nRF Connect Install requires a huge amount of packages
I have developed a set of applications using just SoftDevice for Bluetooth and flash read and writes in the framework of nFR51 and nRF52 SDKs. Now I was thinking of moving to nRF Connect. I already have Visual Studio Code installed for a project that is handled remotely from my Windows 64 10 PC  on a Linux Raspberry PI. So I installed the extensions for Nordic. However, I could not find the locations on my computer where they were installed. VS Code itself is installed on a second disk E.
However I was far from finished. It looks like I need to install a great number of third party programs I have never heard of including the nRF Command Line Tools. I do not intend to use the command line tools and have never used this tool to date. Why do I need this? Is it absolutely necessary to install all these third party packages like 'chocolately',  'west', python??? , Zephyr I can understand... This is probably gigabytes of junk. I cannot image all of this stuff ever getting cleaned up. Do I really need all this? Why Python? That's a whole SDK for building Python applications ... that is huge.
How many of these can I get rid of once nRF Connect is installed. What does 'chocolatey and west do? I realize that I can install even more stuff and get the manager to do all of this for me but that is just hiding all the junk getting downloaded and installed.
I went to the Nordic 'Seminar' in Boston (Waltham) about a month ago where I was introduced to nRF Connect.
So the actual goal here was to see if this project would have a smaller footprint using SoftDevice (used now) or the nRF Connect SDK and which was easier to implement. There is interest in this project (which is a generic health device model over a BTLE tunnel) primarily in China at the moment so It would be nice to have an answer. One thing the seminar did not reveal was the massive amount of support software needed to get off the ground.
  • Hi Brian
    VSCode extensions should be installed in the %USERPROFILE%\.vscode\extensions folder. Typically something like c:\Users\USERNAME\.vscode\extensions. I confirmed this on my own machine, and can see 5 folders with the nordic-semiconductor prefix for the various Nordic extensions.
    That is odd to hear you have never use this before, the nRF Command Line tools contains the base drivers to interface with the debug chip on the various nRF52 DK's, and is used for flashing and debugging the DK's. I would expect you to have used this when working with the nRF5 SDK and the SoftDevices.
    These tools are listed in the Tools and downloads section of the nRF52 series DK's, based on the 'old' platform (nRF5 SDK and SoftDevice).
    Chocolatey should no longer be necessary. This is a packet manager that was used to install the various toolchain components in the first releases of the nRF Connect SDK, but has now been replaced by the Toolchain Manager (TCM) application in nRF Connect for Desktop
    When using the TCM it is basically a one click operation to install a specific version of the SDK, and this includes the various toolchain components such as West and Python.
    You define the install directory for any new SDK versions. Then the SDK's will be installed in a subfolder named v2.1.0 for instance, while the toolchain will be installed in the /toolchain/v2.1.0 folder.
    At the moment each SDK install comes with its own version of the toolchain which does contribute to the bloat definitely, but greatly reduces the chance of build errors caused by incorrect toolchain components.
    Python is used by a lot of the build scripts in the toolchain and as such is critical, with West being the most important of these Python scripts. West is the meta tool that handles the download and update of the various repositories included under the nRF Connect SDK umbrella, and can also be used to start build, flash and other operations from the command line.
    I doubt the whole Python SDK should be downloaded though. The entire toolchain comes in at about 1GB, and I think the Python binaries are a relatively small portion of this.
    I doubt there is much you can get rid of since most of these tools are used for building applications. Possibly you could get rid of chocolatey and leave the scripts in place, but I am not sure.
    Frankly you will be much better of using the Toolchain Manager. As I mentioned earlier all the resulting junk can be found in the [SDK_FOLDER]/toolchain/v2.x.x folder, so using the TCM should not make it any harder to find compared to chocolatey Wink
    You can uninstall the TCM and nRF Connect for Desktop once everything is installed, these are not used for building or developing applications. That said there are a lot of useful apps within nRF Connect for Desktop, such as the Bluetooth application and the Power Profiler (for owners of a Power Profiler Kit), so I think this is an application worth keeping.
    If you really want to keep your system as un-affected as possible the best option is probably to install everything in a virtual machine. If you want to go down this route though it is recommended to run a virtual Linux installation, since the build performance is generally faster in Linux than on Windows.
    I remember, I was there!
    I think we had a chat at the end, regarding the work you have been doing with the SoftDevice Slight smile
    I didn't represent nRF Connect though, so any promises made about it I will put on Karl's shoulders Stuck out tongue winking eye
    Are you talking about memory footprint on the device, or the size of the toolchain?
    What is more easy to implement is a complicated question to answer. The toolchain and build system is definitely more complicated, but making applications is typically not because of the advantages the build system offers. As an example the Bluetooth heart rate example in Zephyr is about 130 lines of code i main.c, compared to a much more complex example in the nRF5 SDK. And exactly the same main file can run fine on the nRF51, nRF52 or nRF53 devices by only changing the board file in the build, which is something the nRF5 SDK could only dream off...
    Your development model is a bit different than most customers though, as you don't really use any of the libraries in the SDK and just program for the SoftDevice directly. I am not sure this will work as well in the new SDK, since we don't really have a SoftDevice anymore, but have split the BLE controller and host into two separate pieces of software.
    To be fair, I think we mentioned most of these tools in the seminar, but it is true that Python isn't mentioned in the slides. This I can take as feedback to future iterations of the slides. Chocolatey is not mentioned either, but as I said we recommend using the TCM instead, rather than having to install all the tools manually.
    Finally I hope you have taken the time to go through the DevAcademy?
    It really makes a big difference in getting started with the nRF Connect SDK Slight smile
    Best regards
    Torbjørn
  • Hi! Thanks for the reply. I do use nFR Connect for desk top mainly for installing hex files on the nRF52840 dongle, so I would not get rid of that.
    If the command line tools are being used I am not actively using them. All building and installing of HEX files onto the DKs have been with Segger ES or Keil IDEs. For debugging I also use these IDEs and for display of log messages I use putty. Perhaps the command line tools could replace putty.
    I used SoftDevice because it was right at the GATT/GAP level. The project I am working on is basically proprietary above that so there is little help from the BTLE part of the SDK. The SoftDevice APIs were straight forward enough that I found them easier to use than the SDK for the BT SIG health device profiles perhaps because I didn't have to learn as much. Every GATT BTLE project depends (in the end) upon those basic GATT features so there was little difference between writing a BP or a Glucose meter using SoftDevice. The crap that goes in the measurement characteristics is always a pain and I blame BT SIG for that. IN addition I started with the Btle PC driver package on the dongle which ONLY has SoftDevice.
    When I was referring to project size I meant the size of the installed code on the MCU. Using SoftDevice for a BP meter was less than half the size of using the SDK BP example. For this project there is only one service and two characteristics, notifications/indications and client writes. No reads. It supports all health devices. That is another good reason for SoftDevice. I guess I will find out what nRFConnect SDK offers..
  • And exactly the same main file can run fine on the nRF51, nRF52 or nRF53 devices by only changing the board file in the build, which is something the nRF5 SDK could only dream off...
    Wrong, it exists 5 years ago without any scripting software only gcc compiler. It has been posted on this forum since.
    https://embeddedsoftdev.blogspot.com/2017/12/bluetooth-le-with-nordic-nrf51-nrf52.html
    https://embeddedsoftdev.blogspot.com/2018/02/bluetooth-le-with-nordic-nrf51-nrf52.html
    With only a few line of code, no RTOS, no 10K line of defines.
    Original source code here
    https://github.com/I-SYST/EHAL
    new version moved here
    https://github.com/IOsonata/IOsonata
  • Hi Brian
    I got a tip that SES includes its own set of JLink drivers, so that probably explains why you never used the command line tools.
    Peripheral only applications are usually smaller in memory footprint in the nRF Connect SDK (NCS), but not by as much as half.
    Using the heart rate example as a reference again the nRF5 SDK version comes in at about 252kB flash, 43kB RAM, while the nRF Connect SDK version comes in at around 172kB flash 34kB RAM.
    An advantage in NCS code size wise is that the Bluetooth host is implemented in source, which means you can optimize out procedures or functions that you don't use. With the SoftDevice you obviously didn't have this capability.
    A drawback of NCS is that you need some libraries in place (such as the Zephyr RTOS) that you don't with the SoftDevice, but Zephyr is pretty light weight memory wise.
    The best of luck. If you have any issues along the way you know where to find us Slight smile
    Best regards
    Torbjørn
  • Hi
    Not for the nRF53 I assume Wink
    Being multi core the nRF53 is more challenging to support with the same code base, which is something the nRF5 SDK wasn't really ideal for.
    T.
