Issue connecting from iPad Air to extended advertising set of nrf53
We are facing an issue where we cannot connect to an extended advertisement set from iPad Air 3rd gen with OS version 15.7 using either nRF Connect or LightBlue.
Connection to legacy advertisement set works fine, as does connecting from an Android P device.
The issue also appears with code from the nrf/samples/multiple_adv_sets sample with BT_LE_OPT_EXT_ADV flag added to the connectable set. Legacy set was commented out for clarity.
The version of SDK used is 3.1.99-dev2, issue was also present in 3.1.99-dev1 and 3.1.2.
The device appears with MAC ef:e5:fa:e1:62:e1 in the logs.
It appears the iPad is attempting to connect and does so, but drops the connection on client side with some error relating to device address.
Log of the attempt is attached. Packet capture (via nRF52340 dongle, nRF sniffer and Wireshark) is also attached.
If necessary, we can also enable debug info for the sample.
snifferCapture.pcapng.gz
Nov 23 09:55:19.912  HCI Command      0x0000  00:00:00:00:00:00  LE Extended Create Connection - Filter Accept List - 1M Scans: 30ms/300ms Conn Interval: 10ms/30ms - 2M Scans: 30ms/300ms Conn Interval: 10ms/30ms
	Opcode: 0x2043 (OGF: 0x08    OCF: 0x43)
	Parameter Length: 42 (0x2A)
	Filter Policy: Use Filter Accept List
	Own Address Type: Random
	Peer Address Type: Public
	Peer Address: 00:00:00:00:00:00
	PHY: LE 1M
		Scan Interval: 300 ms
		Scan Window: 30 ms
		Connection Interval Min: 10 ms
		Connection Interval Max: 30 ms
		Connection Latency: 0
		Supervision Timeout: 720 ms
		Minimum CE Length: 1.25 ms
		Maximum CE Length: 7.5 ms
	PHY: LE 2M
		Scan Window: 30 ms
Nov 23 09:55:19.912  HCI Command      0x0000                     00000000: 4320 2A01 0100 0000 0000 0000 03E0 0130  C *............0
Nov 23 09:55:19.916  HCI Event        0x0000                     Command Status - LE Extended Create Connection
	Parameter Length: 4 (0x04)
	Status: 0x00 - Success
	Num HCI Command Packets: 0x01
	Opcode: 0x2043 (OGF: 0x08    OCF: 0x43) - [Low Energy] LE Extended Create Connection
Nov 23 09:55:19.916  HCI Event        0x0000                     00000000: 0F04 0001 4320                           ....C
Nov 23 09:55:19.936  HCI Event        0x0000  68:27:37:4B:F2:A9  LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9  -74 dBm - Manufacturer Specific Data - Channel 39
Nov 23 09:55:19.937  HCI Event        0x0000  62:DB:94:51:E0:08  LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08  -73 dBm - Manufacturer Specific Data - Channel 37
Nov 23 09:55:20.004  HCI Event        0x0000  02:AD:F5:8E:3F:09  LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09  -71 dBm - Manufacturer Specific Data - Channel 39
Nov 23 09:55:20.044  HCI Event        0x0000  EF:E5:FA:E1:62:E1  LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1  -43 dBm - SID: 0 - Nordic multi adv sets - Channel 2
Nov 23 09:55:20.048  HCI Event        0x0000  7C:64:56:8A:BC:FB  LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB  -90 dBm - Manufacturer Specific Data - Channel 37
Nov 23 09:55:20.049  HCI Event        0x0000  68:27:37:4B:F2:A9  LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9  -81 dBm - Manufacturer Specific Data - Channel 39
Nov 23 09:55:20.049  HCI Event        0x0000  68:27:37:4B:F2:A9  LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9  -81 dBm - [AV] Samsung Soundbar MS550 - Channel 39
Nov 23 09:55:20.319  HCI Event        0x0000  02:AD:F5:8E:3F:09  LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09  -81 dBm - Manufacturer Specific Data - Channel 37
Nov 23 09:55:20.338  HCI Event        0x0000  40:ED:98:1A:BC:A8  LE - Ext ADV - 1 Report - Normal - Public - 40:ED:98:1A:BC:A8  -58 dBm - FiiO UTWS5 - Manufacturer Specific Data - Manufacturer Specific Data - Channel 37
Nov 23 09:55:20.338  HCI Event        0x0000  68:27:37:4B:F2:A9  LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9  -82 dBm - Manufacturer Specific Data - Channel 37
Nov 23 09:55:20.338  HCI Event        0x0000  68:27:37:4B:F2:A9  LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9  -82 dBm - [AV] Samsung Soundbar MS550 - Channel 37
Nov 23 09:55:20.353  HCI Event        0x0000  EF:E5:FA:E1:62:E1  LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1  -47 dBm - SID: 0 - Nordic multi adv sets - Channel 0
Nov 23 09:55:20.638  HCI Event        0x0000  02:AD:F5:8E:3F:09  LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09  -72 dBm - Manufacturer Specific Data - Channel 38
Nov 23 09:55:20.938  HCI Event        0x0000  7C:64:56:8A:BC:FB  LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB  -91 dBm - Manufacturer Specific Data - Channel 39
Nov 23 09:55:20.939  HCI Event        0x0000  7C:64:56:8A:BC:FB  LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB  -91 dBm - [TV] Samsung 6 Series (55) - Channel 39
Nov 23 09:55:20.941  HCI Event        0x0000  40:ED:98:1A:BC:A8  LE - Ext ADV - 1 Report - Normal - Public - 40:ED:98:1A:BC:A8  -51 dBm - FiiO UTWS5 - Manufacturer Specific Data - Manufacturer Specific Data - Channel 39
Nov 23 09:55:20.941  HCI Event        0x0000  40:ED:98:1A:BC:A8  LE - Ext ADV - 1 Report - Normal - Public - 40:ED:98:1A:BC:A8  -51 dBm - Manufacturer Specific Data - Channel 39
Nov 23 09:55:20.943  HCI Event        0x0000  68:27:37:4B:F2:A9  LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9  -81 dBm - Manufacturer Specific Data - Channel 39
Nov 23 09:55:20.943  HCI Event        0x0000  68:27:37:4B:F2:A9  LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9  -81 dBm - [AV] Samsung Soundbar MS550 - Channel 39
Nov 23 09:55:20.944  HCI Event        0x0000  02:AD:F5:8E:3F:09  LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09  -81 dBm - Manufacturer Specific Data - Channel 39
Nov 23 09:55:20.958  HCI Event        0x0000  7C:64:56:8A:BC:FB  LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB  -91 dBm - Manufacturer Specific Data - Channel 39
Nov 23 09:55:20.958  HCI Event        0x0000  7C:64:56:8A:BC:FB  LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB  -89 dBm - [TV] Samsung 6 Series (55) - Channel 39
Nov 23 09:55:21.499  HCI Event        0x0000  EF:E5:FA:E1:62:E1  LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1  -45 dBm - SID: 0 - Nordic multi adv sets - Channel 0
Nov 23 09:55:21.503  HCI Event        0x0000  62:DB:94:51:E0:08  LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08  -73 dBm - Manufacturer Specific Data - Channel 37
Nov 23 09:55:21.546  HCI Event        0x0000  7C:64:56:8A:BC:FB  LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB  -90 dBm - Manufacturer Specific Data - Channel 37
Nov 23 09:55:21.820  HCI Event        0x0000  62:DB:94:51:E0:08  LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08  -76 dBm - Manufacturer Specific Data - Channel 39
Nov 23 09:55:21.821  HCI Event        0x0000  7C:64:56:8A:BC:FB  LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB  -91 dBm - Manufacturer Specific Data - Channel 38
Nov 23 09:55:21.823  HCI Event        0x0000  68:27:37:4B:F2:A9  LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9  -74 dBm - Manufacturer Specific Data - Channel 38
Nov 23 09:55:21.859  HCI Event        0x0000  7C:64:56:8A:BC:FB  LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB  -90 dBm - Manufacturer Specific Data - Channel 39
Nov 23 09:55:21.860  HCI Event        0x0000  7C:64:56:8A:BC:FB  LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB  -90 dBm - [TV] Samsung 6 Series (55) - Channel 39
Nov 23 09:55:22.154  HCI Event        0x0000  68:27:37:4B:F2:A9  LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9  -74 dBm - Manufacturer Specific Data - Channel 39
Nov 23 09:55:22.155  HCI Event        0x0000  62:DB:94:51:E0:08  LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08  -74 dBm - Manufacturer Specific Data - Channel 37
Nov 23 09:55:22.155  HCI Event        0x0000  62:DB:94:51:E0:08  LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08  -74 dBm - [LG] webOS TV OLED48CX9LB - Channel 37
Nov 23 09:55:22.413  HCI Event        0x0000  7C:64:56:8A:BC:FB  LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB  -90 dBm - Manufacturer Specific Data - Channel 37
Nov 23 09:55:22.414  HCI Event        0x0000  EF:E5:FA:E1:62:E1  LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1  -51 dBm - SID: 0 - Nordic multi adv sets - Channel 0
Nov 23 09:55:22.417  HCI Event        0x0000  02:AD:F5:8E:3F:09  LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09  -76 dBm - Manufacturer Specific Data - Channel 37
Nov 23 09:55:22.449  HCI Event        0x0000  62:DB:94:51:E0:08  LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08  -76 dBm - Manufacturer Specific Data - Channel 38
Nov 23 09:55:22.450  HCI Event        0x0000  62:DB:94:51:E0:08  LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08  -76 dBm - [LG] webOS TV OLED48CX9LB - Channel 38
Nov 23 09:55:22.465  HCI Event        0x0000  40:ED:98:1A:BC:A8  LE - Ext ADV - 1 Report - Normal - Public - 40:ED:98:1A:BC:A8  -53 dBm - FiiO UTWS5 - Manufacturer Specific Data - Manufacturer Specific Data - Channel 38
Nov 23 09:55:22.465  HCI Event        0x0000  40:ED:98:1A:BC:A8  LE - Ext ADV - 1 Report - Normal - Public - 40:ED:98:1A:BC:A8  -53 dBm - Manufacturer Specific Data - Channel 38
Nov 23 09:55:22.720  HCI Event        0x0000  7C:64:56:8A:BC:FB  LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB  -92 dBm - Manufacturer Specific Data - Channel 37
Nov 23 09:55:22.722  HCI Event        0x0000  EF:E5:FA:E1:62:E1  LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1  -55 dBm - SID: 0 - Nordic multi adv sets - Channel 1
Nov 23 09:55:22.729  HCI Event        0x0000  02:AD:F5:8E:3F:09  LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09  -70 dBm - Manufacturer Specific Data - Channel 39
Nov 23 09:55:23.006  HCI Event        0x0000  7C:64:56:8A:BC:FB  LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB  -90 dBm - Manufacturer Specific Data - Channel 39
Nov 23 09:55:23.021  HCI Event        0x0000  EF:E5:FA:E1:62:E1  LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1  -51 dBm - SID: 0 - Nordic multi adv sets - Channel 2
Nov 23 09:55:23.046  HCI Event        0x0000  02:AD:F5:8E:3F:09  LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09  -76 dBm - Manufacturer Specific Data - Channel 37
Nov 23 09:55:23.322  HCI Event        0x0000  EF:E5:FA:E1:62:E1  LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1  -43 dBm - SID: 0 - Nordic multi adv sets - Channel 0
Nov 23 09:55:23.357  HCI Event        0x0000  7C:64:56:8A:BC:FB  LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB  -90 dBm - Manufacturer Specific Data - Channel 37
Nov 23 09:55:23.364  HCI Event        0x0000  02:AD:F5:8E:3F:09  LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09  -70 dBm - Manufacturer Specific Data - Channel 38
Nov 23 09:55:23.623  HCI Event        0x0000  EF:E5:FA:E1:62:E1  LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1  -51 dBm - SID: 0 - Nordic multi adv sets - Channel 1
Nov 23 09:55:23.913  HCI Event        0x0000  EF:E5:FA:E1:62:E1  LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1  -47 dBm - SID: 0 - Nordic multi adv sets - Channel 2
Nov 23 09:55:24.206  HCI Event        0x0000  7C:64:56:8A:BC:FB  LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB  -91 dBm - Manufacturer Specific Data - Channel 38
Nov 23 09:55:24.207  HCI Event        0x0000  7C:64:56:8A:BC:FB  LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB  -91 dBm - Manufacturer Specific Data - Channel 37
Nov 23 09:55:24.215  HCI Event        0x0000  EF:E5:FA:E1:62:E1  LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1  -54 dBm - SID: 0 - Nordic multi adv sets - Channel 0
Nov 23 09:55:24.232  HCI Event        0x0000  68:27:37:4B:F2:A9  LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9  -82 dBm - Manufacturer Specific Data - Channel 39
Nov 23 09:55:24.232  HCI Event        0x0000  62:DB:94:51:E0:08  LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08  -73 dBm - Manufacturer Specific Data - Channel 37
Nov 23 09:55:24.251  HCI Event        0x0000  40:ED:98:1A:BC:A8  LE - Ext ADV - 1 Report - Normal - Public - 40:ED:98:1A:BC:A8  -53 dBm - FiiO UTWS5 - Manufacturer Specific Data - Manufacturer Specific Data - Channel 38
Nov 23 09:55:24.251  HCI Event        0x0000  40:ED:98:1A:BC:A8  LE - Ext ADV - 1 Report - Normal - Public - 40:ED:98:1A:BC:A8  -53 dBm - Manufacturer Specific Data - Channel 38
Nov 23 09:55:24.507  HCI Event        0x0000  7C:64:56:8A:BC:FB  LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB  -91 dBm - Manufacturer Specific Data - Channel 37
Nov 23 09:55:24.519  HCI Event        0x0000  02:AD:F5:8E:3F:09  LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09  -71 dBm - Manufacturer Specific Data - Channel 39
Nov 23 09:55:24.523  HCI Event        0x0000  EF:E5:FA:E1:62:E1  LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1  -43 dBm - SID: 0 - Nordic multi adv sets - Channel 1
Nov 23 09:55:24.554  HCI Event        0x0000  62:DB:94:51:E0:08  LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08  -87 dBm - Manufacturer Specific Data - Channel 39
Nov 23 09:55:24.555  HCI Event        0x0000  62:DB:94:51:E0:08  LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08  -87 dBm - [LG] webOS TV OLED48CX9LB - Channel 39
Nov 23 09:55:24.823  HCI Event        0x0000  EF:E5:FA:E1:62:E1  LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1  -45 dBm - SID: 0 - Nordic multi adv sets - Channel 2
Nov 23 09:55:24.838  HCI Event        0x0000  02:AD:F5:8E:3F:09  LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09  -76 dBm - Manufacturer Specific Data - Channel 37
Nov 23 09:55:24.847  HCI Event        0x0000  7C:64:56:8A:BC:FB  LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB  -91 dBm - Manufacturer Specific Data - Channel 39
Nov 23 09:55:24.847  HCI Event        0x0000  7C:64:56:8A:BC:FB  LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB  -92 dBm - Manufacturer Specific Data - Channel 37
Nov 23 09:55:24.847  HCI Event        0x0000  7C:64:56:8A:BC:FB  LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB  -92 dBm - [TV] Samsung 6 Series (55) - Channel 37
Nov 23 09:55:24.863  HCI Event        0x0000  40:ED:98:1A:BC:A8  LE - Ext ADV - 1 Report - Normal - Public - 40:ED:98:1A:BC:A8  -53 dBm - FiiO UTWS5 - Manufacturer Specific Data - Manufacturer Specific Data - Channel 39
Nov 23 09:55:24.864  HCI Event        0x0000  68:27:37:4B:F2:A9  LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9  -82 dBm - Manufacturer Specific Data - Channel 37
Nov 23 09:55:24.864  HCI Event        0x0000  68:27:37:4B:F2:A9  LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9  -82 dBm - [AV] Samsung Soundbar MS550 - Channel 37
Nov 23 09:55:25.118  HCI Event        0x0000  EF:E5:FA:E1:62:E1  LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1  -46 dBm - SID: 0 - Nordic multi adv sets - Channel 0
Nov 23 09:55:25.145  HCI Event        0x0000  02:AD:F5:8E:3F:09  LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09  -71 dBm - Manufacturer Specific Data - Channel 38
Nov 23 09:55:25.409  HCI Event        0x0000  EF:E5:FA:E1:62:E1  LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1  -47 dBm - SID: 0 - Nordic multi adv sets - Channel 1
Nov 23 09:55:25.423  HCI Event        0x0000  62:DB:94:51:E0:08  LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08  -75 dBm - Manufacturer Specific Data - Channel 39
Nov 23 09:55:25.440  HCI Event        0x0000  68:27:37:4B:F2:A9  LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9  -81 dBm - Manufacturer Specific Data - Channel 39
Nov 23 09:55:25.440  HCI Event        0x0000  68:27:37:4B:F2:A9  LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9  -81 dBm - [AV] Samsung Soundbar MS550 - Channel 39
Nov 23 09:55:25.451  HCI Event        0x0000  02:AD:F5:8E:3F:09  LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09  -80 dBm - Manufacturer Specific Data - Channel 39
Nov 23 09:55:25.727  HCI Event        0x0000  62:DB:94:51:E0:08  LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08  -86 dBm - Manufacturer Specific Data - Channel 37
Nov 23 09:55:25.764  HCI Event        0x0000  02:AD:F5:8E:3F:09  LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09  -76 dBm - Manufacturer Specific Data - Channel 37
Nov 23 09:55:26.015  HCI Event        0x0000  7C:64:56:8A:BC:FB  LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB  -90 dBm - Manufacturer Specific Data - Channel 37
Nov 23 09:55:26.016  HCI Event        0x0000  68:27:37:4B:F2:A9  LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9  -81 dBm - Manufacturer Specific Data - Channel 37
Nov 23 09:55:26.023  HCI Event        0x0000  62:DB:94:51:E0:08  LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08  -74 dBm - Manufacturer Specific Data - Channel 37
Nov 23 09:55:26.029  HCI Event        0x0000  EF:E5:FA:E1:62:E1  LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1  -47 dBm - SID: 0 - Nordic multi adv sets - Channel 0
Nov 23 09:55:26.044  HCI Event        0x0000  68:27:37:4B:F2:A9  LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9  -82 dBm - Manufacturer Specific Data - Channel 37
Nov 23 09:55:26.045  HCI Event        0x0000  7C:64:56:8A:BC:FB  LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB  -90 dBm - Manufacturer Specific Data - Channel 38
Nov 23 09:55:26.314  HCI Event        0x0000  EF:E5:FA:E1:62:E1  LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1  -43 dBm - SID: 0 - Nordic multi adv sets - Channel 1
Nov 23 09:55:26.318  HCI Event        0x0000  40:ED:98:1A:BC:A8  LE - Ext ADV - 1 Report - Normal - Public - 40:ED:98:1A:BC:A8  -58 dBm - FiiO UTWS5 - Manufacturer Specific Data - Manufacturer Specific Data - Channel 37
Nov 23 09:55:26.330  HCI Event        0x0000  62:DB:94:51:E0:08  LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08  -76 dBm - Manufacturer Specific Data - Channel 39
Nov 23 09:55:26.365  HCI Event        0x0000  7C:64:56:8A:BC:FB  LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB  -90 dBm - Manufacturer Specific Data - Channel 38
Nov 23 09:55:26.365  HCI Event        0x0000  7C:64:56:8A:BC:FB  LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB  -91 dBm - Manufacturer Specific Data - Channel 39
Nov 23 09:55:26.366  HCI Event        0x0000  7C:64:56:8A:BC:FB  LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB  -90 dBm - [TV] Samsung 6 Series (55) - Channel 39
Nov 23 09:55:26.600  HCI Event        0x0000  02:AD:F5:8E:3F:09  LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09  -76 dBm - Manufacturer Specific Data - Channel 37
Nov 23 09:55:26.601  HCI Event        0x0000  02:AD:F5:8E:3F:09  LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09  -80 dBm - Manufacturer Specific Data - Channel 37
Nov 23 09:55:26.612  HCI Event        0x0000  EF:E5:FA:E1:62:E1  LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1  -42 dBm - SID: 0 - Nordic multi adv sets - Channel 2
Nov 23 09:55:26.641  HCI Event        0x0000  68:27:37:4B:F2:A9  LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9  -74 dBm - Manufacturer Specific Data - Channel 39
Nov 23 09:55:26.641  HCI Event        0x0000  62:DB:94:51:E0:08  LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08  -74 dBm - Manufacturer Specific Data - Channel 37
Nov 23 09:55:26.641  HCI Event        0x0000  62:DB:94:51:E0:08  LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08  -74 dBm - [LG] webOS TV OLED48CX9LB - Channel 37
Nov 23 09:55:26.914  HCI Event        0x0000  02:AD:F5:8E:3F:09  LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09  -76 dBm - Manufacturer Specific Data - Channel 37
Nov 23 09:55:26.916  HCI Event        0x0000  EF:E5:FA:E1:62:E1  LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1  -52 dBm - SID: 0 - Nordic multi adv sets - Channel 0
	Parameter Length: 56 (0x38)
	Num Reports: 0X01
	Report 0
		Event Type: Connectable Advertising - Complete -
		Peer Address: EF:E5:FA:E1:62:E1
		Primary PHY: 1M
		Secondary PHY: 2M
		Advertising SID: 0x0
		Tx Power: Unavailable
		RSSI: -52 dBm
		Periodic Advertising Interval: 0.000000ms (0x0)
		Direct Address Type: Public
		Direct Address: 00:00:00:00:00:00
		Data Length: 30
		Flags: 0x6
			LE Limited General Discoverable Mode
			BR/EDR Not Supported
		16 Bit UUIDs: 0X180A
		Local Name: Nordic multi adv sets
		Data: 02 01 06 03 03 0A 18 16 09 4E 6F 72 64 69 63 20 6D 75 6C 74 69 20 61 64 76 20 73 65 74 73
Nov 23 09:55:26.916  HCI Event        0x0000                     00000000: 3E38 0D01 0100 01E1 62E1 FAE5 EF01 0200  >8......b.......
Nov 23 09:55:26.954  HCI Event        0x0000  62:DB:94:51:E0:08  LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08  -76 dBm - Manufacturer Specific Data - Channel 38
Nov 23 09:55:26.955  HCI Event        0x0000  62:DB:94:51:E0:08  LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08  -76 dBm - [LG] webOS TV OLED48CX9LB - Channel 38
Nov 23 09:55:27.213  HCI Event        0x0000  EF:E5:FA:E1:62:E1  LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1  -42 dBm - SID: 0 - Nordic multi adv sets - Channel 1
Nov 23 09:55:27.228  HCI Event        0x0000  02:AD:F5:8E:3F:09  LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09  -70 dBm - Manufacturer Specific Data - Channel 39
Nov 23 09:55:27.260  HCI Event        0x0000  62:DB:94:51:E0:08  LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08  -85 dBm - Manufacturer Specific Data - Channel 39
Nov 23 09:55:27.262  HCI Event        0x0000  62:DB:94:51:E0:08  LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08  -85 dBm - [LG] webOS TV OLED48CX9LB - Channel 39
Nov 23 09:55:27.522  HCI Event        0x0000  EF:E5:FA:E1:62:E1  LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1  -51 dBm - SID: 0 - Nordic multi adv sets - Channel 2
Nov 23 09:55:27.533  HCI Event        0x0000  02:AD:F5:8E:3F:09  LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09  -79 dBm - Manufacturer Specific Data - Channel 37
Nov 23 09:55:27.559  HCI Event        0x0000  7C:64:56:8A:BC:FB  LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB  -90 dBm - Manufacturer Specific Data - Channel 38
Nov 23 09:55:27.559  HCI Event        0x0000  7C:64:56:8A:BC:FB  LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB  -92 dBm - Manufacturer Specific Data - Channel 37
Nov 23 09:55:27.559  HCI Event        0x0000  7C:64:56:8A:BC:FB  LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB  -92 dBm - [TV] Samsung 6 Series (55) - Channel 37
Nov 23 09:55:27.563  HCI Event        0x0000  40:ED:98:1A:BC:A8  LE - Ext ADV - 1 Report - Normal - Public - 40:ED:98:1A:BC:A8  -58 dBm - FiiO UTWS5 - Manufacturer Specific Data - Manufacturer Specific Data - Channel 37
Nov 23 09:55:27.563  HCI Event        0x0000  40:ED:98:1A:BC:A8  LE - Ext ADV - 1 Report - Normal - Public - 40:ED:98:1A:BC:A8  -58 dBm - Manufacturer Specific Data - Channel 37
Nov 23 09:55:27.571  HCI Event        0x0000  68:27:37:4B:F2:A9  LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9  -81 dBm - Manufacturer Specific Data - Channel 37
Nov 23 09:55:27.571  HCI Event        0x0000  62:DB:94:51:E0:08  LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08  -74 dBm - Manufacturer Specific Data - Channel 37
Nov 23 09:55:27.571  HCI Event        0x0000  62:DB:94:51:E0:08  LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08  -74 dBm - [LG] webOS TV OLED48CX9LB - Channel 37
Nov 23 09:55:27.815  HCI Event        0x0000  EF:E5:FA:E1:62:E1  LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1  -44 dBm - SID: 0 - Nordic multi adv sets - Channel 0
Nov 23 09:55:27.836  HCI Event        0x0000  02:AD:F5:8E:3F:09  LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09  -71 dBm - Manufacturer Specific Data - Channel 38
Nov 23 09:55:27.865  HCI Event        0x0000  68:27:37:4B:F2:A9  LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9  -74 dBm - Manufacturer Specific Data - Channel 38
Nov 23 09:55:27.865  HCI Event        0x0000  68:27:37:4B:F2:A9  LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9  -74 dBm - [AV] Samsung Soundbar MS550 - Channel 38
Nov 23 09:55:28.111  HCI Event        0x0000  EF:E5:FA:E1:62:E1  LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1  -47 dBm - SID: 0 - Nordic multi adv sets - Channel 1
Nov 23 09:55:28.122  HCI Event        0x0000  62:DB:94:51:E0:08  LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08  -75 dBm - Manufacturer Specific Data - Channel 39
Nov 23 09:55:28.150  HCI Event        0x0000  02:AD:F5:8E:3F:09  LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09  -79 dBm - Manufacturer Specific Data - Channel 39
Nov 23 09:55:28.166  HCI Event        0x0000  7C:64:56:8A:BC:FB  LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB  -88 dBm - Manufacturer Specific Data - Channel 38
Nov 23 09:55:28.166  HCI Event        0x0000  68:27:37:4B:F2:A9  LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9  -81 dBm - Manufacturer Specific Data - Channel 39
Nov 23 09:55:28.166  HCI Event        0x0000  68:27:37:4B:F2:A9  LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9  -81 dBm - [AV] Samsung Soundbar MS550 - Channel 39
Nov 23 09:55:28.419  HCI Event        0x0000  EF:E5:FA:E1:62:E1  LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1  -51 dBm - SID: 0 - Nordic multi adv sets - Channel 2
Nov 23 09:55:28.464  HCI Event        0x0000  02:AD:F5:8E:3F:09  LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09  -75 dBm - Manufacturer Specific Data - Channel 37
Nov 23 09:55:28.717  HCI Event        0x0000  EF:E5:FA:E1:62:E1  LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1  -52 dBm - SID: 0 - Nordic multi adv sets - Channel 0
Nov 23 09:55:28.727  HCI Event        0x0000  62:DB:94:51:E0:08  LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08  -73 dBm - Manufacturer Specific Data - Channel 37
Nov 23 09:55:28.754  HCI Event        0x0000  68:27:37:4B:F2:A9  LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9  -74 dBm - Manufacturer Specific Data - Channel 38
Nov 23 09:55:28.754  HCI Event        0x0000  68:27:37:4B:F2:A9  LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9  -74 dBm - [AV] Samsung Soundbar MS550 - Channel 38
Nov 23 09:55:28.895  HCI Command      0x0000                     LE Create Connection Cancel
	Opcode: 0x200E (OGF: 0x08    OCF: 0x0E)
	Parameter Length: 0 (0x00)
Nov 23 09:55:28.895  HCI Command      0x0000                     00000000: 0E20 00                                  . .
Nov 23 09:55:28.907  HCI Event        0x0000                     Command Complete [200E] - LE Create Connection Cancel
	Opcode: 0x200E (OGF: 0x08    OCF: 0x0E) - [Low Energy] LE Create Connection Cancel
Nov 23 09:55:28.907  HCI Event        0x0000                     00000000: 0E04 010E 2000                           .... .
Nov 23 09:55:28.908  HCI Event        0x0040  00:00:00:00:00:00  LE - Enhanced Connection Complete - Unknown Connection Identifier
	Parameter Length: 31 (0x1F)
	Status: 0x02 - Unknown Connection Identifier
	Connection Handle: 0x0040
	Role: 0x0 (Central)
	Peer Address Type: Random
	Peer Address: (null)
	Local Resolvable Private Address: 00:00:00:00:00:00
	Peer Resolvable Private Address: 00:00:00:00:00:00
	Connection Interval: 0x18 (30 ms)
	Connection Latency: 0x0 (0 ms)
	Supervision Timeout: 0x48 (720 ms)
	Central Clock Accuracy: 0x0
Nov 23 09:55:28.908  HCI Event        0x0000                     00000000: 3E1F 0A02 4000 0001 E162 E1FA E5EF 0000  >[email protected]......
Nov 23 09:55:28.909  HCI Command      0x0000  EF:E5:FA:E1:62:E1  LE Remove Device From Filter Accept List - Random - EF:E5:FA:E1:62:E1
	Opcode: 0x2012 (OGF: 0x08    OCF: 0x12)
	Parameter Length: 7 (0x07)
Nov 23 09:55:28.909  HCI Command      0x0000                     00000000: 1220 0701 E162 E1FA E5EF                 . ...b....
Nov 23 09:55:28.914  HCI Event        0x0000                     Command Complete [2012] - LE Remove Device From Filter Accept List
	Opcode: 0x2012 (OGF: 0x08    OCF: 0x12) - [Low Energy] LE Remove Device From Filter Accept List
Nov 23 09:55:28.914  HCI Event        0x0000                     00000000: 0E04 0112 2000                           .... .
iPadAirLogs.txt
