We want a solution for BLE Mesh using Coded PHY.
Normally we provision the Mesh devices using Mobile Apps.
We want Nordic module to act as Mesh provisioner to provision the Mesh devices using coded PHY.
Swaroop
Swaroop
Hi Swaroop,
As far as I know Coded PHY is not supported with Bluetooth mesh. And we don't have a sample for doing provisioning with Coded PHY.
If you want to do that you will need to modify the mesh stack manually, unfortunately. Please note that if you modify the mesh stack, you may need to run qualification on the modified version of the stack.
