Error while building the openthread\coprocessor project for nrf52840_dongle
Dear Nordic Support Team,
I wanted to configure the nRF52840 dongle as radio co-processor. For that I wanted to build and flash the Thread: Co-processor sample in nRF52840 dongle. But when I tried to build the sample I am getting the following error.
Host platform: Mac OS
Zephyr version: 0.14.1
NCS Version: V2.1.0
Board: nrf52840dongle_nrf52840
-- Application: /Users/das/sdk-nrf/samples/openthread/coprocessor
-- Found Python3: /opt/nordic/ncs/toolchains/v2.1.0/bin/python3.9 (found suitable exact version "3.9.6") found components: Interpreter
-- Cache files will be written to: /Users/das/Library/Caches/zephyr
-- Zephyr version: 3.1.99 (/opt/nordic/ncs/v2.1.0/zephyr)
-- Board: nrf52840dongle_nrf52840
-- Found host-tools: zephyr 0.14.1 (/opt/nordic/ncs/toolchains/v2.1.0/opt/zephyr-sdk)
-- Found dtc: /opt/nordic/ncs/toolchains/v2.1.0/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6")
-- Found toolchain: zephyr 0.14.1 (/opt/nordic/ncs/toolchains/v2.1.0/opt/zephyr-sdk)
-- Found BOARD.dts: /opt/nordic/ncs/v2.1.0/zephyr/boards/arm/nrf52840dongle_nrf52840/nrf52840dongle_nrf52840.dts
-- Found devicetree overlay: usb.overlay
-- Generated zephyr.dts: /Users/das/sdk-nrf/samples/openthread/coprocessor/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: /Users/das/sdk-nrf/samples/openthread/coprocessor/build/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: /Users/das/sdk-nrf/samples/openthread/coprocessor/build/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: /Users/das/sdk-nrf/samples/openthread/coprocessor/build/zephyr/dts.cmake
Parsing /Users/das/sdk-nrf/samples/openthread/coprocessor/Kconfig
Loaded configuration '/opt/nordic/ncs/v2.1.0/zephyr/boards/arm/nrf52840dongle_nrf52840/nrf52840dongle_nrf52840_defconfig'
Merged configuration '/Users/das/sdk-nrf/samples/openthread/coprocessor/prj.conf'
Merged configuration '/Users/das/sdk-nrf/samples/openthread/coprocessor/overlay-usb.conf'
Configuration saved to '/Users/das/sdk-nrf/samples/openthread/coprocessor/build/zephyr/.config'
Kconfig header saved to '/Users/das/sdk-nrf/samples/openthread/coprocessor/build/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 10.3.0
-- The CXX compiler identification is GNU 10.3.0
-- Found assembler: /opt/nordic/ncs/toolchains/v2.1.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
-- OpenThread Source Directory: /opt/nordic/ncs/v2.1.0/modules/lib/openthread
-- Check if the system is big endian
-- Searching 16 bit integer
-- Looking for sys/types.h
-- Looking for sys/types.h - found
-- Looking for stdint.h
-- Looking for stdint.h - found
-- Looking for stddef.h
-- Looking for stddef.h - found
-- Check size of unsigned short
-- Check size of unsigned short - done
-- Searching 16 bit integer - Using unsigned short
-- Check if the system is big endian - little endian
-- Package Name: OPENTHREAD
-- Setting default package version: thread-reference-20200818-ncs1-rc3-764-g0d19f9112
-- Package Version: thread-reference-20200818-ncs1-rc3-764-g0d19f9112
In file included from /opt/nordic/ncs/v2.1.0/zephyr/include/zephyr/toolchain/gcc.h:88,
from /opt/nordic/ncs/v2.1.0/zephyr/include/zephyr/toolchain.h:50,
from /opt/nordic/ncs/v2.1.0/zephyr/include/zephyr/devicetree/zephyr.h:15,
from /opt/nordic/ncs/v2.1.0/zephyr/include/zephyr/devicetree.h:3101,
from /opt/nordic/ncs/v2.1.0/zephyr/modules/hal_nordic/nrfx/nrfx_config.h:10,
from /opt/nordic/ncs/v2.1.0/modules/hal/nordic/nrfx/nrfx.h:37,
from /opt/nordic/ncs/v2.1.0/modules/hal/nordic/nrfx/hal/nrf_radio.h:37,
from /opt/nordic/ncs/v2.1.0/nrfxlib/nrf_802154/driver/include/nrf_802154_types.h:44,
from /opt/nordic/ncs/v2.1.0/nrfxlib/nrf_802154/driver/include/nrf_802154.h:48,
from /Users/das/sdk-nrf/samples/openthread/coprocessor/src/nrf_802154_radio_wrapper.c:7:
/opt/nordic/ncs/v2.1.0/zephyr/include/zephyr/device.h:96:39: error: '__device_dts_ord_DT_CHOSEN_zephyr_ieee802154_ORD' undeclared here (not in a function)
96 | #define DEVICE_NAME_GET(name) _CONCAT(__device_, name)
/opt/nordic/ncs/v2.1.0/zephyr/include/zephyr/toolchain/common.h:132:26: note: in definition of macro '_DO_CONCAT'
132 | #define _DO_CONCAT(x, y) x ## y
/opt/nordic/ncs/v2.1.0/zephyr/include/zephyr/device.h:96:31: note: in expansion of macro '_CONCAT'
/opt/nordic/ncs/v2.1.0/zephyr/include/zephyr/device.h:276:37: note: in expansion of macro 'DEVICE_NAME_GET'
276 | #define DEVICE_DT_NAME_GET(node_id) DEVICE_NAME_GET(Z_DEVICE_DT_DEV_NAME(node_id))
/opt/nordic/ncs/v2.1.0/zephyr/include/zephyr/device.h:296:34: note: in expansion of macro 'DEVICE_DT_NAME_GET'
296 | #define DEVICE_DT_GET(node_id) (&DEVICE_DT_NAME_GET(node_id))
/Users/das/sdk-nrf/samples/openthread/coprocessor/src/nrf_802154_radio_wrapper.c:12:2: note: in expansion of macro 'DEVICE_DT_GET'
12 | DEVICE_DT_GET(DT_CHOSEN(zephyr_ieee802154));
Did I miss something to consider in the prj.conf in order to build for nRF52840 dongle.
  • Hello Vipin,
    First of all, how is your Zephyr version 0.14.1? I would assume that your zephyr version was 3.1.99, as that is the one that comes with NCS 2.1.0.
    Secondly, I believe this previous case might touch on your issue.
    Elfving
  • Hi Elfving,
    Thanks!!!
    You are absolutely right Zephyr version is 3.1.99. It's my mistake. I confused with toolchain version and zephyr sdk version. Toolchain version is 0.14.1.
    Actually before I post the query, I have gone through those previous post and made all the suggestions mentioned there.  I set the usb.overlay config files on CMakeLists but that also doesn't help.
    When I tried to build Thread: CLI sample it  builds fine for nRF5340 DK. That shows my nRF Connect for VS Code fine right?
    Do you have any doubts or thoughts on this.
    Regards
    Vipin Das
  • I see.
    Yeah I would think so.
    Though in order to make us a bit more sure of this, could you try building the coprocessor sample for a DK as well, eg. the nRF52840DK. And try another sample for the dongle, just to make sure there is no problem with the dts.
    What MAC version are you using btw?
    Elfving
  • Hi Elfving,
    Thanks!!!
    I already tried to built the coprocessor sample for nRF52840DK as well but the error appears the same.
    [191/424] Building C object CMakeFiles/app.dir/src/nrf_802154_radio_wrapper.c.obj
    FAILED: CMakeFiles/app.dir/src/nrf_802154_radio_wrapper.c.obj
    ccache /opt/nordic/ncs/toolchains/v2.1.2/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DKERNEL -DMBEDTLS_CONFIG_FILE=\"nrf-config.h\" -DMBEDTLS_USER_CONFIG_FILE=\"nrf-config-user.h\" -DNRF52840_XXAA -DNRF_802154_ACK_TIMEOUT_ENABLED=1 -DNRF_802154_CCA_CORR_LIMIT_DEFAULT=2 -DNRF_802154_CCA_CORR_THRESHOLD_DEFAULT=45 -DNRF_802154_CCA_ED_THRESHOLD_DEFAULT=45 -DNRF_802154_CCA_MODE_DEFAULT=NRF_RADIO_CCA_MODE_ED -DNRF_802154_ECB_PRIORITY=-1 -DNRF_802154_ENCRYPTION_ENABLED=1 -DNRF_802154_IE_WRITER_ENABLED=1 -DNRF_802154_INTERNAL_RADIO_IRQ_HANDLING=0 -DNRF_802154_PENDING_EXTENDED_ADDRESSES=16 -DNRF_802154_PENDING_SHORT_ADDRESSES=16 -DNRF_802154_RX_BUFFERS=16 -DNRF_802154_SECURITY_WRITER_ENABLED=1 -DNRF_802154_SWI_PRIORITY=1 -DNRF_802154_TX_STARTED_NOTIFY_ENABLED=1 -DNRF_802154_USE_RAW_API=1 -DUSE_PARTITION_MANAGER=0 -D_FORTIFY_SOURCE=2 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -I/opt/nordic/ncs/v2.1.2/nrf/drivers/mpsl/clock_control -I/opt/nordic/ncs/v2.1.2/zephyr/include/zephyr -I/opt/nordic/ncs/v2.1.2/zephyr/include -Izephyr/include/generated -I/opt/nordic/ncs/v2.1.2/zephyr/soc/arm/nordic_nrf/nrf52 -I/opt/nordic/ncs/v2.1.2/zephyr/lib/libc/newlib/include -I/opt/nordic/ncs/v2.1.2/zephyr/soc/arm/nordic_nrf/common/. -I/opt/nordic/ncs/v2.1.2/zephyr/subsys/usb/device -I/opt/nordic/ncs/v2.1.2/zephyr/subsys/settings/include -I/opt/nordic/ncs/v2.1.2/nrf/include -I/opt/nordic/ncs/v2.1.2/nrf/lib/multithreading_lock/. -I/opt/nordic/ncs/v2.1.2/zephyr/drivers/flash -I/opt/nordic/ncs/v2.1.2/zephyr/modules/openthread/platform/. -I/opt/nordic/ncs/v2.1.2/modules/hal/cmsis/CMSIS/Core/Include -I/opt/nordic/ncs/v2.1.2/modules/hal/nordic/nrfx -I/opt/nordic/ncs/v2.1.2/modules/hal/nordic/nrfx/drivers/include -I/opt/nordic/ncs/v2.1.2/modules/hal/nordic/nrfx/mdk -I/opt/nordic/ncs/v2.1.2/zephyr/modules/hal_nordic/nrfx/. -I/opt/nordic/ncs/v2.1.2/modules/debug/segger/SEGGER -I/opt/nordic/ncs/v2.1.2/modules/debug/segger/Config -I/opt/nordic/ncs/v2.1.2/zephyr/modules/segger/. -I/opt/nordic/ncs/v2.1.2/nrfxlib/mpsl/include -I/opt/nordic/ncs/v2.1.2/nrfxlib/mpsl/include/protocol -Imodules/openthread/build/etc/cmake -I/opt/nordic/ncs/v2.1.2/modules/lib/openthread/etc/cmake -I/opt/nordic/ncs/v2.1.2/nrfxlib/nrf_802154/driver/include -I/opt/nordic/ncs/v2.1.2/nrfxlib/nrf_802154/sl/include -Imodules/nrfxlib/nrfxlib/nrf_security/src/include/generated -I/opt/nordic/ncs/v2.1.2/nrfxlib/nrf_security/include -I/opt/nordic/ncs/v2.1.2/nrfxlib/nrf_security/include/mbedtls -I/opt/nordic/ncs/v2.1.2/nrfxlib/nrf_security/include/psa -I/opt/nordic/ncs/v2.1.2/mbedtls/include -I/opt/nordic/ncs/v2.1.2/mbedtls/include/mbedtls -I/opt/nordic/ncs/v2.1.2/mbedtls/include/psa -I/opt/nordic/ncs/v2.1.2/mbedtls/library -I/opt/nordic/ncs/v2.1.2/nrfxlib/nrf_security/../crypto/nrf_oberon/include -I/opt/nordic/ncs/v2.1.2/nrfxlib/nrf_security/../crypto/nrf_oberon/include/mbedtls -I/opt/nordic/ncs/v2.1.2/nrfxlib/nrf_security/../crypto/nrf_oberon/include/psa -I/opt/nordic/ncs/v2.1.2/nrfxlib/crypto/nrf_oberon/include/mbedtls -I/opt/nordic/ncs/v2.1.2/nrfxlib/crypto/nrf_oberon/include -isystem /opt/nordic/ncs/v2.1.2/zephyr/subsys/cpp/include -isystem /opt/nordic/ncs/v2.1.2/modules/lib/openthread/include -isystem /opt/nordic/ncs/v2.1.2/modules/lib/openthread/examples/platforms -isystem /opt/nordic/ncs/v2.1.2/nrfxlib/crypto/nrf_cc310_platform/include -Os -imacros /Users/das/sdk-nrf/samples/openthread/coprocessor/build/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfpu=fpv4-sp-d16 -mfloat-abi=hard -mfp16-format=ieee --sysroot=/opt/nordic/ncs/toolchains/v2.1.2/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros /opt/nordic/ncs/v2.1.2/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-reorder-functions -fno-defer-pop -fmacro-prefix-map=/Users/das/sdk-nrf/samples/openthread/coprocessor=CMAKE_SOURCE_DIR -fmacro-prefix-map=/opt/nordic/ncs/v2.1.2/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/opt/nordic/ncs/v2.1.2=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=nano.specs -std=c99 -MD -MT CMakeFiles/app.dir/src/nrf_802154_radio_wrapper.c.obj -MF CMakeFiles/app.dir/src/nrf_802154_radio_wrapper.c.obj.d -o CMakeFiles/app.dir/src/nrf_802154_radio_wrapper.c.obj -c ../src/nrf_802154_radio_wrapper.c
    In file included from /opt/nordic/ncs/v2.1.2/zephyr/include/zephyr/toolchain/gcc.h:88,
                     from /opt/nordic/ncs/v2.1.2/zephyr/include/zephyr/toolchain.h:50,
                     from /opt/nordic/ncs/v2.1.2/zephyr/include/zephyr/devicetree/zephyr.h:15,
                     from /opt/nordic/ncs/v2.1.2/zephyr/include/zephyr/devicetree.h:3101,
                     from /opt/nordic/ncs/v2.1.2/zephyr/modules/hal_nordic/nrfx/nrfx_config.h:10,
                     from /opt/nordic/ncs/v2.1.2/modules/hal/nordic/nrfx/nrfx.h:37,
                     from /opt/nordic/ncs/v2.1.2/modules/hal/nordic/nrfx/hal/nrf_radio.h:37,
                     from /opt/nordic/ncs/v2.1.2/nrfxlib/nrf_802154/driver/include/nrf_802154_types.h:44,
                     from /opt/nordic/ncs/v2.1.2/nrfxlib/nrf_802154/driver/include/nrf_802154.h:48,
    /opt/nordic/ncs/v2.1.2/zephyr/include/zephyr/device.h:96:39: error: '__device_dts_ord_DT_CHOSEN_zephyr_ieee802154_ORD' undeclared here (not in a function)
    /opt/nordic/ncs/v2.1.2/zephyr/include/zephyr/toolchain/common.h:132:26: note: in definition of macro '_DO_CONCAT'
    /opt/nordic/ncs/v2.1.2/zephyr/include/zephyr/device.h:96:31: note: in expansion of macro '_CONCAT'
    /opt/nordic/ncs/v2.1.2/zephyr/include/zephyr/device.h:276:37: note: in expansion of macro 'DEVICE_NAME_GET'
    /opt/nordic/ncs/v2.1.2/zephyr/include/zephyr/device.h:296:34: note: in expansion of macro 'DEVICE_DT_NAME_GET'
    I tried Thread: CLI sample for dongle and it built successfully.
    My Mac version is 12.4(macOS Monterey).
    Regards
    Vipin Das
  • Hi Elfving,
    Do you have any other alternate solutions for me to configure/setup OpenThread Border Router on nRF52840 dongle. I am really blocked because of this error.
    Finally I wanted to connect OpenThread Docker to my Thread Network(nRF5340 DK) as mentioned here.
    Please share your thoughts or any alternate solutions.
    Regards
    Vipin Das
