How to set receiver blocking for EN300328 certification in radio test example?
We made two set of firmwares, one with radio test controllable through CLI  RTT and other with DTM.
Problem with DTM firmware is our end product don't have UART or extra GPIOs available. So for the test purpose we are planning to remove one IC and connect the UART TX and RX for DTM.
Our doubts are
1. Can we set the receiver blocking with radio test example? If yes, how?
2. How to set receiver blocking with DTM command?
3. For Japan market , can we set the transmitting carrier frequency (2402,2440,2480)with/without modulation signal(without modulation is applied for JPN market only) (requirement from the test lab)? How to do this in both radio test example and DTM example?
4.  If there is one firmware we can use for FCC/ETSI/EN300328 certification, which one is that? DTM or radio test?
For Japan market the below requirement is also given from the lab.
FOR JPN market, other product operated at FHSS mode:
For example if the product is using below technology:
1 FHSS with 4 operating frequency.
2 Channel spacing around 1MHz.
3 Operating frequency is 2402‐2480MHz
Will this be applicable for BLE?
Vishnu Pradeep
