We are facing an issue where we cannot connect to an extended advertisement set from iPad Air 3rd gen with OS version 15.7 using either nRF Connect or LightBlue.
Connection to legacy advertisement set works fine, as does connecting from an Android P device.
The issue also appears with code from the nrf/samples/multiple_adv_sets sample with BT_LE_OPT_EXT_ADV flag added to the connectable set. Legacy set was commented out for clarity.
The version of SDK used is 3.1.99-dev2, issue was also present in 3.1.99-dev1 and 3.1.2.
The device appears with MAC ef:e5:fa:e1:62:e1 in the logs.
It appears the iPad is attempting to connect and does so, but drops the connection on client side with some error relating to device address.
Log of the attempt is attached. Packet capture (via nRF52340 dongle, nRF sniffer and Wireshark) is also attached.
If necessary, we can also enable debug info for the sample.
Nov 23 09:55:19.912 HCI Command 0x0000 00:00:00:00:00:00 LE Extended Create Connection - Filter Accept List - 1M Scans: 30ms/300ms Conn Interval: 10ms/30ms - 2M Scans: 30ms/300ms Conn Interval: 10ms/30ms Opcode: 0x2043 (OGF: 0x08 OCF: 0x43) Parameter Length: 42 (0x2A) Filter Policy: Use Filter Accept List Own Address Type: Random Peer Address Type: Public Peer Address: 00:00:00:00:00:00 PHY: LE 1M Scan Interval: 300 ms Scan Window: 30 ms Connection Interval Min: 10 ms Connection Interval Max: 30 ms Connection Latency: 0 Supervision Timeout: 720 ms Minimum CE Length: 1.25 ms Maximum CE Length: 7.5 ms PHY: LE 2M Scan Interval: 300 ms Scan Window: 30 ms Connection Interval Min: 10 ms Connection Interval Max: 30 ms Connection Latency: 0 Supervision Timeout: 720 ms Minimum CE Length: 1.25 ms Maximum CE Length: 7.5 ms Nov 23 09:55:19.912 HCI Command 0x0000 00000000: 4320 2A01 0100 0000 0000 0000 03E0 0130 C *............0 Nov 23 09:55:19.916 HCI Event 0x0000 Command Status - LE Extended Create Connection Parameter Length: 4 (0x04) Status: 0x00 - Success Num HCI Command Packets: 0x01 Opcode: 0x2043 (OGF: 0x08 OCF: 0x43) - [Low Energy] LE Extended Create Connection Nov 23 09:55:19.916 HCI Event 0x0000 00000000: 0F04 0001 4320 ....C Nov 23 09:55:19.936 HCI Event 0x0000 68:27:37:4B:F2:A9 LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9 -74 dBm - Manufacturer Specific Data - Channel 39 Nov 23 09:55:19.937 HCI Event 0x0000 62:DB:94:51:E0:08 LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08 -73 dBm - Manufacturer Specific Data - Channel 37 Nov 23 09:55:20.004 HCI Event 0x0000 02:AD:F5:8E:3F:09 LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09 -71 dBm - Manufacturer Specific Data - Channel 39 Nov 23 09:55:20.044 HCI Event 0x0000 EF:E5:FA:E1:62:E1 LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1 -43 dBm - SID: 0 - Nordic multi adv sets - Channel 2 Nov 23 09:55:20.048 HCI Event 0x0000 7C:64:56:8A:BC:FB LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB -90 dBm - Manufacturer Specific Data - Channel 37 Nov 23 09:55:20.049 HCI Event 0x0000 68:27:37:4B:F2:A9 LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9 -81 dBm - Manufacturer Specific Data - Channel 39 Nov 23 09:55:20.049 HCI Event 0x0000 68:27:37:4B:F2:A9 LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9 -81 dBm - [AV] Samsung Soundbar MS550 - Channel 39 Nov 23 09:55:20.319 HCI Event 0x0000 02:AD:F5:8E:3F:09 LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09 -81 dBm - Manufacturer Specific Data - Channel 37 Nov 23 09:55:20.338 HCI Event 0x0000 40:ED:98:1A:BC:A8 LE - Ext ADV - 1 Report - Normal - Public - 40:ED:98:1A:BC:A8 -58 dBm - FiiO UTWS5 - Manufacturer Specific Data - Manufacturer Specific Data - Channel 37 Nov 23 09:55:20.338 HCI Event 0x0000 68:27:37:4B:F2:A9 LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9 -82 dBm - Manufacturer Specific Data - Channel 37 Nov 23 09:55:20.338 HCI Event 0x0000 68:27:37:4B:F2:A9 LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9 -82 dBm - [AV] Samsung Soundbar MS550 - Channel 37 Nov 23 09:55:20.353 HCI Event 0x0000 EF:E5:FA:E1:62:E1 LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1 -47 dBm - SID: 0 - Nordic multi adv sets - Channel 0 Nov 23 09:55:20.638 HCI Event 0x0000 02:AD:F5:8E:3F:09 LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09 -72 dBm - Manufacturer Specific Data - Channel 38 Nov 23 09:55:20.938 HCI Event 0x0000 7C:64:56:8A:BC:FB LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB -91 dBm - Manufacturer Specific Data - Channel 39 Nov 23 09:55:20.939 HCI Event 0x0000 7C:64:56:8A:BC:FB LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB -91 dBm - [TV] Samsung 6 Series (55) - Channel 39 Nov 23 09:55:20.941 HCI Event 0x0000 40:ED:98:1A:BC:A8 LE - Ext ADV - 1 Report - Normal - Public - 40:ED:98:1A:BC:A8 -51 dBm - FiiO UTWS5 - Manufacturer Specific Data - Manufacturer Specific Data - Channel 39 Nov 23 09:55:20.941 HCI Event 0x0000 40:ED:98:1A:BC:A8 LE - Ext ADV - 1 Report - Normal - Public - 40:ED:98:1A:BC:A8 -51 dBm - Manufacturer Specific Data - Channel 39 Nov 23 09:55:20.943 HCI Event 0x0000 68:27:37:4B:F2:A9 LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9 -81 dBm - Manufacturer Specific Data - Channel 39 Nov 23 09:55:20.943 HCI Event 0x0000 68:27:37:4B:F2:A9 LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9 -81 dBm - [AV] Samsung Soundbar MS550 - Channel 39 Nov 23 09:55:20.944 HCI Event 0x0000 02:AD:F5:8E:3F:09 LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09 -81 dBm - Manufacturer Specific Data - Channel 39 Nov 23 09:55:20.958 HCI Event 0x0000 7C:64:56:8A:BC:FB LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB -91 dBm - Manufacturer Specific Data - Channel 39 Nov 23 09:55:20.958 HCI Event 0x0000 7C:64:56:8A:BC:FB LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB -89 dBm - [TV] Samsung 6 Series (55) - Channel 39 Nov 23 09:55:21.499 HCI Event 0x0000 EF:E5:FA:E1:62:E1 LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1 -45 dBm - SID: 0 - Nordic multi adv sets - Channel 0 Nov 23 09:55:21.503 HCI Event 0x0000 62:DB:94:51:E0:08 LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08 -73 dBm - Manufacturer Specific Data - Channel 37 Nov 23 09:55:21.546 HCI Event 0x0000 7C:64:56:8A:BC:FB LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB -90 dBm - Manufacturer Specific Data - Channel 37 Nov 23 09:55:21.820 HCI Event 0x0000 62:DB:94:51:E0:08 LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08 -76 dBm - Manufacturer Specific Data - Channel 39 Nov 23 09:55:21.821 HCI Event 0x0000 7C:64:56:8A:BC:FB LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB -91 dBm - Manufacturer Specific Data - Channel 38 Nov 23 09:55:21.823 HCI Event 0x0000 68:27:37:4B:F2:A9 LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9 -74 dBm - Manufacturer Specific Data - Channel 38 Nov 23 09:55:21.859 HCI Event 0x0000 7C:64:56:8A:BC:FB LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB -90 dBm - Manufacturer Specific Data - Channel 39 Nov 23 09:55:21.860 HCI Event 0x0000 7C:64:56:8A:BC:FB LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB -90 dBm - [TV] Samsung 6 Series (55) - Channel 39 Nov 23 09:55:22.154 HCI Event 0x0000 68:27:37:4B:F2:A9 LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9 -74 dBm - Manufacturer Specific Data - Channel 39 Nov 23 09:55:22.155 HCI Event 0x0000 62:DB:94:51:E0:08 LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08 -74 dBm - Manufacturer Specific Data - Channel 37 Nov 23 09:55:22.155 HCI Event 0x0000 62:DB:94:51:E0:08 LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08 -74 dBm - [LG] webOS TV OLED48CX9LB - Channel 37 Nov 23 09:55:22.413 HCI Event 0x0000 7C:64:56:8A:BC:FB LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB -90 dBm - Manufacturer Specific Data - Channel 37 Nov 23 09:55:22.414 HCI Event 0x0000 EF:E5:FA:E1:62:E1 LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1 -51 dBm - SID: 0 - Nordic multi adv sets - Channel 0 Nov 23 09:55:22.417 HCI Event 0x0000 02:AD:F5:8E:3F:09 LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09 -76 dBm - Manufacturer Specific Data - Channel 37 Nov 23 09:55:22.449 HCI Event 0x0000 62:DB:94:51:E0:08 LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08 -76 dBm - Manufacturer Specific Data - Channel 38 Nov 23 09:55:22.450 HCI Event 0x0000 62:DB:94:51:E0:08 LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08 -76 dBm - [LG] webOS TV OLED48CX9LB - Channel 38 Nov 23 09:55:22.465 HCI Event 0x0000 40:ED:98:1A:BC:A8 LE - Ext ADV - 1 Report - Normal - Public - 40:ED:98:1A:BC:A8 -53 dBm - FiiO UTWS5 - Manufacturer Specific Data - Manufacturer Specific Data - Channel 38 Nov 23 09:55:22.465 HCI Event 0x0000 40:ED:98:1A:BC:A8 LE - Ext ADV - 1 Report - Normal - Public - 40:ED:98:1A:BC:A8 -53 dBm - Manufacturer Specific Data - Channel 38 Nov 23 09:55:22.720 HCI Event 0x0000 7C:64:56:8A:BC:FB LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB -92 dBm - Manufacturer Specific Data - Channel 37 Nov 23 09:55:22.722 HCI Event 0x0000 EF:E5:FA:E1:62:E1 LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1 -55 dBm - SID: 0 - Nordic multi adv sets - Channel 1 Nov 23 09:55:22.729 HCI Event 0x0000 02:AD:F5:8E:3F:09 LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09 -70 dBm - Manufacturer Specific Data - Channel 39 Nov 23 09:55:23.006 HCI Event 0x0000 7C:64:56:8A:BC:FB LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB -90 dBm - Manufacturer Specific Data - Channel 39 Nov 23 09:55:23.021 HCI Event 0x0000 EF:E5:FA:E1:62:E1 LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1 -51 dBm - SID: 0 - Nordic multi adv sets - Channel 2 Nov 23 09:55:23.046 HCI Event 0x0000 02:AD:F5:8E:3F:09 LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09 -76 dBm - Manufacturer Specific Data - Channel 37 Nov 23 09:55:23.322 HCI Event 0x0000 EF:E5:FA:E1:62:E1 LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1 -43 dBm - SID: 0 - Nordic multi adv sets - Channel 0 Nov 23 09:55:23.357 HCI Event 0x0000 7C:64:56:8A:BC:FB LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB -90 dBm - Manufacturer Specific Data - Channel 37 Nov 23 09:55:23.364 HCI Event 0x0000 02:AD:F5:8E:3F:09 LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09 -70 dBm - Manufacturer Specific Data - Channel 38 Nov 23 09:55:23.623 HCI Event 0x0000 EF:E5:FA:E1:62:E1 LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1 -51 dBm - SID: 0 - Nordic multi adv sets - Channel 1 Nov 23 09:55:23.913 HCI Event 0x0000 EF:E5:FA:E1:62:E1 LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1 -47 dBm - SID: 0 - Nordic multi adv sets - Channel 2 Nov 23 09:55:24.206 HCI Event 0x0000 7C:64:56:8A:BC:FB LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB -91 dBm - Manufacturer Specific Data - Channel 38 Nov 23 09:55:24.207 HCI Event 0x0000 7C:64:56:8A:BC:FB LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB -91 dBm - Manufacturer Specific Data - Channel 37 Nov 23 09:55:24.215 HCI Event 0x0000 EF:E5:FA:E1:62:E1 LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1 -54 dBm - SID: 0 - Nordic multi adv sets - Channel 0 Nov 23 09:55:24.232 HCI Event 0x0000 68:27:37:4B:F2:A9 LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9 -82 dBm - Manufacturer Specific Data - Channel 39 Nov 23 09:55:24.232 HCI Event 0x0000 62:DB:94:51:E0:08 LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08 -73 dBm - Manufacturer Specific Data - Channel 37 Nov 23 09:55:24.251 HCI Event 0x0000 40:ED:98:1A:BC:A8 LE - Ext ADV - 1 Report - Normal - Public - 40:ED:98:1A:BC:A8 -53 dBm - FiiO UTWS5 - Manufacturer Specific Data - Manufacturer Specific Data - Channel 38 Nov 23 09:55:24.251 HCI Event 0x0000 40:ED:98:1A:BC:A8 LE - Ext ADV - 1 Report - Normal - Public - 40:ED:98:1A:BC:A8 -53 dBm - Manufacturer Specific Data - Channel 38 Nov 23 09:55:24.507 HCI Event 0x0000 7C:64:56:8A:BC:FB LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB -91 dBm - Manufacturer Specific Data - Channel 37 Nov 23 09:55:24.519 HCI Event 0x0000 02:AD:F5:8E:3F:09 LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09 -71 dBm - Manufacturer Specific Data - Channel 39 Nov 23 09:55:24.523 HCI Event 0x0000 EF:E5:FA:E1:62:E1 LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1 -43 dBm - SID: 0 - Nordic multi adv sets - Channel 1 Nov 23 09:55:24.554 HCI Event 0x0000 62:DB:94:51:E0:08 LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08 -87 dBm - Manufacturer Specific Data - Channel 39 Nov 23 09:55:24.555 HCI Event 0x0000 62:DB:94:51:E0:08 LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08 -87 dBm - [LG] webOS TV OLED48CX9LB - Channel 39 Nov 23 09:55:24.823 HCI Event 0x0000 EF:E5:FA:E1:62:E1 LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1 -45 dBm - SID: 0 - Nordic multi adv sets - Channel 2 Nov 23 09:55:24.838 HCI Event 0x0000 02:AD:F5:8E:3F:09 LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09 -76 dBm - Manufacturer Specific Data - Channel 37 Nov 23 09:55:24.847 HCI Event 0x0000 7C:64:56:8A:BC:FB LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB -91 dBm - Manufacturer Specific Data - Channel 39 Nov 23 09:55:24.847 HCI Event 0x0000 7C:64:56:8A:BC:FB LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB -92 dBm - Manufacturer Specific Data - Channel 37 Nov 23 09:55:24.847 HCI Event 0x0000 7C:64:56:8A:BC:FB LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB -92 dBm - [TV] Samsung 6 Series (55) - Channel 37 Nov 23 09:55:24.863 HCI Event 0x0000 40:ED:98:1A:BC:A8 LE - Ext ADV - 1 Report - Normal - Public - 40:ED:98:1A:BC:A8 -53 dBm - FiiO UTWS5 - Manufacturer Specific Data - Manufacturer Specific Data - Channel 39 Nov 23 09:55:24.864 HCI Event 0x0000 68:27:37:4B:F2:A9 LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9 -82 dBm - Manufacturer Specific Data - Channel 37 Nov 23 09:55:24.864 HCI Event 0x0000 68:27:37:4B:F2:A9 LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9 -82 dBm - [AV] Samsung Soundbar MS550 - Channel 37 Nov 23 09:55:25.118 HCI Event 0x0000 EF:E5:FA:E1:62:E1 LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1 -46 dBm - SID: 0 - Nordic multi adv sets - Channel 0 Nov 23 09:55:25.145 HCI Event 0x0000 02:AD:F5:8E:3F:09 LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09 -71 dBm - Manufacturer Specific Data - Channel 38 Nov 23 09:55:25.409 HCI Event 0x0000 EF:E5:FA:E1:62:E1 LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1 -47 dBm - SID: 0 - Nordic multi adv sets - Channel 1 Nov 23 09:55:25.423 HCI Event 0x0000 62:DB:94:51:E0:08 LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08 -75 dBm - Manufacturer Specific Data - Channel 39 Nov 23 09:55:25.440 HCI Event 0x0000 68:27:37:4B:F2:A9 LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9 -81 dBm - Manufacturer Specific Data - Channel 39 Nov 23 09:55:25.440 HCI Event 0x0000 68:27:37:4B:F2:A9 LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9 -81 dBm - [AV] Samsung Soundbar MS550 - Channel 39 Nov 23 09:55:25.451 HCI Event 0x0000 02:AD:F5:8E:3F:09 LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09 -80 dBm - Manufacturer Specific Data - Channel 39 Nov 23 09:55:25.727 HCI Event 0x0000 62:DB:94:51:E0:08 LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08 -86 dBm - Manufacturer Specific Data - Channel 37 Nov 23 09:55:25.764 HCI Event 0x0000 02:AD:F5:8E:3F:09 LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09 -76 dBm - Manufacturer Specific Data - Channel 37 Nov 23 09:55:26.015 HCI Event 0x0000 7C:64:56:8A:BC:FB LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB -90 dBm - Manufacturer Specific Data - Channel 37 Nov 23 09:55:26.016 HCI Event 0x0000 68:27:37:4B:F2:A9 LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9 -81 dBm - Manufacturer Specific Data - Channel 37 Nov 23 09:55:26.023 HCI Event 0x0000 62:DB:94:51:E0:08 LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08 -74 dBm - Manufacturer Specific Data - Channel 37 Nov 23 09:55:26.029 HCI Event 0x0000 EF:E5:FA:E1:62:E1 LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1 -47 dBm - SID: 0 - Nordic multi adv sets - Channel 0 Nov 23 09:55:26.044 HCI Event 0x0000 68:27:37:4B:F2:A9 LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9 -82 dBm - Manufacturer Specific Data - Channel 37 Nov 23 09:55:26.045 HCI Event 0x0000 7C:64:56:8A:BC:FB LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB -90 dBm - Manufacturer Specific Data - Channel 38 Nov 23 09:55:26.314 HCI Event 0x0000 EF:E5:FA:E1:62:E1 LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1 -43 dBm - SID: 0 - Nordic multi adv sets - Channel 1 Nov 23 09:55:26.318 HCI Event 0x0000 40:ED:98:1A:BC:A8 LE - Ext ADV - 1 Report - Normal - Public - 40:ED:98:1A:BC:A8 -58 dBm - FiiO UTWS5 - Manufacturer Specific Data - Manufacturer Specific Data - Channel 37 Nov 23 09:55:26.330 HCI Event 0x0000 62:DB:94:51:E0:08 LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08 -76 dBm - Manufacturer Specific Data - Channel 39 Nov 23 09:55:26.365 HCI Event 0x0000 7C:64:56:8A:BC:FB LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB -90 dBm - Manufacturer Specific Data - Channel 38 Nov 23 09:55:26.365 HCI Event 0x0000 7C:64:56:8A:BC:FB LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB -91 dBm - Manufacturer Specific Data - Channel 39 Nov 23 09:55:26.366 HCI Event 0x0000 7C:64:56:8A:BC:FB LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB -90 dBm - [TV] Samsung 6 Series (55) - Channel 39 Nov 23 09:55:26.600 HCI Event 0x0000 02:AD:F5:8E:3F:09 LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09 -76 dBm - Manufacturer Specific Data - Channel 37 Nov 23 09:55:26.601 HCI Event 0x0000 02:AD:F5:8E:3F:09 LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09 -80 dBm - Manufacturer Specific Data - Channel 37 Nov 23 09:55:26.612 HCI Event 0x0000 EF:E5:FA:E1:62:E1 LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1 -42 dBm - SID: 0 - Nordic multi adv sets - Channel 2 Nov 23 09:55:26.641 HCI Event 0x0000 68:27:37:4B:F2:A9 LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9 -74 dBm - Manufacturer Specific Data - Channel 39 Nov 23 09:55:26.641 HCI Event 0x0000 62:DB:94:51:E0:08 LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08 -74 dBm - Manufacturer Specific Data - Channel 37 Nov 23 09:55:26.641 HCI Event 0x0000 62:DB:94:51:E0:08 LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08 -74 dBm - [LG] webOS TV OLED48CX9LB - Channel 37 Nov 23 09:55:26.914 HCI Event 0x0000 02:AD:F5:8E:3F:09 LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09 -76 dBm - Manufacturer Specific Data - Channel 37 Nov 23 09:55:26.916 HCI Event 0x0000 EF:E5:FA:E1:62:E1 LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1 -52 dBm - SID: 0 - Nordic multi adv sets - Channel 0 Parameter Length: 56 (0x38) Num Reports: 0X01 Report 0 Event Type: Connectable Advertising - Complete - Address Type: Random Peer Address: EF:E5:FA:E1:62:E1 Primary PHY: 1M Secondary PHY: 2M Advertising SID: 0x0 Tx Power: Unavailable RSSI: -52 dBm Periodic Advertising Interval: 0.000000ms (0x0) Direct Address Type: Public Direct Address: 00:00:00:00:00:00 Data Length: 30 Flags: 0x6 LE Limited General Discoverable Mode BR/EDR Not Supported 16 Bit UUIDs: 0X180A Local Name: Nordic multi adv sets Data: 02 01 06 03 03 0A 18 16 09 4E 6F 72 64 69 63 20 6D 75 6C 74 69 20 61 64 76 20 73 65 74 73 Nov 23 09:55:26.916 HCI Event 0x0000 00000000: 3E38 0D01 0100 01E1 62E1 FAE5 EF01 0200 >8......b....... Nov 23 09:55:26.954 HCI Event 0x0000 62:DB:94:51:E0:08 LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08 -76 dBm - Manufacturer Specific Data - Channel 38 Nov 23 09:55:26.955 HCI Event 0x0000 62:DB:94:51:E0:08 LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08 -76 dBm - [LG] webOS TV OLED48CX9LB - Channel 38 Nov 23 09:55:27.213 HCI Event 0x0000 EF:E5:FA:E1:62:E1 LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1 -42 dBm - SID: 0 - Nordic multi adv sets - Channel 1 Nov 23 09:55:27.228 HCI Event 0x0000 02:AD:F5:8E:3F:09 LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09 -70 dBm - Manufacturer Specific Data - Channel 39 Nov 23 09:55:27.260 HCI Event 0x0000 62:DB:94:51:E0:08 LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08 -85 dBm - Manufacturer Specific Data - Channel 39 Nov 23 09:55:27.262 HCI Event 0x0000 62:DB:94:51:E0:08 LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08 -85 dBm - [LG] webOS TV OLED48CX9LB - Channel 39 Nov 23 09:55:27.522 HCI Event 0x0000 EF:E5:FA:E1:62:E1 LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1 -51 dBm - SID: 0 - Nordic multi adv sets - Channel 2 Nov 23 09:55:27.533 HCI Event 0x0000 02:AD:F5:8E:3F:09 LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09 -79 dBm - Manufacturer Specific Data - Channel 37 Nov 23 09:55:27.559 HCI Event 0x0000 7C:64:56:8A:BC:FB LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB -90 dBm - Manufacturer Specific Data - Channel 38 Nov 23 09:55:27.559 HCI Event 0x0000 7C:64:56:8A:BC:FB LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB -92 dBm - Manufacturer Specific Data - Channel 37 Nov 23 09:55:27.559 HCI Event 0x0000 7C:64:56:8A:BC:FB LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB -92 dBm - [TV] Samsung 6 Series (55) - Channel 37 Nov 23 09:55:27.563 HCI Event 0x0000 40:ED:98:1A:BC:A8 LE - Ext ADV - 1 Report - Normal - Public - 40:ED:98:1A:BC:A8 -58 dBm - FiiO UTWS5 - Manufacturer Specific Data - Manufacturer Specific Data - Channel 37 Nov 23 09:55:27.563 HCI Event 0x0000 40:ED:98:1A:BC:A8 LE - Ext ADV - 1 Report - Normal - Public - 40:ED:98:1A:BC:A8 -58 dBm - Manufacturer Specific Data - Channel 37 Nov 23 09:55:27.571 HCI Event 0x0000 68:27:37:4B:F2:A9 LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9 -81 dBm - Manufacturer Specific Data - Channel 37 Nov 23 09:55:27.571 HCI Event 0x0000 62:DB:94:51:E0:08 LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08 -74 dBm - Manufacturer Specific Data - Channel 37 Nov 23 09:55:27.571 HCI Event 0x0000 62:DB:94:51:E0:08 LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08 -74 dBm - [LG] webOS TV OLED48CX9LB - Channel 37 Nov 23 09:55:27.815 HCI Event 0x0000 EF:E5:FA:E1:62:E1 LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1 -44 dBm - SID: 0 - Nordic multi adv sets - Channel 0 Nov 23 09:55:27.836 HCI Event 0x0000 02:AD:F5:8E:3F:09 LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09 -71 dBm - Manufacturer Specific Data - Channel 38 Nov 23 09:55:27.865 HCI Event 0x0000 68:27:37:4B:F2:A9 LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9 -74 dBm - Manufacturer Specific Data - Channel 38 Nov 23 09:55:27.865 HCI Event 0x0000 68:27:37:4B:F2:A9 LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9 -74 dBm - [AV] Samsung Soundbar MS550 - Channel 38 Nov 23 09:55:28.111 HCI Event 0x0000 EF:E5:FA:E1:62:E1 LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1 -47 dBm - SID: 0 - Nordic multi adv sets - Channel 1 Nov 23 09:55:28.122 HCI Event 0x0000 62:DB:94:51:E0:08 LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08 -75 dBm - Manufacturer Specific Data - Channel 39 Nov 23 09:55:28.150 HCI Event 0x0000 02:AD:F5:8E:3F:09 LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09 -79 dBm - Manufacturer Specific Data - Channel 39 Nov 23 09:55:28.166 HCI Event 0x0000 7C:64:56:8A:BC:FB LE - Ext ADV - 1 Report - Normal - Public - 7C:64:56:8A:BC:FB -88 dBm - Manufacturer Specific Data - Channel 38 Nov 23 09:55:28.166 HCI Event 0x0000 68:27:37:4B:F2:A9 LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9 -81 dBm - Manufacturer Specific Data - Channel 39 Nov 23 09:55:28.166 HCI Event 0x0000 68:27:37:4B:F2:A9 LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9 -81 dBm - [AV] Samsung Soundbar MS550 - Channel 39 Nov 23 09:55:28.419 HCI Event 0x0000 EF:E5:FA:E1:62:E1 LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1 -51 dBm - SID: 0 - Nordic multi adv sets - Channel 2 Nov 23 09:55:28.464 HCI Event 0x0000 02:AD:F5:8E:3F:09 LE - Ext ADV - 1 Report - Normal - Random - 02:AD:F5:8E:3F:09 -75 dBm - Manufacturer Specific Data - Channel 37 Nov 23 09:55:28.717 HCI Event 0x0000 EF:E5:FA:E1:62:E1 LE - Ext ADV - 1 Report - Normal - Random - EF:E5:FA:E1:62:E1 -52 dBm - SID: 0 - Nordic multi adv sets - Channel 0 Nov 23 09:55:28.727 HCI Event 0x0000 62:DB:94:51:E0:08 LE - Ext ADV - 1 Report - Normal - Random - 62:DB:94:51:E0:08 -73 dBm - Manufacturer Specific Data - Channel 37 Nov 23 09:55:28.754 HCI Event 0x0000 68:27:37:4B:F2:A9 LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9 -74 dBm - Manufacturer Specific Data - Channel 38 Nov 23 09:55:28.754 HCI Event 0x0000 68:27:37:4B:F2:A9 LE - Ext ADV - 1 Report - Normal - Public - 68:27:37:4B:F2:A9 -74 dBm - [AV] Samsung Soundbar MS550 - Channel 38 Nov 23 09:55:28.895 HCI Command 0x0000 LE Create Connection Cancel Opcode: 0x200E (OGF: 0x08 OCF: 0x0E) Parameter Length: 0 (0x00) Nov 23 09:55:28.895 HCI Command 0x0000 00000000: 0E20 00 . . Nov 23 09:55:28.907 HCI Event 0x0000 Command Complete [200E] - LE Create Connection Cancel Parameter Length: 4 (0x04) Status: 0x00 - Success Num HCI Command Packets: 0x01 Opcode: 0x200E (OGF: 0x08 OCF: 0x0E) - [Low Energy] LE Create Connection Cancel Nov 23 09:55:28.907 HCI Event 0x0000 00000000: 0E04 010E 2000 .... . Nov 23 09:55:28.908 HCI Event 0x0040 00:00:00:00:00:00 LE - Enhanced Connection Complete - Unknown Connection Identifier Parameter Length: 31 (0x1F) Status: 0x02 - Unknown Connection Identifier Connection Handle: 0x0040 Role: 0x0 (Central) Peer Address Type: Random Peer Address: (null) Local Resolvable Private Address: 00:00:00:00:00:00 Peer Resolvable Private Address: 00:00:00:00:00:00 Connection Interval: 0x18 (30 ms) Connection Latency: 0x0 (0 ms) Supervision Timeout: 0x48 (720 ms) Central Clock Accuracy: 0x0 Nov 23 09:55:28.908 HCI Event 0x0000 00000000: 3E1F 0A02 4000 0001 E162 E1FA E5EF 0000 >[email protected] Nov 23 09:55:28.909 HCI Command 0x0000 EF:E5:FA:E1:62:E1 LE Remove Device From Filter Accept List - Random - EF:E5:FA:E1:62:E1 Opcode: 0x2012 (OGF: 0x08 OCF: 0x12) Parameter Length: 7 (0x07) Address Type: Random Address: EF:E5:FA:E1:62:E1 Nov 23 09:55:28.909 HCI Command 0x0000 00000000: 1220 0701 E162 E1FA E5EF . ...b.... Nov 23 09:55:28.914 HCI Event 0x0000 Command Complete [2012] - LE Remove Device From Filter Accept List Parameter Length: 4 (0x04) Status: 0x00 - Success Num HCI Command Packets: 0x01 Opcode: 0x2012 (OGF: 0x08 OCF: 0x12) - [Low Energy] LE Remove Device From Filter Accept List Nov 23 09:55:28.914 HCI Event 0x0000 00000000: 0E04 0112 2000 .... .
