Warnings in RTE_Components when using packs
I am trying to set up an environment based on CMSIS Packs. However, when using some components from nRF_Libraries, these lines get added to RTE_Components.h:
#define GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS=4>nrf_drv_gpiote
#define GPIOTE_ENABLED=1>.
  #define GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS=1>.
Since I use RTE_Components.h in most of my own files, I am flooded with compiler warnings regarding these definitions:
C:\Data\Projects\HGBLE\application\arm\RTE\RTE_Components.h(13): warning:  #2775-D: white space is required between the macro name "GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS" and its replacement text
C:\Data\Projects\HGBLE\application\arm\RTE\RTE_Components.h(14): warning:  #2775-D: white space is required between the macro name "GPIOTE_ENABLED" and its replacement text
C:\Data\Projects\HGBLE\application\arm\RTE\RTE_Components.h(15): warning:  #2775-D: white space is required between the macro name "GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS" and its replacement text
C:\Data\Projects\HGBLE\application\arm\RTE\RTE_Components.h(15): warning:  #47-D: incompatible redefinition of macro "GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS" (declared at line 13)
Is this an expected behaviour? What can I do to silence these compiler warnings?
  • well where are those defines coming from? They're garbage, the '=' and the '>' shouldn't be there obviously. It looks like a source file has been badly edited, most likely the nrf_drv_config.h in your project. you need to go fix it.
  • They are coming from NordicSemiconductor.nRF_Libraries.pdsc (line 394, app_button component definition) and NordicSemiconductor.nRF_Drivers.pdsc (line 835/836, nrf_drv_gpiote component definition). I could edit these in my installation, but that would mean editing them on the local machine of each developer and break compatibility.
    I am aware that there is already a problem when these two components are used together in the latest SDK versions, but I'm not sure this particular problem with CMSIS packs is known too.
