nrf-programmer app fails randomly ot upload image using SDFU to pca10059 target, I have to repeat process several times to get job done.
Version 3.0.4, OS Debian GNU/Linux bookworm/sid.
Previous versions were working correctly.
Log:
2022-11-21T09:58:31.123Z DEBUG Application data folder: /home/ask/.config/nrfconnect/pc-nrfconnect-programmer
2022-11-21T09:58:31.293Z INFO Using nrf-device-lib-js version: 0.4.13
2022-11-21T09:58:31.294Z INFO Using nrf-device-lib version: 0.12.8
2022-11-21T09:58:31.294Z INFO Using nrfjprog DLL version: 10.16.0
2022-11-21T09:58:31.294Z INFO Using JLink version: JLink_V7.66e
2022-11-21T09:58:31.339Z DEBUG App pc-nrfconnect-programmer v3.0.4 official
2022-11-21T09:58:31.340Z DEBUG App path: /home/ask/.nrfconnect-apps/node_modules/pc-nrfconnect-programmer
2022-11-21T09:58:31.340Z DEBUG nRFConnect 3.12.0, required by the app is (^3.12.0)
2022-11-21T09:58:31.340Z DEBUG nRFConnect path: /tmp/.mount_nrfconaowLZx/resources/app.asar
2022-11-21T09:58:31.340Z DEBUG HomeDir: /home/ask
2022-11-21T09:58:31.340Z DEBUG TmpDir: /tmp
2022-11-21T09:58:31.342Z INFO Installed JLink version does not match the provided version (V7.66a)
2022-11-21T09:58:36.130Z DEBUG Client Id: 0f133aa6-340c-4e39-a5c7-3acb61a304d5
2022-11-21T09:58:36.209Z DEBUG Google Analytics for category pc-nrfconnect-programmer has initialized
2022-11-21T09:58:42.511Z DEBUG Sending usage data {"category":"pc-nrfconnect-programmer","action":"architecture","label":"x64"}
2022-11-21T09:58:42.513Z DEBUG Sending usage data {"category":"pc-nrfconnect-programmer","action":"Open device","label":"nordicUsb"}
2022-11-21T09:58:42.518Z INFO Using @nordicsemiconductor/nrf-device-lib-js to communicate with target via USB SDFU protocol
2022-11-21T09:58:42.518Z DEBUG Sending usage data {"category":"pc-nrfconnect-programmer","action":"Open jlink device family","label":"NRF52_FAMILY"}
2022-11-21T09:58:42.519Z DEBUG Sending usage data {"category":"pc-nrfconnect-programmer","action":"Open jlink device version","label":"nRF52840"}
2022-11-21T09:58:42.520Z DEBUG Sending usage data {"category":"pc-nrfconnect-programmer","action":"Open jlink device board version","label":"PCA10059"}
2022-11-21T09:58:43.692Z INFO Update files regions according to Application core
2022-11-21T09:58:43.693Z INFO Parse memory regions for file
2022-11-21T09:58:54.493Z INFO Parsing HEX file: /home/ask/dev/macrix/cptech/sw3/firmware/SW_Inclinometer/deploy/inclinometer_pca10059_sd_0.3.0-83.hex
2022-11-21T09:58:54.552Z INFO File was last modified at 11/21/2022, 10:58:10 AM
2022-11-21T09:58:54.699Z INFO Update files regions according to Application core
2022-11-21T09:58:54.699Z INFO Parse memory regions for file
2022-11-21T09:58:54.700Z INFO SoftDevice detected, id 0x100 (S140 v7.2.0)
2022-11-21T09:58:58.064Z INFO Does not need to be reloaded: /home/ask/dev/macrix/cptech/sw3/firmware/SW_Inclinometer/deploy/inclinometer_pca10059_sd_0.3.0-83.hex
2022-11-21T09:58:58.067Z INFO SdReq for SoftDevice is set as 0x00.
2022-11-21T09:58:58.068Z INFO Hash is generated by SHA256
2022-11-21T09:58:58.074Z INFO Performing DFU. This may take a few seconds
2022-11-21T09:58:58.113Z INFO Opening serial port for SDFU programming: 0%
2022-11-21T09:58:58.514Z INFO Opening serial port for SDFU programming: 100%
2022-11-21T09:58:58.515Z INFO Uploading image through SDFU: 0%
2022-11-21T09:58:58.689Z INFO Uploading image through SDFU: 1%
2022-11-21T09:58:58.689Z INFO Uploading image through SDFU: 2%
2022-11-21T09:58:58.850Z INFO Uploading image through SDFU: 3%
2022-11-21T09:58:58.851Z INFO Uploading image through SDFU: 4%
2022-11-21T09:58:58.851Z INFO Uploading image through SDFU: 5%
2022-11-21T09:58:59.012Z INFO Uploading image through SDFU: 6%
2022-11-21T09:58:59.012Z INFO Uploading image through SDFU: 7%
2022-11-21T09:58:59.012Z INFO Uploading image through SDFU: 8%
2022-11-21T09:58:59.173Z INFO Uploading image through SDFU: 9%
2022-11-21T09:58:59.173Z INFO Uploading image through SDFU: 10%
2022-11-21T09:58:59.334Z INFO Uploading image through SDFU: 11%
2022-11-21T09:58:59.334Z INFO Uploading image through SDFU: 12%
2022-11-21T09:58:59.334Z INFO Uploading image through SDFU: 13%
2022-11-21T09:58:59.495Z INFO Uploading image through SDFU: 14%
2022-11-21T09:58:59.495Z INFO Uploading image through SDFU: 15%
2022-11-21T09:58:59.495Z INFO Uploading image through SDFU: 16%
2022-11-21T09:58:59.656Z INFO Uploading image through SDFU: 17%
2022-11-21T09:58:59.656Z INFO Uploading image through SDFU: 18%
2022-11-21T09:58:59.817Z INFO Uploading image through SDFU: 19%
2022-11-21T09:58:59.817Z INFO Uploading image through SDFU: 20%
2022-11-21T09:58:59.818Z INFO Uploading image through SDFU: 21%
2022-11-21T09:58:59.978Z INFO Uploading image through SDFU: 22%
2022-11-21T09:58:59.979Z INFO Uploading image through SDFU: 23%
2022-11-21T09:58:59.979Z INFO Uploading image through SDFU: 24%
2022-11-21T09:59:00.139Z INFO Uploading image through SDFU: 25%
2022-11-21T09:59:00.140Z INFO Uploading image through SDFU: 26%
2022-11-21T09:59:00.301Z INFO Uploading image through SDFU: 27%
2022-11-21T09:59:00.301Z INFO Uploading image through SDFU: 28%
2022-11-21T09:59:00.301Z INFO Uploading image through SDFU: 29%
2022-11-21T09:59:00.462Z INFO Uploading image through SDFU: 30%
2022-11-21T09:59:00.462Z INFO Uploading image through SDFU: 31%
2022-11-21T09:59:00.462Z INFO Uploading image through SDFU: 32%
2022-11-21T09:59:00.623Z INFO Uploading image through SDFU: 33%
2022-11-21T09:59:00.623Z INFO Uploading image through SDFU: 34%
2022-11-21T09:59:00.785Z INFO Uploading image through SDFU: 35%
2022-11-21T09:59:00.785Z INFO Uploading image through SDFU: 36%
2022-11-21T09:59:00.785Z INFO Uploading image through SDFU: 37%
2022-11-21T09:59:00.945Z INFO Uploading image through SDFU: 38%
2022-11-21T09:59:00.945Z INFO Uploading image through SDFU: 39%
2022-11-21T09:59:00.946Z INFO Uploading image through SDFU: 40%
2022-11-21T09:59:01.106Z INFO Uploading image through SDFU: 41%
2022-11-21T09:59:01.107Z INFO Uploading image through SDFU: 42%
2022-11-21T09:59:01.268Z INFO Uploading image through SDFU: 43%
2022-11-21T09:59:01.268Z INFO Uploading image through SDFU: 44%
2022-11-21T09:59:01.268Z INFO Uploading image through SDFU: 45%
2022-11-21T09:59:01.429Z INFO Uploading image through SDFU: 46%
2022-11-21T09:59:01.429Z INFO Uploading image through SDFU: 47%
2022-11-21T09:59:01.429Z INFO Uploading image through SDFU: 48%
2022-11-21T09:59:01.590Z INFO Uploading image through SDFU: 49%
2022-11-21T09:59:01.590Z INFO Uploading image through SDFU: 50%
2022-11-21T09:59:01.751Z INFO Uploading image through SDFU: 51%
2022-11-21T09:59:01.751Z INFO Uploading image through SDFU: 52%
2022-11-21T09:59:01.752Z INFO Uploading image through SDFU: 53%
2022-11-21T09:59:01.912Z INFO Uploading image through SDFU: 54%
2022-11-21T09:59:01.912Z INFO Uploading image through SDFU: 55%
2022-11-21T09:59:01.912Z INFO Uploading image through SDFU: 56%
2022-11-21T09:59:02.073Z INFO Uploading image through SDFU: 57%
2022-11-21T09:59:02.073Z INFO Uploading image through SDFU: 58%
2022-11-21T09:59:02.235Z INFO Uploading image through SDFU: 59%
2022-11-21T09:59:02.235Z INFO Uploading image through SDFU: 60%
2022-11-21T09:59:02.235Z INFO Uploading image through SDFU: 61%
2022-11-21T09:59:02.396Z INFO Uploading image through SDFU: 62%
2022-11-21T09:59:02.396Z INFO Uploading image through SDFU: 63%
2022-11-21T09:59:02.396Z INFO Uploading image through SDFU: 64%
2022-11-21T09:59:02.557Z INFO Uploading image through SDFU: 65%
2022-11-21T09:59:02.557Z INFO Uploading image through SDFU: 66%
2022-11-21T09:59:02.718Z INFO Uploading image through SDFU: 67%
2022-11-21T09:59:02.718Z INFO Uploading image through SDFU: 68%
2022-11-21T09:59:02.718Z INFO Uploading image through SDFU: 69%
2022-11-21T09:59:02.879Z INFO Uploading image through SDFU: 70%
2022-11-21T09:59:02.879Z INFO Uploading image through SDFU: 71%
2022-11-21T09:59:02.879Z INFO Uploading image through SDFU: 72%
2022-11-21T09:59:03.040Z INFO Uploading image through SDFU: 73%
2022-11-21T09:59:03.040Z INFO Uploading image through SDFU: 74%
2022-11-21T09:59:03.201Z INFO Uploading image through SDFU: 75%
2022-11-21T09:59:03.202Z INFO Uploading image through SDFU: 76%
2022-11-21T09:59:03.202Z INFO Uploading image through SDFU: 77%
2022-11-21T09:59:03.363Z INFO Uploading image through SDFU: 78%
2022-11-21T09:59:03.363Z INFO Uploading image through SDFU: 79%
2022-11-21T09:59:03.363Z INFO Uploading image through SDFU: 80%
2022-11-21T09:59:03.524Z INFO Uploading image through SDFU: 81%
2022-11-21T09:59:03.524Z INFO Uploading image through SDFU: 82%
2022-11-21T09:59:03.685Z INFO Uploading image through SDFU: 83%
2022-11-21T09:59:03.686Z INFO Uploading image through SDFU: 84%
2022-11-21T09:59:03.686Z INFO Uploading image through SDFU: 85%
2022-11-21T09:59:03.847Z INFO Uploading image through SDFU: 86%
2022-11-21T09:59:03.847Z INFO Uploading image through SDFU: 87%
2022-11-21T09:59:03.847Z INFO Uploading image through SDFU: 88%
2022-11-21T09:59:04.008Z INFO Uploading image through SDFU: 89%
2022-11-21T09:59:04.008Z INFO Uploading image through SDFU: 90%
2022-11-21T09:59:04.169Z INFO Uploading image through SDFU: 91%
2022-11-21T09:59:04.170Z INFO Uploading image through SDFU: 92%
2022-11-21T09:59:04.170Z INFO Uploading image through SDFU: 93%
2022-11-21T09:59:04.332Z INFO Uploading image through SDFU: 94%
2022-11-21T09:59:04.332Z INFO Uploading image through SDFU: 95%
2022-11-21T09:59:04.333Z INFO Uploading image through SDFU: 96%
2022-11-21T09:59:04.492Z INFO Uploading image through SDFU: 97%
2022-11-21T09:59:04.492Z INFO Uploading image through SDFU: 98%
2022-11-21T09:59:04.653Z INFO Uploading image through SDFU: 99%
2022-11-21T09:59:04.653Z INFO Uploading image through SDFU: 100%
2022-11-21T09:59:04.782Z INFO Waiting for serial port to be attached: 0%
2022-11-21T09:59:05.265Z DEBUG Sending usage data {"category":"pc-nrfconnect-programmer","action":"Close device","label":""}
2022-11-21T09:59:05.267Z INFO Target device closed
2022-11-21T09:59:07.444Z INFO Device was attached: 100%
2022-11-21T09:59:07.444Z INFO Opening serial port for SDFU programming: 0%
2022-11-21T09:59:07.445Z INFO Opening serial port for SDFU programming: 100%
2022-11-21T09:59:07.445Z INFO Uploading image through SDFU: 0%
2022-11-21T09:59:07.445Z INFO Uploading image through SDFU: 1%
2022-11-21T09:59:07.445Z INFO Uploading image through SDFU: 3%
2022-11-21T09:59:07.445Z INFO Uploading image through SDFU: 4%
2022-11-21T09:59:07.445Z INFO Uploading image through SDFU: 6%
2022-11-21T09:59:07.445Z INFO Uploading image through SDFU: 7%
2022-11-21T09:59:07.445Z INFO Uploading image through SDFU: 9%
2022-11-21T09:59:07.445Z INFO Uploading image through SDFU: 10%
2022-11-21T09:59:07.445Z INFO Uploading image through SDFU: 12%
2022-11-21T09:59:09.286Z ERROR (Origin: "Error when running fw program.")
