Clarification of UART instances on NRF52840
Hi.
I am developing a custom board using the NRF52840. The mcu needs to connect to a modem and a gnss module. Both modules will communicate with the mcu over UART
I'm using the app_uart API, and it's not quite clear how to use this API with 2 instances (and when I say 2 "instances", I mean 2 physical UART interfaces).  Is that even posible?
Thanks.
Tim
  • APP_UART uses hardcoded instance in app_uart.c and app_uart_fifo.c in the below line.
    static nrf_drv_uart_t app_uart_inst = NRF_DRV_UART_INSTANCE(APP_UART_DRIVER_INSTANCE);
    It is a bit tricky to do multiple instances but it is possible. You need to have two instances of app_uart and edit the names like the API. For example you can have two new files into the project like app_uart1.h
     * Copyright (c) 2015 - 2021, Nordic Semiconductor ASA
     * All rights reserved.
    #include "sdk_common.h"
    #if NRF_MODULE_ENABLED(APP_UART)
    #include "app_uart.h"
    #include "nrf_drv_uart.h"
    #include "nrf_assert.h"
    static uint8_t tx_buffer[1];
    static uint8_t rx_buffer[1];
    static volatile bool rx_done;
    static app_uart_event_handler_t   m_event_handler;            /**< Event handler function. */
    static nrf_drv_uart_t app_uart_inst = NRF_DRV_UART_INSTANCE(APP_UART_DRIVER_INSTANCE_1);
    static void uart_event_handler(nrf_drv_uart_event_t * p_event, void* p_context)
        if (p_event->type == NRF_DRV_UART_EVT_RX_DONE)
            // Received bytes counter has to be checked, because there could be event from RXTO interrupt
            if (p_event->data.rxtx.bytes)
                app_uart_evt_t app_uart_event;
                app_uart_event.evt_type   = APP_UART_DATA;
                app_uart_event.data.value = p_event->data.rxtx.p_data[0];
                rx_done = true;
                m_event_handler(&app_uart_event);
            (void)nrf_drv_uart_rx(&app_uart_inst, rx_buffer, 1);
        else if (p_event->type == NRF_DRV_UART_EVT_ERROR)
            app_uart_event.evt_type                 = APP_UART_COMMUNICATION_ERROR;
            app_uart_event.data.error_communication = p_event->data.error.error_mask;
        else if (p_event->type == NRF_DRV_UART_EVT_TX_DONE)
           // Last byte from FIFO transmitted, notify the application.
           // Notify that new data is available if this was first byte put in the buffer.
           app_uart_event.evt_type = APP_UART_TX_EMPTY;
    uint32_t app_uart1_init(const app_uart_comm_params_t * p_comm_params,
                           app_uart_buffers_t           * p_buffers,
                           app_uart_event_handler_t       event_handler,
                           app_irq_priority_t             irq_priority)
        nrf_drv_uart_config_t config = NRF_DRV_UART_DEFAULT_CONFIG;
        config.baudrate = (nrf_uart_baudrate_t)p_comm_params->baud_rate;
        config.hwfc = (p_comm_params->flow_control == APP_UART_FLOW_CONTROL_DISABLED) ?
                NRF_UART_HWFC_DISABLED : NRF_UART_HWFC_ENABLED;
        config.interrupt_priority = irq_priority;
        config.parity = p_comm_params->use_parity ? NRF_UART_PARITY_INCLUDED : NRF_UART_PARITY_EXCLUDED;
        config.pselcts = p_comm_params->cts_pin_no;
        config.pselrts = p_comm_params->rts_pin_no;
        config.pselrxd = p_comm_params->rx_pin_no;
        config.pseltxd = p_comm_params->tx_pin_no;
        m_event_handler = event_handler;
        rx_done = false;
        uint32_t err_code = nrf_drv_uart_init(&app_uart_inst, &config, uart_event_handler);
        VERIFY_SUCCESS(err_code);
        // Turn on receiver if RX pin is connected
        if (p_comm_params->rx_pin_no != UART_PIN_DISCONNECTED)
            return nrf_drv_uart_rx(&app_uart_inst, rx_buffer,1);
            return NRF_SUCCESS;
    uint32_t app_uart1_get(uint8_t * p_byte)
        ASSERT(p_byte);
        uint32_t err_code = NRF_SUCCESS;
        if (rx_done)
            *p_byte = rx_buffer[0];
            rx_done = false;
            err_code = NRF_ERROR_NOT_FOUND;
        return err_code;
    uint32_t app_uart1_put(uint8_t byte)
        tx_buffer[0] = byte;
        ret_code_t ret =  nrf_drv_uart_tx(&app_uart_inst, tx_buffer, 1);
        if (NRF_ERROR_BUSY == ret)
            return NRF_ERROR_NO_MEM;
        else if (ret != NRF_SUCCESS)
            return NRF_ERROR_INTERNAL;
            return NRF_SUCCESS;
    uint32_t app_uart1_flush(void)
        return NRF_SUCCESS;
    uint32_t app_uart1_close(void)
        nrf_drv_uart_uninit(&app_uart_inst);
        return NRF_SUCCESS;
    #endif //NRF_MODULE_ENABLED(APP_UART)
    Where I have changed the API in app_uart1.c to have app_uart1_init etc.
    I also have app_uart_inst in app_uart1.c to use APP_UART_DRIVER_INSTANCE_1 (instead of APP_UART_DRIVER_INSTANCE) which you should add in your sdk_config.h file to use the second instance of the uart in app_uart1.c.
    And yes if you want app_uart to be used for two instances it is NOT possible without editing the libraries files.
    Second way is to use app_uart for one instance and nrf_drv_uart directly for the second instance.
