Modem Firmware Programming on the Elprotronic GangPro - Arm
We are nearing production stage of our project, and are looking at programming on a large scale. Using the nRF9160 we need to program the latest modem firmware along with our application firmware.
The GangPro Software can handle our application FW no problem, but I am questioning its ability to do the modem FW, as it doesn't accept zip files like the Nordic Programmer software. Obviously I can see there are a number of binary/hex files in the zip file which I could program to the SiP but I don't know if that will be as simple as it sounds.
According to the infocentre you need to split the hex file into 8kb blocks and program them in continuous sections that are page aligned... - https://infocenter.nordicsemi.com/index.jsp?topic=%2Fnan_041%2FAPP%2Fnan_production_programming%2Fupdating_modem.html
As you can see from the screenshot, I have the ability to select a .bin/.hex/.txt file and program that, but I don't know if that would inherently know the area of flash to program it to, or know the exact way that should happen.
Apologies if this is more a question for Elprotronic, but I would have thought someone else has had this question before.
Thanks
Damien
