Kernel panic when I remove uart0_default
I have a simple application running on our custom board based on nRF52840. Our board does not have any uart pins connected so we use RTT exclusively for console I/O. I attempted to remove all references to uart pins from the board.dts file and this causes a kernel panic. Is there any example project that shows the proper way to replace uart with RTT?
My custom board files are attached. The files work as-is, however if I remove uart0_default and uart0_sleep from the miTracerV2.dtsi I will get the kernel panic.
miTracerV2.zip
