Recommended SPI Pin for nRF52820
Hi, from nRF52820 datasheet, some GPIOs pins are stated it use for low frequency I/O only with up to 10KHz.
May I know is that mean these Pins are not suitable for SPI? As SPI frequency normally in MHz.
And what is the switching frequency of other GPIOs Pins?
  • Hi
    Yes, this is correct. They shouldn't be used for serial communication since it can interfere with the radio. You should use other pins that aren't marked as low frequency/low drive.
    There isn't similar limitation on other GPIO pins that doesn't have this marking.
    regards
    Jared
