52832 PPI and GPIOTE, TIMER
hi, I want to use PPI function for timer trigger GPIOTE,
when timer interrupt comes, my output pin will toggle, but I find my code doesn't work, I think it is GPIOTE mistake, because I use timer for triggering other timer task, its ok.
could you check my code?
thanks
void GPIOTE_PPI_init(void)
    ret_code_t err_code;
    nrf_drv_gpiote_out_config_t m_gpiote;
    err_code = nrf_drv_gpiote_out_init(GPIO_OUTPUT_PIN_NUMBER, &m_gpiote);
		/*ppi_channel1*/
		err_code = nrf_drv_ppi_channel_alloc(&ppi_channel1);
    compare_evt_addr_down = nrf_drv_comp_event_address_get(NRF_COMP_EVENT_DOWN);
    gpiote_task_addr_down = nrf_drv_gpiote_clr_task_addr_get(GPIO_OUTPUT_PIN_NUMBER);
		err_code = nrf_drv_ppi_channel_assign(ppi_channel1,
                                          nrf_drv_timer_event_address_get(&m_timer0,
        NRF_TIMER_EVENT_COMPARE0),
                                          gpiote_task_addr_down);
    err_code = nrf_drv_ppi_channel_enable(ppi_channel1);
		/*ppi_channel2*/
		err_code = nrf_drv_ppi_channel_alloc(&ppi_channel2);
    compare_evt_addr_up	=	nrf_drv_comp_event_address_get(NRF_COMP_EVENT_UP);
    gpiote_task_addr_up = nrf_drv_gpiote_set_task_addr_get(GPIO_OUTPUT_PIN_NUMBER);
		err_code = nrf_drv_ppi_channel_assign(ppi_channel2,
                                          nrf_drv_timer_event_address_get(&m_timer1,
                                          gpiote_task_addr_up);
    err_code = nrf_drv_ppi_channel_enable(ppi_channel2);
    nrf_drv_gpiote_out_task_enable(GPIO_OUTPUT_PIN_NUMBER);
