Hi All,
I use iot_ipv6_udp_client example on nRF51 DK. I modified it and send data in one direction only (not receiving back). Testing has shown that the maximum packet rate for short packets (20 - 30 bytes of payload) is about 13 packets per second. For packets of 140 bytes payload maximum packets rate is 10 packets per second. That means that the data rate approximately is 1400 bytes per second. When I tested the BLE UART example, I watched the transmission speed about 2300 bytes per second. Regarding the information about BLE 4.2 (IoT), I expect that the data rate should rise about 2.5 times. But the real data transfer rate was much lower.
Q: How can I increase the speed of data transmission via UDP and what speed (in one direction) the maximum I can expect?
Thanks in advance.
