Hi, I'm using NCS v1.9.1, and attempting to upgrade MCUBoot via DFU over BLE using the nRF Connect for Mobile app.
I'm able to successfully DFU the application image. However, after many attempts using different configuration options for B0, MCUBoot, and the application image, I'm still unable to DFU MCUBoot to either slot.
I have these configs enabled in my application image in prj.conf:
CONFIG_SECURE_BOOT=y
CONFIG_SB_SIGNING_KEY_FILE="/var/tmp/mcuboot_priv.pem"
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_MCUBOOT_IMAGE_VERSION="0.1.3+3"
CONFIG_MCUMGR=y
CONFIG_MCUMGR_CMD_OS_MGMT=y
CONFIG_MCUMGR_CMD_IMG_MGMT=y
CONFIG_MCUMGR_SMP_BT=y
CONFIG_MCUMGR_SMP_BT_AUTHEN=n
CONFIG_FW_INFO_FIRMWARE_VERSION=7
CONFIG_BUILD_S1_VARIANT=y
And this is the MCUBoot config (defined in child_image/mcuboot.conf):
I bumped the firmware version, rebuilt, and attempted to DFU MCUBoot - here are the logs from nRF Connect for Mobile when I attempt to DFU the dfu_mcuboot.zip file found in build/zephyr:
nRF Connect, 2022-11-15
Device_Bringup (F8:8E:E5:F9:5E:80)
V 10:31:39.786 Connecting to F8:8E:E5:F9:5E:80...
D 10:31:39.786 gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
D 10:31:40.032 [Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
I 10:31:40.032 Connected to F8:8E:E5:F9:5E:80
V 10:31:40.050 Discovering services...
D 10:31:40.050 gatt.discoverServices()
D 10:31:40.059 [Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
I 10:31:40.473 Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
D 10:31:40.780 [Callback] Services discovered with status: 0
I 10:31:40.780 Services discovered
V 10:31:40.785 Generic Attribute (0x1801)
- Service Changed [I] (0x2A05)
Client Characteristic Configuration (0x2902)
- Client Supported Features [R W] (0x2B29)
- Database Hash [R] (0x2B2A)
Generic Access (0x1800)
- Device Name [R] (0x2A00)
- Appearance [R] (0x2A01)
- Peripheral Preferred Connection Parameters [R] (0x2A04)
Nordic UART Service (6e400001-b5a3-f393-e0a9-e50e24dcca9e)
- TX Characteristic [N] (6e400003-b5a3-f393-e0a9-e50e24dcca9e)
- RX Characteristic [W WNR] (6e400002-b5a3-f393-e0a9-e50e24dcca9e)
SMP Service (8d53dc1d-1db7-4cd3-868b-8a527460aa84)
- SMP Characteristic [N WNR] (da2e7828-fbce-4e01-ae9e-261174997c48)
D 10:31:40.785 gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
D 10:31:40.786 gatt.setCharacteristicNotification(6e400003-b5a3-f393-e0a9-e50e24dcca9e, true)
I 10:31:40.868 Connection parameters updated (interval: 45.0ms, latency: 0, timeout: 5000ms)
I 10:31:45.279 Connection parameters updated (interval: 45.0ms, latency: 0, timeout: 420ms)
V 10:32:00.617 [McuMgr] Connecting...
D 10:32:00.620 [McuMgr] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, LE 1M)
D 10:32:00.656 [McuMgr] [Callback] Connection state changed with status: 0 and new state: 2 (CONNECTED)
I 10:32:00.659 [McuMgr] Connected to F8:8E:E5:F9:5E:80
D 10:32:00.660 [McuMgr] wait(300)
V 10:32:00.963 [McuMgr] Discovering services...
D 10:32:00.966 [McuMgr] gatt.discoverServices()
I 10:32:00.977 [McuMgr] Services discovered
V 10:32:00.981 [McuMgr] Primary service found
V 10:32:00.989 [McuMgr] Requesting new MTU...
D 10:32:00.991 [McuMgr] gatt.requestMtu(498)
I 10:32:01.077 [McuMgr] MTU changed to: 252
D 10:32:01.081 [McuMgr] gatt.setCharacteristicNotification(da2e7828-fbce-4e01-ae9e-261174997c48, true)
V 10:32:01.086 [McuMgr] Enabling notifications for da2e7828-fbce-4e01-ae9e-261174997c48
D 10:32:01.088 [McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00)
I 10:32:01.257 [McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb, value: (0x) 01-00
I 10:32:01.262 [McuMgr] Notifications enabled
V 10:32:01.264 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND)
D 10:32:01.267 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48)
I 10:32:01.277 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 00-00-00-01-00-00-FF-06-A0
I 10:32:01.391 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 01-00-00-06-00-00-FF-06-BF-62-72-63-08-FF
A 10:32:01.402 [McuMgr] Received Header (Op: 1, Flags: 0, Len: 6, Group: 0, Seq: 255, Command: 6) CBOR {"rc":8}
W 10:32:01.405 [McuMgr] Error: NOT_SUPPORTED (8)
A 10:32:01.419 [McuMgr] Sending (10 bytes) Header (Op: 0, Flags: 0, Len: 2, Group: 1, Seq: 0, Command: 0) CBOR {}
V 10:32:01.422 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND)
D 10:32:01.423 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48)
I 10:32:01.426 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 00-00-00-02-00-01-00-00-BF-FF
I 10:32:01.754 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 01-00-00-88-00-01-00-00-BF-66-69-6D-61-67-65-73-9F-BF-64-73-6C-6F-74-00-67-76-65-72-73-69-6F-6E-67-30-2E-31-2E-33-2E-33-64-68-61-73-68-58-20-EE-1D-7B-A1-5F-C2-90-C0-6F-3E-35-18-A4-16-6C-F0-6A-C4-57-03-35-2D-D1-F0-9B-A1-15-A3-C9-79-E7-8D-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F5-66-61-63-74-69-76-65-F5-69-70-65-72-6D-61-6E-65-6E-74-F4-FF-FF-6B-73-70-6C-69-74-53-74-61-74-75-73-00-FF
A 10:32:01.770 [McuMgr] Received Header (Op: 1, Flags: 0, Len: 136, Group: 1, Seq: 0, Command: 0) CBOR {"images":[{"slot":0,"version":"0.1.3.3","hash":"7h17oV/CkMBvPjUYpBZs8GrEVwM1LdHwm6EVo8l5540=","bootable":true,"pending":false,"confirmed":true,"active":true,"permanent":false}],"splitStatus":0}
V 10:32:01.816 [McuMgr] Uploading firmware...
A 10:32:27.270 [McuMgr] 40015 bytes sent in 24794 ms (1.61 kB/s)
A 10:32:52.423 [McuMgr] 40016 bytes sent in 24524 ms (1.63 kB/s)
A 10:32:52.456 [McuMgr] Sending (10 bytes) Header (Op: 2, Flags: 0, Len: 2, Group: 63, Seq: 105, Command: 0) CBOR {}
V 10:32:52.461 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND)
D 10:32:52.464 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48)
I 10:32:52.469 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 02-00-00-02-00-3F-69-00-BF-FF
I 10:32:52.603 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 03-00-00-06-00-3F-69-00-BF-62-72-63-08-FF
A 10:32:52.607 [McuMgr] Received Header (Op: 3, Flags: 0, Len: 6, Group: 63, Seq: 105, Command: 0) CBOR {"rc":8}
W 10:32:52.618 [McuMgr] Error: NOT_SUPPORTED (8)
V 10:32:52.623 [McuMgr] New state: TEST
A 10:32:52.627 [McuMgr] Sending (58 bytes) Header (Op: 2, Flags: 0, Len: 50, Group: 1, Seq: 106, Command: 0) CBOR {"confirm":false,"hash":"xhwt/XiW5zEsJ42ZLiN0w+Myr3dL9xf+lq2Q7zcUQWs="}
V 10:32:52.631 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND)
D 10:32:52.631 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48)
I 10:32:52.639 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 02-00-00-32-00-01-6A-00-BF-67-63-6F-6E-66-69-72-6D-F4-64-68-61-73-68-58-20-C6-1C-2D-FD-78-96-E7-31-2C-27-8D-99-2E-23-74-C3-E3-32-AF-77-4B-F7-17-FE-96-AD-90-EF-37-14-41-6B-FF
I 10:32:53.100 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 03-00-00-06-00-01-6A-00-BF-62-72-63-03-FF
A 10:32:53.106 [McuMgr] Received Header (Op: 3, Flags: 0, Len: 6, Group: 1, Seq: 106, Command: 0) CBOR {"rc":3}
W 10:32:53.110 [McuMgr] Error: IN_VALUE (3)
V 10:32:53.127 [McuMgr] Disconnecting...
D 10:32:53.131 [McuMgr] gatt.disconnect()
D 10:32:53.159 [McuMgr] [Callback] Connection state changed with status: 0 and new state: 0 (DISCONNECTED)
I 10:32:53.164 [McuMgr] Disconnected
D 10:32:53.168 [McuMgr] gatt.close()
Any ideas what the issue could be or other things to try? Thanks in advance.
