Thingy:91
Hello!
I am trying to connect my Thingy91 to nrfCloud, but after successfully activating the SIM card, I receive error 40412: No device found for this id. The device has not yet been provisioned.
My device was to begin with registered and could be found under “Devices” in nrfCloud. When updating it with the newest release FW, it just would not connect to the cloud, and it only said, “Please connect your device”, even though the device was on. I then deleted the device from nrfCloud, and tried to add it again, and received error 40412.
When updating the FW I followed the steps in the Getting started with Thingy:91 guide and used the newest release from Nordic Thingy:91 Downloads. After receiving the error, I did so again, in order to verify that I did it correctly the first time, but I still received the error. I repeated this process a lot of times, and still got the same result.
I noted that every time I performed the process of the guide, my device never blinked the way the guide said it should. When trying to connect LTE device to the cloud (step 5-8 in “Connecting to nRF Cloud”) , my device goes directly into blinking green three times, which according to the User Interface page indicates trying to connect to cloud. The guide says that it should blink double white for this step of the setup process, cloud association.
I also had a look at the LTE Link Monitor and noticed that the signaling connection status notification (+CSCON) switches between idle and connected mode. Could this be related to the error code?
The SIM card was successfully added, when I tried to add the device, and is listed under “SIM card” in nrfCloud. I am also located in Norway, which according to IBASIS should have national LTE-M coverage.  The thingy:91 I am using is version 1.6.0.
Am I doing something wrong here, that I am just not able to see myself? Or do you have any other suggestion as to why the device won’t connect to nrfCloud?
Thank you in advance!
Best Regards
Martha
  • Thank you for replying to the previous questions.
    Here is how to Troubleshoot nRF Code 40412.
    Could you please verify that you entered the PIN and HWID correclty? Did you prepend 'nrf-' to the IMEI?
    MInv said:
    Let me know if you need more of the log.
    Yes, the rest of the low would be interesting.
    Could it be that there's network related errors in your connection? Could you try using at_client, in combination with the LTE Link Monitor PC application? This automatically enables network related error/cause codes to be printed if any appear.
    Issue these commands from the PC application:
    AT+CEREG=5
    AT+CFUN=1
    AT+CFUN?
    And please post the log from letting this run for some time.
  • Yes, I have verified that both the IMEI and PIN were entered correctly, and yes, I also typed "nrf-" prior to the IMEI number when trying to add the LTE device.
    Here is the longer version of the log, when using the commands you specify. I have removed some parts, referring to the IMEI number etc. of my device. Hope that is okay.
    2022-11-21T07:59:10.280Z DEBUG modem >> AT+CFUN?
    2022-11-21T07:59:10.288Z DEBUG modem << +CFUN: 1
    2022-11-21T07:59:10.297Z DEBUG modem << OK
    2022-11-21T07:59:10.317Z DEBUG modem >> AT+CGSN=1
    2022-11-21T07:59:10.326Z DEBUG modem << +CGSN:
    2022-11-21T07:59:10.329Z DEBUG modem << OK
    2022-11-21T07:59:10.332Z DEBUG modem >> AT+CGMI
    2022-11-21T07:59:10.340Z DEBUG modem << Nordic Semiconductor ASA
    2022-11-21T07:59:10.343Z DEBUG modem << OK
    2022-11-21T07:59:10.348Z DEBUG modem >> AT+CGMM
    2022-11-21T07:59:10.354Z DEBUG modem << nRF9160-SICA
    2022-11-21T07:59:10.356Z DEBUG modem << OK
    2022-11-21T07:59:10.358Z DEBUG modem >> AT+CGMR
    2022-11-21T07:59:10.365Z DEBUG modem << mfw_nrf9160_1.3.2
    2022-11-21T07:59:10.366Z DEBUG modem << OK
    2022-11-21T07:59:10.367Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.3.2] SerNr:
    2022-11-21T07:59:10.368Z DEBUG modem >> AT+CEMODE?
    2022-11-21T07:59:10.376Z DEBUG modem << +CEMODE: 2
    2022-11-21T07:59:10.378Z DEBUG modem << OK
    2022-11-21T07:59:10.384Z DEBUG modem >> AT%XCBAND=?
    2022-11-21T07:59:10.394Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,18,19,20,25,26,28,66)
    2022-11-21T07:59:10.395Z DEBUG modem << OK
    2022-11-21T07:59:10.401Z DEBUG modem >> AT+CMEE?
    2022-11-21T07:59:10.407Z DEBUG modem << +CMEE: 0
    2022-11-21T07:59:10.408Z DEBUG modem << OK
    2022-11-21T07:59:10.410Z DEBUG modem >> AT+CMEE=1
    2022-11-21T07:59:10.415Z DEBUG modem << OK
    2022-11-21T07:59:10.418Z DEBUG modem >> AT+CNEC?
    2022-11-21T07:59:10.423Z DEBUG modem << +CNEC: 16
    2022-11-21T07:59:10.426Z DEBUG modem << OK
    2022-11-21T07:59:10.429Z DEBUG modem >> AT+CNEC=24
    2022-11-21T07:59:10.434Z DEBUG modem << OK
    2022-11-21T07:59:10.436Z DEBUG modem >> AT+CGEREP?
    2022-11-21T07:59:10.442Z DEBUG modem << +CGEREP: 1,0
    2022-11-21T07:59:10.444Z DEBUG modem << OK
    2022-11-21T07:59:10.447Z DEBUG modem >> AT+CIND=1,1,1
    2022-11-21T07:59:10.453Z DEBUG modem << OK
    2022-11-21T07:59:10.456Z DEBUG modem >> AT+CEREG=5
    2022-11-21T07:59:10.461Z DEBUG modem << OK
    2022-11-21T07:59:10.464Z DEBUG modem >> AT+CEREG?
    2022-11-21T07:59:10.472Z DEBUG modem << +CEREG: 5,2,"09CC","0210E116",7
    2022-11-21T07:59:10.474Z DEBUG modem << OK
    2022-11-21T07:59:10.480Z DEBUG modem >> AT%CESQ=1
    2022-11-21T07:59:10.484Z DEBUG modem << OK
    2022-11-21T07:59:10.489Z DEBUG modem >> AT+CESQ
    2022-11-21T07:59:10.497Z DEBUG modem << +CESQ: 99,99,255,255,25,53
    2022-11-21T07:59:10.498Z DEBUG modem << OK
    2022-11-21T07:59:10.507Z DEBUG modem >> AT%XSIM=1
    2022-11-21T07:59:10.512Z DEBUG modem << OK
    2022-11-21T07:59:10.514Z DEBUG modem >> AT%XSIM?
    2022-11-21T07:59:10.521Z DEBUG modem << %XSIM: 1
    2022-11-21T07:59:10.523Z DEBUG modem << OK
    2022-11-21T07:59:10.529Z DEBUG modem >> AT+CPIN?
    2022-11-21T07:59:10.535Z DEBUG modem << +CPIN: READY
    2022-11-21T07:59:10.537Z DEBUG modem << OK
    2022-11-21T07:59:10.543Z DEBUG modem >> AT+CPINR="SIM PIN"
    2022-11-21T07:59:10.557Z DEBUG modem << +CPINR: "SIM PIN",3
    2022-11-21T07:59:10.558Z DEBUG modem << OK
    2022-11-21T07:59:10.562Z DEBUG modem >> AT+CIMI
    2022-11-21T07:59:10.569Z DEBUG modem <<
    2022-11-21T07:59:10.570Z DEBUG modem << OK
    2022-11-21T07:59:10.571Z INFO IMSIdentity:
    2022-11-21T07:59:11.477Z DEBUG modem << +CGEV: ME PDN ACT 0,0
    2022-11-21T07:59:11.482Z DEBUG modem << +CNEC_ESM: 50,0
    2022-11-21T07:59:11.486Z DEBUG modem << %MDMEV: SEARCH STATUS 2
    2022-11-21T07:59:11.486Z DEBUG modem << +CEREG: 5,"09CC","0210E116",7,,,"11100000","11100000"
    2022-11-21T07:59:11.492Z DEBUG modem >> AT+CGDCONT?
    2022-11-21T07:59:11.493Z DEBUG modem << +CIND: "service",1
    2022-11-21T07:59:11.494Z DEBUG modem << +CIND: "roam",1
    2022-11-21T07:59:11.495Z DEBUG modem << %XTIME: "40","22111270952140","00"
    2022-11-21T07:59:11.502Z DEBUG modem << +CGDCONT: 0,"IP","ibasis.iot","",0,0
    2022-11-21T07:59:11.504Z DEBUG modem << OK
    2022-11-21T07:59:11.512Z DEBUG modem >> AT+COPS=3,2
    2022-11-21T07:59:11.517Z DEBUG modem << OK
    2022-11-21T07:59:11.521Z DEBUG modem >> AT+CGACT?
    2022-11-21T07:59:11.528Z DEBUG modem << +CGACT: 0,1
    2022-11-21T07:59:11.529Z DEBUG modem << OK
    2022-11-21T07:59:11.532Z DEBUG modem >> AT+COPS?
    2022-11-21T07:59:11.540Z DEBUG modem << +COPS: 0,2,"24202",7
    2022-11-21T07:59:11.542Z DEBUG modem << OK
    2022-11-21T07:59:11.546Z DEBUG modem >> AT%XCBAND
    2022-11-21T07:59:11.552Z DEBUG modem << %XCBAND: 20
    2022-11-21T07:59:11.553Z DEBUG modem << OK
    2022-11-21T07:59:11.559Z DEBUG modem >> AT+CGDCONT?
    2022-11-21T07:59:11.569Z DEBUG modem << +CGDCONT: 0,"IP","ibasis.iot","",0,0
    2022-11-21T07:59:11.570Z DEBUG modem << OK
    2022-11-21T07:59:11.576Z DEBUG modem >> AT+CGACT?
    2022-11-21T07:59:11.582Z DEBUG modem << +CGACT: 0,1
    2022-11-21T07:59:11.583Z DEBUG modem << OK
    2022-11-21T07:59:12.524Z DEBUG modem << [00:00:05.210,052] [1;33m<wrn> modem_module: Event: PDP context 0, PDN type IPv4 only allowed[0m
    2022-11-21T07:59:12.525Z DEBUG modem << [00:00:05.221,771] [0m<inf> app_event_manager: MODEM_EVT_LTE_CONNECTED[0m
    2022-11-21T07:59:12.526Z DEBUG modem << [00:00:05.222,351] [0m<inf> app_event_manager: MODEM_EVT_LTE_PSM_UPDATE[0m
    2022-11-21T07:59:12.527Z DEBUG modem << [00:00:05.223,388] [1;33m<wrn> cloud_module: Cloud connection establishment in progress[0m
    2022-11-21T07:59:12.527Z DEBUG modem << [00:00:05.223,388] [1;33m<wrn> cloud_module: New connection attempt in 32 seconds if not successful[0m
    2022-11-21T07:59:12.528Z DEBUG modem << [00:00:05.223,541] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2022-11-21T07:59:12.528Z DEBUG modem << [00:00:05.229,736] [0m<inf> app_event_manager: DATA_EVT_DATE_TIME_OBTAINED[0m
    2022-11-21T07:59:18.728Z DEBUG modem << +CSCON: 0
    2022-11-21T07:59:19.067Z DEBUG modem << +CSCON: 1
    2022-11-21T07:59:26.162Z DEBUG modem << +CSCON: 0
    2022-11-21T07:59:26.537Z DEBUG modem << +CSCON: 1
    2022-11-21T07:59:33.913Z DEBUG modem << +CSCON: 0
    2022-11-21T07:59:34.068Z DEBUG modem << +CSCON: 1
    2022-11-21T07:59:41.449Z DEBUG modem << +CSCON: 0
    2022-11-21T07:59:42.493Z DEBUG modem << [00:00:35.227,416] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2022-11-21T07:59:43.608Z DEBUG modem << +CSCON: 1
    2022-11-21T07:59:44.514Z DEBUG modem << [00:00:37.223,571] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTION_TIMEOUT[0m
    2022-11-21T07:59:44.515Z DEBUG modem << [00:00:37.224,121] [1;33m<wrn> cloud_module: Cloud connection establishment in progress[0m
    2022-11-21T07:59:44.516Z DEBUG modem << [00:00:37.224,151] [1;33m<wrn> cloud_module: New connection attempt in 64 seconds if not successful[0m
    2022-11-21T07:59:44.518Z DEBUG modem << [00:00:37.224,304] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2022-11-21T07:59:50.969Z DEBUG modem << +CSCON: 0
    2022-11-21T07:59:51.107Z DEBUG modem << +CSCON: 1
    2022-11-21T07:59:51.312Z DEBUG modem << %CESQ: 55,2,16,2
    2022-11-21T07:59:52.354Z DEBUG modem << %CESQ: 55,2,21,3
    2022-11-21T07:59:54.374Z DEBUG modem >> AT+CEREG=5
    2022-11-21T07:59:54.387Z DEBUG modem << OK
    2022-11-21T07:59:58.409Z DEBUG modem << +CSCON: 0
    2022-11-21T07:59:58.547Z DEBUG modem << +CSCON: 1
    2022-11-21T08:00:05.650Z DEBUG modem << +CSCON: 0
    2022-11-21T08:00:06.087Z DEBUG modem << +CSCON: 1
    2022-11-21T08:00:08.515Z DEBUG modem << %CESQ: 56,2,26,3
    2022-11-21T08:00:09.530Z DEBUG modem >> AT+CFUN=1
    2022-11-21T08:00:09.543Z DEBUG modem << OK
    2022-11-21T08:00:13.296Z DEBUG modem << +CSCON: 0
    2022-11-21T08:00:13.872Z DEBUG modem << %CESQ: 56,2,21,3
    2022-11-21T08:00:14.510Z DEBUG modem << [00:01:07.238,616] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2022-11-21T08:00:18.031Z DEBUG modem >> AT+CFUN?
    2022-11-21T08:00:18.047Z DEBUG modem << +CFUN: 1
    2022-11-21T08:00:18.050Z DEBUG modem << OK
    2022-11-21T08:00:18.053Z DEBUG modem >> AT+CGSN=1
    2022-11-21T08:00:18.069Z DEBUG modem << +CGSN:
    2022-11-21T08:00:18.071Z DEBUG modem << OK
    2022-11-21T08:00:18.073Z DEBUG modem >> AT+CGMI
    2022-11-21T08:00:18.086Z DEBUG modem << Nordic Semiconductor ASA
    2022-11-21T08:00:18.087Z DEBUG modem << OK
    2022-11-21T08:00:18.091Z DEBUG modem >> AT+CGMM
    2022-11-21T08:00:18.103Z DEBUG modem << nRF9160-SICA
    2022-11-21T08:00:18.104Z DEBUG modem << OK
    2022-11-21T08:00:18.107Z DEBUG modem >> AT+CGMR
    2022-11-21T08:00:18.116Z DEBUG modem << mfw_nrf9160_1.3.2
    2022-11-21T08:00:18.116Z DEBUG modem << OK
    2022-11-21T08:00:18.117Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.3.2] SerNr:
    2022-11-21T08:00:18.120Z DEBUG modem >> AT+CEMODE?
    2022-11-21T08:00:18.125Z DEBUG modem << +CEMODE: 2
    2022-11-21T08:00:18.128Z DEBUG modem << OK
    2022-11-21T08:00:18.131Z DEBUG modem >> AT%XCBAND=?
    2022-11-21T08:00:18.147Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,18,19,20,25,26,28,66)
    2022-11-21T08:00:18.148Z DEBUG modem << OK
    2022-11-21T08:00:18.154Z DEBUG modem >> AT+CMEE?
    2022-11-21T08:00:18.169Z DEBUG modem << +CMEE: 1
    2022-11-21T08:00:18.171Z DEBUG modem << OK
    2022-11-21T08:00:18.173Z DEBUG modem >> AT+CNEC?
    2022-11-21T08:00:18.179Z DEBUG modem << +CNEC: 24
    2022-11-21T08:00:18.181Z DEBUG modem << OK
    2022-11-21T08:00:18.183Z DEBUG modem >> AT+CGEREP?
    2022-11-21T08:00:18.190Z DEBUG modem << +CGEREP: 1,0
    2022-11-21T08:00:18.191Z DEBUG modem << OK
    2022-11-21T08:00:18.194Z DEBUG modem >> AT+CIND=1,1,1
    2022-11-21T08:00:18.198Z DEBUG modem << OK
    2022-11-21T08:00:18.202Z DEBUG modem >> AT+CEREG=5
    2022-11-21T08:00:18.209Z DEBUG modem << OK
    2022-11-21T08:00:18.213Z DEBUG modem >> AT+CEREG?
    2022-11-21T08:00:18.224Z DEBUG modem << +CEREG: 5,5,"09CC","0210E116",7,,,"11100000","11100000"
    2022-11-21T08:00:18.226Z DEBUG modem << OK
    2022-11-21T08:00:18.230Z DEBUG modem >> AT+COPS=3,2
    2022-11-21T08:00:18.239Z DEBUG modem << OK
    2022-11-21T08:00:18.242Z DEBUG modem >> AT+COPS?
    2022-11-21T08:00:18.252Z DEBUG modem << +COPS: 0,2,"24202",7
    2022-11-21T08:00:18.254Z DEBUG modem << OK
    2022-11-21T08:00:18.259Z DEBUG modem >> AT%XCBAND
    2022-11-21T08:00:18.271Z DEBUG modem << %XCBAND: 20
    2022-11-21T08:00:18.272Z DEBUG modem << OK
    2022-11-21T08:00:18.276Z DEBUG modem >> AT+CGDCONT?
    2022-11-21T08:00:18.291Z DEBUG modem << +CGDCONT: 0,"IP","ibasis.iot","",0,0
    2022-11-21T08:00:18.293Z DEBUG modem << OK
    2022-11-21T08:00:18.298Z DEBUG modem >> AT+CGACT?
    2022-11-21T08:00:18.303Z DEBUG modem << +CGACT: 0,1
    2022-11-21T08:00:18.304Z DEBUG modem << OK
    2022-11-21T08:00:18.308Z DEBUG modem >> AT%CESQ=1
    2022-11-21T08:00:18.312Z DEBUG modem << OK
    2022-11-21T08:00:18.314Z DEBUG modem >> AT+CESQ
    2022-11-21T08:00:18.322Z DEBUG modem << +CESQ: 99,99,255,255,23,56
    2022-11-21T08:00:18.324Z DEBUG modem << OK
    2022-11-21T08:00:18.326Z DEBUG modem >> AT%XSIM=1
    2022-11-21T08:00:18.331Z DEBUG modem << OK
    2022-11-21T08:00:18.333Z DEBUG modem >> AT%XSIM?
    2022-11-21T08:00:18.338Z DEBUG modem << %XSIM: 1
    2022-11-21T08:00:18.340Z DEBUG modem << OK
    2022-11-21T08:00:18.343Z DEBUG modem >> AT+CPIN?
    2022-11-21T08:00:18.349Z DEBUG modem << +CPIN: READY
    2022-11-21T08:00:18.350Z DEBUG modem << OK
    2022-11-21T08:00:18.357Z DEBUG modem >> AT+CPINR="SIM PIN"
    2022-11-21T08:00:18.377Z DEBUG modem << +CPINR: "SIM PIN",3
    2022-11-21T08:00:18.378Z DEBUG modem << OK
    2022-11-21T08:00:18.381Z DEBUG modem >> AT+CIMI
    2022-11-21T08:00:18.387Z DEBUG modem <<
    2022-11-21T08:00:18.388Z DEBUG modem << OK
    2022-11-21T08:00:18.389Z INFO IMSIdentity:
    2022-11-21T08:00:47.585Z DEBUG modem << +CSCON: 1
    2022-11-21T08:00:48.520Z DEBUG modem << [00:01:41.224,304] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTION_TIMEOUT[0m
    2022-11-21T08:00:48.523Z DEBUG modem << [00:01:41.224,853] [1;33m<wrn> cloud_module: Cloud connection establishment in progress[0m
    2022-11-21T08:00:48.525Z DEBUG modem << [00:01:41.224,884] [1;33m<wrn> cloud_module: New connection attempt in 128 seconds if not successful[0m
    2022-11-21T08:00:48.527Z DEBUG modem << [00:01:41.225,036] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2022-11-21T08:00:54.742Z DEBUG modem << +CSCON: 0
    2022-11-21T08:00:55.085Z DEBUG modem << +CSCON: 1
    2022-11-21T08:01:02.416Z DEBUG modem << +CSCON: 0
    2022-11-21T08:01:02.554Z DEBUG modem << +CSCON: 1
    2022-11-21T08:01:08.442Z DEBUG modem << %CESQ: 51,2,25,3
    2022-11-21T08:01:09.696Z DEBUG modem << +CSCON: 0
    2022-11-21T08:01:09.784Z DEBUG modem << %CESQ: 56,2,24,3
    2022-11-21T08:01:09.835Z DEBUG modem << [00:02:02.523,498] [0m<inf> app_event_manager: APP_EVT_DATA_GET_ALL[0m
    2022-11-21T08:01:09.837Z DEBUG modem << [00:02:02.524,169] [0m<inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, MOD_STAT, NEIGHBOR_CELLS)[0m
    2022-11-21T08:01:09.838Z DEBUG modem << [00:02:02.525,115] [0m<inf> app_event_manager: SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
    2022-11-21T08:01:09.838Z DEBUG modem << [00:02:02.568,298] [0m<inf> app_event_manager: MODEM_EVT_MODEM_STATIC_DATA_READY[0m
    2022-11-21T08:01:09.839Z DEBUG modem << [00:02:02.616,699] [0m<inf> app_event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_READY[0m
    2022-11-21T08:01:09.839Z DEBUG modem << [00:02:02.669,830] [0m<inf> app_event_manager: MODEM_EVT_BATTERY_DATA_READY[0m
    2022-11-21T08:01:10.865Z DEBUG modem << %NCELLMEAS: 0,"0210E116","24202","09CC",33,6300,56,57,28,124106,1650,52,43,18,23,100,52,48,20,31,121804
    2022-11-21T08:01:10.932Z DEBUG modem << +CSCON: 1
    2022-11-21T08:01:11.880Z DEBUG modem << [00:02:04.596,466] [0m<inf> app_event_manager: MODEM_EVT_NEIGHBOR_CELLS_DATA_READY[0m
    2022-11-21T08:01:11.882Z DEBUG modem << [00:02:04.597,229] [0m<inf> app_event_manager: DATA_EVT_DATA_READY[0m
    2022-11-21T08:01:17.207Z DEBUG modem << +CSCON: 0
    2022-11-21T08:01:18.514Z DEBUG modem << [00:02:11.238,372] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2022-11-21T08:01:46.679Z DEBUG modem << %CESQ: 54,2,19,2
    2022-11-21T08:01:51.159Z DEBUG modem << %CESQ: 54,2,24,3
    2022-11-21T08:02:27.008Z DEBUG modem << %CESQ: 59,2,24,3
    2022-11-21T08:02:32.125Z DEBUG modem << %CESQ: 54,2,20,2
    2022-11-21T08:02:46.208Z DEBUG modem << %CESQ: 49,2,21,3
    2022-11-21T08:02:55.601Z DEBUG modem << +CSCON: 1
    2022-11-21T08:02:56.531Z DEBUG modem << [00:03:49.225,036] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTION_TIMEOUT[0m
    2022-11-21T08:02:56.533Z DEBUG modem << [00:03:49.225,585] [1;33m<wrn> cloud_module: Cloud connection establishment in progress[0m
    2022-11-21T08:02:56.533Z DEBUG modem << [00:03:49.225,616] [1;33m<wrn> cloud_module: New connection attempt in 256 seconds if not successful[0m
    2022-11-21T08:02:56.534Z DEBUG modem << [00:03:49.225,769] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2022-11-21T08:03:02.833Z DEBUG modem << +CSCON: 0
    2022-11-21T08:03:03.102Z DEBUG modem << +CSCON: 1
    2022-11-21T08:03:08.873Z DEBUG modem << %NCELLMEAS: 0,"0210E116","24202","09CC",32,6300,56,50,23,242106,6300,352,40,4,0,6300,42,36,-2,0,240218
    2022-11-21T08:03:09.853Z DEBUG modem << [00:04:02.523,498] [0m<inf> app_event_manager: APP_EVT_DATA_GET_ALL[0m
    2022-11-21T08:03:09.856Z DEBUG modem << [00:04:02.524,291] [0m<inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, NEIGHBOR_CELLS)[0m
    2022-11-21T08:03:09.859Z DEBUG modem << [00:04:02.525,238] [0m<inf> app_event_manager: SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
    2022-11-21T08:03:09.861Z DEBUG modem << [00:04:02.555,328] [0m<inf> app_event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_READY[0m
    2022-11-21T08:03:09.863Z DEBUG modem << [00:04:02.588,012] [0m<inf> app_event_manager: MODEM_EVT_BATTERY_DATA_READY[0m
    2022-11-21T08:03:09.865Z DEBUG modem << [00:04:02.600,067] [0m<inf> app_event_manager: MODEM_EVT_NEIGHBOR_CELLS_DATA_READY[0m
    2022-11-21T08:03:09.869Z DEBUG modem << [00:04:02.600,799] [0m<inf> app_event_manager: DATA_EVT_DATA_READY[0m
    2022-11-21T08:03:10.416Z DEBUG modem << +CSCON: 0
    2022-11-21T08:03:10.571Z DEBUG modem << +CSCON: 1
    2022-11-21T08:03:17.713Z DEBUG modem << +CSCON: 0
    2022-11-21T08:03:17.801Z DEBUG modem << %CESQ: 59,2,24,3
    2022-11-21T08:03:18.100Z DEBUG modem << +CSCON: 1
    2022-11-21T08:03:19.003Z DEBUG modem << %CESQ: 53,2,24,3
    2022-11-21T08:03:19.844Z DEBUG modem << %CESQ: 48,2,23,3
    2022-11-21T08:03:25.377Z DEBUG modem << +CSCON: 0
    2022-11-21T08:03:25.481Z DEBUG modem << %CESQ: 42,2,18,2
    2022-11-21T08:03:26.518Z DEBUG modem << [00:04:19.238,616] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2022-11-21T08:03:27.809Z DEBUG modem << %CESQ: 47,2,20,2
    2022-11-21T08:05:09.603Z DEBUG modem << %NCELLMEAS: 0,"0210E116","24202","09CC",32,6300,56,55,29,362826,6300,352,38,-5,0,6300,42,36,-9,0,1650,52,41,14,24,100,52,49,21,32,257484
    2022-11-21T08:05:09.874Z DEBUG modem << [00:06:02.523,498] [0m<inf> app_event_manager: APP_EVT_DATA_GET_ALL[0m
    2022-11-21T08:05:09.877Z DEBUG modem << [00:06:02.524,169] [0m<inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, NEIGHBOR_CELLS, GNSS)[0m
    2022-11-21T08:05:09.880Z DEBUG modem << [00:06:02.537,811] [0m<inf> app_event_manager: GNSS_EVT_ACTIVE[0m
    2022-11-21T08:05:09.881Z DEBUG modem << [00:06:02.538,299] [0m<inf> app_event_manager: GNSS_EVT_AGPS_NEEDED[0m
    2022-11-21T08:05:09.882Z DEBUG modem << [00:06:02.538,970] [0m<inf> app_event_manager: SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
    2022-11-21T08:05:09.883Z DEBUG modem << [00:06:02.539,367] [1;33m<wrn> data_module: Failed to request A-GPS data, error: -13[0m
    2022-11-21T08:05:09.884Z DEBUG modem << [00:06:02.539,367] [1;33m<wrn> data_module: This is expected to fail if we are not in a connected state[0m
    2022-11-21T08:05:09.884Z DEBUG modem << [00:06:02.592,102] [0m<inf> app_event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_READY[0m
    2022-11-21T08:05:09.885Z DEBUG modem << [00:06:02.628,601] [0m<inf> app_event_manager: MODEM_EVT_BATTERY_DATA_READY[0m
    2022-11-21T08:05:09.886Z DEBUG modem << [00:06:03.334,045] [0m<inf> app_event_manager: MODEM_EVT_NEIGHBOR_CELLS_DATA_READY[0m
    2022-11-21T08:05:46.341Z DEBUG modem << [00:06:39.053,283] [0m<inf> app_event_manager: GNSS_EVT_TIMEOUT[0m
    2022-11-21T08:05:46.343Z DEBUG modem << [00:06:39.053,741] [0m<inf> app_event_manager: GNSS_EVT_INACTIVE[0m
    2022-11-21T08:05:46.344Z DEBUG modem << [00:06:39.054,229] [0m<inf> app_event_manager: DATA_EVT_DATA_READY[0m
    2022-11-21T08:07:09.280Z DEBUG modem << %NCELLMEAS: 0,"0210E116","24202","09CC",32,6300,56,56,28,482506,6300,352,37,-11,0,6300,42,36,-13,0,1650,52,46,24,24,100,52,48,25,32,257484
    2022-11-21T08:07:09.845Z DEBUG modem << [00:08:02.523,498] [0m<inf> app_event_manager: APP_EVT_DATA_GET_ALL[0m
    2022-11-21T08:07:09.846Z DEBUG modem << [00:08:02.524,169] [0m<inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, NEIGHBOR_CELLS, GNSS)[0m
    2022-11-21T08:07:09.847Z DEBUG modem << [00:08:02.536,346] [0m<inf> app_event_manager: GNSS_EVT_ACTIVE[0m
    2022-11-21T08:07:09.848Z DEBUG modem << [00:08:02.536,987] [0m<inf> app_event_manager: SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
    2022-11-21T08:07:09.848Z DEBUG modem << [00:08:02.569,091] [0m<inf> app_event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
    2022-11-21T08:07:09.849Z DEBUG modem << [00:08:02.599,426] [0m<inf> app_event_manager: MODEM_EVT_BATTERY_DATA_READY[0m
    2022-11-21T08:07:09.849Z DEBUG modem << [00:08:03.015,686] [0m<inf> app_event_manager: MODEM_EVT_NEIGHBOR_CELLS_DATA_READY[0m
    2022-11-21T08:07:11.563Z DEBUG modem << +CSCON: 1
    2022-11-21T08:07:12.523Z DEBUG modem << [00:08:05.225,769] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTION_TIMEOUT[0m
    2022-11-21T08:07:12.524Z DEBUG modem << [00:08:05.226,318] [1;33m<wrn> cloud_module: Cloud connection establishment in progress[0m
    2022-11-21T08:07:12.526Z DEBUG modem << [00:08:05.226,348] [1;33m<wrn> cloud_module: New connection attempt in 512 seconds if not successful[0m
    2022-11-21T08:07:12.527Z DEBUG modem << [00:08:05.226,501] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2022-11-21T08:07:18.817Z DEBUG modem << +CSCON: 0
    2022-11-21T08:07:31.003Z DEBUG modem << %CESQ: 49,2,15,2
    2022-11-21T08:07:31.053Z DEBUG modem << +CSCON: 1
    2022-11-21T08:07:31.058Z DEBUG modem << %CESQ: 50,2,20,2
    2022-11-21T08:07:37.465Z DEBUG modem << +CSCON: 0
    2022-11-21T08:07:42.503Z DEBUG modem << [00:08:35.232,055] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2022-11-21T08:07:49.693Z DEBUG modem << +CSCON: 1
    2022-11-21T08:07:55.305Z DEBUG modem << +CSCON: 0
    2022-11-21T08:08:00.030Z DEBUG modem << [00:08:52.754,882] [0m<inf> app_event_manager: GNSS_EVT_TIMEOUT[0m
    2022-11-21T08:08:00.038Z DEBUG modem << [00:08:52.755,340] [0m<inf> app_event_manager: GNSS_EVT_INACTIVE[0m
    2022-11-21T08:08:00.039Z DEBUG modem << [00:08:52.755,828] [0m<inf> app_event_manager: DATA_EVT_DATA_READY[0m
    2022-11-21T08:09:09.601Z DEBUG modem << %NCELLMEAS: 0,"0210E116","24202","09CC",33,6300,56,57,28,602826,6300,55,46,7,0,6300,54,45,4,0,1650,52,52,21,24,100,52,46,24,33,527404
    2022-11-21T08:09:09.840Z DEBUG modem << [00:10:02.523,498] [0m<inf> app_event_manager: APP_EVT_DATA_GET_ALL[0m
    2022-11-21T08:09:09.841Z DEBUG modem << [00:10:02.524,169] [0m<inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, NEIGHBOR_CELLS, GNSS)[0m
    2022-11-21T08:09:09.842Z DEBUG modem << [00:10:02.536,346] [0m<inf> app_event_manager: GNSS_EVT_ACTIVE[0m
    2022-11-21T08:09:09.843Z DEBUG modem << [00:10:02.536,987] [0m<inf> app_event_manager: SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
    2022-11-21T08:09:09.843Z DEBUG modem << [00:10:02.590,240] [0m<inf> app_event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_READY[0m
    2022-11-21T08:09:09.844Z DEBUG modem << [00:10:02.632,415] [0m<inf> app_event_manager: MODEM_EVT_BATTERY_DATA_READY[0m
    2022-11-21T08:09:09.844Z DEBUG modem << [00:10:03.340,850] [0m<inf> app_event_manager: MODEM_EVT_NEIGHBOR_CELLS_DATA_READY[0m
    2022-11-21T08:09:43.137Z DEBUG modem << [00:10:35.858,276] [0m<inf> app_event_manager: GNSS_EVT_TIMEOUT[0m
    2022-11-21T08:09:43.139Z DEBUG modem << [00:10:35.858,734] [0m<inf> app_event_manager: GNSS_EVT_INACTIVE[0m
    2022-11-21T08:09:43.139Z DEBUG modem << [00:10:35.859,222] [0m<inf> app_event_manager: DATA_EVT_DATA_READY[0m
    2022-11-21T08:09:51.170Z DEBUG modem << %CESQ: 56,2,24,3
    2022-11-21T08:10:14.210Z DEBUG modem << %CESQ: 51,2,21,3
    2022-11-21T08:11:09.282Z DEBUG modem << %NCELLMEAS: 0,"0210E116","24202","09CC",33,6300,56,56,29,722506,6300,54,43,2,0,6300,55,39,-7,0,1650,52,42,18,24,100,52,47,26,33,527404
    2022-11-21T08:11:09.836Z DEBUG modem << [00:12:02.523,498] [0m<inf> app_event_manager: APP_EVT_DATA_GET_ALL[0m
    2022-11-21T08:11:09.838Z DEBUG modem << [00:12:02.524,169] [0m<inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, NEIGHBOR_CELLS, GNSS)[0m
    2022-11-21T08:11:09.838Z DEBUG modem << [00:12:02.536,437] [0m<inf> app_event_manager: GNSS_EVT_ACTIVE[0m
    2022-11-21T08:11:09.840Z DEBUG modem << [00:12:02.537,078] [0m<inf> app_event_manager: SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
    2022-11-21T08:11:09.840Z DEBUG modem << [00:12:02.569,030] [0m<inf> app_event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_READY[0m
    2022-11-21T08:11:09.841Z DEBUG modem << [00:12:02.599,334] [0m<inf> app_event_manager: MODEM_EVT_BATTERY_DATA_READY[0m
    2022-11-21T08:11:09.842Z DEBUG modem << [00:12:03.025,634] [0m<inf> app_event_manager: MODEM_EVT_NEIGHBOR_CELLS_DATA_READY[0m
    2022-11-21T08:11:44.036Z DEBUG modem << [00:12:36.761,138] [0m<inf> app_event_manager: GNSS_EVT_TIMEOUT[0m
    2022-11-21T08:11:44.038Z DEBUG modem << [00:12:36.761,596] [0m<inf> app_event_manager: GNSS_EVT_INACTIVE[0m
    2022-11-21T08:11:44.039Z DEBUG modem << [00:12:36.762,054] [0m<inf> app_event_manager: DATA_EVT_DATA_READY[0m
    2022-11-21T08:12:43.971Z DEBUG modem << %CESQ: 56,2,24,3
    2022-11-21T08:12:47.171Z DEBUG modem << %CESQ: 50,2,19,2
    2022-11-21T08:13:09.602Z DEBUG modem << %NCELLMEAS: 0,"0210E116","24202","09CC",33,6300,56,49,21,842826,6300,54,47,16,0,6300,55,39,1,0,1650,52,43,15,24,100,52,52,26,32,527404
    2022-11-21T08:13:09.832Z DEBUG modem << [00:14:02.523,498] [0m<inf> app_event_manager: APP_EVT_DATA_GET_ALL[0m
    2022-11-21T08:13:09.837Z DEBUG modem << [00:14:02.524,169] [0m<inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, NEIGHBOR_CELLS, GNSS)[0m
    2022-11-21T08:13:09.837Z DEBUG modem << [00:14:02.536,376] [0m<inf> app_event_manager: GNSS_EVT_ACTIVE[0m
    2022-11-21T08:13:09.838Z DEBUG modem << [00:14:02.537,017] [0m<inf> app_event_manager: SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
    2022-11-21T08:13:09.839Z DEBUG modem << [00:14:02.590,332] [0m<inf> app_event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_READY[0m
    2022-11-21T08:13:09.839Z DEBUG modem << [00:14:02.632,659] [0m<inf> app_event_manager: MODEM_EVT_BATTERY_DATA_READY[0m
    2022-11-21T08:13:09.840Z DEBUG modem << [00:14:03.350,219] [0m<inf> app_event_manager: MODEM_EVT_NEIGHBOR_CELLS_DATA_READY[0m
    2022-11-21T08:13:43.138Z DEBUG modem << [00:14:35.868,164] [0m<inf> app_event_manager: GNSS_EVT_TIMEOUT[0m
    2022-11-21T08:13:43.140Z DEBUG modem << [00:14:35.868,652] [0m<inf> app_event_manager: GNSS_EVT_INACTIVE[0m
    2022-11-21T08:13:43.140Z DEBUG modem << [00:14:35.869,110] [0m<inf> app_event_manager: DATA_EVT_DATA_READY[0m
    2022-11-21T08:15:09.280Z DEBUG modem << %NCELLMEAS: 0,"0210E116","24202","09CC",33,6300,56,53,25,962506,6300,54,46,11,0,6300,55,43,6,0,1650,52,53,27,24,100,52,45,19,32,527404
    2022-11-21T08:15:09.825Z DEBUG modem << [00:16:02.523,498] [0m<inf> app_event_manager: APP_EVT_DATA_GET_ALL[0m
    2022-11-21T08:15:09.828Z DEBUG modem << [00:16:02.524,169] [0m<inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, NEIGHBOR_CELLS, GNSS)[0m
    2022-11-21T08:15:09.830Z DEBUG modem << [00:16:02.536,346] [0m<inf> app_event_manager: GNSS_EVT_ACTIVE[0m
    2022-11-21T08:15:09.831Z DEBUG modem << [00:16:02.536,987] [0m<inf> app_event_manager: SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
    2022-11-21T08:15:09.832Z DEBUG modem << [00:16:02.568,908] [0m<inf> app_event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
    2022-11-21T08:15:09.833Z DEBUG modem << [00:16:02.599,243] [0m<inf> app_event_manager: MODEM_EVT_BATTERY_DATA_READY[0m
    2022-11-21T08:15:09.833Z DEBUG modem << [00:16:03.035,186] [0m<inf> app_event_manager: MODEM_EVT_NEIGHBOR_CELLS_DATA_READY[0m
    2022-11-21T08:15:43.543Z DEBUG modem << +CSCON: 1
    2022-11-21T08:15:44.492Z DEBUG modem << [00:16:37.226,501] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTION_TIMEOUT[0m
    2022-11-21T08:15:44.495Z DEBUG modem << [00:16:37.227,050] [1;33m<wrn> cloud_module: Cloud connection establishment in progress[0m
    2022-11-21T08:15:44.503Z DEBUG modem << [00:16:37.227,081] [1;33m<wrn> cloud_module: New connection attempt in 2048 seconds if not successful[0m
    2022-11-21T08:15:44.505Z DEBUG modem << [00:16:37.227,233] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2022-11-21T08:15:50.657Z DEBUG modem << +CSCON: 0
    2022-11-21T08:15:52.164Z DEBUG modem << +CSCON: 1
    2022-11-21T08:15:53.072Z DEBUG modem << [00:16:45.816,375] [0m<inf> app_event_manager: GNSS_EVT_TIMEOUT[0m
    2022-11-21T08:15:53.075Z DEBUG modem << [00:16:45.816,864] [0m<inf> app_event_manager: GNSS_EVT_INACTIVE[0m
    2022-11-21T08:15:53.078Z DEBUG modem << [00:16:45.817,352] [0m<inf> app_event_manager: DATA_EVT_DATA_READY[0m
    2022-11-21T08:15:58.338Z DEBUG modem << +CSCON: 0
    2022-11-21T08:15:58.555Z DEBUG modem << +CSCON: 1
    2022-11-21T08:16:05.938Z DEBUG modem << +CSCON: 0
    2022-11-21T08:16:06.084Z DEBUG modem << +CSCON: 1
    2022-11-21T08:16:13.217Z DEBUG modem << +CSCON: 0
    2022-11-21T08:16:14.473Z DEBUG modem << [00:17:07.231,140] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2022-11-21T08:17:09.585Z DEBUG modem << %NCELLMEAS: 0,"0210E116","24202","09CC",34,6300,56,52,24,1082826,6300,54,48,15,0,6300,55,43,5,0,1650,52,53,23,24,100,52,40,18,32,1025324
    2022-11-21T08:17:09.804Z DEBUG modem << [00:18:02.523,498] [0m<inf> app_event_manager: APP_EVT_DATA_GET_ALL[0m
    2022-11-21T08:17:09.806Z DEBUG modem << [00:18:02.524,169] [0m<inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, NEIGHBOR_CELLS, GNSS)[0m
    2022-11-21T08:17:09.806Z DEBUG modem << [00:18:02.536,346] [0m<inf> app_event_manager: GNSS_EVT_ACTIVE[0m
    2022-11-21T08:17:09.807Z DEBUG modem << [00:18:02.536,987] [0m<inf> app_event_manager: SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
    2022-11-21T08:17:09.808Z DEBUG modem << [00:18:02.590,209] [0m<inf> app_event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
    2022-11-21T08:17:09.808Z DEBUG modem << [00:18:02.638,244] [0m<inf> app_event_manager: MODEM_EVT_BATTERY_DATA_READY[0m
    2022-11-21T08:17:09.809Z DEBUG modem << [00:18:03.360,656] [0m<inf> app_event_manager: MODEM_EVT_NEIGHBOR_CELLS_DATA_READY[0m
    2022-11-21T08:17:40.915Z DEBUG modem << %CESQ: 55,2,23,3
    2022-11-21T08:17:43.760Z DEBUG modem << [00:18:36.516,601] [0m<inf> app_event_manager: GNSS_EVT_TIMEOUT[0m
    2022-11-21T08:17:43.761Z DEBUG modem << [00:18:36.517,059] [0m<inf> app_event_manager: GNSS_EVT_INACTIVE[0m
    2022-11-21T08:17:43.762Z DEBUG modem << [00:18:36.517,547] [0m<inf> app_event_manager: DATA_EVT_DATA_READY[0m
    2022-11-21T08:18:51.944Z DEBUG modem << %CESQ: 53,2,18,2
    2022-11-21T08:19:09.250Z DEBUG modem << %NCELLMEAS: 0,"0210E116","24202","09CC",34,6300,56,56,25,1202506,6300,54,46,6,0,6300,55,44,3,0,1650,52,53,26,24,1650,51,39,-3,24,100,52,40,20,32,100,51,35,11,32,1025324
    2022-11-21T08:19:09.783Z DEBUG modem << [00:20:02.523,498] [0m<inf> app_event_manager: APP_EVT_DATA_GET_ALL[0m
    2022-11-21T08:19:09.786Z DEBUG modem << [00:20:02.524,169] [0m<inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, NEIGHBOR_CELLS, GNSS)[0m
    2022-11-21T08:19:09.788Z DEBUG modem << [00:20:02.536,315] [0m<inf> app_event_manager: GNSS_EVT_ACTIVE[0m
    2022-11-21T08:19:09.789Z DEBUG modem << [00:20:02.536,956] [0m<inf> app_event_manager: SENSOR_EVT_ENVIRONMENTAL_DATA_READY[0m
    2022-11-21T08:19:09.790Z DEBUG modem << [00:20:02.569,122] [0m<inf> app_event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_READY[0m
    2022-11-21T08:19:09.790Z DEBUG modem << [00:20:02.599,426] [0m<inf> app_event_manager: MODEM_EVT_BATTERY_DATA_READY[0m
    2022-11-21T08:19:09.791Z DEBUG modem << [00:20:03.047,821] [0m<inf> app_event_manager: MODEM_EVT_NEIGHBOR_CELLS_DATA_READY[0m
  • Thank you for the longer log. We are looking at this and will get back to you.
  • Hi Martha, sorry for the delay.
    The last log shows that the device does get a valid IPv4 address from the network so it could be an LTE connection has an issue. Could it be that you are out of data? Could you please check the data plan?
    You could also do a pin(Edit: ping) test with the serial_lte_modem sample to confirm and run a test like this:
    AT+CFUN=4
    AT+CFUN?
    AT%XSYSTEMMODE=1,0,0,0
    AT+CEREG=5
    AT+CFUN=1
    AT+CFUN?
    AT#XPING="www.google.com",45,5000,5,1000
    XPING is only supported by serial_lte_modem sample and does not work with at_client.
    When checking the nrfCloud sim card section, the sim card should have a good amount of data left.
