App timer in repeated mode always runs with the same delay
I am starting a new ticket as per the suggestion from a previous ticket.
I have RTC configured to trigger every 1 ms and that keeps track on milliseconds since startup. I use that variable to log(using RTT) when the timer is triggered.
There is only one app timer which refreshes watchdog. The timer does various tasks. I log the ticks since startup at various points in the timer and it takes about 2 ms to complete.
Here is some source code that show rtc and app timer. using RTT logger for some debug messages. The source is based is based on the nrf ble uart example and the soft device is running and advertising. The timer is configurted to run every 1000 ms but it is always triggered at 1024 ms. This means that every 40 triggers, the tasks in timer would have run one less time which is not acceptable.
/** @brief: Function for handling the RTC0 interrupts.
 * Triggered on TICK and COMPARE0 match.
static void rtc_handler(nrf_drv_rtc_int_type_t int_type)
    (void) int_type;
    //increment 1m tick ctr
    g_ticks_since_startup++;
 * @brief Handler for timer events.
 * @param p_context
static void timer_handler(void * p_context)
    (void) p_context;
    NRF_LOG_RAW_INFO("Timer %d\n", g_ticks_since_startup);
    //feed the watchdog
    nrf_drv_wdt_channel_feed(m_channel_id);
    //do more stuff
    //get uart sensor data
    sensor_poll(&m_nus);
    NRF_LOG_RAW_INFO("Timer end %d,", g_ticks_since_startup);
    //set flush logs flag
    flush_pending_logs = true;
/**@brief Function for initializing the timer module.
static void timers_init(void)
    err_code = app_timer_create(&m_timer, APP_TIMER_MODE_REPEATED, timer_handler);
    err_code = app_timer_start(m_timer, APP_TIMER_TICKS(1000), NULL);
 * @brief WDT events handler.
void wdt_event_handler(void)
    NRF_LOG_RAW_INFO("WDT trig\r\n");
    //NOTE: The max amount of time we can spend in WDT interrupt is two cycles of 32768[Hz] clock - after that, reset occurs
    /* Init systick driver */
    nrf_drv_systick_init();
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    //RTC Init
    lfclk_config();
    rtc_config();
    //feed the watchdog
    gpio_init();
    //uart sensor init
    sensor_init();
    //set the ble tx power
    sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_SCAN_INIT, BLE_CONN_HANDLE_INVALID, BLE_TX_POWER);
    // Start advertising.
    advertising_start();
    //initalise the local adc for battery voltage monitoring
    saadc_init();
    //init the temperature sensor
    g_mc_termperature = 0;
    // Enter main loop.
    for (;;)
        // Clear the event register.
        __SEV();
        __WFE();
        // Wait for an event.
        __WFE();
        if(flush_pending_logs)
            //flush logs
            flush_pending_logs = false;
        idle_state_handle();
How can I figure out what is causing this and ensure the timer runs every 1000 ms.
Regards
    How do you measure the 1024 ms? Are you using toggling GPIOs and measure the timing externally using a logic analyzer, or do you use the 1ms RTC counter to measure the time? The RTC runs off the 32.768 kHz LFCLK, which makes it not possible to trigger in interrupt at exactly 1 ms. If you run at maximum frequency RTC Prescaler = 0, the closest would be ~976 us (32 / 32768Hz), or ~1007 us (33 / 32768Hz). The app_timer should be able to trigger at 1000ms intervals, but note that the interrupts/event handling might be delayed by other higher priority interrupts in the system.
    • What is the output from the APP_TIMER_TICKS() macro?
    • Are you using app_timer2 in your application?
    • Which SDK version are you using?
    Jørgen
  • Hello Jorgen,
    I use the rtc counter to measure the 1ms ticks.
    Yes I am using app_timer2 and the SDK version is nRF5_SDK_17.0.2.
    The APP_TIMER_TICKS(1000) outputs 16384.
    Here is the rtc_config function
    #define LF_CLK_FREQ_HZ                  32768U
    #define RTC_CTR_FREQ_HZ                 1000U
    #define COMPARE_COUNTERTIME             (1UL)
    /** @brief Function initialization and configuration of RTC driver instance.
    static void rtc_config(void)
        uint32_t err_code;
        //Initialize RTC instance, every 10 ms
        nrf_drv_rtc_config_t config = NRF_DRV_RTC_DEFAULT_CONFIG;
        config.prescaler = (uint16_t)((LF_CLK_FREQ_HZ / RTC_CTR_FREQ_HZ) - 1U); //e.g PRESCALER = round(32.768 kHz / 100 Hz) - 1 = 327
        err_code = nrf_drv_rtc_init(&rtc, &config, rtc_handler);
        //Enable tick event & interrupt
        nrf_drv_rtc_tick_enable(&rtc,true);
        //Set compare channel to trigger interrupt after COMPARE_COUNTERTIME seconds
        err_code = nrf_drv_rtc_cc_set(&rtc, 2U, (COMPARE_COUNTERTIME * RTC_CTR_FREQ_HZ), true);
        //Power on RTC instance
        nrf_drv_rtc_enable(&rtc);
    Based on your comment I am measuring the 1ms ticks incorrectly. My final aim is to ensure that the the timer runs every 1000ms and if that requires modifying the rtc counter then what changes do I need to make?
    Regards
    Ankit
  • I am going to be offline until 11th Dec 2022. Please don't close this case due to inactivity. I will respond as soon as I am back online.
    Do you need to count each millisecond? If you start an RTC or a app_timer instance with the CC/TICK set to the same as the frequency of the RTC (32768/(PRESCALER + 1), then that should run at every 1000 ms. If you need to count each millisecond, you need to check your ticks and make sure you count the right amount of events in a second. I.e. if the RTC runs as 32.768 kHz, and you configure a each "ms" to tick at CC=32, you will need to count to 1024 "ms" before you reach 1000 ms (32768/32).
  • Hello
    Apologies for the delay in the response. Based on the your comment,
    am I right in understanding that ticks don't correspond to milliseconds in this case?
    Hence 1024 ticks counted by the rtc counter indicate 1000 ms have elapsed?
    Regards
    Ankit
