[matter] Test-Harness and DUT failed to be paired
Hi  all,
I trying to use test-harness v2.6 raspi and nRF52840dk to test commissioning.The result is always failure, and the error is timeout
The firmware DK flash is build from matter V1.0.0 Release,connectedhomeip/examples/lock-app/nrfconnect.
I have tried to test-harness v2.4 with DK flashed the same firmware commissioning successfully. But both test-harness v2.4 and test-harness v2.5 fail to time out.
Has anyone tested this? why V2.6 can't be commissioning successfully?
Below are the logs of chiptool and DK.
ubuntu@ubuntu:~/apps$ ./chip-tool pairing ble-thread 66 hex:0e080000000000010000000300001935060004001fffe002085b35dead5b35beef0708fd2c6fd19ad8db3f051000112233445566778899aabbccddeeff03043562333501025b350410eff65884a3c56f18b1d6204fec9432060c0402a0f7f8 20202021 4004
[1667898591.850033][3796:3796] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
[1667898591.855532][3796:3796] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
[1667898591.855844][3796:3796] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
[1667898591.855968][3796:3796] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
[1667898591.856293][3796:3796] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-RQtTxi)
[1667898591.856896][3796:3796] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1667898591.856948][3796:3796] CHIP:DL: NVS set: chip-counters/reboot-count = 2 (0x2)
[1667898591.857859][3796:3796] CHIP:DL: Got Ethernet interface: eth0
[1667898591.858535][3796:3796] CHIP:DL: Found the primary Ethernet interface:eth0
[1667898591.859136][3796:3796] CHIP:DL: Got WiFi interface: wlan0
[1667898591.859199][3796:3796] CHIP:DL: Failed to reset WiFi statistic counts
[1667898591.859249][3796:3796] CHIP:IN: UDP::Init bind&listen port=0
[1667898591.859363][3796:3796] CHIP:IN: UDP::Init bound to port=41818
[1667898591.859387][3796:3796] CHIP:IN: BLEBase::Init - setting/overriding transport
[1667898591.859408][3796:3796] CHIP:IN: TransportMgr initialized
[1667898591.859443][3796:3796] CHIP:FP: Initializing FabricTable from persistent storage
[1667898591.859573][3796:3796] CHIP:TS: Last Known Good Time: 2022-10-21T23:13:11
[1667898591.861073][3796:3796] CHIP:FP: Fabric index 0x1 was retrieved from storage. Compressed FabricId 0x289D5D313AA5011B, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
[1667898591.863124][3796:3796] CHIP:ZCL: Using ZAP configuration...
[1667898591.866958][3796:3796] CHIP:DL: Avahi client registered
[1667898591.868044][3796:3796] CHIP:CTL: System State Initialized...
[1667898591.868140][3796:3796] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1667898591.868179][3796:3796] CHIP:CTL: Setting attestation nonce to random value
[1667898591.868214][3796:3796] CHIP:CTL: Setting CSR nonce to random value
[1667898591.868482][3796:3801] CHIP:DL: CHIP task running
[1667898591.868654][3796:3801] CHIP:DL: HandlePlatformSpecificBLEEvent 32784
[1667898591.868716][3796:3801] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1667898591.868746][3796:3801] CHIP:CTL: Setting attestation nonce to random value
[1667898591.868902][3796:3801] CHIP:CTL: Setting CSR nonce to random value
[1667898591.869964][3796:3801] CHIP:CTL: Generating NOC
[1667898591.871105][3796:3801] CHIP:FP: Validating NOC chain
[1667898591.873192][3796:3801] CHIP:FP: NOC chain validation successful
[1667898591.873369][3796:3801] CHIP:FP: Updated fabric at index: 0x1, Node ID: 0x000000000001B669
[1667898591.873407][3796:3801] CHIP:TS: Last Known Good Time: 2022-10-21T23:13:11
[1667898591.873434][3796:3801] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
[1667898591.873459][3796:3801] CHIP:TS: Retaining current Last Known Good Time
[1667898591.877553][3796:3801] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
[1667898591.879500][3796:3801] CHIP:TS: Committing Last Known Good Time to storage: 2022-10-21T23:13:11
[1667898591.881251][3796:3801] CHIP:CTL: Joined the fabric at index 1. Compressed fabric ID is: 0x0000000000000000
[1667898591.892944][3796:3801] CHIP:IN: SecureSession[0xffff8c009d20]: Allocated Type:1 LSID:64643
[1667898591.893004][3796:3801] CHIP:SC: Assigned local session key ID 64643
[1667898591.893083][3796:3801] CHIP:SC: Including MRP parameters in PBKDF param request
[1667898591.893157][3796:3801] CHIP:IN: Prepared unauthenticated message 0xffffa0a2dc58 to 0x0000000000000000 (0)  of type 0x20 and protocolId (0, 0) on exchange 47590i with MessageCounter:76027510.
[1667898591.893203][3796:3801] CHIP:IN: Sending unauthenticated msg 0xffffa0a2dc58 with MessageCounter:76027510 to 0x0000000000000000 at monotonic time: 00000000003A0647 msec
[1667898591.893259][3796:3801] CHIP:IN: Message appended to BLE send queue
[1667898591.893285][3796:3801] CHIP:SC: Sent PBKDF param request
[1667898591.893316][3796:3801] CHIP:CTL: Setting thread operational dataset from parameters
[1667898591.893349][3796:3801] CHIP:CTL: Setting attempt thread scan from parameters
[1667898591.893373][3796:3801] CHIP:CTL: Setting attestation nonce to random value
[1667898591.893409][3796:3801] CHIP:CTL: Setting CSR nonce to random value
[1667898591.893457][3796:3801] CHIP:CTL: Commission called for node ID 0x0000000000000042
[1667898591.893809][3796:3802] CHIP:DL: TRACE: Bluez mainloop starting Thread
[1667898591.893988][3796:3799] CHIP:DL: TRACE: Bus acquired for name C-0ed4
[1667898591.901969][3796:3801] CHIP:DL: PlatformBlueZInit init success
[1667898591.908023][3796:3799] CHIP:BLE: BLE removing known devices.
[1667898591.909702][3796:3799] CHIP:BLE: BLE initiating scan.
[1667898591.916952][3796:3799] CHIP:BLE: Device 30:B5:30:25:0B:DE does not look like a CHIP device.
[1667898591.928004][3796:3799] CHIP:BLE: New device scanned: F0:65:2E:2F:C1:D0
[1667898591.928087][3796:3799] CHIP:BLE: Device discriminator match. Attempting to connect.
[1667898591.932084][3796:3799] CHIP:BLE: Scan complete notification without an active scan.
[1667898592.087033][3796:3799] CHIP:DL: ConnectDevice complete
[1667898593.591129][3796:3799] CHIP:DL: Char1 /org/bluez/hci0/dev_F0_65_2E_2F_C1_D0/service0001
[1667898593.591181][3796:3799] CHIP:DL: Char1 /org/bluez/hci0/dev_F0_65_2E_2F_C1_D0/service0010
[1667898593.591216][3796:3799] CHIP:DL: Char1 /org/bluez/hci0/dev_F0_65_2E_2F_C1_D0/service0001
[1667898593.591237][3796:3799] CHIP:DL: Char1 /org/bluez/hci0/dev_F0_65_2E_2F_C1_D0/service0010
[1667898593.591260][3796:3799] CHIP:DL: Char1 /org/bluez/hci0/dev_F0_65_2E_2F_C1_D0/service0001
[1667898593.591279][3796:3799] CHIP:DL: Char1 /org/bluez/hci0/dev_F0_65_2E_2F_C1_D0/service0010
[1667898593.591307][3796:3799] CHIP:DL: Char1 /org/bluez/hci0/dev_F0_65_2E_2F_C1_D0/service0001
[1667898593.591326][3796:3799] CHIP:DL: Char1 /org/bluez/hci0/dev_F0_65_2E_2F_C1_D0/service0010
[1667898593.591348][3796:3799] CHIP:DL: Char1 /org/bluez/hci0/dev_F0_65_2E_2F_C1_D0/service0001
[1667898593.591367][3796:3799] CHIP:DL: Char1 /org/bluez/hci0/dev_F0_65_2E_2F_C1_D0/service0010
[1667898593.591389][3796:3799] CHIP:DL: Char1 /org/bluez/hci0/dev_F0_65_2E_2F_C1_D0/service0001
[1667898593.591408][3796:3799] CHIP:DL: Char1 /org/bluez/hci0/dev_F0_65_2E_2F_C1_D0/service0010
[1667898593.591434][3796:3799] CHIP:DL: Char1 /org/bluez/hci0/dev_F0_65_2E_2F_C1_D0/service0010
[1667898593.591453][3796:3799] CHIP:DL: Char1 /org/bluez/hci0/dev_F0_65_2E_2F_C1_D0/service0010
[1667898593.591477][3796:3799] CHIP:DL: Char1 /org/bluez/hci0/dev_F0_65_2E_2F_C1_D0/service0010
[1667898593.591496][3796:3799] CHIP:DL: Char1 /org/bluez/hci0/dev_F0_65_2E_2F_C1_D0/service0010
[1667898593.591522][3796:3799] CHIP:DL: Char1 /org/bluez/hci0/dev_F0_65_2E_2F_C1_D0/service0001
[1667898593.591541][3796:3799] CHIP:DL: Char1 /org/bluez/hci0/dev_F0_65_2E_2F_C1_D0/service0010
[1667898593.591563][3796:3799] CHIP:DL: Char1 /org/bluez/hci0/dev_F0_65_2E_2F_C1_D0/service0001
[1667898593.591583][3796:3799] CHIP:DL: Char1 /org/bluez/hci0/dev_F0_65_2E_2F_C1_D0/service0010
[1667898593.591604][3796:3799] CHIP:DL: Char1 /org/bluez/hci0/dev_F0_65_2E_2F_C1_D0/service0001
[1667898593.591623][3796:3799] CHIP:DL: Char1 /org/bluez/hci0/dev_F0_65_2E_2F_C1_D0/service0010
[1667898593.591650][3796:3799] CHIP:DL: Char1 /org/bluez/hci0/dev_F0_65_2E_2F_C1_D0/service0010
[1667898593.591669][3796:3799] CHIP:DL: Char1 /org/bluez/hci0/dev_F0_65_2E_2F_C1_D0/service0010
[1667898593.591695][3796:3799] CHIP:DL: New BLE connection 0xffff980351e0, device F0:65:2E:2F:C1:D0, path /org/bluez/hci0/dev_F0_65_2E_2F_C1_D0
[1667898593.591802][3796:3801] CHIP:DL: HandlePlatformSpecificBLEEvent 16385
[1667898593.591836][3796:3801] CHIP:IN: BleConnectionComplete: endPoint 0xaaaacdad00d8
[1667898594.036347][3796:3801] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1667898594.134120][3796:3801] CHIP:DL: HandlePlatformSpecificBLEEvent 16388
[1667898594.134202][3796:3801] CHIP:BLE: subscribe complete, ep = 0xaaaacdad00d8
[1667898594.134555][3796:3799] CHIP:DL: Indication received, conn = 0xffff980351e0
[1667898594.134741][3796:3801] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1667898594.134805][3796:3801] CHIP:BLE: peripheral chose BTP version 4; central expected between 4 and 4
[1667898594.134855][3796:3801] CHIP:BLE: using BTP fragment sizes rx 244 / tx 244.
[1667898594.134899][3796:3801] CHIP:BLE: local and remote recv window size = 5
[1667898594.135080][3796:3801] CHIP:IN: BLE EndPoint 0xaaaacdad00d8 Connection Complete
[1667898594.279429][3796:3801] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1667898594.282063][3796:3799] CHIP:DL: Indication received, conn = 0xffff980351e0
[1667898594.282315][3796:3801] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1667898594.282539][3796:3801] CHIP:EM: Received message of type 0x21 with protocolId (0, 0) and MessageCounter:63814348 on exchange 47590i
[1667898594.282617][3796:3801] CHIP:EM: Found matching exchange: 47590i, Delegate: 0xffff8c00ae30
[1667898594.282707][3796:3801] CHIP:SC: Received PBKDF param response
[1667898594.282800][3796:3801] CHIP:SC: Peer assigned session ID 58142
[1667898594.282877][3796:3801] CHIP:SC: Found MRP parameters in the message
[1667898594.294712][3796:3801] CHIP:IN: Prepared unauthenticated message 0xffffa0a2d7e8 to 0x0000000000000000 (0)  of type 0x22 and protocolId (0, 0) on exchange 47590i with MessageCounter:76027511.
[1667898594.294768][3796:3801] CHIP:IN: Sending unauthenticated msg 0xffffa0a2d7e8 with MessageCounter:76027511 to 0x0000000000000000 at monotonic time: 00000000003A0FA9 msec
[1667898594.294865][3796:3801] CHIP:SC: Sent spake2p msg1
[1667898594.377033][3796:3801] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1667898596.377928][3796:3799] CHIP:DL: Indication received, conn = 0xffff980351e0
[1667898596.378219][3796:3801] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1667898596.378446][3796:3801] CHIP:EM: Received message of type 0x23 with protocolId (0, 0) and MessageCounter:63814349 on exchange 47590i
[1667898596.378564][3796:3801] CHIP:EM: Found matching exchange: 47590i, Delegate: 0xffff8c00ae30
[1667898596.378754][3796:3801] CHIP:SC: Received spake2p msg2
[1667898596.382067][3796:3801] CHIP:IN: Prepared unauthenticated message 0xffffa0a2d928 to 0x0000000000000000 (0)  of type 0x24 and protocolId (0, 0) on exchange 47590i with MessageCounter:76027512.
[1667898596.382179][3796:3801] CHIP:IN: Sending unauthenticated msg 0xffffa0a2d928 with MessageCounter:76027512 to 0x0000000000000000 at monotonic time: 00000000003A17D0 msec
[1667898596.382376][3796:3801] CHIP:SC: Sent spake2p msg3
[1667898596.472969][3796:3801] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1667898596.522416][3796:3799] CHIP:DL: Indication received, conn = 0xffff980351e0
[1667898596.522597][3796:3801] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1667898596.522755][3796:3801] CHIP:EM: Received message of type 0x40 with protocolId (0, 0) and MessageCounter:63814350 on exchange 47590i
[1667898596.522832][3796:3801] CHIP:EM: Found matching exchange: 47590i, Delegate: 0xffff8c00ae30
[1667898596.523132][3796:3801] CHIP:SC: SecureSession[0xffff8c009d20]: Moving from state 'kEstablishing' --> 'kActive'
[1667898596.523180][3796:3801] CHIP:IN: SecureSession[0xffff8c009d20]: Activated - Type:1 LSID:64643
[1667898596.523214][3796:3801] CHIP:IN: New secure session activated for device <FFFFFFFB00000000, 0>, LSID:64643 PSID:58142!
[1667898596.523257][3796:3801] CHIP:CTL: Remote device completed SPAKE2+ handshake
[1667898596.523291][3796:3801] CHIP:TOO: Pairing Success
[1667898596.523321][3796:3801] CHIP:TOO: PASE establishment successful
[1667898596.523356][3796:3801] CHIP:CTL: Commissioning stage next step: 'SecurePairing' -> 'ReadCommissioningInfo'
[1667898596.523394][3796:3801] CHIP:CTL: Performing next commissioning step 'ReadCommissioningInfo'
[1667898596.523443][3796:3801] CHIP:CTL: Sending request for commissioning information
[1667898596.523562][3796:3801] CHIP:DMG: SendReadRequest ReadClient[0xffff8c016a20]: Sending Read Request
[1667898596.523781][3796:3801] CHIP:IN: Prepared secure message 0xffffa0a2d138 to 0xFFFFFFFB00000000 (0)  of type 0x2 and protocolId (0, 1) on exchange 47591i with MessageCounter:19450924.
[1667898596.523857][3796:3801] CHIP:IN: Sending encrypted msg 0xffffa0a2d138 with MessageCounter:19450924 to 0xFFFFFFFB00000000 (0) at monotonic time: 00000000003A185E msec
[1667898596.523989][3796:3801] CHIP:DMG: MoveToState ReadClient[0xffff8c016a20]: Moving to [AwaitingIn]
[1667898596.619488][3796:3801] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1667898596.866579][3796:3799] CHIP:DL: Indication received, conn = 0xffff980351e0
[1667898596.866853][3796:3801] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1667898597.010597][3796:3799] CHIP:DL: Indication received, conn = 0xffff980351e0
[1667898597.011005][3796:3801] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1667898597.011165][3796:3801] CHIP:EM: Received message of type 0x5 with protocolId (0, 1) and MessageCounter:172714638 on exchange 47591i
[1667898597.011200][3796:3801] CHIP:EM: Found matching exchange: 47591i, Delegate: 0xffff8c016a30
[1667898597.011289][3796:3801] CHIP:DMG: ReportDataMessage =
[1667898597.011315][3796:3801] CHIP:DMG: {
[1667898597.011335][3796:3801] CHIP:DMG: 	AttributeReportIBs =
[1667898597.011363][3796:3801] CHIP:DMG: 	[
[1667898597.011384][3796:3801] CHIP:DMG: 		AttributeReportIB =
[1667898597.011418][3796:3801] CHIP:DMG: 		{
[1667898597.011442][3796:3801] CHIP:DMG: 			AttributeDataIB =
[1667898597.011469][3796:3801] CHIP:DMG: 			{
[1667898597.011496][3796:3801] CHIP:DMG: 				DataVersion = 0xeac7ff90,
[1667898597.011522][3796:3801] CHIP:DMG: 				AttributePathIB =
[1667898597.011550][3796:3801] CHIP:DMG: 				{
[1667898597.011578][3796:3801] CHIP:DMG: 					Endpoint = 0x0,
[1667898597.011607][3796:3801] CHIP:DMG: 					Cluster = 0x31,
[1667898597.011637][3796:3801] CHIP:DMG: 					Attribute = 0x0000_0003,
[1667898597.011664][3796:3801] CHIP:DMG: 				}
[1667898597.011693][3796:3801] CHIP:DMG:
[1667898597.011721][3796:3801] CHIP:DMG: 				Data = 20,
[1667898597.011746][3796:3801] CHIP:DMG: 			},
[1667898597.011774][3796:3801] CHIP:DMG:
[1667898597.011796][3796:3801] CHIP:DMG: 		},
[1667898597.011827][3796:3801] CHIP:DMG:
[1667898597.011848][3796:3801] CHIP:DMG: 		AttributeReportIB =
[1667898597.011875][3796:3801] CHIP:DMG: 		{
[1667898597.011899][3796:3801] CHIP:DMG: 			AttributeDataIB =
[1667898597.011924][3796:3801] CHIP:DMG: 			{
[1667898597.011949][3796:3801] CHIP:DMG: 				DataVersion = 0xd87b2cdb,
[1667898597.011975][3796:3801] CHIP:DMG: 				AttributePathIB =
[1667898597.012001][3796:3801] CHIP:DMG: 				{
[1667898597.012028][3796:3801] CHIP:DMG: 					Endpoint = 0x0,
[1667898597.012058][3796:3801] CHIP:DMG: 					Cluster = 0x28,
[1667898597.012087][3796:3801] CHIP:DMG: 					Attribute = 0x0000_0004,
[1667898597.012114][3796:3801] CHIP:DMG: 				}
[1667898597.012142][3796:3801] CHIP:DMG:
[1667898597.012169][3796:3801] CHIP:DMG: 				Data = 32774,
[1667898597.012194][3796:3801] CHIP:DMG: 			},
[1667898597.012221][3796:3801] CHIP:DMG:
[1667898597.012243][3796:3801] CHIP:DMG: 		},
[1667898597.012275][3796:3801] CHIP:DMG:
[1667898597.012296][3796:3801] CHIP:DMG: 		AttributeReportIB =
[1667898597.012323][3796:3801] CHIP:DMG: 		{
[1667898597.012345][3796:3801] CHIP:DMG: 			AttributeDataIB =
[1667898597.012371][3796:3801] CHIP:DMG: 			{
[1667898597.012397][3796:3801] CHIP:DMG: 				DataVersion = 0xd87b2cdb,
[1667898597.012422][3796:3801] CHIP:DMG: 				AttributePathIB =
[1667898597.012449][3796:3801] CHIP:DMG: 				{
[1667898597.012476][3796:3801] CHIP:DMG: 					Endpoint = 0x0,
[1667898597.012505][3796:3801] CHIP:DMG: 					Cluster = 0x28,
[1667898597.012533][3796:3801] CHIP:DMG: 					Attribute = 0x0000_0002,
[1667898597.012560][3796:3801] CHIP:DMG: 				}
[1667898597.012588][3796:3801] CHIP:DMG:
[1667898597.012615][3796:3801] CHIP:DMG: 				Data = 65521,
[1667898597.012640][3796:3801] CHIP:DMG: 			},
[1667898597.012668][3796:3801] CHIP:DMG:
[1667898597.012690][3796:3801] CHIP:DMG: 		},
[1667898597.012720][3796:3801] CHIP:DMG:
[1667898597.012741][3796:3801] CHIP:DMG: 		AttributeReportIB =
[1667898597.012768][3796:3801] CHIP:DMG: 		{
[1667898597.012791][3796:3801] CHIP:DMG: 			AttributeDataIB =
[1667898597.012816][3796:3801] CHIP:DMG: 			{
[1667898597.012842][3796:3801] CHIP:DMG: 				DataVersion = 0xcca4d571,
[1667898597.012867][3796:3801] CHIP:DMG: 				AttributePathIB =
[1667898597.012893][3796:3801] CHIP:DMG: 				{
[1667898597.012920][3796:3801] CHIP:DMG: 					Endpoint = 0x0,
[1667898597.012950][3796:3801] CHIP:DMG: 					Cluster = 0x30,
[1667898597.012978][3796:3801] CHIP:DMG: 					Attribute = 0x0000_0003,
[1667898597.013005][3796:3801] CHIP:DMG: 				}
[1667898597.013033][3796:3801] CHIP:DMG:
[1667898597.013060][3796:3801] CHIP:DMG: 				Data = 0,
[1667898597.013085][3796:3801] CHIP:DMG: 			},
[1667898597.013112][3796:3801] CHIP:DMG:
[1667898597.013134][3796:3801] CHIP:DMG: 		},
[1667898597.013164][3796:3801] CHIP:DMG:
[1667898597.013185][3796:3801] CHIP:DMG: 		AttributeReportIB =
[1667898597.013212][3796:3801] CHIP:DMG: 		{
[1667898597.013235][3796:3801] CHIP:DMG: 			AttributeDataIB =
[1667898597.013260][3796:3801] CHIP:DMG: 			{
[1667898597.013285][3796:3801] CHIP:DMG: 				DataVersion = 0xcca4d571,
[1667898597.013311][3796:3801] CHIP:DMG: 				AttributePathIB =
[1667898597.013338][3796:3801] CHIP:DMG: 				{
[1667898597.013365][3796:3801] CHIP:DMG: 					Endpoint = 0x0,
[1667898597.013394][3796:3801] CHIP:DMG: 					Cluster = 0x30,
[1667898597.013423][3796:3801] CHIP:DMG: 					Attribute = 0x0000_0002,
[1667898597.013449][3796:3801] CHIP:DMG: 				}
[1667898597.013477][3796:3801] CHIP:DMG:
[1667898597.013504][3796:3801] CHIP:DMG: 				Data = 0,
[1667898597.013528][3796:3801] CHIP:DMG: 			},
[1667898597.013555][3796:3801] CHIP:DMG:
[1667898597.013578][3796:3801] CHIP:DMG: 		},
[1667898597.013609][3796:3801] CHIP:DMG:
[1667898597.013629][3796:3801] CHIP:DMG: 		AttributeReportIB =
[1667898597.013658][3796:3801] CHIP:DMG: 		{
[1667898597.013709][3796:3801] CHIP:DMG: 			AttributeDataIB =
[1667898597.013738][3796:3801] CHIP:DMG: 			{
[1667898597.013763][3796:3801] CHIP:DMG: 				DataVersion = 0xcca4d571,
[1667898597.013789][3796:3801] CHIP:DMG: 				AttributePathIB =
[1667898597.013815][3796:3801] CHIP:DMG: 				{
[1667898597.013843][3796:3801] CHIP:DMG: 					Endpoint = 0x0,
[1667898597.013871][3796:3801] CHIP:DMG: 					Cluster = 0x30,
[1667898597.013900][3796:3801] CHIP:DMG: 					Attribute = 0x0000_0001,
[1667898597.013926][3796:3801] CHIP:DMG: 				}
[1667898597.013953][3796:3801] CHIP:DMG:
[1667898597.013979][3796:3801] CHIP:DMG: 				Data =
[1667898597.014005][3796:3801] CHIP:DMG: 				{
[1667898597.014064][3796:3801] CHIP:DMG: 					0x0 = 60,
[1667898597.014092][3796:3801] CHIP:DMG: 					0x1 = 900,
[1667898597.014121][3796:3801] CHIP:DMG: 				},
[1667898597.014146][3796:3801] CHIP:DMG: 			},
[1667898597.014174][3796:3801] CHIP:DMG:
[1667898597.014196][3796:3801] CHIP:DMG: 		},
[1667898597.014227][3796:3801] CHIP:DMG:
[1667898597.014248][3796:3801] CHIP:DMG: 		AttributeReportIB =
[1667898597.014275][3796:3801] CHIP:DMG: 		{
[1667898597.014297][3796:3801] CHIP:DMG: 			AttributeDataIB =
[1667898597.014322][3796:3801] CHIP:DMG: 			{
[1667898597.014348][3796:3801] CHIP:DMG: 				DataVersion = 0xcca4d571,
[1667898597.014373][3796:3801] CHIP:DMG: 				AttributePathIB =
[1667898597.014400][3796:3801] CHIP:DMG: 				{
[1667898597.014427][3796:3801] CHIP:DMG: 					Endpoint = 0x0,
[1667898597.014456][3796:3801] CHIP:DMG: 					Cluster = 0x30,
[1667898597.014484][3796:3801] CHIP:DMG: 					Attribute = 0x0000_0000,
[1667898597.014510][3796:3801] CHIP:DMG: 				}
[1667898597.014538][3796:3801] CHIP:DMG:
[1667898597.014565][3796:3801] CHIP:DMG: 				Data = 0,
[1667898597.014590][3796:3801] CHIP:DMG: 			},
[1667898597.014617][3796:3801] CHIP:DMG:
[1667898597.014639][3796:3801] CHIP:DMG: 		},
[1667898597.014669][3796:3801] CHIP:DMG:
[1667898597.014690][3796:3801] CHIP:DMG: 		AttributeReportIB =
[1667898597.014717][3796:3801] CHIP:DMG: 		{
[1667898597.014739][3796:3801] CHIP:DMG: 			AttributeDataIB =
[1667898597.014764][3796:3801] CHIP:DMG: 			{
[1667898597.014790][3796:3801] CHIP:DMG: 				DataVersion = 0xeac7ff90,
[1667898597.014815][3796:3801] CHIP:DMG: 				AttributePathIB =
[1667898597.014842][3796:3801] CHIP:DMG: 				{
[1667898597.014869][3796:3801] CHIP:DMG: 					Endpoint = 0x0,
[1667898597.014898][3796:3801] CHIP:DMG: 					Cluster = 0x31,
[1667898597.014927][3796:3801] CHIP:DMG: 					Attribute = 0x0000_FFFC,
[1667898597.014953][3796:3801] CHIP:DMG: 				}
[1667898597.014981][3796:3801] CHIP:DMG:
[1667898597.015008][3796:3801] CHIP:DMG: 				Data = 2,
[1667898597.015033][3796:3801] CHIP:DMG: 			},
[1667898597.015060][3796:3801] CHIP:DMG:
[1667898597.015082][3796:3801] CHIP:DMG: 		},
[1667898597.015108][3796:3801] CHIP:DMG:
[1667898597.015128][3796:3801] CHIP:DMG: 	],
[1667898597.015175][3796:3801] CHIP:DMG:
[1667898597.015198][3796:3801] CHIP:DMG: 	SuppressResponse = true,
[1667898597.015221][3796:3801] CHIP:DMG: 	InteractionModelRevision = 1
[1667898597.015240][3796:3801] CHIP:DMG: }
[1667898597.015889][3796:3801] CHIP:CTL: ----- NetworkCommissioning Features: has Thread. endpointid = 0
[1667898597.015981][3796:3801] CHIP:CTL: Successfully finished commissioning step 'ReadCommissioningInfo'
[1667898597.016011][3796:3801] CHIP:CTL: Commissioning stage next step: 'ReadCommissioningInfo' -> 'ArmFailSafe'
[1667898597.016039][3796:3801] CHIP:CTL: Performing next commissioning step 'ArmFailSafe'
[1667898597.016057][3796:3801] CHIP:CTL: Arming failsafe (60 seconds)
[1667898597.016118][3796:3801] CHIP:DMG: ICR moving to [AddingComm]
[1667898597.016144][3796:3801] CHIP:DMG: ICR moving to [AddedComma]
[1667898597.016255][3796:3801] CHIP:IN: Prepared secure message 0xffffa0a2cdf8 to 0xFFFFFFFB00000000 (0)  of type 0x8 and protocolId (0, 1) on exchange 47592i with MessageCounter:19450925.
[1667898597.016292][3796:3801] CHIP:IN: Sending encrypted msg 0xffffa0a2cdf8 with MessageCounter:19450925 to 0xFFFFFFFB00000000 (0) at monotonic time: 00000000003A1A4A msec
[1667898597.016394][3796:3801] CHIP:DMG: ICR moving to [CommandSen]
[1667898597.204758][3796:3801] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1667898597.254290][3796:3799] CHIP:DL: Indication received, conn = 0xffff980351e0
[1667898597.254526][3796:3801] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1667898597.254806][3796:3801] CHIP:EM: Received message of type 0x9 with protocolId (0, 1) and MessageCounter:172714639 on exchange 47592i
[1667898597.254878][3796:3801] CHIP:EM: Found matching exchange: 47592i, Delegate: 0xffff9800d608
[1667898597.254954][3796:3801] CHIP:DMG: ICR moving to [ResponseRe]
[1667898597.255044][3796:3801] CHIP:DMG: InvokeResponseMessage =
[1667898597.255099][3796:3801] CHIP:DMG: {
[1667898597.255150][3796:3801] CHIP:DMG: 	suppressResponse = false,
[1667898597.255203][3796:3801] CHIP:DMG: 	InvokeResponseIBs =
[1667898597.255272][3796:3801] CHIP:DMG: 	[
[1667898597.255326][3796:3801] CHIP:DMG: 		InvokeResponseIB =
[1667898597.255408][3796:3801] CHIP:DMG: 		{
[1667898597.255465][3796:3801] CHIP:DMG: 			CommandDataIB =
[1667898597.255534][3796:3801] CHIP:DMG: 			{
[1667898597.255607][3796:3801] CHIP:DMG: 				CommandPathIB =
[1667898597.255689][3796:3801] CHIP:DMG: 				{
[1667898597.255772][3796:3801] CHIP:DMG: 					EndpointId = 0x0,
[1667898597.255850][3796:3801] CHIP:DMG: 					ClusterId = 0x30,
[1667898597.255928][3796:3801] CHIP:DMG: 					CommandId = 0x1,
[1667898597.256001][3796:3801] CHIP:DMG: 				},
[1667898597.256084][3796:3801] CHIP:DMG:
[1667898597.256145][3796:3801] CHIP:DMG: 				CommandFields =
[1667898597.256224][3796:3801] CHIP:DMG: 				{
[1667898597.256300][3796:3801] CHIP:DMG: 					0x0 = 0,
[1667898597.256382][3796:3801] CHIP:DMG: 					0x1 = "" (0 chars),
[1667898597.256465][3796:3801] CHIP:DMG: 				},
[1667898597.256533][3796:3801] CHIP:DMG: 			},
[1667898597.256610][3796:3801] CHIP:DMG:
[1667898597.256670][3796:3801] CHIP:DMG: 		},
[1667898597.256743][3796:3801] CHIP:DMG:
[1667898597.256796][3796:3801] CHIP:DMG: 	],
[1667898597.256863][3796:3801] CHIP:DMG:
[1667898597.256917][3796:3801] CHIP:DMG: 	InteractionModelRevision = 1
[1667898597.256968][3796:3801] CHIP:DMG: },
[1667898597.257094][3796:3801] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
[1667898597.257169][3796:3801] CHIP:CTL: Received ArmFailSafe response errorCode=0
[1667898597.257229][3796:3801] CHIP:CTL: Successfully finished commissioning step 'ArmFailSafe'
[1667898597.257279][3796:3801] CHIP:CTL: No NetworkScan enabled or WiFi/Thread endpoint not specified, skipping ScanNetworks
[1667898597.257324][3796:3801] CHIP:CTL: Commissioning stage next step: 'ArmFailSafe' -> 'ConfigRegulatory'
[1667898597.257381][3796:3801] CHIP:CTL: Performing next commissioning step 'ConfigRegulatory'
[1667898597.257426][3796:3801] CHIP:CTL: Setting Regulatory Config
[1667898597.257470][3796:3801] CHIP:CTL: Device does not support configurable regulatory location
[1667898597.257581][3796:3801] CHIP:DMG: ICR moving to [AddingComm]
[1667898597.257645][3796:3801] CHIP:DMG: ICR moving to [AddedComma]
[1667898597.257991][3796:3801] CHIP:IN: Prepared secure message 0xffffa0a2c898 to 0xFFFFFFFB00000000 (0)  of type 0x8 and protocolId (0, 1) on exchange 47593i with MessageCounter:19450926.
[1667898597.258077][3796:3801] CHIP:IN: Sending encrypted msg 0xffffa0a2c898 with MessageCounter:19450926 to 0xFFFFFFFB00000000 (0) at monotonic time: 00000000003A1B3C msec
[1667898597.258253][3796:3801] CHIP:DMG: ICR moving to [CommandSen]
[1667898597.258364][3796:3801] CHIP:DMG: ICR moving to [AwaitingDe]
[1667898597.448362][3796:3801] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1667898597.662666][3796:3799] CHIP:DL: Indication received, conn = 0xffff980351e0
[1667898597.662941][3796:3801] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1667898597.663252][3796:3801] CHIP:EM: Received message of type 0x9 with protocolId (0, 1) and MessageCounter:172714640 on exchange 47593i
[1667898597.663333][3796:3801] CHIP:EM: Found matching exchange: 47593i, Delegate: 0xffff8c009588
[1667898597.663424][3796:3801] CHIP:DMG: ICR moving to [ResponseRe]
[1667898597.663530][3796:3801] CHIP:DMG: InvokeResponseMessage =
[1667898597.663595][3796:3801] CHIP:DMG: {
[1667898597.663655][3796:3801] CHIP:DMG: 	suppressResponse = false,
[1667898597.663717][3796:3801] CHIP:DMG: 	InvokeResponseIBs =
[1667898597.663798][3796:3801] CHIP:DMG: 	[
[1667898597.663861][3796:3801] CHIP:DMG: 		InvokeResponseIB =
[1667898597.663959][3796:3801] CHIP:DMG: 		{
[1667898597.664026][3796:3801] CHIP:DMG: 			CommandDataIB =
[1667898597.664109][3796:3801] CHIP:DMG: 			{
[1667898597.664194][3796:3801] CHIP:DMG: 				CommandPathIB =
[1667898597.664289][3796:3801] CHIP:DMG: 				{
[1667898597.664369][3796:3801] CHIP:DMG: 					EndpointId = 0x0,
[1667898597.664468][3796:3801] CHIP:DMG: 					ClusterId = 0x30,
[1667898597.664564][3796:3801] CHIP:DMG: 					CommandId = 0x3,
[1667898597.664656][3796:3801] CHIP:DMG: 				},
[1667898597.664745][3796:3801] CHIP:DMG:
[1667898597.664823][3796:3801] CHIP:DMG: 				CommandFields =
[1667898597.664910][3796:3801] CHIP:DMG: 				{
[1667898597.664999][3796:3801] CHIP:DMG: 					0x0 = 0,
[1667898597.665102][3796:3801] CHIP:DMG: 					0x1 = "" (0 chars),
[1667898597.665191][3796:3801] CHIP:DMG: 				},
[1667898597.665272][3796:3801] CHIP:DMG: 			},
[1667898597.665354][3796:3801] CHIP:DMG:
[1667898597.665424][3796:3801] CHIP:DMG: 		},
[1667898597.665508][3796:3801] CHIP:DMG:
[1667898597.665569][3796:3801] CHIP:DMG: 	],
[1667898597.665646][3796:3801] CHIP:DMG:
[1667898597.665755][3796:3801] CHIP:DMG: 	InteractionModelRevision = 1
[1667898597.665816][3796:3801] CHIP:DMG: },
[1667898597.665961][3796:3801] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0003
[1667898597.671670][3796:3801] CHIP:CTL: Received SetRegulatoryConfig response errorCode=0
[1667898597.671763][3796:3801] CHIP:CTL: Successfully finished commissioning step 'ConfigRegulatory'
[1667898597.671824][3796:3801] CHIP:CTL: Commissioning stage next step: 'ConfigRegulatory' -> 'SendPAICertificateRequest'
[1667898597.671893][3796:3801] CHIP:CTL: Performing next commissioning step 'SendPAICertificateRequest'
[1667898597.671948][3796:3801] CHIP:CTL: Sending request for PAI certificate
[1667898597.671999][3796:3801] CHIP:CTL: Sending Certificate Chain request to 0xffff8c00ade0 device
[1667898597.672208][3796:3801] CHIP:DMG: ICR moving to [AddingComm]
[1667898597.674504][3796:3801] CHIP:DMG: ICR moving to [AddedComma]
[1667898597.674656][3796:3801] CHIP:IN: Prepared secure message 0xffffa0a2c7d8 to 0xFFFFFFFB00000000 (0)  of type 0x8 and protocolId (0, 1) on exchange 47594i with MessageCounter:19450927.
[1667898597.674714][3796:3801] CHIP:IN: Sending encrypted msg 0xffffa0a2c7d8 with MessageCounter:19450927 to 0xFFFFFFFB00000000 (0) at monotonic time: 00000000003A1CDD msec
[1667898597.674864][3796:3801] CHIP:DMG: ICR moving to [CommandSen]
[1667898597.674964][3796:3801] CHIP:DMG: ICR moving to [AwaitingDe]
[1667898597.750850][3796:3801] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1667898597.889058][3796:3799] CHIP:DL: Indication received, conn = 0xffff980351e0
[1667898597.889334][3796:3801] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1667898597.979133][3796:3799] CHIP:DL: Indication received, conn = 0xffff980351e0
[1667898597.979405][3796:3801] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1667898598.066944][3796:3799] CHIP:DL: Indication received, conn = 0xffff980351e0
[1667898598.067442][3796:3801] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1667898598.067744][3796:3801] CHIP:EM: Received message of type 0x9 with protocolId (0, 1) and MessageCounter:172714641 on exchange 47594i
[1667898598.067823][3796:3801] CHIP:EM: Found matching exchange: 47594i, Delegate: 0xffff9800d608
[1667898598.067919][3796:3801] CHIP:DMG: ICR moving to [ResponseRe]
[1667898598.068025][3796:3801] CHIP:DMG: InvokeResponseMessage =
[1667898598.068252][3796:3801] CHIP:DMG: {
[1667898598.068318][3796:3801] CHIP:DMG: 	suppressResponse = false,
[1667898598.068381][3796:3801] CHIP:DMG: 	InvokeResponseIBs =
[1667898598.068461][3796:3801] CHIP:DMG: 	[
[1667898598.068524][3796:3801] CHIP:DMG: 		InvokeResponseIB =
[1667898598.068667][3796:3801] CHIP:DMG: 		{
[1667898598.068794][3796:3801] CHIP:DMG: 			CommandDataIB =
[1667898598.068927][3796:3801] CHIP:DMG: 			{
[1667898598.069058][3796:3801] CHIP:DMG: 				CommandPathIB =
[1667898598.069197][3796:3801] CHIP:DMG: 				{
[1667898598.069335][3796:3801] CHIP:DMG: 					EndpointId = 0x0,
[1667898598.069475][3796:3801] CHIP:DMG: 					ClusterId = 0x3e,
[1667898598.069614][3796:3801] CHIP:DMG: 					CommandId = 0x3,
[1667898598.069750][3796:3801] CHIP:DMG: 				},
[1667898598.069881][3796:3801] CHIP:DMG:
[1667898598.070057][3796:3801] CHIP:DMG: 				CommandFields =
[1667898598.070159][3796:3801] CHIP:DMG: 				{
[1667898598.070258][3796:3801] CHIP:DMG: 					0x0 = [
[1667898598.070518][3796:3801] CHIP:DMG: 							0x30, 0x82, 0x1, 0xcb, 0x30, 0x82, 0x1, 0x71, 0xa0, 0x3, 0x2, 0x1, 0x2, 0x2, 0x8, 0x56, 0xad, 0x82, 0x22, 0xad, 0x94, 0x5b, 0x64, 0x30, 0xa, 0x6, 0x8, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x4, 0x3, 0x2, 0x30, 0x30, 0x31, 0x18, 0x30, 0x16, 0x6, 0x3, 0x55, 0x4, 0x3, 0xc, 0xf, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x54, 0x65, 0x73, 0x74, 0x20, 0x50, 0x41, 0x41, 0x31, 0x14, 0x30, 0x12, 0x6, 0xa, 0x2b, 0x6, 0x1, 0x4, 0x1, 0x82, 0xa2, 0x7c, 0x2, 0x1, 0xc, 0x4, 0x46, 0x46, 0x46, 0x31, 0x30, 0x20, 0x17, 0xd, 0x32, 0x32, 0x30, 0x32, 0x30, 0x35, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x5a, 0x18, 0xf, 0x39, 0x39, 0x39, 0x39, 0x31, 0x32, 0x33, 0x31, 0x32, 0x33, 0x35, 0x39, 0x35, 0x39, 0x5a, 0x30, 0x3d, 0x31, 0x25, 0x30, 0x23, 0x6, 0x3, 0x55, 0x4, 0x3, 0xc, 0x1c, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x44, 0x65, 0x76, 0x20, 0x50, 0x41, 0x49, 0x20, 0x30, 0x78, 0x46, 0x46, 0x46, 0x31, 0x20, 0x6e, 0x6f, 0x20, 0x50, 0x49, 0x44, 0x31, 0x14, 0x30, 0x12, 0x6, 0xa, 0x2b, 0x6, 0x1, 0x4, 0x1, 0x82, 0xa2, 0x7c, 0x2, 0x1, 0xc, 0x4, 0x46, 0x46, 0x46, 0x31, 0x30, 0x59, 0x30, 0x13, 0x6, 0x7, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x2, 0x1, 0x6, 0x8, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x3, 0x1, 0x7, 0x3, 0x42, 0x0, 0x4, 0x41, 0x9a, 0x93, 0x15, 0xc2, 0x17, 0x3e, 0xc, 0x8c, 0x87, 0x6d, 0x3, 0xcc, 0xfc, 0x94, 0x48, 0x52, 0x64, 0x7f, 0x7f, 0xec, 0x5e, 0x50, 0x82, 0xf4, 0x5, 0x99, 0x28, 0xec, 0xa8, 0x94, 0xc5, 0x94, 0x15, 0x13, 0x9, 0xac, 0x63, 0x1e, 0x4c, 0xb0, 0x33, 0x92, 0xaf, 0x68, 0x4b, 0xb, 0xaf, 0xb7, 0xe6, 0x5b, 0x3b, 0x81, 0x62, 0xc2, 0xf5, 0x2b, 0xf9, 0x31, 0xb8, 0xe7, 0x7a, 0xaa, 0x82, 0xa3, 0x66, 0x30, 0x64, 0x30, 0x12, 0x6, 0x3, 0x55, 0x1d, 0x13, 0x1, 0x1, 0xff, 0x4, 0x8, 0x30, 0x6, 0x1, 0x1, 0xff, 0x2, 0x1,
[1667898598.070686][3796:3801] CHIP:DMG: 					] (463 bytes)
[1667898598.070785][3796:3801] CHIP:DMG: 				},
[1667898598.070880][3796:3801] CHIP:DMG: 			},
[1667898598.070976][3796:3801] CHIP:DMG:
[1667898598.071029][3796:3801] CHIP:DMG: 		},
[1667898598.071115][3796:3801] CHIP:DMG:
[1667898598.071159][3796:3801] CHIP:DMG: 	],
[1667898598.071213][3796:3801] CHIP:DMG:
[1667898598.071257][3796:3801] CHIP:DMG: 	InteractionModelRevision = 1
[1667898598.071298][3796:3801] CHIP:DMG: },
[1667898598.071396][3796:3801] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0003
[1667898598.071451][3796:3801] CHIP:CTL: Received certificate chain from the device
[1667898598.071501][3796:3801] CHIP:CTL: Successfully finished commissioning step 'SendPAICertificateRequest'
[1667898598.071545][3796:3801] CHIP:CTL: Commissioning stage next step: 'SendPAICertificateRequest' -> 'SendDACCertificateRequest'
[1667898598.071594][3796:3801] CHIP:CTL: Performing next commissioning step 'SendDACCertificateRequest'
[1667898598.071631][3796:3801] CHIP:CTL: Sending request for DAC certificate
[1667898598.071665][3796:3801] CHIP:CTL: Sending Certificate Chain request to 0xffff8c00ade0 device
[1667898598.071762][3796:3801] CHIP:DMG: ICR moving to [AddingComm]
[1667898598.071813][3796:3801] CHIP:DMG: ICR moving to [AddedComma]
[1667898598.071972][3796:3801] CHIP:IN: Prepared secure message 0xffffa0a2c7e8 to 0xFFFFFFFB00000000 (0)  of type 0x8 and protocolId (0, 1) on exchange 47595i with MessageCounter:19450928.
[1667898598.072043][3796:3801] CHIP:IN: Sending encrypted msg 0xffffa0a2c7e8 with MessageCounter:19450928 to 0xFFFFFFFB00000000 (0) at monotonic time: 00000000003A1E6A msec
[1667898598.072205][3796:3801] CHIP:DMG: ICR moving to [CommandSen]
[1667898598.072362][3796:3801] CHIP:DMG: ICR moving to [AwaitingDe]
[1667898598.246880][3796:3801] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1667898598.250755][3796:3799] CHIP:DL: Indication received, conn = 0xffff980351e0
[1667898598.250968][3796:3801] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1667898598.384194][3796:3799] CHIP:DL: Indication received, conn = 0xffff980351e0
[1667898598.384470][3796:3801] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1667898598.472119][3796:3799] CHIP:DL: Indication received, conn = 0xffff980351e0
[1667898598.472402][3796:3801] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1667898598.472715][3796:3801] CHIP:EM: Received message of type 0x9 with protocolId (0, 1) and MessageCounter:172714642 on exchange 47595i
[1667898598.472795][3796:3801] CHIP:EM: Found matching exchange: 47595i, Delegate: 0xffff9800a4a8
[1667898598.472891][3796:3801] CHIP:DMG: ICR moving to [ResponseRe]
[1667898598.472997][3796:3801] CHIP:DMG: InvokeResponseMessage =
[1667898598.473062][3796:3801] CHIP:DMG: {
[1667898598.473122][3796:3801] CHIP:DMG: 	suppressResponse = false,
[1667898598.473185][3796:3801] CHIP:DMG: 	InvokeResponseIBs =
[1667898598.473267][3796:3801] CHIP:DMG: 	[
[1667898598.473330][3796:3801] CHIP:DMG: 		InvokeResponseIB =
[1667898598.473428][3796:3801] CHIP:DMG: 		{
[1667898598.473501][3796:3801] CHIP:DMG: 			CommandDataIB =
[1667898598.473590][3796:3801] CHIP:DMG: 			{
[1667898598.473737][3796:3801] CHIP:DMG: 				CommandPathIB =
[1667898598.473839][3796:3801] CHIP:DMG: 				{
[1667898598.473935][3796:3801] CHIP:DMG: 					EndpointId = 0x0,
[1667898598.474035][3796:3801] CHIP:DMG: 					ClusterId = 0x3e,
[1667898598.474133][3796:3801] CHIP:DMG: 					CommandId = 0x3,
[1667898598.474226][3796:3801] CHIP:DMG: 				},
[1667898598.474318][3796:3801] CHIP:DMG:
[1667898598.474396][3796:3801] CHIP:DMG: 				CommandFields =
[1667898598.474481][3796:3801] CHIP:DMG: 				{
[1667898598.474575][3796:3801] CHIP:DMG: 					0x0 = [
[1667898598.474919][3796:3801] CHIP:DMG: 							0x30, 0x82, 0x1, 0xe7, 0x30, 0x82, 0x1, 0x8d, 0xa0, 0x3, 0x2, 0x1, 0x2, 0x2, 0x7, 0x21, 0xf6, 0x6d, 0xf5, 0x1d, 0x72, 0x58, 0x30, 0xa, 0x6, 0x8, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x4, 0x3, 0x2, 0x30, 0x3d, 0x31, 0x25, 0x30, 0x23, 0x6, 0x3, 0x55, 0x4, 0x3, 0xc, 0x1c, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x44, 0x65, 0x76, 0x20, 0x50, 0x41, 0x49, 0x20, 0x30, 0x78, 0x46, 0x46, 0x46, 0x31, 0x20, 0x6e, 0x6f, 0x20, 0x50, 0x49, 0x44, 0x31, 0x14, 0x30, 0x12, 0x6, 0xa, 0x2b, 0x6, 0x1, 0x4, 0x1, 0x82, 0xa2, 0x7c, 0x2, 0x1, 0xc, 0x4, 0x46, 0x46, 0x46, 0x31, 0x30, 0x20, 0x17, 0xd, 0x32, 0x32, 0x30, 0x32, 0x30, 0x35, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x5a, 0x18, 0xf, 0x39, 0x39, 0x39, 0x39, 0x31, 0x32, 0x33, 0x31, 0x32, 0x33, 0x35, 0x39, 0x35, 0x39, 0x5a, 0x30, 0x53, 0x31, 0x25, 0x30, 0x23, 0x6, 0x3, 0x55, 0x4, 0x3, 0xc, 0x1c, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x44, 0x65, 0x76, 0x20, 0x44, 0x41, 0x43, 0x20, 0x30, 0x78, 0x46, 0x46, 0x46, 0x31, 0x2f, 0x30, 0x78, 0x38, 0x30, 0x30, 0x36, 0x31, 0x14, 0x30, 0x12, 0x6, 0xa, 0x2b, 0x6, 0x1, 0x4, 0x1, 0x82, 0xa2, 0x7c, 0x2, 0x1, 0xc, 0x4, 0x46, 0x46, 0x46, 0x31, 0x31, 0x14, 0x30, 0x12, 0x6, 0xa, 0x2b, 0x6, 0x1, 0x4, 0x1, 0x82, 0xa2, 0x7c, 0x2, 0x2, 0xc, 0x4, 0x38, 0x30, 0x30, 0x36, 0x30, 0x59, 0x30, 0x13, 0x6, 0x7, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x2, 0x1, 0x6, 0x8, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x3, 0x1, 0x7, 0x3, 0x42, 0x0, 0x4, 0x5e, 0x91, 0xed, 0x92, 0x50, 0x16, 0xcc, 0x82, 0x67, 0x19, 0x7a, 0x9, 0xb, 0x75, 0x33, 0xe5, 0x54, 0xe2, 0x5c, 0x8b, 0x9, 0x3c, 0xdd, 0xca, 0x9e, 0xaf, 0xcb, 0xa7, 0x47, 0xfe, 0xb8, 0xb5, 0xb8, 0xdc, 0x78, 0x9f, 0xf, 0x9d, 0xb0, 0xd8, 0xfc, 0xae, 0xac, 0x6c, 0xfd, 0x83, 0x9c, 0x51, 0xb3, 0xbd, 0xe, 0x4b, 0xc
[1667898598.475107][3796:3801] CHIP:DMG: 					] (491 bytes)
[1667898598.475205][3796:3801] CHIP:DMG: 				},
[1667898598.475294][3796:3801] CHIP:DMG: 			},
[1667898598.475391][3796:3801] CHIP:DMG:
[1667898598.475463][3796:3801] CHIP:DMG: 		},
[1667898598.475546][3796:3801] CHIP:DMG:
[1667898598.475607][3796:3801] CHIP:DMG: 	],
[1667898598.475684][3796:3801] CHIP:DMG:
[1667898598.475749][3796:3801] CHIP:DMG: 	InteractionModelRevision = 1
[1667898598.475809][3796:3801] CHIP:DMG: },
[1667898598.475952][3796:3801] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0003
[1667898598.476033][3796:3801] CHIP:CTL: Received certificate chain from the device
[1667898598.476103][3796:3801] CHIP:CTL: Successfully finished commissioning step 'SendDACCertificateRequest'
[1667898598.476170][3796:3801] CHIP:CTL: Commissioning stage next step: 'SendDACCertificateRequest' -> 'SendAttestationRequest'
[1667898598.476237][3796:3801] CHIP:CTL: Performing next commissioning step 'SendAttestationRequest'
[1667898598.476291][3796:3801] CHIP:CTL: Sending Attestation Request to the device.
[1667898598.476496][3796:3801] CHIP:CTL: Sending Attestation request to 0xffff8c00ade0 device
[1667898598.476626][3796:3801] CHIP:DMG: ICR moving to [AddingComm]
[1667898598.476699][3796:3801] CHIP:DMG: ICR moving to [AddedComma]
[1667898598.476893][3796:3801] CHIP:IN: Prepared secure message 0xffffa0a2c7a8 to 0xFFFFFFFB00000000 (0)  of type 0x8 and protocolId (0, 1) on exchange 47596i with MessageCounter:19450929.
[1667898598.476987][3796:3801] CHIP:IN: Sending encrypted msg 0xffffa0a2c7a8 with MessageCounter:19450929 to 0xFFFFFFFB00000000 (0) at monotonic time: 00000000003A1FFF msec
[1667898598.477192][3796:3801] CHIP:DMG: ICR moving to [CommandSen]
[1667898598.477266][3796:3801] CHIP:CTL: Sent Attestation request, waiting for the Attestation Information
[1667898598.477372][3796:3801] CHIP:DMG: ICR moving to [AwaitingDe]
[1667898598.605978][3796:3801] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1667898598.654122][3796:3799] CHIP:DL: Indication received, conn = 0xffff980351e0
[1667898598.654409][3796:3801] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1667898598.879169][3796:3799] CHIP:DL: Indication received, conn = 0xffff980351e0
[1667898598.879672][3796:3801] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1667898598.968984][3796:3799] CHIP:DL: Indication received, conn = 0xffff980351e0
[1667898598.969259][3796:3801] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1667898598.969587][3796:3801] CHIP:EM: Received message of type 0x9 with protocolId (0, 1) and MessageCounter:172714643 on exchange 47596i
[1667898598.969720][3796:3801] CHIP:EM: Found matching exchange: 47596i, Delegate: 0xffff98036d18
[1667898598.969825][3796:3801] CHIP:DMG: ICR moving to [ResponseRe]
[1667898598.969937][3796:3801] CHIP:DMG: InvokeResponseMessage =
[1667898598.970003][3796:3801] CHIP:DMG: {
[1667898598.970064][3796:3801] CHIP:DMG: 	suppressResponse = false,
[1667898598.970127][3796:3801] CHIP:DMG: 	InvokeResponseIBs =
[1667898598.970208][3796:3801] CHIP:DMG: 	[
[1667898598.970271][3796:3801] CHIP:DMG: 		InvokeResponseIB =
[1667898598.970365][3796:3801] CHIP:DMG: 		{
[1667898598.970433][3796:3801] CHIP:DMG: 			CommandDataIB =
[1667898598.970514][3796:3801] CHIP:DMG: 			{
[1667898598.970589][3796:3801] CHIP:DMG: 				CommandPathIB =
[1667898598.970675][3796:3801] CHIP:DMG: 				{
[1667898598.970770][3796:3801] CHIP:DMG: 					EndpointId = 0x0,
[1667898598.970869][3796:3801] CHIP:DMG: 					ClusterId = 0x3e,
[1667898598.970966][3796:3801] CHIP:DMG: 					CommandId = 0x1,
[1667898598.971058][3796:3801] CHIP:DMG: 				},
[1667898598.971147][3796:3801] CHIP:DMG:
[1667898598.971232][3796:3801] CHIP:DMG: 				CommandFields =
[1667898598.971318][3796:3801] CHIP:DMG: 				{
[1667898598.971404][3796:3801] CHIP:DMG: 					0x0 = [
[1667898598.971754][3796:3801] CHIP:DMG: 							0x15, 0x31, 0x1, 0x1c, 0x2, 0x30, 0x82, 0x2, 0x18, 0x6, 0x9, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0xd, 0x1, 0x7, 0x2, 0xa0, 0x82, 0x2, 0x9, 0x30, 0x82, 0x2, 0x5, 0x2, 0x1, 0x3, 0x31, 0xd, 0x30, 0xb, 0x6, 0x9, 0x60, 0x86, 0x48, 0x1, 0x65, 0x3, 0x4, 0x2, 0x1, 0x30, 0x82, 0x1, 0x70, 0x6, 0x9, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0xd, 0x1, 0x7, 0x1, 0xa0, 0x82, 0x1, 0x61, 0x4, 0x82, 0x1, 0x5d, 0x15, 0x24, 0x0, 0x1, 0x25, 0x1, 0xf1, 0xff, 0x36, 0x2, 0x5, 0x0, 0x80, 0x5, 0x1, 0x80, 0x5, 0x2, 0x80, 0x5, 0x3, 0x80, 0x5, 0x4, 0x80, 0x5, 0x5, 0x80, 0x5, 0x6, 0x80, 0x5, 0x7, 0x80, 0x5, 0x8, 0x80, 0x5, 0x9, 0x80, 0x5, 0xa, 0x80, 0x5, 0xb, 0x80, 0x5, 0xc, 0x80, 0x5, 0xd, 0x80, 0x5, 0xe, 0x80, 0x5, 0xf, 0x80, 0x5, 0x10, 0x80, 0x5, 0x11, 0x80, 0x5, 0x12, 0x80, 0x5, 0x13, 0x80, 0x5, 0x14, 0x80, 0x5, 0x15, 0x80, 0x5, 0x16, 0x80, 0x5, 0x17, 0x80, 0x5, 0x18, 0x80, 0x5, 0x19, 0x80, 0x5, 0x1a, 0x80, 0x5, 0x1b, 0x80, 0x5, 0x1c, 0x80, 0x5, 0x1d, 0x80, 0x5, 0x1e, 0x80, 0x5, 0x1f, 0x80, 0x5, 0x20, 0x80, 0x5, 0x21, 0x80, 0x5, 0x22, 0x80, 0x5, 0x23, 0x80, 0x5, 0x24, 0x80, 0x5, 0x25, 0x80, 0x5, 0x26, 0x80, 0x5, 0x27, 0x80, 0x5, 0x28, 0x80, 0x5, 0x29, 0x80, 0x5, 0x2a, 0x80, 0x5, 0x2b, 0x80, 0x5, 0x2c, 0x80, 0x5, 0x2d, 0x80, 0x5, 0x2e, 0x80, 0x5, 0x2f, 0x80, 0x5, 0x30, 0x80, 0x5, 0x31, 0x80, 0x5, 0x32, 0x80, 0x5, 0x33, 0x80, 0x5, 0x34, 0x80, 0x5, 0x35, 0x80, 0x5, 0x36, 0x80, 0x5, 0x37, 0x80, 0x5, 0x38, 0x80, 0x5, 0x39, 0x80, 0x5, 0x3a, 0x80, 0x5, 0x3b, 0x80, 0x5, 0x3c, 0x80, 0x5, 0x3d, 0x80, 0x5, 0x3e, 0x80, 0x5, 0x3f, 0x80, 0x5, 0x40, 0x80, 0x5, 0x41, 0x80, 0x5, 0x42, 0x80, 0x5, 0x43, 0x80, 0x5, 0x44, 0x80, 0x5, 0x45, 0x80, 0x5, 0x46, 0x80, 0x5, 0x47, 0x80, 0x5, 0x48, 0x80, 0x5, 0x49, 0x80, 0x5, 0x4a, 0x80, 0x5, 0
[1667898598.971952][3796:3801] CHIP:DMG: 					] (584 bytes)
[1667898598.972050][3796:3801] CHIP:DMG: 					0x1 = [
[1667898598.972185][3796:3801] CHIP:DMG: 							0x7d, 0xa7, 0x58, 0xc6, 0x74, 0xb5, 0xfc, 0x3f, 0xee, 0x1c, 0x2a, 0x54, 0xcc, 0xfa, 0x80, 0xb2, 0x3a, 0x46, 0xee, 0xf8, 0xb, 0xc7, 0xdb, 0xd2, 0xf0, 0x7b, 0x0, 0xd3, 0x21, 0x65, 0x65, 0xb8, 0x47, 0x93, 0xae, 0xfa, 0xf2, 0x41, 0xac, 0x79, 0x5f, 0xe, 0xe2, 0x38, 0x1a, 0xac, 0xe7, 0x60, 0x9c, 0x66, 0xf9, 0xf3, 0xe7, 0x68, 0x21, 0xf1, 0xcf, 0x3, 0x3e, 0x70, 0x5b, 0xcc, 0x77, 0xe5,
[1667898598.972295][3796:3801] CHIP:DMG: 					] (64 bytes)
[1667898598.972394][3796:3801] CHIP:DMG: 				},
[1667898598.972480][3796:3801] CHIP:DMG: 			},
[1667898598.972569][3796:3801] CHIP:DMG:
[1667898598.972640][3796:3801] CHIP:DMG: 		},
[1667898598.972724][3796:3801] CHIP:DMG:
[1667898598.972785][3796:3801] CHIP:DMG: 	],
[1667898598.972863][3796:3801] CHIP:DMG:
[1667898598.972925][3796:3801] CHIP:DMG: 	InteractionModelRevision = 1
[1667898598.972985][3796:3801] CHIP:DMG: },
[1667898598.973134][3796:3801] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0001
[1667898598.973217][3796:3801] CHIP:CTL: Received Attestation Information from the device
[1667898598.973288][3796:3801] CHIP:CTL: Successfully finished commissioning step 'SendAttestationRequest'
[1667898598.973404][3796:3801] CHIP:CTL: Commissioning stage next step: 'SendAttestationRequest' -> 'AttestationVerification'
[1667898598.973479][3796:3801] CHIP:CTL: Performing next commissioning step 'AttestationVerification'
[1667898598.973536][3796:3801] CHIP:CTL: Verifying attestation
[1667898598.998303][3796:3801] CHIP:CTL: Failed in verifying 'Attestation Information' command received from the device: err 601. Look at AttestationVerificationResult enum to understand the errors
[1667898598.998391][3796:3801] CHIP:CTL: Error on commissioning step 'AttestationVerification': '../../src/controller/CHIPDeviceController.cpp:1027: CHIP Error 0x000000AC: Internal error'
[1667898598.998413][3796:3801] CHIP:CTL: Failed to perform commissioning step 8
[1667898598.998436][3796:3801] CHIP:CTL: Going from commissioning step 'AttestationVerification' with lastErr = '../../src/controller/CHIPDeviceController.cpp:1027: CHIP Error 0x000000AC: Internal error' -> 'Cleanup'
[1667898598.998469][3796:3801] CHIP:CTL: Performing next commissioning step 'Cleanup' with completion status = '../../src/controller/CHIPDeviceController.cpp:1027: CHIP Error 0x000000AC: Internal error'
[1667898598.998490][3796:3801] CHIP:CTL: Expiring failsafe on proxy 0xffff8c00ade0
[1667898598.998560][3796:3801] CHIP:DMG: ICR moving to [AddingComm]
[1667898598.998589][3796:3801] CHIP:DMG: ICR moving to [AddedComma]
[1667898598.998703][3796:3801] CHIP:IN: Prepared secure message 0xffffa0a2bd48 to 0xFFFFFFFB00000000 (0)  of type 0x8 and protocolId (0, 1) on exchange 47597i with MessageCounter:19450930.
[1667898598.998741][3796:3801] CHIP:IN: Sending encrypted msg 0xffffa0a2bd48 with MessageCounter:19450930 to 0xFFFFFFFB00000000 (0) at monotonic time: 00000000003A2209 msec
[1667898598.998847][3796:3801] CHIP:DMG: ICR moving to [CommandSen]
[1667898598.998907][3796:3801] CHIP:DMG: ICR moving to [AwaitingDe]
[1667898599.145988][3796:3801] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1667898599.236759][3796:3799] CHIP:DL: Indication received, conn = 0xffff980351e0
[1667898599.237010][3796:3801] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1667898599.237296][3796:3801] CHIP:EM: Received message of type 0x9 with protocolId (0, 1) and MessageCounter:172714644 on exchange 47597i
[1667898599.237369][3796:3801] CHIP:EM: Found matching exchange: 47597i, Delegate: 0xffff98036e78
[1667898599.237447][3796:3801] CHIP:DMG: ICR moving to [ResponseRe]
[1667898599.237539][3796:3801] CHIP:DMG: InvokeResponseMessage =
[1667898599.237594][3796:3801] CHIP:DMG: {
[1667898599.237645][3796:3801] CHIP:DMG: 	suppressResponse = false,
[1667898599.237750][3796:3801] CHIP:DMG: 	InvokeResponseIBs =
[1667898599.237822][3796:3801] CHIP:DMG: 	[
[1667898599.237876][3796:3801] CHIP:DMG: 		InvokeResponseIB =
[1667898599.237958][3796:3801] CHIP:DMG: 		{
[1667898599.238015][3796:3801] CHIP:DMG: 			CommandDataIB =
[1667898599.238091][3796:3801] CHIP:DMG: 			{
[1667898599.238164][3796:3801] CHIP:DMG: 				CommandPathIB =
[1667898599.238239][3796:3801] CHIP:DMG: 				{
[1667898599.238321][3796:3801] CHIP:DMG: 					EndpointId = 0x0,
[1667898599.238399][3796:3801] CHIP:DMG: 					ClusterId = 0x30,
[1667898599.238476][3796:3801] CHIP:DMG: 					CommandId = 0x1,
[1667898599.238555][3796:3801] CHIP:DMG: 				},
[1667898599.238631][3796:3801] CHIP:DMG:
[1667898599.238705][3796:3801] CHIP:DMG: 				CommandFields =
[1667898599.238777][3796:3801] CHIP:DMG: 				{
[1667898599.238853][3796:3801] CHIP:DMG: 					0x0 = 0,
[1667898599.238943][3796:3801] CHIP:DMG: 					0x1 = "" (0 chars),
[1667898599.239027][3796:3801] CHIP:DMG: 				},
[1667898599.239101][3796:3801] CHIP:DMG: 			},
[1667898599.239183][3796:3801] CHIP:DMG:
[1667898599.239243][3796:3801] CHIP:DMG: 		},
[1667898599.239316][3796:3801] CHIP:DMG:
[1667898599.239368][3796:3801] CHIP:DMG: 	],
[1667898599.239436][3796:3801] CHIP:DMG:
[1667898599.239489][3796:3801] CHIP:DMG: 	InteractionModelRevision = 1
[1667898599.239540][3796:3801] CHIP:DMG: },
[1667898599.239666][3796:3801] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
[1667898599.239740][3796:3801] CHIP:CTL: Failsafe disarmed
[1667898599.239800][3796:3801] CHIP:CTL: Successfully finished commissioning step 'Cleanup'
[1667898599.239875][3796:3801] CHIP:TOO: Device commissioning Failure: ../../src/controller/CHIPDeviceController.cpp:1027: CHIP Error 0x000000AC: Internal error
[1667898599.239967][3796:3801] CHIP:DIS: Closing all BLE connections
[1667898599.240020][3796:3801] CHIP:IN: Clearing BLE pending packets.
[1667898599.240140][3796:3801] CHIP:BLE: Auto-closing end point's BLE connection.
[1667898599.240192][3796:3801] CHIP:DL: Closing BLE GATT connection (con 0xffff980351e0)
[1667898599.240360][3796:3801] CHIP:DMG: ICR moving to [AwaitingDe]
[1667898599.240531][3796:3799] CHIP:DL: BluezDisconnect peer=F0:65:2E:2F:C1:D0
[1667898599.240806][3796:3796] CHIP:CTL: Shutting down the commissioner
[1667898599.240874][3796:3796] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1667898599.240920][3796:3796] CHIP:CTL: Shutting down the controller
[1667898599.240982][3796:3796] CHIP:IN: Expiring all sessions for fabric 0x1!!
[1667898599.241034][3796:3796] CHIP:FP: Forgetting fabric 0x1
[1667898599.241096][3796:3796] CHIP:TS: Pending Last Known Good Time: 2022-10-21T23:13:11
[1667898599.241349][3796:3796] CHIP:TS: Previous Last Known Good Time: 2022-10-21T23:13:11
[1667898599.241406][3796:3796] CHIP:TS: Reverted Last Known Good Time to previous value
[1667898599.241491][3796:3796] CHIP:CTL: Shutting down the commissioner
[1667898599.241534][3796:3796] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1667898599.241572][3796:3796] CHIP:CTL: Shutting down the controller
[1667898599.241608][3796:3796] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
[1667898599.243671][3796:3796] CHIP:DMG: IM WH moving to [Uninitialized]
[1667898599.243753][3796:3796] CHIP:DMG: IM WH moving to [Uninitialized]
[1667898599.243798][3796:3796] CHIP:DMG: IM WH moving to [Uninitialized]
[1667898599.243924][3796:3796] CHIP:DMG: IM WH moving to [Uninitialized]
[1667898599.243982][3796:3796] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
[1667898599.244140][3796:3796] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
[1667898599.244589][3796:3796] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-EGimzo)
[1667898599.245876][3796:3796] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1667898599.246052][3796:3796] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
[1667898599.246110][3796:3796] CHIP:DL: Inet Layer shutdown
[1667898599.246158][3796:3796] CHIP:DL: BLE shutdown
[1667898599.247695][3796:3796] CHIP:DL: System Layer shutdown
[1667898599.247807][3796:3796] CHIP:IN: SecureSession[0xffff8c009d20]: MarkForEviction Type:1 LSID:64643
[1667898599.247835][3796:3796] CHIP:SC: SecureSession[0xffff8c009d20]: Moving from state 'kActive' --> 'kPendingEviction'
[1667898599.247858][3796:3796] CHIP:IN: SecureSession[0xffff8c009d20]: Released - Type:1 LSID:64643
[1667898599.247924][3796:3796] CHIP:TOO: Run command failure: ../../src/controller/CHIPDeviceController.cpp:1027: CHIP Error 0x000000AC: Internal error
uart:~$
uart:~$ D: 7407 [IN]SecureSession[0x200030f0]: Allocated Type:1 LSID:58142
D: 7413 [SC]Assigned local session key ID 58142
D: 7417 [SC]Waiting for PBKDF param request
D: 7421 [DL]CHIPoBLE advertising set to on
I: 7425 [DIS]Updating services using commissioning mode 1
D: 7430 [DL]Using Thread extended MAC for hostname.
D: 7435 [DL]Using Thread extended MAC for hostname.
I: 7441 [DIS]Advertise commission parameter vendorID=65521 productID=32774 discriminator=4004/15 cm=1
E: 7450 [DIS]Failed to advertise commissionable node: 3
E: 7455 [DIS]Failed to finalize service update: 1c
I: 7462 [DL]CHIPoBLE advertising started
I: 7467 [DL]NFC Tag emulation started
I: 14876 [DL]BLE connection established (ConnId: 0x00)
I: 14881 [DL]Current number of connections: 1/1
I: 14885 [DL]CHIPoBLE advertising stopped
I: 14889 [DL]NFC Tag emulation stopped
D: 16830 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 16837 [BLE]local and remote recv window sizes = 5
I: 16841 [BLE]selected BTP version 4
I: 16845 [BLE]using BTP fragment sizes rx 244 / tx 244.
D: 16927 [DL]ConnId: 0x00, New CCCD value: 0x0002
D: 16932 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 6)
D: 16939 [IN]BLE EndPoint 0x20011d00 Connection Complete
I: 16944 [DL]CHIPoBLE connection established (ConnId: 0x00, GATT MTU: 247)
D: 17024 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 17033 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 17040 [EM]>>> [E:47590r M:76027510] (U) Msg RX from 0:F7C620AF8D6897A3 [0000] --- Type 0000:20 (SecureChannel:PBKDFParamRequest)
D: 17052 [EM]Handling via exchange: 47590r, Delegate: 0x2000521c
D: 17057 [SC]Received PBKDF param request
D: 17061 [SC]Peer assigned session ID 64643
D: 17065 [SC]Found MRP parameters in the message
D: 17070 [SC]Including MRP parameters in PBKDF param response
I: 17076 [EM]<<< [E:47590r M:63814348] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:21 (SecureChannel:PBKDFParamResponse)
I: 17087 [IN](U) Sending msg 63814348 to IP address 'BLE'
D: 17093 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 140)
D: 17100 [SC]Sent PBKDF param response
D: 17171 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 17179 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 17186 [EM]>>> [E:47590r M:76027511] (U) Msg RX from 0:F7C620AF8D6897A3 [0000] --- Type 0000:22 (SecureChannel:PASE_Pake1)
D: 17197 [EM]Found matching exchange: 47590r, Delegate: 0x2000521c
D: 17203 [SC]Received spake2p msg1
I: 19080 [EM]<<< [E:47590r M:63814349] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:23 (SecureChannel:PASE_Pake2)
I: 19091 [IN](U) Sending msg 63814349 to IP address 'BLE'
D: 19096 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 132)
D: 19104 [SC]Sent spake2p msg2
E: 19107 [DL]Long dispatch time: 1928 ms, for event type 16388
D: 19267 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 19275 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 19283 [EM]>>> [E:47590r M:76027512] (U) Msg RX from 0:F7C620AF8D6897A3 [0000] --- Type 0000:24 (SecureChannel:PASE_Pake3)
D: 19294 [EM]Found matching exchange: 47590r, Delegate: 0x2000521c
D: 19300 [SC]Received spake2p msg3
D: 19303 [SC]Sending status report. Protocol code 0, exchange 47590
I: 19309 [EM]<<< [E:47590r M:63814350] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
I: 19321 [IN](U) Sending msg 63814350 to IP address 'BLE'
D: 19326 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 35)
I: 19334 [SC]SecureSession[0x200030f0]: Moving from state 'kEstablishing' --> 'kActive'
D: 19342 [IN]SecureSession[0x200030f0]: Activated - Type:1 LSID:58142
D: 19348 [IN]New secure session activated for device <FFFFFFFB00000000, 0>, LSID:58142 PSID:64643!
I: 19357 [SVR]Commissioning completed session establishment step
I: 19363 [DIS]Updating services using commissioning mode 0
D: 19369 [DL]Using Thread extended MAC for hostname.
D: 19374 [DL]Using Thread extended MAC for hostname.
I: 19379 [DIS]Advertise commission parameter vendorID=65521 productID=32774 discriminator=4004/15 cm=0
E: 19388 [DIS]Failed to advertise extended commissionable node: 3
D: 19394 [DIS]Scheduling extended discovery timeout in 900s
E: 19399 [DIS]Failed to finalize service update: 1c
D: 19404 [DL]CHIPoBLE advertising set to off
I: 19408 [SVR]Device completed Rendezvous process
E: 19413 [DL]Long dispatch time: 138 ms, for event type 16388
D: 19419 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 19427 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 19435 [EM]>>> [E:47591r M:19450924] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
D: 19446 [EM]Handling via exchange: 47591r, Delegate: 0x2000f6cc
D: 19451 [IM]Received Read request
D: 19458 [DMG]IM RH moving to [GeneratingReports]
D: 19462 [DMG]Building Reports for ReadHandler with LastReportGeneration = 0 DirtyGeneration = 0
D: 19471 [DMG]<RE:Run> Cluster 31, Attribute 3 is dirty
D: 19476 [DMG]Reading attribute: Cluster=0x0000_0031 Endpoint=0 AttributeId=0x0000_0003 (expanded=1)
D: 19485 [DMG]<RE:Run> Cluster 28, Attribute 4 is dirty
D: 19490 [DMG]Reading attribute: Cluster=0x0000_0028 Endpoint=0 AttributeId=0x0000_0004 (expanded=0)
D: 19499 [DMG]<RE:Run> Cluster 28, Attribute 2 is dirty
D: 19504 [DMG]Reading attribute: Cluster=0x0000_0028 Endpoint=0 AttributeId=0x0000_0002 (expanded=0)
D: 19513 [DMG]<RE:Run> Cluster 30, Attribute 3 is dirty
D: 19518 [DMG]Reading attribute: Cluster=0x0000_0030 Endpoint=0 AttributeId=0x0000_0003 (expanded=0)
D: 19527 [DMG]<RE:Run> Cluster 30, Attribute 2 is dirty
D: 19532 [DMG]Reading attribute: Cluster=0x0000_0030 Endpoint=0 AttributeId=0x0000_0002 (expanded=0)
D: 19541 [DMG]<RE:Run> Cluster 30, Attribute 1 is dirty
D: 19546 [DMG]Reading attribute: Cluster=0x0000_0030 Endpoint=0 AttributeId=0x0000_0001 (expanded=0)
D: 19555 [DMG]<RE:Run> Cluster 30, Attribute 0 is dirty
D: 19560 [DMG]Reading attribute: Cluster=0x0000_0030 Endpoint=0 AttributeId=0x0000_0000 (expanded=0)
D: 19569 [DMG]<RE:Run> Cluster 31, Attribute fffc is dirty
D: 19575 [DMG]Reading attribute: Cluster=0x0000_0031 Endpoint=0 AttributeId=0x0000_FFFC (expanded=1)
D: 19584 [DMG]<RE> Sending report (payload has 228 bytes)...
I: 19591 [EM]<<< [E:47591r M:172714638] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData)
I: 19601 [IN](S) Sending msg 172714638 on secure session with LSID: 58142
D: 19607 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 19615 [DMG]<RE> OnReportConfirm: NumReports = 0
D: 19620 [DMG]<RE> ReportsInFlight = 0 with readHandler 0, RE has no more messages
D: 19627 [DMG]IM RH moving to [AwaitingDestruction]
D: 19632 [DMG]All ReadHandler-s are clean, clear GlobalDirtySet
D: 19754 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 19762 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 21)
D: 19949 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 19958 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 19966 [EM]>>> [E:47592r M:19450925] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
D: 19977 [EM]Handling via exchange: 47592r, Delegate: 0x2000f6cc
D: 19983 [DMG]Received command for Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0000
I: 19990 [FS]GeneralCommissioning: Received ArmFailSafe (60s)
D: 19996 [DMG]Endpoint 0, Cluster 0x0000_0030 update version to cca4d572
D: 20003 [DMG]Command handler moving to [ Preparing]
D: 20008 [DMG]Command handler moving to [AddingComm]
D: 20012 [DMG]Command handler moving to [AddedComma]
D: 20017 [DMG]Decreasing reference count for CommandHandler, remaining 0
I: 20025 [EM]<<< [E:47592r M:172714639] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 20035 [IN](S) Sending msg 172714639 on secure session with LSID: 58142
D: 20042 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 20050 [DMG]Command handler moving to [CommandSen]
D: 20054 [DMG]Command handler moving to [AwaitingDe]
E: 20059 [DL]Long dispatch time: 101 ms, for event type 16388
D: 20144 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 20243 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 20251 [EM]>>> [E:47593r M:19450926] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
D: 20261 [EM]Handling via exchange: 47593r, Delegate: 0x2000f6cc
D: 20268 [DMG]Received command for Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0002
D: 20440 [DMG]Endpoint 0, Cluster 0x0000_0030 update version to cca4d573
D: 20446 [DMG]Command handler moving to [ Preparing]
D: 20451 [DMG]Command handler moving to [AddingComm]
D: 20456 [DMG]Command handler moving to [AddedComma]
D: 20461 [DMG]Decreasing reference count for CommandHandler, remaining 0
I: 20468 [EM]<<< [E:47593r M:172714640] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 20479 [IN](S) Sending msg 172714640 on secure session with LSID: 58142
D: 20485 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 20493 [DMG]Command handler moving to [CommandSen]
D: 20498 [DMG]Command handler moving to [AwaitingDe]
E: 20502 [DL]Long dispatch time: 260 ms, for event type 16388
D: 20548 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 20556 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 20564 [EM]>>> [E:47594r M:19450927] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
D: 20575 [EM]Handling via exchange: 47594r, Delegate: 0x2000f6cc
D: 20582 [DMG]Received command for Endpoint=0 Cluster=0x0000_003E Command=0x0000_0002
I: 20589 [ZCL]OpCreds: Certificate Chain request received for PAI
D: 20595 [DMG]Command handler moving to [ Preparing]
D: 20600 [DMG]Command handler moving to [AddingComm]
D: 20605 [DMG]Command handler moving to [AddedComma]
D: 20609 [DMG]Decreasing reference count for CommandHandler, remaining 0
I: 20619 [EM]<<< [E:47594r M:172714641] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 20630 [IN](S) Sending msg 172714641 on secure session with LSID: 58142
D: 20636 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 20644 [DMG]Command handler moving to [CommandSen]
D: 20649 [DMG]Command handler moving to [AwaitingDe]
D: 20773 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 20781 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 20863 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 20871 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 48)
D: 20953 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 20961 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 20969 [EM]>>> [E:47595r M:19450928] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
D: 20980 [EM]Handling via exchange: 47595r, Delegate: 0x2000f6cc
D: 20987 [DMG]Received command for Endpoint=0 Cluster=0x0000_003E Command=0x0000_0002
I: 20994 [ZCL]OpCreds: Certificate Chain request received for DAC
D: 21000 [DMG]Command handler moving to [ Preparing]
D: 21005 [DMG]Command handler moving to [AddingComm]
D: 21010 [DMG]Command handler moving to [AddedComma]
D: 21015 [DMG]Decreasing reference count for CommandHandler, remaining 0
I: 21024 [EM]<<< [E:47595r M:172714642] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 21035 [IN](S) Sending msg 172714642 on secure session with LSID: 58142
D: 21041 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 21049 [DMG]Command handler moving to [CommandSen]
D: 21054 [DMG]Command handler moving to [AwaitingDe]
D: 21133 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 21141 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 21268 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 21276 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 76)
D: 21358 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 21366 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 21375 [EM]>>> [E:47596r M:19450929] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
D: 21385 [EM]Handling via exchange: 47596r, Delegate: 0x2000f6cc
D: 21392 [DMG]Received command for Endpoint=0 Cluster=0x0000_003E Command=0x0000_0000
I: 21399 [ZCL]OpCreds: Received an AttestationRequest command
I: 21435 [ZCL]OpCreds: AttestationRequest successful.
D: 21440 [DMG]Command handler moving to [ Preparing]
D: 21445 [DMG]Command handler moving to [AddingComm]
D: 21450 [DMG]Command handler moving to [AddedComma]
D: 21455 [DMG]Decreasing reference count for CommandHandler, remaining 0
I: 21465 [EM]<<< [E:47596r M:172714643] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 21476 [IN](S) Sending msg 172714643 on secure session with LSID: 58142
D: 21482 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 21490 [DMG]Command handler moving to [CommandSen]
D: 21495 [DMG]Command handler moving to [AwaitingDe]
E: 21500 [DL]Long dispatch time: 134 ms, for event type 16388
D: 21538 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 21546 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 21763 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 21771 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 236)
D: 21853 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 21944 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 21952 [EM]>>> [E:47597r M:19450930] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
D: 21963 [EM]Handling via exchange: 47597r, Delegate: 0x2000f6cc
D: 21970 [DMG]Received command for Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0000
I: 21977 [FS]GeneralCommissioning: Received ArmFailSafe (0s)
I: 21983 [FS]Fail-safe timer expired
D: 21986 [DMG]Command handler moving to [ Preparing]
D: 21991 [DMG]Command handler moving to [AddingComm]
D: 21995 [DMG]Command handler moving to [AddedComma]
D: 22000 [DMG]Decreasing reference count for CommandHandler, remaining 0
I: 22007 [EM]<<< [E:47597r M:172714644] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 22018 [IN](S) Sending msg 172714644 on secure session with LSID: 58142
D: 22025 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 22033 [DMG]Command handler moving to [CommandSen]
D: 22038 [DMG]Command handler moving to [AwaitingDe]
E: 22042 [SVR]Failsafe timer expired
D: 22046 [IN]SecureSession[0x200030f0]: MarkForEviction Type:1 LSID:58142
I: 22052 [SC]SecureSession[0x200030f0]: Moving from state 'kActive' --> 'kPendingEviction'
D: 22060 [IN]SecureSession[0x200030f0]: Released - Type:1 LSID:58142
E: 22066 [SVR]Commissioning failed (attempt 1): 32
D: 22071 [IN]Clearing BLE pending packets.
I: 22075 [BLE]Releasing end point's BLE connection back to application.
I: 22081 [DL]Closing BLE GATT connection (ConnId 00)
D: 22089 [IN]SecureSession[0x200030f0]: Allocated Type:1 LSID:58143
D: 22095 [SC]Assigned local session key ID 58143
D: 22099 [SC]Waiting for PBKDF param request
D: 22103 [DL]CHIPoBLE advertising set to on
I: 22107 [DIS]Updating services using commissioning mode 1
D: 22112 [DL]Using Thread extended MAC for hostname.
D: 22117 [DL]Using Thread extended MAC for hostname.
I: 22123 [DIS]Advertise commission parameter vendorID=65521 productID=32774 discriminator=4004/15 cm=1
E: 22132 [DIS]Failed to advertise commissionable node: 3
E: 22137 [DIS]Failed to finalize service update: 1c
E: 22142 [ZCL]OpCreds: Got FailSafeTimerExpired
E: 22146 [ZCL]OpCreds: Proceeding to FailSafeCleanup on fail-safe expiry!
I: 22153 [TS]Pending Last Known Good Time: 2022-11-02T14:54:43
I: 22159 [TS]Previous Last Known Good Time: 2022-11-02T14:54:43
I: 22165 [TS]Reverted Last Known Good Time to previous value
E: not connected!
D: 22173 [DMG]Endpoint 0, Cluster 0x0000_0030 update version to cca4d574
D: 22179 [ZCL]Failsafe timeout, tell platform driver to revert network credentials.
E: 22188 [DL]Long dispatch time: 145 ms, for event type 32782
I: 22193 [FS]Fail-safe cleanly disarmed
D: 22197 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
E: 22204 [BLE]no endpoint for BLE sent data ack
D: 22209 [DL]ConnId: 0x00, New CCCD value: 0x0000
E: 22213 [BLE]no endpoint for unsub recvd
I: 22528 [DL]BLE GAP connection terminated (reason 0x22)
I: 22533 [DL]Current number of connections: 0/1
I: 22540 [DL]CHIPoBLE advertising started
I: 22545 [DL]NFC Tag emulation started
I: 52544 [DL]CHIPoBLE advertising mode changed to slow
    Could you point me to what test-harness v2.6 raspi is and where to find it? As far as I can see this is not something that we have created
    Andreas
  • test-harness is the specified test tool provided by Matter. Products must be tested with this tool if they want to pass the matter certification.
    You can download it at this link.it's a mirror image of a raspberry PI.
    graniteriverlabs1-my.sharepoint.com/.../onedrive.aspx
    I've had a chat with our Matter developers and they are wondering about which certificates you're using?
    Since your attestation is failing, the issue might be with the certificates. This issue should not be present if you're using test certificates, but if you're using generated certificates for the DUT, then you will have to provide the folder with the certificates as well.
    Can you also verify if the controller version is also from v2.6TH?
    And are you using the controller manually, or are you using the Test-harness?
    Andreas
