CONFIG_NFCT_PINS_AS_GPIOS=y doesn't work
I'm using an ISP2053 (nrf5340) chip on a custom board and debugging using the nrf5340dk. I'd like to use P0.02, P0.03 as part of an SPI bus.
I set up a simple experiment where I set `CONFIG_NFCT_PINS_AS_GPIOS=y` in my prj.conf and some code to toggle various pins that I can read on my board. P0.02 and P0.03 are always 0V and other pins toggle between 0V and 3V.
I believe the NFCPINS UICR register (0x00FF8028) should read 0xFFFFFFFE but using nrfjprog I can see that the register reads 0xFFFFFFFF:
nrfjprog --memrd 0x00FF8028
0x00FF8028: FFFFFFFF |....|
After I flash the code using nrfconnect vscode, I can set the register to 0xFFFFFFFE:
nrfjprog --memwr 0x00FF8028 --val 0xFFFFFFFE
Parsing parameters.
Writing.
0x00FF8028: FFFFFFFE |....|
Now the NFC GPIO pins toggle on and off like the other pins.
Is this intended? It seems like CONFIG_NFCT_PINS_AS_GPIOS=y doesn't change the register value. I can see in Guiconfig, the `NFCT pins as GPIO` option is selected. Other options in prj.conf work.
I'd prefer not have to run `nrfjprog --memwr 0x00FF8028 --val 0xFFFFFFFE` when flashing. How do I diagnose the problem further?
I'm using ncs v2.1.1.
1 2 3
