Precise bus fault in memq_enqueue
We are running Zephyr 2.4 via PlatformIO on a nRF52840 based product. While spamming the nRF with a ton of BLE packets, after about 15 minutes or so we get the following bus fault:
00> [00:13:28.106,445] <err> os: ***** BUS FAULT *****
00> [00:13:28.106,475] <err> os:  Precise data bus error
00> [00:13:28.106,475] <err> os:  BFAR Address: 0x20aa81ae
00> [00:13:28.106,506] <err> os: r0/a1: 0x2000c13c r1/a2: 0x2000cc50 r2/a3: 0x2000d3e8
00> [00:13:28.106,506] <err> os: r3/a4: 0x200009b0 r12/ip: 0x00000000 r14/lr: 0x0002208b
00> [00:13:28.106,506] <err> os: xpsr: 0x21000211
00> [00:13:28.106,536] <err> os: s[ 0]: 0x00000000 s[ 1]: 0x00000000 s[ 2]: 0x00000000 s[ 3]: 0x00000000
00> [00:13:28.106,536] <err> os: s[ 4]: 0x00000000 s[ 5]: 0x00000000 s[ 6]: 0x00000000 s[ 7]: 0x00000000
00> [00:13:28.106,536] <err> os: s[ 8]: 0x00000000 s[ 9]: 0x00000000 s[10]: 0x00000000 s[11]: 0x00000000
00> [00:13:28.106,567] <err> os: s[12]: 0x00000000 s[13]: 0x00000000 s[14]: 0x00000000 s[15]: 0x00000000
00> [00:13:28.106,567] <err> os: fpscr: 0x2000f3b8
00> [00:13:28.106,567] <err> os: Faulting instruction address (r15/pc): 0x0003f34a
00> [00:13:28.106,597] <err> os: >>> ZEPHYR FATAL ERROR 0: CPU exception on CPU 0
00> [00:13:28.106,597] <err> os: Fault during interrupt handling
00>
00> [00:13:28.106,597] <err> os: Current thread: 0x20005510 (unknown)
00> [00:13:28.678,009] <err> os: Halting system
Can you advise on what we could do to overcome this issue?
Thank you,
    can you check the failing instruction with addr2line as explained by Alseth in this post?
  • Hi Hakon,
    Thanks for getting back to me. This is the result of running addr2line:
    C:\Users\mab\.platformio\packages\framework-zephyr\subsys\bluetooth\controller\util/memq.c:92
    which points to this line:
    memq_link_t *memq_enqueue(memq_link_t *link, void *mem, memq_link_t **tail)
    /* Let the old tail element point to the new tail element */
    (*tail)->next = link;
    Please advise on what steps we can take to debug this issue further.
  • Hi Hakon,
    We upgraded to a newer version of Zephyr (v.2.7.1) in PlatformIO and are still seeing the same error (the crash happens within ~5 minutes). Here's a deeper call stack:
    1. memq_enqueue@0x00043bce (c:\Users\mab\.platformio\packages\framework-zephyr\subsys\bluetooth\controller\util\memq.c:95)
    2. ull_rx_put@0x00029036 (c:\Users\mab\.platformio\packages\framework-zephyr\subsys\bluetooth\controller\ll_sw\ull.c:1728)
    3. lll_conn_isr_rx@0x0002e9c4 (c:\Users\mab\.platformio\packages\framework-zephyr\subsys\bluetooth\controller\ll_sw\nordic\lll\lll_conn.c:369)
    4. isr_radio@0x0002ef4a (c:\Users\mab\.platformio\packages\framework-zephyr\subsys\bluetooth\controller\ll_sw\nordic\hal\nrf5\radio\radio.c:79)
    5. radio_nrf5_isr_body@0x00045b20 (c:\Users\mab\.platformio\packages\framework-zephyr\subsys\bluetooth\controller\ll_sw\nordic\lll\lll.c:92)
    6. radio_nrf5_isr@0x00045b20 (c:\Users\mab\.platformio\packages\framework-zephyr\subsys\bluetooth\controller\ll_sw\nordic\lll\lll.c:86)
    Please advise
  • Can you check which thread id 0x20005510 corresponds to? Or just use CONFIG_THREAD_NAME=y.
  • Hey Hakon,
    Mo and I are working on the same problem. It looks like it corresponds to idle 00 thread.
    00> [00:14:04.793,151] <err> os: ***** BUS FAULT *****
    00> [00:14:04.793,151] <err> os:   Precise data bus error
    00> [00:14:04.793,151] <err> os:   BFAR Address: 0x205036d9
    00> [00:14:04.793,182] <err> os: r0/a1:  0x2000b178  r1/a2:  0x2000bed4  r2/a3:  0x2000c338
    00> [00:14:04.793,182] <err> os: r3/a4:  0x00000000 r12/ip:  0xb6a81002 r14/lr:  0x000290cd
    00> [00:14:04.793,182] <err> os:  xpsr:  0x41000211
    00> [00:14:04.793,212] <err> os: s[ 0]:  0x00000000  s[ 1]:  0x00000000  s[ 2]:  0x00000000  s[ 3]:  0x00000000
    00> [00:14:04.793,212] <err> os: s[ 4]:  0x00000000  s[ 5]:  0x00000000  s[ 6]:  0x00000000  s[ 7]:  0x00000000
    00> [00:14:04.793,243] <err> os: s[ 8]:  0x00000000  s[ 9]:  0x00000000  s[10]:  0x00000000  s[11]:  0x00000000
    00> [00:14:04.793,243] <err> os: s[12]:  0x00000000  s[13]:  0x00000000  s[14]:  0x00000000  s[15]:  0x00000000
    00> [00:14:04.793,273] <err> os: fpscr:  0x2000d6c0
    00> [00:14:04.793,273] <err> os: Faulting instruction address (r15/pc): 0x00043cee
    00> [00:14:04.793,273] <err> os: >>> ZEPHYR FATAL ERROR 0: CPU exception on CPU 0
    00> [00:14:04.793,273] <err> os: Fault during interrupt handling
    00>
    00> [00:14:04.793,304] <err> os: Current thread: 0x20005770 (idle 00
