Change console/mcumgr uart from UART_0 to UART_1
I'm using the nRF Connect SDK v1.9.0 and a nRF5340 on a custom board.
I want to use MCUBoot as a primary bootloader. On the development kit, the UART connecting the nRF5340 and the interface IC is UART_0. There the project central_bas worked fine.
Now I have a board were UART_0 from the nRF5340 is connected to another IC, and I only have access to UART_1 over some pin header.
Is it possible to route the input and output that MCUBoot and e.g. mcumgr usually send via UART_0 over UART_1?
I tried to set a <BOARD>.overlay file:
    chosen {
        zephyr,console = &uart1;
		zephyr,shell-uart = &uart1;
		zephyr,uart-mcumgr = &uart1;
But this fails in linking with "undefined reference to uart1"
In the device.h file it says: If you get an error that looks like <tt>undefined reference to __device_dts_ord_<N></tt>, that is what happened. Check to make sure your device driver is being compiled, usually by enabling the Kconfig options it requires.
 * @def DEVICE_DT_GET
 * @brief Get a <tt>const struct device*</tt> from a devicetree node
 * identifier
 * @details Returns a pointer to a device object created from a
 * devicetree node, if any device was allocated by a driver.
 * If no such device was allocated, this will fail at linker time. If
 * you get an error that looks like <tt>undefined reference to
 * __device_dts_ord_<N></tt>, that is what happened. Check to make
 * sure your device driver is being compiled, usually by enabling the
 * Kconfig options it requires.
 * @param node_id A devicetree node identifier
 * @return A pointer to the device object created for that node
#define DEVICE_DT_GET(node_id) (&DEVICE_DT_NAME_GET(node_id))
What Kconfig is required to use UART_1 in this case?
Alex
prj.conf:
# Copyright (c) 2019 Nordic Semiconductor ASA
CONFIG_NCS_SAMPLES_DEFAULTS=y
CONFIG_BT=y
CONFIG_BT_DEBUG_LOG=y
CONFIG_BT_CENTRAL=y
CONFIG_BT_SMP=y
CONFIG_BT_GATT_CLIENT=y
CONFIG_BT_GATT_DM=y
CONFIG_HEAP_MEM_POOL_SIZE=1024
CONFIG_BT_BAS_CLIENT=y
CONFIG_BT_SCAN=y
CONFIG_BT_SCAN_FILTER_ENABLE=y
CONFIG_BT_SCAN_UUID_CNT=1
CONFIG_BT_PRIVACY=y
CONFIG_BT_SETTINGS=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
CONFIG_DK_LIBRARY=y
# --- Adding MCUBoot --- #
# Ensure an MCUboot-compatible binary is generated.
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_MCUBOOT_IMAGE_VERSION="1.0.0+1"	# maj.min.rev+build
# Enable mcumgr.
CONFIG_MCUMGR=y
# Enable most core commands.
CONFIG_MCUMGR_CMD_IMG_MGMT=y
CONFIG_MCUMGR_CMD_OS_MGMT=y
# Enable the serial mcumgr transport.
CONFIG_MCUMGR_SMP_UART=y
#CONFIG_MCUMGR_CMD_IMG_MGMT=y
# Some command handlers require a large stack. Important for mcumgr, would otherwise timeout
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
