Hello everyone!
While programming nRF52805 module, I am encountering an error in memory reading stage. Logs from the application (both Failure and success cases) are attached below for reference.
Log generated in case of error:
***************THIS LOG IS GENERATED DURING ISSUE***************
2022-11-13T09:26:33.116Z DEBUG Application data folder: C:\Users\***\AppData\Roaming\nrfconnect\pc-nrfconnect-programmer
2022-11-13T09:26:33.295Z DEBUG App pc-nrfconnect-programmer v3.0.4 official
2022-11-13T09:26:33.296Z DEBUG App path: C:\Users\***\.nrfconnect-apps\node_modules\pc-nrfconnect-programmer
2022-11-13T09:26:33.296Z DEBUG nRFConnect 3.12.0, required by the app is (^3.12.0)
2022-11-13T09:26:33.296Z DEBUG nRFConnect path: C:\Users\***\AppData\Local\Programs\nrfconnect\resources\app.asar
2022-11-13T09:26:33.296Z DEBUG HomeDir: C:\Users\***
2022-11-13T09:26:33.296Z DEBUG TmpDir: C:\Users\***\AppData\Local\Temp
2022-11-13T09:26:33.733Z INFO Using nrf-device-lib-js version: 0.4.13
2022-11-13T09:26:33.733Z INFO Using nrf-device-lib version: 0.12.8
2022-11-13T09:26:33.734Z INFO Using nrfjprog DLL version: 10.16.0
2022-11-13T09:26:33.734Z INFO Using JLink version: JLink_V7.66a
2022-11-13T09:26:33.734Z INFO Installed JLink version does not match the provided version (V7.66a)
2022-11-13T09:26:37.132Z INFO Using @nordicsemiconductor/nrf-device-lib-js to communicate with target via JLink
2022-11-13T09:26:37.132Z INFO JLink OB firmware version J-Link OB-SAM3U128-V2-NordicSemi compiled Jan 20 2022 16:43:31
2022-11-13T09:26:37.133Z INFO Device family NRF52_FAMILY
2022-11-13T09:26:37.133Z INFO Device version NRF52805_xxAA_REV1
2022-11-13T09:26:37.133Z INFO Board version PCA10040
2022-11-13T09:26:37.134Z INFO Loading readback protection status for Application core
2022-11-13T09:26:38.135Z DEBUG Client Id: 190cb99e-3c75-456a-9700-d057cc92f5cc
2022-11-13T09:26:38.979Z INFO Readback protection status: NRFDL_PROTECTION_STATUS_NONE
2022-11-13T09:26:41.063Z INFO Parse memory regions for Application core
2022-11-13T09:26:41.071Z INFO Update files regions according to Application core
2022-11-13T09:26:41.072Z INFO Parse memory regions for file
2022-11-13T09:26:41.089Z INFO Device is loaded and ready for further operation
2022-11-13T09:26:41.094Z INFO Reading memory for NRFDL_DEVICE_CORE_APPLICATION core
2022-11-13T09:26:42.891Z DEBUG Google Analytics for category pc-nrfconnect-programmer has initialized
2022-11-13T09:26:45.455Z ERROR Failed to get device memory map: async task failure for id: 2363309243 msg: JLINKARM_DLL_ERROR (Origin: "Error when running fw program.")
2022-11-13T09:26:45.458Z DEBUG Sending usage data {"category":"pc-nrfconnect-programmer","action":"Open jlink OB version","label":"J-Link OB-SAM3U128-V2-NordicSemi compiled Jan 20 2022 16:43:31"}
2022-11-13T09:26:45.468Z DEBUG Sending usage data {"category":"pc-nrfconnect-programmer","action":"Open jlink device family","label":"NRF52_FAMILY"}
2022-11-13T09:26:45.475Z DEBUG Sending usage data {"category":"pc-nrfconnect-programmer","action":"Open jlink device version","label":"NRF52805_xxAA_REV1"}
2022-11-13T09:26:45.481Z DEBUG Sending usage data {"category":"pc-nrfconnect-programmer","action":"Open jlink device board version","label":"PCA10040"}
2022-11-13T09:26:45.487Z DEBUG Sending usage data {"category":"pc-nrfconnect-programmer","action":"Open device","label":"jlink"}
2022-11-13T09:26:45.492Z DEBUG Sending usage data {"category":"pc-nrfconnect-programmer","action":"architecture","label":"ia32"}
2022-11-13T09:26:45.498Z DEBUG Sending usage data {"category":"pc-nrfconnect-programmer","action":"Report error","label":"win32; ia32; v3.0.4; Failed to get device memory map: async task failure for id: 2363309243 msg: JLINKARM_DLL_ERROR (Origin: \"Error when running fw program.\")"}
2022-11-13T09:26:45.509Z ERROR Error when reading device
Usually this kind of error doesn't occur while programming the module.
A successful programming iteration produces following log:
***************THIS LOG IS GENERATED IN A SUCCESSFUL ITERATION***************
2022-11-11T09:23:43.156Z DEBUG Application data folder: C:\Users\***\AppData\Roaming\nrfconnect\pc-nrfconnect-programmer
2022-11-11T09:23:43.325Z DEBUG App pc-nrfconnect-programmer v3.0.4 official
2022-11-11T09:23:43.325Z DEBUG App path: C:\Users\***\.nrfconnect-apps\node_modules\pc-nrfconnect-programmer
2022-11-11T09:23:43.325Z DEBUG nRFConnect 3.12.0, required by the app is (^3.12.0)
2022-11-11T09:23:43.325Z DEBUG nRFConnect path: C:\Users\***\AppData\Local\Programs\nrfconnect\resources\app.asar
2022-11-11T09:23:43.326Z DEBUG HomeDir: C:\Users\***
2022-11-11T09:23:43.326Z DEBUG TmpDir: C:\Users\***\AppData\Local\Temp
2022-11-11T09:23:43.727Z INFO Using nrf-device-lib-js version: 0.4.13
2022-11-11T09:23:43.728Z INFO Using nrf-device-lib version: 0.12.8
2022-11-11T09:23:43.728Z INFO Using nrfjprog DLL version: 10.16.0
2022-11-11T09:23:43.728Z INFO Using JLink version: JLink_V7.66a
2022-11-11T09:23:43.728Z INFO Installed JLink version does not match the provided version (V7.66a)
2022-11-11T09:23:46.687Z INFO Using @nordicsemiconductor/nrf-device-lib-js to communicate with target via JLink
2022-11-11T09:23:46.688Z INFO JLink OB firmware version J-Link OB-SAM3U128-V2-NordicSemi compiled Jan 20 2022 16:43:31
2022-11-11T09:23:46.688Z INFO Device family NRF52_FAMILY
2022-11-11T09:23:46.688Z INFO Device version NRF52805_xxAA_REV1
2022-11-11T09:23:46.688Z INFO Board version PCA10040
2022-11-11T09:23:46.688Z INFO Loading readback protection status for Application core
2022-11-11T09:23:48.176Z DEBUG Client Id: 190cb99e-3c75-456a-9700-d057cc92f5cc
2022-11-11T09:23:48.442Z INFO Readback protection status: NRFDL_PROTECTION_STATUS_NONE
2022-11-11T09:23:50.309Z INFO Parse memory regions for Application core
2022-11-11T09:23:50.316Z INFO Update files regions according to Application core
2022-11-11T09:23:50.316Z INFO Parse memory regions for file
2022-11-11T09:23:50.327Z INFO Device is loaded and ready for further operation
2022-11-11T09:23:50.332Z INFO Reading memory for NRFDL_DEVICE_CORE_APPLICATION core
2022-11-11T09:23:50.830Z DEBUG Google Analytics for category pc-nrfconnect-programmer has initialized
2022-11-11T09:23:56.478Z INFO Reading memory for NRFDL_DEVICE_CORE_APPLICATION core completed
2022-11-11T09:23:56.481Z INFO Parse memory regions for Application core
2022-11-11T09:23:56.481Z INFO SoftDevice detected, id 0x125 (S113 v7.3.0)
2022-11-11T09:23:57.896Z INFO Resetting device completed
2022-11-11T09:23:59.282Z INFO Parsing HEX file: G:\.shortcut-targets-by-id\1qVHXTxpD1Dfh0tWwLsNSdSFwx8f02T9J\BLE Binaries\ble_app_uart_pca10040e_nrf52805_s113.hex
2022-11-11T09:23:59.298Z INFO File was last modified at 9/2/2022, 3:50:51 PM
2022-11-11T09:23:59.320Z INFO Update files regions according to Application core
2022-11-11T09:23:59.320Z INFO Parse memory regions for file
2022-11-11T09:23:59.345Z INFO Parsing HEX file: G:\.shortcut-targets-by-id\1qVHXTxpD1Dfh0tWwLsNSdSFwx8f02T9J\BLE Binaries\s113_nrf52_7.3.0_softdevice.hex
2022-11-11T09:23:59.346Z INFO File was last modified at 11/23/2021, 7:43:11 PM
2022-11-11T09:23:59.400Z INFO Update files regions according to Application core
2022-11-11T09:23:59.400Z INFO Parse memory regions for file
2022-11-11T09:23:59.400Z INFO SoftDevice detected, id 0x125 (S113 v7.3.0)
2022-11-11T09:24:02.782Z INFO Recovering NRFDL_DEVICE_CORE_APPLICATION core
2022-11-11T09:24:07.914Z INFO Recovering NRFDL_DEVICE_CORE_APPLICATION core completed
2022-11-11T09:24:07.918Z INFO Device recovery completed
2022-11-11T09:24:07.919Z INFO Writing procedure starts for NRFDL_DEVICE_CORE_APPLICATION core
2022-11-11T09:24:07.992Z INFO Writing HEX to NRFDL_DEVICE_CORE_APPLICATION core
2022-11-11T09:24:09.245Z INFO {"chip_erase_mode":"ERASE_ALL","qspi_erase_mode":"ERASE_NONE","reset":"RESET_NONE","verify":"VERIFY_NONE"} 100%
2022-11-11T09:24:09.245Z INFO Uploading image through JLink: 0%
2022-11-11T09:24:13.135Z INFO Uploading image through JLink: 100%
2022-11-11T09:24:13.332Z INFO Writing HEX to NRFDL_DEVICE_CORE_APPLICATION core completed
2022-11-11T09:24:13.332Z INFO Writing procedure ends for NRFDL_DEVICE_CORE_APPLICATION core
2022-11-11T09:24:14.715Z INFO Resetting device completed
2022-11-11T09:24:14.719Z INFO Using @nordicsemiconductor/nrf-device-lib-js to communicate with target via JLink
2022-11-11T09:24:14.719Z INFO JLink OB firmware version J-Link OB-SAM3U128-V2-NordicSemi compiled Jan 20 2022 16:43:31
2022-11-11T09:24:14.720Z DEBUG Sending usage data {"category":"pc-nrfconnect-programmer","action":"Open jlink OB version","label":"J-Link OB-SAM3U128-V2-NordicSemi compiled Jan 20 2022 16:43:31"}
2022-11-11T09:24:14.722Z DEBUG Sending usage data {"category":"pc-nrfconnect-programmer","action":"Open jlink device family","label":"NRF52_FAMILY"}
2022-11-11T09:24:14.724Z DEBUG Sending usage data {"category":"pc-nrfconnect-programmer","action":"Open jlink device version","label":"NRF52805_xxAA_REV1"}
2022-11-11T09:24:14.726Z DEBUG Sending usage data {"category":"pc-nrfconnect-programmer","action":"Open jlink device board version","label":"PCA10040"}
2022-11-11T09:24:14.727Z DEBUG Sending usage data {"category":"pc-nrfconnect-programmer","action":"Open device","label":"jlink"}
2022-11-11T09:24:14.729Z DEBUG Sending usage data {"category":"pc-nrfconnect-programmer","action":"architecture","label":"ia32"}
2022-11-11T09:24:14.731Z DEBUG Sending usage data {"category":"pc-nrfconnect-programmer","action":"Open jlink OB version","label":"J-Link OB-SAM3U128-V2-NordicSemi compiled Jan 20 2022 16:43:31"}
2022-11-11T09:24:14.732Z INFO Device family NRF52_FAMILY
2022-11-11T09:24:14.732Z DEBUG Sending usage data {"category":"pc-nrfconnect-programmer","action":"Open jlink device family","label":"NRF52_FAMILY"}
2022-11-11T09:24:14.733Z INFO Device version NRF52805_xxAA_REV1
2022-11-11T09:24:14.734Z DEBUG Sending usage data {"category":"pc-nrfconnect-programmer","action":"Open jlink device version","label":"NRF52805_xxAA_REV1"}
2022-11-11T09:24:14.735Z INFO Board version PCA10040
2022-11-11T09:24:14.735Z DEBUG Sending usage data {"category":"pc-nrfconnect-programmer","action":"Open jlink device board version","label":"PCA10040"}
2022-11-11T09:24:14.736Z INFO Loading readback protection status for Application core
2022-11-11T09:24:16.216Z INFO Readback protection status: NRFDL_PROTECTION_STATUS_NONE
2022-11-11T09:24:17.588Z INFO Parse memory regions for Application core
2022-11-11T09:24:17.589Z INFO Update files regions according to Application core
2022-11-11T09:24:17.589Z INFO Parse memory regions for file
2022-11-11T09:24:17.590Z INFO SoftDevice detected, id 0x125 (S113 v7.3.0)
2022-11-11T09:24:17.599Z INFO Device is loaded and ready for further operation
2022-11-11T09:24:17.601Z INFO Reading memory for NRFDL_DEVICE_CORE_APPLICATION core
2022-11-11T09:24:23.646Z INFO Reading memory for NRFDL_DEVICE_CORE_APPLICATION core completed
2022-11-11T09:24:23.648Z INFO Parse memory regions for Application core
2022-11-11T09:24:23.648Z INFO SoftDevice detected, id 0x125 (S113 v7.3.0)
2022-11-11T09:24:25.050Z INFO Resetting device completed
My questions are:
1. What can be possible reasons for this issue?
2. How to resolve this issue?
Thanks in advance for your kind help
Best Regards,
Suraj S.
