Can I user NRF TWI Manager to write varying lengths from a buffer?
I am attempting to use the NRF twi manager based on the "twi master using nrf twi manager" example. I noticed that the example only reads and wrties a single byte and hence the transfer sizes can be defined as constants. However, I am trying to use an I2C uart module, since NRF52832 only has one UART, to output some debug information.
Hence the writes are of variable length and I am struggling to get the code to compile as it requires the transfer[x].length to be a constant. So my question is if I can use the manager to schedule these writes.
I have attempted to use the standard twi master which results in watchdog resets as the "while (m_xfer_done == false)" results in a blocking call even when using an event handler. I understand that I could implement a queuing mechanism however, I am trying to avoid that effort if the twi manager does this already.
Ankit
