How to change mesh bootloader flash size?
Hi
When I build mesh bootloader code, there shows flash size not enough,
Could you tell me wher I can change the size, please?
c:/progra~2/gnutoo~1/62017-~1/bin/../lib/gcc/arm-none-eabi/6.3.1/../../../../arm-none-eabi/bin/ld.exe: mesh\bootloader\mesh_bootloader_serial_gccarmemb_nrf52833_xxAA.elf section `.text' will not fit in region `FLASH'
c:/progra~2/gnutoo~1/62017-~1/bin/../lib/gcc/arm-none-eabi/6.3.1/../../../../arm-none-eabi/bin/ld.exe: region FLASH overflowed with .data and user data
c:/progra~2/gnutoo~1/62017-~1/bin/../lib/gcc/arm-none-eabi/6.3.1/../../../../arm-none-eabi/bin/ld.exe: region `FLASH' overflowed by 11300 bytes
  • No , I don't think so
    I followed https://infocenter.nordicsemi.com/index.jsp?topic=%2Fug_nrf52833_dk%2FUG%2Fnrf52833_DK%2Fhw_debug_out.html&cp=4_1_4_7_8
    ,  program 4 hex files to EV board, as follow:
    1) device_page_nrf52833_xxAA_s113_7.0.1.hex
    2) dfu_nrf52833_xxAA_s113_7.0.1.hex
    3) s113_nrf52_7.0.1_softdevice.hex
    4) mesh_bootloader_serial_gccarmemb_nrf52833_xxAA.hex
    Second ,  connected Ev board with PC,  then runned command "nrfutil --verbose dfu serial -pkg xxx.zip -p COM5 -b 115200 -fc --mesh"  to update other devices,   it can update successful.
    But ,  if programed
    4) mesh_bootloader_gccarmemb_nrf52833_xxAA.hex
    program mesh_bootloader_gccarmemb_nrf52833_xxAA.hex instead of mesh_bootloader_serial_gccarmemb_nrf52833_xxAA.hex,
    runned command "nrfutil --verbose dfu serial -pkg xxx.zip -p COM5 -b 115200 -fc --mesh",  it is get message "Abort event. Reason: 0x3"  after sending almost 50% of xxx.zip.
    So , may I know why?
    Are you sure that was the link you were trying to copy? Please note that the links in the URL of your internet browser doesn't update after you click on internal links in Infocenter. To copy a link, right click the link, and select "copy link".
    I assume you meant to link to this page:
    https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.meshsdk.v5.0.0/md_doc_user_guide_modules_dfu_configuring_performing.html
    What is it that you don't think?
    When you are doing your two tests, are you using one or two DKs?
    When you are updating via DFU, then you need one device connected via serial, which will then forward the image to the rest of the nodes. The one that is connected to the serial will need to be programmed with the mesh_bootloader_serial_gccarmemb_nrf52833_xxAA.hex. The rest can be programmed with mesh_bootloader_gccarmemb_nrf52833_xxAA.hex.
    But I think I understand what you are trying to do now. Do you want the one that is connected to the computer to be connected with the USB instead of via UART? So you want to use the USB for actual bootloader DFU purposes? Or do you want to use USB for your application outside of DFU purposes?
    BR,
    Edvin
  • Do you want the one that is connected to the computer to be connected with the USB instead of via UART? So you want to use the USB for actual bootloader DFU purposes?
    yes,  So I must add usb driver in bothe part of bootloader and application , right?
    I talked to one of the developers of the bootloader in our Mesh SDK. The difference between the serial bootloader and the non-serial bootloader is that in the case where there is no application, or the application is "broken", the serial bootloader can work as a UART standalone bootloader, to receive a new image via UART. In all common usecases, you could use the non-serial bootloader for all nodes. The UART part of the bootloader is not used as long as the application is working. All normal UART transport is being handled in the application. So you shouldn't need to modify the bootloader. You can use the non-serial one, and then replace the UART handling with USB in your application.
    Edvin
  • I agree with you , but actually, if I use non-serial bootloader,   it got message "Abort event. Reason: 0x3"  after sending almost 50% of xxx.zip.
