - read_connected_emu_snr
[2022-Nov-11 12:20:21] [trace] [ Worker] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
[2022-Nov-11 12:20:21] [debug] [  nRFXX] - read_device_family
[2022-Nov-11 12:20:21] [debug] [SeggerBackend] - read_debug_port_idr
[2022-Nov-11 12:20:21] [debug] [SeggerBackend] - read_debug_port_register
[2022-Nov-11 12:20:21] [debug] [SeggerBackend] - ---just_read_debug_port_register
[2022-Nov-11 12:20:21] [debug] [SeggerBackend] - coresight_configure
[2022-Nov-11 12:20:21] [trace] [  JLink] - JLINK_GetHWStatus(...)
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.179ms returns 0
[2022-Nov-11 12:20:21] [trace] [  JLink] - JLINK_CORESIGHT_Configure()
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 100.662ms returns 0
[2022-Nov-11 12:20:21] [debug] [SeggerBackend] - ---just_select_debug_port_register
[2022-Nov-11 12:20:21] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
[2022-Nov-11 12:20:21] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.889ms returns -1
[2022-Nov-11 12:20:21] [error] [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
[2022-Nov-11 12:20:21] [debug] [SeggerBackend] - ---just_abort_debug_action
[2022-Nov-11 12:20:21] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
[2022-Nov-11 12:20:21] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.837ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.883ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.867ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.887ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.884ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.915ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.580ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.591ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.548ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.513ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.495ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.562ms returns -1
[2022-Nov-11 12:20:21] [trace] [ Client] - Command read_device_family executed for 123 milliseconds with result -102
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.500ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.505ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.498ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.452ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.504ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.510ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.559ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.488ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.456ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.568ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.457ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.484ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.502ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.522ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.519ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.014ms
[2022-Nov-11 12:20:21] [trace] [ Worker] - Command read_device_family executed for 120 milliseconds with result -102
[2022-Nov-11 12:20:21] [debug] [  nRFXX] - close
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.012ms returns 0x01
[2022-Nov-11 12:20:21] [debug] [SeggerBackend] - close
[2022-Nov-11 12:20:21] [debug] [SeggerBackend] - disconnect_from_emu
[2022-Nov-11 12:20:21] [debug] [SeggerBackend] - ---just_disconnect_from_emu
[2022-Nov-11 12:20:21] [debug] [SeggerBackend] - is_connected_to_device
[2022-Nov-11 12:20:21] [trace] [  JLink] - JLINK_IsConnected()
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.005ms returns FALSE
[2022-Nov-11 12:20:21] [debug] [SeggerBackend] - ---just_is_debug_region_powered
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.514ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.631ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.570ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.486ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.469ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.496ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.473ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.462ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.507ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.516ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.537ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.567ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.508ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.569ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.449ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.455ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.464ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.538ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.607ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.550ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.475ms returns -1
[2022-Nov-11 12:20:21] [trace] [  JLink] - - 0.015ms
[2022-Nov-11 12:20:21] [trace] [  JLink] - JLINK_Close()
[2022-Nov-11 12:20:21] [debug] [SeggerBackend] - Segger Backend closed.
[2022-Nov-11 12:20:21] [debug] [  nRFXX] - nRF family DLL closed
[2022-Nov-11 12:20:21] [trace] [ Client] - Command close executed for 261 milliseconds with result 0
[2022-Nov-11 12:20:21] [debug] [ Client] - terminate
[2022-Nov-11 12:20:21] [trace] [ Worker] - Command close executed for 245 milliseconds with result 0
[2022-Nov-11 12:20:21] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
[2022-Nov-11 12:20:21] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
[2022-Nov-11 12:20:21] [trace] [ Worker] - Executed 8 commands for 405 milliseconds
[2022-Nov-11 12:20:21] [debug] [ Client] - Worker process exited with code: 0
[2022-Nov-11 12:20:21] [debug] [ Client] - Child process terminated with result 0
[2022-Nov-11 12:20:21] [trace] [ Client] - Executed 8 commands for 509 milliseconds
