nrf5340 Audio DK external flash shield
I am trying to configure the nrf5340 audio example to add the ability to update the firmware using a serial connection.
In the audio example documentation, there are a few references to using an "external flash shield" to have enough memory to support a multi-image bootloader configuration.
Is there a physical PCB that can be attached to the nrf5340-audio-dev-kit PCB, or do I need to use jumper wires to connect the audio dev kit to an external flash memory device?
If there is a physical PCB "shield", can you tell me the PN and who I can purchase this from?
-- Kristopher
