Flash usage
Hi I hope you can help me with this.
I'm using a nrf52833. When I build I see Flash usage of 278044 B.
Regions Size 512KB.
My custom board has this in the Flash0 settion of the dts.
&flash0 {
	partitions {
		#address-cells = <1>;
		#size-cells = <1>;
		boot_partition: partition@0 {
			label = "mcuboot";
			reg = <0x0 0xc000>;
		slot0_partition: partition@c000 {
			label = "image-0";
			reg = <0xc000 0x32000>;
		slot1_partition: partition@3e000 {
			label = "image-1";
			reg = <0x3e000 0x32000>;
		scratch_partition: partition@70000 {
			label = "image-scratch";
			reg = <0x70000 0xa000>;
		storage_partition: partition@7a000 {
			label = "storage";
			reg = <0x7a000 0x6000>;
Which looks like this thanks to the VScode stuff.
It appears that my image-0 and image-1 partitions are too small for my rom.
I guess it works at the moment because overflowing from image-0 to image-1 isn't causing any problems.
I want to make "storage" as large as possible to collect test user sampling data.
I dont use DFU, so I think I do not need "image-1" or "image-scratch". Is this correct? Can I also remove "MCUboot"? I plan to use APP_PROTECT in the final version.
How do I build release mode? Is this just by changing the Kconfig settings? Is there a page that I can refer to? (so I get it right)
Thanks for your help!
  • I changed my dts to look like this and it seems to work fine. I'm not sure if I might have inadvertently broken something
    &flash0 {
    	partitions {
    		#size-cells = <1>;
    		slot0_partition: partition@0 {
    			label = "image-0";
    			reg = <0x0 0x47000>;
    		storage_partition: partition@47000 {
    			label = "storage";
    			reg = <0x47000 0x39000>;
    I'm concerned that my ROM is >200K but I'm using experimental features for changing the TX power.
    CONFIG_BT_LL_SW_SPLIT=y                             #I want to switch this off
    CONFIG_BT_CTLR_ADVANCED_FEATURES=y
    I believe this is unnecessary in the newer version (I'm still on 2.0.2 because my SPI code breaks because of something deprecated in 2.1.0 onwards.) I can see that LL_SW folder in the memory report is >90KB.
    I'm working on adding a release_mode.conf with these extra CONFIG options
    CONFIG_RESET_ON_FATAL_ERROR=y
    # Disable all debug features
    CONFIG_SHELL=n
    CONFIG_OPENTHREAD_SHELL=n
    CONFIG_CONSOLE=n
    CONFIG_UART_CONSOLE=n
    CONFIG_SERIAL=n
    CONFIG_LOG=n
    CONFIG_LOG_MODE_MINIMAL=n
    CONFIG_ASSERT_VERBOSE=n
    CONFIG_PRINTK=n
    CONFIG_PRINTK_SYNC=n
    CONFIG_THREAD_NAME=n
    I'm not sure how to make the compiler code generation release mode though. And I would still like to find a guide that shows me how to build a proper release mode build with all the stuff that I might have overlooked (because it's goign to be needed soon)
    -Jason
    You can remove mcuboot if you do not need dfu, this will go a long way to solve any flash space issues you are having. Remove CONFIG_BOOTLOADER_MCUBOOT=y or set CONFIG_BOOTLOADER_MCUBOOT=n.
    For configuring build modes, please see https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/gs_modifying.html#gs-modifying-build-types and let me know if you have any questions regarding the instructions.
    For suggestions to release mode configurations, you may find it useful to compare the non-release and release configurations found in nrf/applications/nrf_desktop.
  • Thanks. I hoped there was a complete guide but this is good. I will figure out the .conf settings.
    How do I set the compiler to generate release mode code? Minimal size, or maximal speed. I assume its set to "debug" somewhere but I can't see it in Kconfig (which is where I assumed it was)
    Thanks for your help (again!)
  • OMG I just found it. Lol.
    In Build and Link Features->Compiler Options->Optimization level (this was a drop down that I didn't notice somehow)
    I think that's all I needed. THANKS
