I've been trying to get breakpoints working on a new nRF Connect project but have been running into an issue: when I hit "Debug" in the nRF Connect plugin in VSCode, the app compiles, loads, and logs everything from my application, but seems to ignore the breakpoints. Then, it seems to reboot, because it says it's loading Zephyr again, but this time it never succeeds. The call stack on the left has values but then quickly becomes empty.
I am using a nRF52DK (nRF52832) and am also experiencing the same issue with a BMD-300 Dev Kit.
Here is the log:
*** Booting Zephyr OS build v3.1.99-ncs1-1 ***
I: Starting bootloader
I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
I: Boot source: none
I: Swap type: none
I: Bootloader chainload address offset: 0xc000
�*** Booting Zephyr OS build v3.1.99-ncs1-1 ***
[00:00:00.004,699] <inf> [Logs from myapp showing that the main() function finished successfully.]
The device seems to hang at this point and isn't advertising via BLE. When I load the same app without the debugger, it advertises and works perfectly.
A few things I have already tried:
1. I made sure the "Enable debug options" is checked for my build configuration and did a pristine build
2. I restarted VSCode
3. I unplugged and plugged in the device
I've attached an image of the setup if that's helpful.
Any help you could provide would be greatly appreciated. Thank you.
