nRF52832 Mesh Bootloader not running
I'm using a custom board with an nrf52832. I can also emulate using an nrf52840dk. I have to compile the bootloader because there is no LF crystal on my custom board. So I set:
#define NRF_SDH_CLOCK_LF_SRC 0 // RC
#define NRF_SDH_CLOCK_LF_RC_CTIV 16
#define NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 2
#define NRF_SDH_CLOCK_LF_XTAL_ACCURACY 7
#define NRF_SDH_CLOCK_LF_ACCURACY 1
#define NRFX_CLOCK_CONFIG_LF_SRC 0
#define CLOCK_CONFIG_LF_SRC 0
in sdk_config.h in both the application and bootloader include folders. The precompiled bootloader does not work either.
My mesh application runs fine without the bootloader but with the device address page and softdevice. The mesh application is using nrf sdk for mesh v5.0.0 with nrf5 SDK v17.0.2. The address page is compiled for the s132 v7.2.0 softdevice and for the nrf52832_xxAA hardware:
python .\device_page_generator.py -c .\bootloader_config_X49_REV_B.json -d nrf52832_xxAA -sd "s132_7.2.0" --output bin\X49_REV_B_device_page_nrf52832_xxAA_s132_7.2.0.hex
The softdevice is the s132 v7.2.0 and has worked fine on my other nRF52832 projects.
When I add the gccarmemb bootloader compiled for the nRF52832, the application does not start at all. Compiling the bootloader with the BOOTLOADER_DEBUG_ENABLE flag set causes compilation to fail with memory overflow:
[build] c:/progra~2/gnuarm~1/102020~1/bin/../lib/gcc/arm-none-eabi/10.2.1/../../../../arm-none-eabi/bin/ld.exe: mesh\bootloader\mesh_bootloader_gccarmemb_nrf52832_xxAA.elf section `.text' will not fit in region `FLASH'
[build] c:/progra~2/gnuarm~1/102020~1/bin/../lib/gcc/arm-none-eabi/10.2.1/../../../../arm-none-eabi/bin/ld.exe: region FLASH overflowed with .data and user data
[build] c:/progra~2/gnuarm~1/102020~1/bin/../lib/gcc/arm-none-eabi/10.2.1/../../../../arm-none-eabi/bin/ld.exe: region `FLASH' overflowed by 1084 bytes
[build] collect2.exe: error: ld returned 1 exit status
[build] ninja: build stopped: subcommand failed.
I have other projects that are working well. Mesh applications for the nRF52840 with the mesh bootloader work, and Mesh LPN applications with the nRF5 SDK secure bootloader also work.
I have not tinkered with the linker script. What could be the problem?
