I want implement beacon function on my Qualcomm BSP board.
However, I'm testing with nRF52 DK in advance.
And need DFU OTA update for my F/W application.
So I'm implementing it by referring to some examples.
1. ble_app_beacon
2. ble_app_buttonless_dfu
3. secure_bootloader
Based on ble_beacon example, a code was added to enter secure_bootloader for DFU update.
// Start execution.
NRF_LOG_INFO("Beacon example started.");
advertising_start();
// Enter main loop.
for (;; )
//NRF_LOG_INFO("loop %d", loop);
nrf_delay_ms(1000);
NRF_LOG_INFO("timer %d", loop++);
//NRF_LOG_FLUSH();
if (loop >= 10) {
loop = 0;
NRF_LOG_INFO("detect 10secs.");
NRF_LOG_INFO("clear gpregret(0).");
sd_power_gpregret_clr(0, 0xFFFFFFFF);
NRF_LOG_INFO("set 0xB1 to gpregret(0).");
sd_power_gpregret_set(0, BOOTLOADER_DFU_START);
NRF_LOG_INFO("shoutdown for goto DFU");
nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_DFU);
idle_state_handle();
This is simple, application will start advertising for beacon broadcast.
And then will enter DFU secure bootloader after 10secs later.
<info> app: Setting vector table to bootloader: 0x00078000
<info> app: Setting vector table to main app: 0x00026000
<info> app_timer: RTC: initialized.
<info> app: Beacon example started.
<info> app: timer 0
<info> app: timer 1
<info> app: timer 2
<info> app: timer 3
<info> app: timer 4
<info> app: timer 5
<info> app: timer 6
<info> app: timer 7
<info> app: timer 8
<info> app: timer 9
<info> app: detect 10secs.
<info> app: clear gpregret(0).
<info> app: set 0xB1 to gpregret(0).
<info> app: shoutdown for goto DFU
<info> app: Power management wants to reset to DFU mode.
<info> app: Power management allowed to reset to DFU mode.
But it can't enter DFU secure bootloader, and then will start application soon.
This is bootloader code
uint32_t ret_val;
uint32_t gpregret = 0;
// Must happen before flash protection is applied, since it edits a protected page.
nrf_bootloader_mbr_addrs_populate();
// Protect MBR and bootloader code from being overwritten.
ret_val = nrf_bootloader_flash_protect(0, MBR_SIZE);
APP_ERROR_CHECK(ret_val);
ret_val = nrf_bootloader_flash_protect(BOOTLOADER_START_ADDR, BOOTLOADER_SIZE);
(void) NRF_LOG_INIT(nrf_bootloader_dfu_timer_counter_get);
NRF_LOG_INFO("Inside main");
sd_power_gpregret_get(0, &gpregret);
if (gpregret == 0xB1) {
NRF_LOG_INFO("Detect gpregret 0xB1 for init bootloader");
ret_val = nrf_bootloader_init(dfu_observer);
} else {
NRF_LOG_INFO("Not detect gpregret 0xB1. will start application");
nrf_bootloader_app_start();
NRF_LOG_FLUSH();
NRF_LOG_ERROR("After main, should never be reached.");
NRF_LOG_FLUSH();
APP_ERROR_CHECK_BOOL(false);
Please advise me.
Thanks.
